View Full Version : General Maintenance & Repairs
  1. RH front blinker driving me nuts!
  2. normal for air pump to come off and on while driving?
  3. fuel additive
  4. Hardtop Weatherstipping....
  5. Power Steering Problems - Help!
  6. Torque Spec
  7. Maintenance manual for 04 GTO?
  8. odd problem... electrical (short?? starter??)
  9. car storing...sort of
  10. Flickering Headlights??
  11. a window question
  12. Rotella 5W40 synthetic?
  13. adding fuel takes 30 min??
  14. Air bag question
  15. No Gauges and nothing when I turn the key.
  16. drivetrain vibration
  17. Headlights acting up
  18. Which amsoil?
  19. Anyone know where to get.....?
  20. Hatch rattle
  21. Bleeding cooling system
  22. Are the wires that connect to the throttle body supposed to be tight?
  23. Should I use Mobil 1 10w30 in my 98 SS M6?
  24. 98 M6 SS, growling noise on start-up
  25. oil pressure issue
  26. Oil Pressure to high?
  27. High Pitch Squeek When Turning Right
  28. Cooling system flush...help!
  29. Control arm cost - does this sound right?
  30. fuel filter
  31. left blinker won't turn off by itself after turn
  32. somekind of valvetrain noise?
  33. Low Voltage! doesn't feel like it though...
  34. 40K mile service
  35. Couldn't believe this... ATF in manual transmission!?
  36. Re-Setting the Oil Change Light
  37. K&N air filter for 96 Camaro SS?
  38. High pitch noise emitting from car...
  39. Oil Change Overfill
  40. Car won't hold idle
  41. Need help with 98 T/A Headlamps and Alarm
  42. Parking brake loose/tight?
  43. Steering colum squeak
  44. Knock sensor question
  45. High rev, then wants to Stall!???!
  46. Quick Question? HELP!!!!
  47. Squeaking noise from t-tops
  48. Help please
  49. Where can I find..
  50. idle problem
  51. rattling noise when getting on the gas
  52. Strange High Idle Problem with my 98 TA
  53. Strange idiot light
  54. Driver side window motor goin out..
  55. Bad timing chain?
  56. Pics of engine bay and a/c line
  57. check "guages" flashing driving me nutz
  58. Cooling problem
  59. low oil, rough idle
  60. power antenna on a 1990 corvette broke
  61. Gatorback Belts?
  62. engine noise
  63. Just popped my hood and.....
  64. Need a new radiator
  65. ABS question..
  66. Calling all A/C Experts!
  67. very strange electrical problem......drivers side brake light
  68. car wont start
  69. bad knock sensor?
  70. parking my ls1 for a few months
  71. i have a rattle
  72. Need Help Bad
  73. Still having problems!
  74. something wrong with my car
  75. Cheapest Car lnsurance Quote
  76. p0412 trouble code
  77. not the fuel pump?
  78. Center Console Lose as ???
  79. Water in passenger side?
  80. Different oil pressure sensors between years?
  81. Rear end leak
  82. Temp Sensor?
  83. Bad lifter? Need opnion
  84. non-synthetic oil choice ?
  85. Ticking
  86. Want to go back to black face gauges
  87. Windows won't go up? WTF?!?
  88. Rattle - could it be IN my Y pipe?
  89. Power Window Motor Template?
  90. Squeak by the passenger door over bumps, stops when my friends holds it...
  91. Help with high beams
  92. Front end creak
  93. is my Z28 water logged? please help.
  94. rear end noise
  95. t-top frame
  96. Missfire under hard acceleration. Please hellp!!!!
  97. Oil Pressure?!
  98. How are my fluid Choices.
  99. Lightweight battery
  100. Sensor Question
  101. Trans smoothness diff between years or gears?
  102. Another stupid turn signal thread
  103. Need Help!!!
  104. Coolant sensor issue ... maybe?
  105. Spark Plug Recommendation
  106. 95 TransAm Won't Start, mechanic at a loss
  107. anyone else burn alot of oil?
  108. driver-side power window rattles
  109. where to get a new wiper arm?
  110. LT1 running Slugish!!! HELP!!!
  111. Smoke on plug change
  112. Door sag
  113. Did the LT1 come with a popcorn maker?
  114. Strange engine noise
  115. Leave jack and spare tire in or not?
  116. belt squeking
  117. P0440 Evaporative Emission Control System Malfunction
  118. car switches off for a second or two
  119. Spoiler brakelight(3rd) bulb #
  120. keys locked in car
  121. Where'd You Guys Get New Headlights At?
  122. Removing Thermostat
  123. how useful is this piece?
  124. overheat
  125. seat help pleas read
  126. Speedometer light
  127. car keeps stalling - mechanic claims it needs a new computer chip??
