- starter solenoid
- Cant get in my f#$^ing hatch!
- eng. sens. fuse?!?!?!?!WTF
- shifter rattling???
- Head gasket gone bad or Power steering cooler leak?
- throwing code P0410?
- Car Will Not Idle.
- Abs Inop/ Asr Off
- Help with headlights
- high beems not working
- AC seals
- Electrical Problem?
- Turn signal troubles
- Door falling apart.
- A4 shifter knob clip
- Brass headlight gear issues :(
- Ac Leak!?!?!
- new optima battery,how to mount?
- Window/Door Problems - Please Help!
- I LOVE PB Blaster
- Gas Pedal Sticking
- SES Code Info!!
- 91 Z71 truck making grinding noises
- Change parking lights TA 1999
- went to start my car and...
- Help. Vacuum leak problems.
- roughness after poly motor mounts
- O2 question
- Flushing the Radiator? Now engine is getting hot??
- Batt will not hold a charge after winter storage
- whats this blue smoke all about
- Window Regulator
- Fuel Rail/Injectors Assembly
- P0140,p0135
- Fuel Filter loactaion and Installation??
- what fuse is this
- security light
- Time for a coolant change, info needed.
- Car struggles?
- Pulleys or Something Else!
- 90 and back??
- car won't start
- Having Headlight and Wiper Problems with 98ws6
- Thats the deal with German Castrol Oil?
- SES light question
- Cruise Control Acceleration Issue
- rattle??
- Cruise Control Situation
- Need Real Quick Help
- how to change ac belt
- threw a code
- Part number for parking light housings in front bumper?
- A/C not coming out of vents???
- AC problem
- where to buy German Castrol?
- Help! cant get starter out!
- Am I burning oil?
- Best Place put in Sea Foam??
- ASR turned off
- Pinion Seal
- for those that are running Optima batteries.....
- Whats The Stock Plug Gap
- tune up time
- Really Big Problem
- Blown cats common?
- Weird Starting Issue
- cylinder numbers
- New Guage cluster
- Plugs question
- So, the dealership told me... (banging caused by exhaust?)
- what is code p1153
- what does this do.
- Tail light
- Auto Meter gauge light
- gas pedal arm loose
- frequent tapping sound coming from engine bay
- valvoline dexron III ATF
- EGR Valve replacement
- Is my alternator going bad?
- Car idles slightly high at startup (1100 rpms) 98 Trans Am A4
- engine stumbling
- Codes
- y-pipe
- Anyone convert from T-tops to hardtop?
- SES light - code P0405
- AC don't work
- demonic turn signal - please help
- 99% stock & less than 200 miles per tank WTF
- No Brake Pedal Pressure Sometimes
- Overheating at the Stop Light
- I can't remove my T-Tops. Any ideas?
- bogging
- Cruise control / throttle problem, URGENT HELP NEEDED
- fluids for a 99
- 5w-40
- Reinstalling a/c
- Help diagnose this noise
- Power Window Problem ( NOT MOTOR)
- Car will not charge..
- problems with lights on a Corvette C5
- window motor install
- puff of smoke from exhaust?
- I'm getting a *thud* under acceleration...
- Specs on LS1 cat
- irritating squeak
- Digital Odometer Issues
- Car in the air: One hub spinning more slowly (bearings?)
- cruise control giving me sh!t
- A4 to M6 Swap!
- Car won't start.
- Dispose Antifreeze???
- steering wheel and column seems loose.
- Car idling at 2000....help?
- Oil leak at the front of the engine
- A/C Compressor removal...
- Wheel - Ticking/Clicking Sound
- 2001 Trans Am Oil Usage problem...
- help
- Wynn's Engine Tune-Up?
- electrical problems
- Power steering pump and alternator options.
- BIG problem with my torque arm mount!!!!
- Jsut replaced my crankshaft sensor..still having issues
- A.I.R. vac line?
- another oil question
- Is there anything I can do about the hatch rattle?
