View Full Version : General Maintenance & Repairs
  1. Service engine soon
  2. quick question
  3. HELP! Replaced Transmission Mount...
  4. weird noise when in drive and stopped
  5. No power steering at idle???
  6. DS sun visor fell in my lap!
  7. Voltage running high??? What does your car run at??? Blowing LED gauges HELP!!!!!!!!
  8. Power surge??? PLS Help
  9. Part # ??
  10. help!!!!
  11. Seafoam??
  12. clunking popping noise
  13. Body Control Module (BCM)
  14. oil dipstick tube broken
  15. Whipers..
  16. K&N Recharge Kit =MPG
  17. bearing noise from the motor
  18. what filter to use with Suncoast creations hood
  19. Cruise Control Clutch switch question HELP!?!
  20. p0171 help?
  21. light bulb change of the indicator??
  22. flashing SES light....and very sluggish
  23. I need to replace the neutral safety switch.
  24. Anyone try or any thoughts on the Seafoam Auto Trans cleaner?
  25. car won't start
  26. 2001 corvette engine problem
  27. Would it be O.K. to...
  28. Power window motor replacement?
  29. Rattling on Acceleration
  30. brake light issue (I have searched)
  31. air bag light???
  32. Car won't start?
  33. In need of some tech advice
  34. inaccurate tach
  35. i bought a flaming river steering shaft and it dosent line up!!
  36. SS is 10yrs old w/ 19k miles – What to change/replace?
  37. Power steering return line location?
  38. interior lights question
  39. A/C Compressor ?
  40. Help with installing water pump!!!
  41. please Help!!
  42. So I got my Air Bag Light scanned and...
  43. powersteering leak common?
  44. whats the worst you've seen?
  45. electrical issues
  46. Just wanted to thank the LS1 techies
  47. Brake line question
  48. Oil in throttle body and car smoking
  49. Power Steering Q?
  50. Help! 180 Fix Gone Awry
  51. Weird problem
  52. Help! Dead car w/ elec problems?
  53. SES light came on this morning
  54. parking brake lever "slips" sometimes
  55. 25K oil change interval?
  56. Help!!!!!!!!
  57. 99 Z28 frontend noise???
  58. guidelines for checked fuel and ignigtion system???
  59. Headgasket leaking oil on LT1?
  60. oh my god. how bad is it?
  61. PLease help my car is bogging down!!!
  62. Please Help!!!!!!!!!
  63. Windshield washer fluid Jet doesn’t work
  64. Seat Belt guides
  65. Tranny mount??? Sponser who
  66. Maf Help
  67. Air Pump ? Help!?!?!?
  68. Help!!!!!
  69. Power steering hoses from LT1 work on LS1??
  70. Quaker State gives you more torque!!
  71. rear defroster
  72. Just Bought: WS6 A4 w/couple of issues, Any help appreciated
  73. car keeps wanting to die!! :(
  74. Long oil filter?
  75. Radiater reapir anomoly (with pics), any ideas?
  76. 93 T/A needs help!!!
  77. Just Sea Foamed my car.. funny
  78. My Right Head Lamp is a bit moving when opened, Anyway to stop that? 1995 T/A
  79. Need help quick, electronic problems, no start
  80. remote key fob problem, need help....
  81. car keeps blowing fuses
  82. engine fuse
  83. maf sensor need help
  84. What part is this? its the bracket that aims the light(pic inside)
  85. what would this be
  86. need help asap!!
  87. Can you tell if a coil pack is going bad?
  88. H20 sludge
  89. Question about gapping / plugs
  90. Who sells Stock AC Delco plugs?
  91. Fuel Pump Relay location on 2000 Camaro
  92. Problem on keeping engine running
  93. P0133 code
  94. Maf Replacement
  95. front wheel bearings - Are they Serviceable?
  96. Which water pump?
  97. Winter truck
  98. Car will not start - neutral safety switch issue?
  99. noob needs help
  100. Cam is missing a chunk - Do I need to replace it
  101. Plastic Weld
  102. Headlight Help
  103. what could it be?
  104. Clinking sound coming from rear end
  105. shredded Fuel line
  106. About to buy a NHRA bird... Has Leak.. Any ideas?
  107. Jeep Whistling sound.
  108. Slow window motors? Check this out...
  109. Front turn signals..
  110. Jackstand Placement
  111. Oil Psi
  112. problem with my window
  113. Ms
  114. Please help me!! lights
  115. HVAC and Headlight control lights dont work
  116. In little richard voice HELP ME PLEASE Electronic question???
  117. motor mount?