  128. what's the deal with my headlights??
  129. i-pipe stuck to muffler
  130. Detonation.....caused by not having knock sensor?!?!
  131. Rattling under 3,000 RPM with 1/2 throttle or 3/4
  132. Oil pan seal replacement
  133. Engine cranks, but no go.
  134. Lifter Problems?
  135. Turn Signal Bulb
  136. How do you get the sun visors off???
  137. Fail Safe Thermostat
  138. Adjusting the headlights
  139. Window Motor Help
  140. Roof Bubbling
  141. Car didnt wanna start after work?
  142. how much does a water pump cost?
  143. Bad Coil Pack?
  144. ridiculous gas gauge on my 96 Camaro SS
  145. Scheduled Maintenance Q's
  146. Turn signal flasher
  147. Shift Boot Retainer
  148. help w/ recharging A/C please?
  149. Distributor/Timing Belt NON-FBODY (Sorry) Girlfriend's Car
  150. Car won't start.. battery is fine, no gauges?
  151. HELP: Brake lights WON'T turn off
  152. Transmission repair HHEEELLLLPPP!!!
  153. Power window motor took a dump
  154. Missfire under hard acceleration? Please help!!!
  155. Rear end noise / diagnosis help requested
  156. How do you know when a cat is bad?
  157. DexCool question?
  158. A/C is pissing me off
  159. Now what??
  160. what should i do... 53k 8 yrs old...
  161. valve cover gaskets replacement????
  162. My drivers mirror on my c5 is loose, easy fix?
  163. how to replace the windsheild wiper blade arms, and window motors?
  164. Clicking noise after a few WOT pulls
  165. Overheating - solved... You'd never guess how
  166. Window motor help PLEASE
  167. normal oil pressure?
  168. want to do some maintenance need info.
  169. fluttering noise in passenger air vent
  170. Mirror wiggling
  171. Camaro 2002 Alternator Wiring Diagram
  172. Smoke/Steam from TB??
  173. Not an LS1 but please help
  174. ASR keeps cutting off
  175. Stupid Rattle!
  176. A/C squeaks
  177. Lots of problems.
  178. Started to change coolant.. Need some help
  179. $800.00 for a tuneup?!
  180. Question??
  181. T/A headlights
  182. Help AC is not working!
  183. Clunking noise in the rear??
  184. Fuel filter in a 92 Camry
  185. tail lamp
  186. Question about exaust manifold.
  187. 93 lt1 a4 keeps stalling
  188. starting problem
  189. 1st gear clunking
  190. organic,metallic or ceramic pads
  191. Steam from dipstick tube???
  192. plug wires diameter
  193. Seat Belt
  194. idles at 500 rpms?
  195. Urgent!help needed
  196. Time for a game of Guess What's Leaking! *Pics*
  197. trying to get my front lower control arms out - bolt stuck!
  198. Smoke!, video
  199. Screw up or Coincidence????
  200. Loud knocking noise
  201. What the hell is wrong with my car?
  202. What to check after mouse attack?
  203. Misfire source?
  204. NEED AN ANSWER< QUICK!!!
  205. Key stuck in ignition
  206. steerwheel vibration
  207. OVER HEATING, bad
  208. How to wash undercarrige?
  209. Coolant Level Problem Help Needed
  210. Defrost won't turn off by itself. What's the problem?
  211. Car acting weird
  212. PLEASE HELP!!! Car died after track pass
  213. part number request, small plastic part for ttop cars
  214. dang im pissed
  215. kendall oil
  216. Wndow Question
  217. Stuck left turn signal???
  218. front wheel bearing/hub torque
  219. Knock sensor's bad, how hard is it to change?
  220. Howling noise
  221. Replaced my heads after they were rebuilt...........
  222. Oxygen Sensors
  223. Quick newb questions.
  224. Another oil thread
  225. Top end cleaner?
  226. No Voltage
  227. Fluid change pics...Help.
  228. Windshield wiper arm,
  229. o2 sensor replacement questions
  230. Power Window Problem Yes I searched
  231. won't drop below 1500 rpms
  232. window motor swap
  233. Does this look repairable?
  234. ac temp
  235. Looking to Manual fan switch on 98 trans am
  236. problem with airbag wiring
  237. Proper Way to Lift Up F-Body Car with Hand Jack
  238. 2004 Dodge Neon, check engine light is on
  239. trans fluid brands
  240. Lower airbox??
  241. Trans Mount??
  242. trans fluid?
  243. Removing AC
  244. oil and temperature gauges moving?
  245. how to remove u-joint?
  246. Royal Purple Racing 41 Motor Oil?
  247. car died randomly!
  248. A/C condensor noisy
  249. part number for LONG K&N oil filter?
  250. headlight short
