- electrical question
- car cover help
- help A/C is not working and it is bloody hot!!!
- help again with power steering
- Just sea foamed 95
- Service engine light code... Cat gone bad?
- Your thoughts on Lucas Oil ??
- AC Question
- Need AC Help:
- Intermittent High Idle Problem - TPS related
- low coolant light?
- Burning oil!!!!!!!
- car is making lots of funny sounds when turning
- Coolant overflow problems!!!
- LEAN Code Bank 1
- car wont start!!!!
- A.C. Stop Blowing HELP
- Power window help...
- GM Says $550 for this..Thoughts?
- Will a Low Amp Alternator cause you to throw a code?
- Loud Clunk
- Serious Help with an Electrical Problem.
- Clean out or flush gas tank...?? any ideas?
- How do you dispose of old batteries?
- vibration after track?
- poly trans mount installed now a vibration?
- Window Motor...
- Kill Switch
- What battery? 2000 Corvette
- Alternator Wires SOOO CONFUSED!!! please help
- Installed shifter now whining
- coil problems
- Rear seat hardware...
- where to cut out for fuel pump easy change?
- Motor mounts and fuel pump??. how expensive? How hard?
- Wierd Whine/Noise
- Turn signals work when they want
- Im So Damn Pissed!!!
- Newbie Oil Change Question
- weird taillight problem
- stock fan problem - what is it supposed to do?
- High RPM detonation
- lip broken on battery tray
- Car shuts off for a split second during a WOT shift
- K&N Filter Cleaning
- Heater Core Write Up?
- SES light - running lean
- Water in Floorboard!! Help!
- my steering wheel shakes...
- Replaced Water Pump...New Trick Removing All Coolant
- Shifter raises 1 to 2 inches when you give car gas, tons of slack in drivetrain
- Automatic headlights
- Stupid question about used oil…
- LS6 Intake Installed Now Hurt Motor?
- Changed my oil and now my rear end is busted...
- lets play "whats wrong with my car"
- Brake lights
- How can i get better gas mileage
- how to move headlight down?
- Just switched to GC 0-W30 and have louder valvetrain noise....
- Convertible Top 1995 Z28 question
- Popup Headlight problem
- Found a bearing ball stuck in my EGR valve, any suggestions?
- very annoying rattle
- my rubber bushings are shot
- check engine light, fan sensor?
- rear axle bump stop #s
- DRL dimming
- Torquing exhaust manifold bolts???
- F-Body Shop Manual For Download NEED SCHEMATICS
- pcv valve
- Low oil light
- Black Gunk on the Clear Plastic Behind Behind the Door Panel
- Cleaned my engine bay..problem with voltage now
- Num 7 misfire, tried changing wire, spark and coil?
- my 97 z strong?
- Lost My Get Up & GO
- oil leak
- Safe to
- Weird problem...
- car not starting....
- How many times have you replaced your window motors?
- A/c Not Blowing Cold At All. Please Help!!!
- Transmission fluid fill
- Power window motor removal & install guide?
- water pump going out?
- Reliability of High Mileage 3.8 V6?
- strange rattling sound when engine is cold.
- maintenace on ws6
- 3.8 head gasket
- speedo actin up
- Driver Side Power Window Problem
- burning smell above 85?!
- Whining Noise After Car Runs And Gets Hot
- Video & Mp3's (Weird Noise) Wheel Bearing? Rear Dif? Suspension? Brakes?
- blue smoke on start up
- Broken Windsheild wiper transmission...
- transmission fluid help
- motor and trans mounts
- I'm incredibly stupid. Flooded motor w/ water, pics
- Fuel Injector Cleaner
- VATS Problem?
- exhaust leak
- Trip odometer and SES reseting every time car is turned of?
- MS4 now getting a stumble and SERVICE VEHICLE light
- Symptoms of a bad A/C Compressor?
- Turn Signal relay ???
- car wash!!
- Differences in 99 and why is it slow?
- After plugs and wires ...............
- Quick easy engine "BAY" harness question.
- How to manually close power windows?
- Name this sound
- Installing LTs, New Plugs??