  118. Oil Leak Source
  119. I Hate Autozone!!!!
  120. Glove Box Light Switch Bracket??!??!
  121. Visor Mirror Cracked!?!?!
  122. Problem with dropping RPMS
  123. Which spark plugs do you like/use (outside of your LSx)?
  124. Yahoo! Alternator.
  125. Lower control arm bolt question (sfc)
  126. New belt?
  127. Just got some paint work done & now i have 3 warring lights on?
  128. coil packs
  129. 02 sensor issues
  130. Rear defroster / defogger quit....how to fix?
  131. loud squeak, bad pulley?
  132. Reccomended Oil and Filter
  133. Thinking altenator, but now I'm wondering
  134. Oil leak above filter
  135. Never Using Mobile1 Again
  136. How do I change my oil pump?
  137. How many VIN Markings are there on a FBODY
  138. headlight burn out.
  139. this should prbably go in the too late now section...
  140. need help with my ac
  141. Loading problem... I'm at a loss
  142. Bipolar Headlight?
  143. Which battery tender to get?
  144. Leaking from back of my motor
  145. Erratic Idle
  146. Whats the deal with Bosch Plugs?
  147. lt1 oil leak help
  148. Can Someone Tell Me...
  149. HELP! car died after 10 mintues of driving
  150. Car overheating big time, need help!
  151. Fixed my miss at idle and ticking.....
  152. P0410 = New Air Pump???
  153. Car wont start...need some help
  154. 02 zo6 window stays up.
  155. Having a starting problem
  156. how to install new poly motor mounts?
  157. Trans Am headlight proplem. only opens half way
  158. coolant temp
  159. question about coolant
  160. Engine Knock/Tick . . . What could it be?
  161. Factory Alarm Questions
  162. door handle busted
  163. Car jerks and hard to start..
  164. Power steering popped a hose
  165. need help asap!!
  166. backfiring while hitting it...
  167. Need Help Fast!!
  168. remote key fob not working!! ugh
  169. coil rail removal help
  170. Anyone use LC20?
  171. can i fit transam door panels on a Camaro?
  172. Shorting out
  173. Whats the Fog light Part number?
  174. Flush transmission? 9 year old firebird but with low miles
  175. need help oil in headers
  176. Alternator for the 4th time. Help!
  177. ok when my cars cold it makes a .....
  178. Where is coolant plug?
  179. Cats?!!?
  180. coolant headaches
  181. Check Engine?
  182. missing door screw piece.
  183. Will not take fuel
  184. My car Shakes bad
  185. Cluster won't work??? HELP
  186. oil change tutorial
  187. New spark plug wires???
  188. lossing power
  189. i need fog lamps
  190. Car gets very hot at a stop, but very cool while going
  191. heater problems????
  192. Driver side dOOr sags!!!
  193. asr delete need help asap
  194. Clear corner DRL bulb #
  195. Dead short in car...
  196. broken flip out cup holder!!
  197. Vibration
  198. rpm's drop slooowww! on 02 WS6
  199. Rear defroster?
  200. when to clean the k and n filter?
  201. brake light
  202. Who's brakelights turn on at WOT?
  203. 180,000 miles and its all falling apart, now the power steering pulley??
  204. Any one else go threw blinkers alot??
  205. why do camaros with ttops rattle so much?
  206. Need Help after Radiator Install.
  207. alternator question
  208. LOW OIL light
  209. Thumps and bumps
  210. loud fans
  211. Need help putting A/C back in...
  212. air intake rubbing on my hood?
  213. Radiator boiling???
  214. hit a bump, loud buzzing noise, pulled wiper motor fuse - need help.
  215. What Battery
  216. Idle Problem
  217. power steering flush
  218. Window Wiper Arm Help
  219. got a quick question?
  220. headlights
  221. Right turn signal indicator doesnt flash, stays steady, turn signals work fine
  222. weird window questions.... meh
  223. Water inside car???
  224. Rough driving when at constant speed (after dead alternator)
  225. electric water pump installed...intake problem
  226. Thud/Bangin when making a turn
  227. Need Quick Help!!! (Non-Ls1 related)
  228. drivers window internal parts going bad ???
  229. problems with lt1, vids inside
  230. Dirty oil?
  231. Need some help
  232. Weird idle after wash
  233. Ideling funny
  234. 7.5" or 8.5"
  235. bad plugs?
  236. need help!!!
  237. Window motor removal and reinstallation directions
  238. That time again..
  239. Rear end problem
  240. Need help testing my o2's...
  241. O2 sensors
  242. idle problems after intake install
  243. smog
  244. i just bought a new 2000 formula
  245. Seafoam ?
  246. Need some help please
  247. Haunted T/A?
  248. oil pressure sending unit accessable with intake on?
  249. A/C line repair
  250. BRUSHING SOUND (front driver side)
