- Rebuild for LS1
- Question about install new VATS Ignition lock and keys!
- Sidemirror
- cruise control not working
- power loss
- Moisture in reverse light
- these squeeks are driving me insane
- Oil Question
- 98 z doesnt like to start
- speedo
- seat belt guide
- cruise control question
- smoke from oil filler neck??????????????????????
- '97 LT1 misfiring troubles
- Trouble code Question
- F'in Window Motor!!!!!!!!!
- New Battery?
- QUICK questions about seafoam
- Seat buckle plastic broken
- Couple ??'s
- Gauge readings.
- cruise control doesn't work
- m6 fluid question
- BIG Problems on cold start!!! HELP???
- Belts?
- silly question
- why does my trip reset?
- What's your oil filter?
- Where do you attach an engine hoist?
- Any tips on changing the alternator on a 2000 SS
- jumper wire harness lt1
- Crankshaft Poisiton and Camshaft Position Sensors
- Prestone Universal Antifreeze
- Exhaust leak cause bad gas mileage?
- SES light....possible causes?
- Headlight question for trans am
- Question for Patman?
- High pitched noise...?
- Help me choose right weight of oil???
- Odd rear end noise, not constant, help?
- Replacement seat belt guide
- Cold weather and BAD idle!!
- Inspection ?
- Bent pushrod Maybe?????
- Cheapest place for stock plugs?
- Start up problem
- Hood hinges
- WTF car starts itself
- Oil around filler cap of engine?
- Turn signal relay?
- Power Steering making noise
- SES light comes on, off, and now on again?
- Type of oil for 115,000 mile LS1?
- Strut linkage fell off?
- 2002 Gauge cluster
- help with airbag deployment on 91 dodge spirit (slightly offtopic)
- PCM Questions
- dodge hemi sites?
- Had an Odd Problem This Morning
- 5w-40 vs 0w-40
- clunk from the center...
- SES light and sounds
- Trans Am spoiler mounted third brake light problem
- Recommended scheduled maintenance
- Popping sound from front end
- 1/4 Mile Times
- Which Replacement Power Window Motor Brand?
- 112k what maintenance
- how much a shop can charge you for parts?
- Need Help: Rear Brake Lights no work
- horrible gas mileage
- DRL Socket Turn Signal
- "low coolant" light stays on, after distributor swap
- Noise When Stopping!!
- turn signal bulb
- is this a safe way to change the oil?
- How much loss of oil thorugh dip stick tube inlet???
- trans am headlight control module
- Fluttering/shaking when braking
- Intake air idle control Valve causing Dead battery!
- Low Oil light... oil consumption??
- Needing a little help
- No power in low end
- Gas overflow
- removing manifold on 98 vette
- Heater fan Question
- Alternator problem
- Misfire
- weird noise help
- Help Bad Stumble
- Opinions Please Platinum or Other??
- E-Brake light wont go off
- coolant leak
- Intermittent Grinding M6
- What sensor could cut off spark at high revs?
- Just hit 59k! what maintenance to do for 60k?
- Maintenance at 15k miles?
- Can traction control be add added?
- Battery maybe? Electrical problem
- Noise when turning...
- Wipers won't park
- Coolant smell, foggy windows....
- squeakin door hinge
- Electrical Problem
- oil change light??
- Power Steering Pump going?
- SS through a P1416 code, WTF?
- Ticking noise when turning...
- How do I remove under coating? And a few weight questions
- help trouble shoot to get my car to start, what do i check?
- Rear Window Defogger Not Functional
- Synthetic oil question?
- power surge
- Spark plug replacement in 98 LS1 Camaro
- Rattling Turn Signal Lever
- 01 ws6 door panel removal?
- Lighter Question PLease Help
- How to Remove rear rotors on a 99 camaro?
- Help with ignition on a friends car and catback suggestions
- help!!
- help!!
- Replacing the fog light bulb on my Camaro
- Radiator hoses? Who makes the best ones?
- Help losing power and gas mileage
- alternator going bad?