- Something in door
- popping suspension
- steering wheel removal problem
- Is it possible to order 1 spark plug wire anywhere?
- Radio and Windows don't work, why???
- Just stalls
- using acdelco oil filter w/ Amsoil?
- Jacking Points For Newbie
- Woot! found GC 0W-30
- Rough Sounds + Messed Up Idle
- having trouble with my VATS i think (HELP!!!)
- Air Bag light intermittent after rain enters car
- Airbags...is it possible?
- where to look
- Need help removing interior sail panel
- Gurgling?
- Removing handle from t top
- Need some pointers for recharging A/C
- Ohh shit.. Im fu*ked
- The back of my headlight motor fell off
- 98 firebird brakelights
- damn squeaks
- car not downshifting
- cleaning tb
- Idle worse after cleaning IAC? WTF!?
- cracked friggin block
- Psycho gauges...
- Daytime running lamp
- need urgent help - electrical problem
- Coolant light?
- best plugs and wires?
- Window a little crooked
- Car on jacks, hand spinning wheels, how much resistance is normal?
- I know it's a dummy gauge, but....
- Studder in the motor?
- Strange noise
- Do I need new Rockers?
- good deal on engine
- Crazy Steering Issues
- I feel dumb asking this but...
- no power
- intake manifold question
- Light flicker
- window motors
- *****automatic tranny shifter boot help****
- very important. fixing t tops
- Clunk from rear passenger side...
- Fluid Recomendations? 98-02
- time to change plugs?
- engine removal questions ???
- grease fittings
- A/C not working on high setting
- Service engine soon light = Check engine light?
- battery pretty much blew up
- Weird rattle/squeak is driving me insane...
- Squeaky suspension
- royal purple or castrol gc?
- alternator wiring?
- AC broken in TX heat :(
- darn bad thing!
- surging issue
- squeaky belt.. losing my mind...
- GC 0w30
- ?Radiator repair?
- How can you tell if you have a bad opti?
- Car wouldn't start after wash?
- non LS1 related flexplate issue
- Bad vibration
- what do u think is wrong here on my dyno!
- rear noise on a stcok 97 z28
- Aftermarket rear jounce bumpers
- Shaking and Rattling like Crazy.
- A/C liquid Line replacement - can I do it?
- Electrical gremlin
- water pump or lose main bearing in alterantor?
- Delco Iridium plug gap question
- Replacing A/C Compressor
- Chiltons or Haynes?
- Steering Column Question.....Car turns but will not start...
- alternator
- idler pulley torque specs
- whistling now from my belt?
- Odd A/C Problem
- Metal Shavings
- Best Window Motor Replacement
- AC recharge
- good deal or not!!
- AC problem
- Engine Starting Problems TECH HELP NEEDED!
- What Glue Did You Use For The Headlight Motor Gear??
- keyless entry
- knock sensors
- Installing New Window Motor?
- A/C Questions
- cars acting goofy...
- overheating
- Rear End
- Gas coming out
- vacuum leak
- Leaky driver side tail light.
- alternator help
- Engine pull on an 05 GTO, fairly straight-forward job?
- GC 0w30 in Denton TX
- What is the size of this hose
- car overheating
- Headlight motor connector
- Ripped line
- Hot & Humid weather
- AC Pulleys
- Coolant Flush
- WTF happened?
- Turn Signal
- First problems with SS
- car died
- white smoke
- Volt gauge ?
- Engine Issue
- Idle Issues
- Any body use Valvoline 5W-30?
- Well changed the plugs today...
- Possible window motor problem, help please!
- Not as easy as I thought
- Mobil 1 10w30 oil, use it or take it back?
- Stripped headlight screw
- Is my car worth keeping?
- 6mpg??? WTF???
- Adjusting Diff Questions
- installing fuel filter
- hard starting??!!
- Is your AC fan motor loud?
- WOOT Found GC 0w30!!!
- Need Help With Headlight Prob
- Odd squeeks and squeals from front wheels
- OIL PRESSURE İndicator??? TA 1995
- GC 0W30 in summer?