- out of storage and oil change
- Seat belt light wont go out
- how to change foglights
- convertible rattles
- Help,Please..Oil burning smell at WOT
- Service Vehicle Light
- Cold Start- why the backfire?
- bad rattle after going into 3rd gear while racing - what broke?
- Having my first LS1 problems
- Clutch and Rear end problems.. PLEASE HELP!!!
- Door Gap looks bigger
- No start and engine will not rotate.
- synthetic oil
- A/C Compressor gone, can i use a used compressor?
- High Idle
- advice: a/c compressor hose leak found!
- Please Help/irritating noise
- miss fire but from what?
- number 8 plug????
- exhaust vibration
- Never buy a MICROGUARD!
- battery size for 02 z28 !!
- i think i got the wrong ngk's
- I Need Some Good Help
- 6 and 8 Flooding..Help please!
- Another Horn Problem
- Oil Suggestions
- Oil Plug Size
- Viberation???
- Seafoam kill new O2 Sensors??
- Header install
- Prestone Radiator Fluid?
- fluids
- 6.0L longblock weight?
- Rough idle and whining noise on low RPMs
- Reverse Lights Not working
- Sway bar hitting diff making noise...pics anyone?
- Brake idle surge
- Pics of my spark plugs.. opinions?
- Random multiple cylinder misfires... hmmm
- squeeking noise from front end (metal rubbing sound)
- PO300 / PO307 Misfire, (Catalyst Damaging type), Can't track it down
- Car Sputtering while at a stop
- ASR not working????
- Is AZ going to stop carrying GC?
- 98 WS6 not starting weird stuff!!!
- Adjusting foglights?
- Whats everyones choice on wires??
- Anybody ever get a "creaking" sound from the back of the car?
- Just broke 50,000 miles... anything I should check?
- changed to lighter oil, now have small leak
- no oil getting to the top end
- Wheel hop, do I have it?
- p1416 code wtf
- "service engine soon" light came on
- WTF! damn window motor
- Recommended diff oil?
- belt change, what will i need?
- Idle Drops
- need horn help...
- Car does not want to stay running?
- Cleaning Gauge cluster
- 94 4l60e tranny problem
- Idle dropping
- Wheels squeaking at low speeds
- Patman, your services are needed....
- Brake Upgrade Vibration
- draning oil
- Switch wiring question
- Car Pulls To The Right While Driving/Braking. What The Hell?
- what could cause my heat not to work
- metallic ringing noise coming from car
- Interior lights "flashing" at idle??
- SES P0152 and vibration
- cold engine clatter
- GC question
- Starting Problems
- wheres the traction control module?
- power antenna wont go down fully
- t top weatherstripping
- Obd2
- Head Gasket or Exhaust Manifold Gasket?
- Compression Leak?
- Alignment Needed?
- Weather Stripping?
- Help asap!~ AC High/Low side
- Car throwing P0172 and P0175
- Help! ASAP!
- How to replace Seatbelt loops?
- Stock Volt Gauge
- for light replacement
- A thud noise from the rear
- How to install Headlight Socket
- bogging down help!
- Started my car twice
- Crank sprocket removal?
- power window
- smell coming from car
- Who has changed a door pin?
- Weird Problem...Need Help
- Madman manual steering rack
- (GERMAN) Castrol Syntec 0W-30 CHEAP at AUTOZONE!
- A/C Problem! Can yall help?
- battery problems
- EGR valve
- throttle sticking ?
- Ticking me off
- random egine misfire
- Battery Dead
- Need Help...Plug will not go into head
- service engine soon light!!
- resetting SES light?
- Car won't start...
- Cooling Fan Runs on Start Up?
- can't get spark plug boot off
- oil gauge goes up and down
- no power to my code scanner port???
- Whining noise in engine?
- Wierd coolant problem
- Oil change frequency question
- How often do you guys change plugs?
- o2 Sensor, Car Bogs and "pops"
- VIbration at higher RPM's