- Turning off A/C when defrost is on?
- leaking exhuast manifold
- HELP my brothers car wont start
- Help Pinion Seal Leaks
- Heater problems...
- could this be the main cp?
- 27 inch slick
- t-tops, flying out and on to road
- NEW Mass air flow sensor cleaner
- Oil in Exhaust??
- German made Castrol Syntec 0w-30 question
- Service Manual in PDF?
- QUICK please help
- rough idle?? what to do
- 2002 Z28 instumennt cluster
- Accidently stumbled upon Dex-cool suit
- rear wheel bearings #s?
- Can someone tell me how to Refill an A4 tranny?
- tire pressure
- Oil question
- check gauges flickers
- Replacing Door Handle Bezel
- dies when using clutch, grinding noise in idle
- will bad cats cause transmission lag?
- ? about posssible piston slap
- Bars Leak...will it help a blown head gasket
- mobil 1 5w30 or 0-40
- Misefire cylinder 7 HeLP!!
- Oil brands
- Help W Clutch install
- Disengage Ebrake - Working Under Car
- Window rattles need alittle help
- miles till spark plug change?
- engine overhaul
- helppppppp
- Car Wont Start PLEASE HELP
- maintenance list
- Checking the Basics
- Plugs & Wires - Best Brand
- Did burnout , SES light came on
- Low oil pressure in a 98'
- Help - SES light and Directionals don't work!
- 2001 SS 51k Only mod is a SLP lid Service Engine Soon light????
- passenger side thump over big bumps??
- A few Problems
- Flickering Lights..Come Inside.
- help with 89 Isuzu truck
- Car runs like POS when cold....
- screaching noise
- Ticking on drivers side floor
- Help Car Wont' Start
- 1997 Cluster
- Help Removing Center Console
- hatch noise
- Turn signal question?
- Please help cant rid myself of detonation noise? cant seem to solve it
- Radiator Water Disappearing
- Fog Light Isues
- Ses Light
- torch or impact wrench
- Check Engine Light help
- prolonging my storage...
- HELP!! Engine turns over but will not start
- Car hard to start
- Torque arm bolts
- Help! Car Won't Start
- 02 camaro ss shudder
- Air Bag Light!!!
- cruse control
- (Urgent) Output shaft
- torque specs for m6
- OBD-II P0404 Light help
- Engine Diagnostics Code
- Steering wheel lights?
- window motor how-to?
- Oil Dripping 95 T/a Convert.
- Radiator bubbling.head gaskets and air?
- Wheel stud ?
- SES light for EVAP
- misfire??
- Knock from the ORY?
- help with taking off front bumper support
- Turn / DRL bulb frequently burns out
- HELP Removal of Center console
- quick coolant flush question
- Tools needed for..(URGENT)
- Car tried starting itself
- Gas gauge not working right
- noise after 17x9s
- What grade and brand of oil do you use in your LS1?
- Looking for a fuel pump part number
- passenger headlight wont come up
- black smoke
- LT1 brake spindle vs. LS1 brake spindle
- whining after a hard turn
- Weird sound coming from rear of car
- Revs hanging and slow to return to idle, help please
- !URGENT - Are ABS systems identical on LT1 and LS1 cars?
- is there something wrong with the whip??
- after a wreck, what airbags components need to be replaced?
- rear end noise
- Popping noise when i turn
- leaky 2000 SS - water on floor?
- Idler Pulley?
- The only thing wrong is seat belt retraction
- lights flashing - parasitic drain?
- PS pump question
- Fuse Box
- Trans leak
- Best Head Lights
- Steering wheel feels loose again.
- brake light; automatic headlights
- Weird whining noise
- Dirty coolant?
- wiper switch...
- turn signal problems
- Oil Pressure at 0 psi??
- Wheel Hub Bearing?
- tranny thuds, opinions needed
- How to use Seafoam properly?
- Steps for removing LS1??
- squeak in hatch?
- What type of water pump gaskets should I get.
- turn signal driving me nuts
- Leaves in the engine bay
