- tips for oiling a kn filter
- hesitation on 4.6 mustang?
- Clutch install on v6 mustang, any tips or write ups
- Might have Hydrolocked?? HELP!!
- Is it my battery or alt. or even a lose wire?
- power mirrors, not working so good
- possible causes of vibration?
- Plugs, MAF, or IAC/IAT?
- stock wires vs. msd wires
- How to tell if its a head gasket??
- Any of you changed your front wheel bearing hubs?
- How do I bleed the power steering?
- popping sound?
- car revs to 3000 on startup, then dies.
- 150 mi/tank.. what to fix?
- changing to royal purple?
- temp gauge...
- Little prob...
- Car sputters. need help
- Car Running BAD!
- Brake booster
- sea foam
- Turn signal problem
- help! car down on power
- Clear Coat
- MPH gauge doesn't work
- how much A/C oil should I use?
- MSD spark plug wires
- royal purple
- alternator help
- Do all LS1's run rough?
- Tell me if you think the rear main cover gaskets leaking... pics attached
- Something Wrong with My Car.. Need Some Opinions!!
- Car is fast approaching 94,000 miles....
- starting problem, battery?
- Frost on A/C lines
- EGR not working
- overheating?
- Squeaks
- Car takes a bit to finally start
- Have you encountered this issue?
- powersteering help
- Firehawk Storage
- Fuel or Ignition
- Basic troubleshooting and Maintenance....
- Cold Air on '99
- Found in glove box What is it?
- alot of vibration coming from clutch
- leaky main seal?
- How exactly do you fix the burning oil?
- A/c HELP
- A problem, please help
- a/c smells like ass
- How to turn on a/c compressor to add r134?
- No reverse lights
- HEadlight motor... is it to late
- Going from regular oil to Synthetic?
- Changing trans mount...
- Help .. fuel tank problem
- O2 Sensor cause Misfire
- another window motor thread...
- Driver/Pass Seats Lose??
- constant overheating but it's not boiling over.....
- what is the Check Gauges Light?
- Does anyone get 250 miles
- Electrical System Issue, would like some help please.....
- Chirp noise over bumps
- Vaccum Question
- Checking mpg?
- Oil leak questions
- Squeaky Clutch Pedal Linkage
- plugged cat or torque converter?
- ahhh ttop leaks
- Turn signal
- Bleeding Clutch..Instructions
- Spun Bearing(s)?
- Why does my suspension creak??
- Oil Change light?
- Mixing green & gold German Castrol?
- Front hub rattling on small bumps
- My GC experience...
- Found GC - going to start changing my own oil
- Rubbing noise when turning left
- LS1 making a "ticking" sound at idle
- whine and static in speaker
- Grinding noise when shifting
- not a f-body but checking the fluid on a malibus transmission
- Window Motor Part Number?
- anyone tried this intake from ebay?
- clutch probs
- E/Brake adjustment
- Help, Headlights are making a horrible noise
- Security Ring On Key cylinder...
- Need more help
- Help...manifold Install Totally Wrong
- any ideas to take care of dents?
- showing age?
- a/c vents not working
- Experienced mechanics come in....
- security light on car wont start!
- serpitine belt needs replacing again??
- Bosch platinum +4 spark plugs?
- Lifting an F-Body
- Lost keys...
- low coolant light on help
- A/C not always turning on?
- daily driver bogging/hesitating
- 95 3.4L Stutter?
- coolant tank
- replaced T/A gauge cluster with camaro cluster
- whats wrong with my car?
- Lots of sputtering before the engine turns over
- Need Some Trouble Shooting on...
- window motor-- which rivets?
- routine oil change
- Ever so slight miss at idle and lower rpms
- change oil light?? Seatbelt
- throttle cable
- o2 problems
- Removing wiper arms, what do you use?
- electrical question
- car cover help
- help A/C is not working and it is bloody hot!!!
- help again with power steering
- Just sea foamed 95
- Service engine light code... Cat gone bad?
- Your thoughts on Lucas Oil ??
- AC Question
- Need AC Help:
- Intermittent High Idle Problem - TPS related
- low coolant light?
- Burning oil!!!!!!!
- car is making lots of funny sounds when turning
- Coolant overflow problems!!!
