View Full Version : General Maintenance & Repairs
  1. power stearing fluid/leak ??
  2. Body Experts Inside! Structural dimension reference points.
  3. replacing the seatbelt holder on side of seat
  4. What does the torque arm connect to?
  5. Banging noise
  6. noise
  7. Bit size for removing rear seats
  8. Headlight problem
  9. No A/C sucks in 100* temps, Help!!
  10. Engine wont turn over, looking for answers
  11. SS 3rd brake light?
  12. AC finally done?!
  13. this makes me so angry!
  14. A/C vent blower problem..
  15. pump
  16. airconditioning slows down....
  17. Who would be best to replace my windshield?
  18. high idle theory?
  19. What is this?
  20. Help With Diagnosis - Engine Stalling
  21. Where is the running light control box???
  22. Wits end, misfire I can't diagnose
  23. anyone no what this is????
  24. No reverse lights
  25. 98 TA - Clicking Starter
  26. Major door/window problem please help!
  27. headlight motor, or wiring?
  28. How does the PCM Monitor the Rear O2's
  29. tranny cooler causes car to over heat i think!
  30. Voltage gauge problem or something else?
  31. engine noise after oil change
  32. wtf body noise?
  33. Driver side window won't go down... not motor
  34. Need some A/C advise
  35. loud ping when A4 LS1 goes into gear
  36. WATER LEAK, Drivers side floor
  37. Wierd Engine noise
  38. Another new noise...
  39. Sounds like paper stuck on tire?
  40. Engine knocking
  41. If you just install rear lowering springs....
  42. Headlight wiring (drivers side)
  43. Rear Hatch Leaking, Anybody
  44. SES Light has been on and I finally got codes
  45. port/polish or buy 80mm tb
  46. AC gaskets???
  47. Help with pro 5 and lss
  48. HVAC system?
  49. Weird ticking noise
  50. Need help with A/C - blowing warm and strange pressures
  51. Failed CA Smog!!! Help please
  52. Do O2 Sensors have anything to do with exhaust leaks?
  53. Freon - does it wear out w/ time?
  54. Turn Signal (I'm an amateur)
  55. my steering is jacked up!!
  56. is the compressor i bought bad?
  57. Popping in front suspension
  58. ac recharge location??
  59. Vibration
  60. Need Key And Ignition Help!!!!
  61. How can I stop the noise????
  62. Problem with Interior Lights on Convertible
  63. Headlight Dimming Problems Please Help!
  64. squaking like a mofo.....
  65. Whistle Noise
  66. Replacing AC Accumulator (dryer)
  67. AC blowing hot air?
  68. Buddy drove through a puddle.. Hydrolocked?
  69. Do you have a cheap ebay power window motor?
  70. Failed OBD & Emission Readiness Inspection, Advice Needed
  71. Won't idle
  72. Tripometer keeps resetting itself
  73. A4 Shifter button broke
  74. Exhaust leak?
  75. mobil 1 or GC synthetic, higher oil pressure
  76. Did brakes on truck now abs light is on
  77. Coolant smell
  78. what is killing my gas milage
  79. Cooling fan fuse keeps blowing
  80. Wierd Wind/Whistling Noise
  81. is driving without headlight cover okay in the rain?
  82. Random Air Bag Light
  83. odd rattle on cold start and hard left turns??? non ls1 car
  84. will z06 rotors work??
  85. Found an ONLINE STORE that sells GC 0W-30!!
  86. Changing brakes and Turning Rotors
  87. Strange starting problem - please help
  88. still having fuel problems
  89. wheel bearing
  90. Need leather seat passenger side Camaro 99
  91. Window sticks - replaced switch no help
  92. Freon - add to high or low side?
  93. A/C control panel switch went bad, part #????
  94. Multiple Misfiring...Help!!!
  95. felt in door panel gone bad?
  96. 84 olds cutlass ciera HELP!
  97. removing alternator
  98. 95 Z28 missing..?????
  99. Airbags
  100. EGR Cleaning?
  101. Replacing door hinge bushing?
  102. Ignition switch
  103. 1404 ses code help plz
  104. A/C Question
  105. keychip problem??
  106. 4L60E pan torque specs.
  107. Got a weird starting problem...help?
  108. Good Place to buy body parts used or new.
  109. Why the fock is my car so loud inside!?!?!
  110. power window wont go down
  111. i want your opinion
  112. 84 Nissan will not idle
  113. Anyone have ALLDATA or Mitchell?
  114. Window Motor
  115. Broke something today, need help
  116. Headlight Issue
  117. erratic temperature readings
  118. Help w/ my a/c
  119. Headlight gear stripped!!! Can someone help me PLEASE
  120. Seafoam for Transmissions
  121. I need f@ckin help bad, ~~~~~~~~~~~~~~~~~~
  122. AC Compressor Install
  123. Can someone please cross-reference a few part #'s for me?
  124. Whats up with my brakes now?
  125. Door Chime is buzzing horribly
  126. E-Brake problems
  127. New Window Motor
  128. Clunk in back drivers side
  129. Power steering leak
  130. so thats what that noise was: PICS INSIDE
  131. pinon seal leaking
  132. Will a 130A LQ9 alternator work on an F-body?
  133. Intermittent vibration on highway - crazy!
  134. Stuck plug wire.
  135. how to remove plastic between hood and windsheild?