- LEAN Code Bank 1
- car wont start!!!!
- A.C. Stop Blowing HELP
- Power window help...
- GM Says $550 for this..Thoughts?
- Will a Low Amp Alternator cause you to throw a code?
- Loud Clunk
- Serious Help with an Electrical Problem.
- Clean out or flush gas tank...?? any ideas?
- How do you dispose of old batteries?
- vibration after track?
- poly trans mount installed now a vibration?
- Window Motor...
- Kill Switch
- What battery? 2000 Corvette
- Alternator Wires SOOO CONFUSED!!! please help
- Installed shifter now whining
- coil problems
- Rear seat hardware...
- where to cut out for fuel pump easy change?
- Motor mounts and fuel pump??. how expensive? How hard?
- Wierd Whine/Noise
- Turn signals work when they want
- Im So Damn Pissed!!!
- Newbie Oil Change Question
- weird taillight problem
- stock fan problem - what is it supposed to do?
- High RPM detonation
- lip broken on battery tray
- Car shuts off for a split second during a WOT shift
- K&N Filter Cleaning
- Heater Core Write Up?
- SES light - running lean
- Water in Floorboard!! Help!
- my steering wheel shakes...
- Replaced Water Pump...New Trick Removing All Coolant
- Shifter raises 1 to 2 inches when you give car gas, tons of slack in drivetrain
- Automatic headlights
- Stupid question about used oil…
- LS6 Intake Installed Now Hurt Motor?
- Changed my oil and now my rear end is busted...
- lets play "whats wrong with my car"
- Brake lights
- How can i get better gas mileage
- how to move headlight down?
- Just switched to GC 0-W30 and have louder valvetrain noise....
- Convertible Top 1995 Z28 question
- Popup Headlight problem
- Found a bearing ball stuck in my EGR valve, any suggestions?
- very annoying rattle
- my rubber bushings are shot
- check engine light, fan sensor?
- rear axle bump stop #s
- DRL dimming
- Torquing exhaust manifold bolts???
- F-Body Shop Manual For Download NEED SCHEMATICS
- pcv valve
- Low oil light
- Black Gunk on the Clear Plastic Behind Behind the Door Panel
- Cleaned my engine bay..problem with voltage now
- Num 7 misfire, tried changing wire, spark and coil?
- my 97 z strong?
- Lost My Get Up & GO
- oil leak
- Safe to
- Weird problem...
- car not starting....
- How many times have you replaced your window motors?
- A/c Not Blowing Cold At All. Please Help!!!
- Transmission fluid fill
- Power window motor removal & install guide?
- water pump going out?
- Reliability of High Mileage 3.8 V6?
- strange rattling sound when engine is cold.
- maintenace on ws6
- 3.8 head gasket
- speedo actin up
- Driver Side Power Window Problem
- burning smell above 85?!
- Whining Noise After Car Runs And Gets Hot
- Video & Mp3's (Weird Noise) Wheel Bearing? Rear Dif? Suspension? Brakes?
- blue smoke on start up
- Broken Windsheild wiper transmission...
- transmission fluid help
- motor and trans mounts
- I'm incredibly stupid. Flooded motor w/ water, pics
- Fuel Injector Cleaner
- VATS Problem?
- exhaust leak
- Trip odometer and SES reseting every time car is turned of?
- MS4 now getting a stumble and SERVICE VEHICLE light
- Symptoms of a bad A/C Compressor?
- Turn Signal relay ???
- car wash!!
- Differences in 99 and why is it slow?
- After plugs and wires ...............
- Quick easy engine "BAY" harness question.
- How to manually close power windows?
- Name this sound
- Installing LTs, New Plugs??
- Something in door
- popping suspension
- steering wheel removal problem
- Is it possible to order 1 spark plug wire anywhere?
- Radio and Windows don't work, why???
- Just stalls
- using acdelco oil filter w/ Amsoil?
- Jacking Points For Newbie
- Woot! found GC 0W-30
- Rough Sounds + Messed Up Idle
- having trouble with my VATS i think (HELP!!!)
- Air Bag light intermittent after rain enters car
- Airbags...is it possible?
- where to look
- Need help removing interior sail panel
- Gurgling?