  136. Rear Brakes
  137. window fix?
  138. AC Removal Questions
  139. Trouble shifting out of 1st at WOT...
  140. Exhaust Squeak
  141. Anybody looking for new spark plug wires let me know
  142. a/c clutch is gone..
  143. Fuel Level problems ???
  144. Turn signal?
  145. Question about tail lights
  146. ATTEN:!!!! Read this STOLEN!!!
  147. So dealer says ignition cylinder not covered under warranty
  148. silverado problems
  149. Window stripping comming off!!
  150. stripped manifold bolt
  151. Coolant low?
  152. i think my cars ruined please help :(
  153. After driving in hard rain, (street floods also)
  154. truck problem please help quickly
  155. Rattle from dash area
  156. Don't raise your hood if...
  157. Need help identifying part (Radiator)
  158. 1970's BMW 2002 poor high end performance
  159. Low Coolant Light on and off?????
  160. Floor Jack Reccomendations
  161. I guess this qualifies...
  162. got a ? for others w/ lowered fbody's
  163. knocking from engine??
  164. What is best Brake Fluid for clutch?
  165. thoughts about Fel Pro Head Gaskets???
  166. poping sound when turning and stoping
  167. Car running hotter after converter install
  168. Power Window/Lock Switch Assembly?
  169. whistling/whining noise around 40mph
  170. What type of Serpentine Belt Does the LS1 use trying to buy one!
  171. Switched to German Castrol, oil pressure higher...
  172. a/c compressor housing
  173. Street Scene Speed Grille
  174. Brake Light Stuck On?
  175. Right front wheel clicking >solved<
  176. fog light question??
  177. problem w/ ac blower
  178. need help the abs inop light is on
  179. I have a new trans mount, but does this look right?
  180. wierd a/c noise..
  181. Which Transmission Mount To Use???
  182. Q oil
  183. I need wiring diagrams
  184. LT1 running rough
  185. Leaking Coolant out of over flow line?
  186. overflow tank overflowing
  187. Car cranks but wont start
  188. blowing fuses
  189. Electrical issue
  190. gas gauge/tank problems
  191. Cylinder #6 Misfire?
  192. knock from rear when getting on the gas
  193. installing power windows
  194. oil leak
  195. a/c leak
  196. trans am a/c
  197. low idle with maf plugged in
  198. How To Seafoam Your Car
  199. What are effects of a bad TPS sensor?
  200. tensioner pulley squeking
  201. Bad Coil Pack or Plug Wires?
  202. Question on Foglight bulb replacement
  203. missed third, now headlights dont work..
  204. Rear axel clunking sound!PLEASE HELP!
  205. Where is the Low Coolant Sensor located?
  206. Rear passenger clunk
  207. running light question...
  208. And then I noticed the little door.........
  209. Electrical Question
  210. squeaky engine
  211. Electrical problems
  212. Noisy poly TA bushing
  213. Moble one 10w-30 question
  214. gc 0w-30
  215. ac compressor
  216. Im THIS || close to getting a ac delete pully, gonna give it one more go
  217. Window Motor Replacement Problems
  218. Battery Dead??? No Start
  219. Crankshaft Endplay
  220. Tail lights melted!!!
  221. Basic oil question
  222. My Car is Possessed
  223. oil pan plug stripped
  224. U-Joint Problem
  225. AC/Lights Dashboard Knob
  226. Just A Quick Question
  227. A/C "dies" after extended use
  228. HELP! Trying to replace passenger side window motor
  229. Throttle Lag at 2.2K RPM
  230. What Is That Squeeking!!!!!!!!!
  231. Tensioner Pulley?
  232. Traction Control Acting Funny
  233. Flushing Cooling System
  234. Blows fuse when put in reverse
  235. Does anyone have problems with t/a motor connections?
  236. Need Help! Front Suspension/Steering!
  237. AC fan possibly going?
  238. 93 saturn a/c?
  239. headlight bulb swap
  240. Trouble starting after LS6 intake install
  241. start noise coming from starting A/C
  242. My brakes suck. WTF?
  243. Uber tool against spark plug #8!
  244. WHY , i don't know
  245. WTF!!! This Is Strange
  246. Engine Cleaning???
  247. something wrong with the power seats
  248. Help Me
  249. very bad knock
  250. A-pillar trim removal (T-top)?
