View Full Version : General Maintenance & Repairs
  1. wiper switch...
  2. turn signal problems
  3. Oil Pressure at 0 psi??
  4. Wheel Hub Bearing?
  5. tranny thuds, opinions needed
  6. How to use Seafoam properly?
  7. Steps for removing LS1??
  8. squeak in hatch?
  9. What type of water pump gaskets should I get.
  10. turn signal driving me nuts
  11. Leaves in the engine bay
  12. T-top care...
  13. tranny fluid shooting out the dipstick
  14. fuel gauge weirdness
  15. 2 new front corner panels being replaced, Price??
  16. Weird Electrical Issue ... Please Help!
  17. Aluminum Drain Bolt
  18. Help me out guys
  19. Some help please my cars making unwanted noises
  20. Wiper's aren't parking correctly...
  21. Oil leak- rear main seal?
  22. Broken bolt (Oil pan)
  23. How to fix vacuum leak?
  24. Front driver-side turn signal bulb burnt out
  25. P0420-Bad Cat?
  26. A/C question.
  27. car is smoking
  28. engine knock
  29. P0446 - What does this mean?
  30. spark plugs - What a Pain!!!
  31. Oil pick up tube part number?
  32. Werid Electrical Problem
  33. Spec Stage III clutch installation doc
  34. HELP!! Replacing clutch - pilot bearing question
  35. Dam water in my clear corners!!
  36. Which filter???
  37. Wind noise with window up
  38. Lowering and tires scrubbing
  39. Firebird Headlight Problems
  40. major power loss after gas fillup
  41. bolt sizes/lengths?
  42. hmm...odd noise coming from engine bay...help!
  43. New MAF causing problems
  44. What's the best Tranny Fluid (gear oil)?
  45. check engine light after a belt replace
  46. PCM reset time
  47. GM Top End Cleaner?
  48. calling all lowered cars
  49. car up and died
  50. torque specs??
  51. vibrating or rubbing sound.
  52. T-Top locks....
  53. 100k on the clock; first oil change; what do you recomend?
  54. Motor oil choices? i need to change
  55. Torque for Jam Nuts on Adj. Panhard Rod
  56. o2 sensor or cat?
  57. rattle/clinking noise
  58. Patman????
  59. Performance lag
  60. keyless remote quit working today but!!!!
  61. Help!!!! having ignition/charging problem.
  62. window screeching noise - what could it be?
  63. rear defrost problem help!!
  64. Rearend Whine kinda wawawawawa
  65. Where can I find a repair manual for my 98 Z28
  66. What does the PCV plug into?
  67. Drive Cycle
  68. General question
  69. TA fan making squeaking noise
  70. Annoying noise
  71. TA 3rd Brake light problem
  72. jack question
  73. best transmission fluid and rear end fluid??
  74. Adj PHR Clunk?
  75. Royal Purple..... good or bad
  76. starting problem
  77. Gas mileage
  78. Rust on dip stick/filler cap? WTH
  79. car not wanting to start
  80. Lock Cylinder Broken?
  81. Back firing
  82. belt squeeking?
  83. whats a good ls1 cam..
  84. looking for new exhaust manifold studs
  85. where to get rid of old fluids?
  86. Washer fluid wont spray.
  87. Window question...
  88. Battery
  89. windsheild
  90. Temp ?
  91. Car lifted wrong
  92. water temp high
  93. headlights make grinding noise when locking car
  94. Check Engine light
  95. windshield wiper fluid broken
  96. battery cable
  97. Front DS wheel bearing, sealed unit?
  98. Passanger side DRL is dimmer than the drivers side.
  99. T-tops Ticking/Tapping
  100. car is bogging out...plus occasional low idle
  101. 2000 accent engine
  102. knowledge needed
  103. Whats the Best engine flush???
  104. 6.0L 2000 truck starting hard when hot/warm
  105. Castrol Syntec (Euro)
  106. tapping/ clicking noise when cold
  107. Rear suspension creeks
  108. my car has gremlins
  109. Broken driver side mirror
  110. dash lights?
  111. power window door issue (pics inside)
  112. changing tailight bulbs?
  113. Need a favor(I need ONE plug wire)
  114. Buzzer sound?
  115. Rear Defrost Not Working Help
  116. Engine swap, special tools/writeup?
  117. bad Duralast alternator from Autozone
  118. oil cap neck is loose
  119. pop up headlight broken... not the motor
  120. Cracked interior door panel...:( *DON'T QUOTE PICS!
  121. do you use oil additive?
  122. Drive train weak link
  123. where can i buy Gasket Maker?
  124. Is 0W-40 a suitable oil?
  125. Car running unusually hot
  126. need help on window motor please!
  127. clunk and squeak noise from rear??
  128. uh oh something weird with the car
  129. battery being drained, what can i do please help :o(
  130. Start up after a year
  131. Problem with car after battery being dead
  132. Intake Manifold HVAC
  133. new fluids in used car?
  134. third-gen tpi won't rev past 4800-5000 rpms
  135. My car started bogging down
  136. '94 Mercury Sable - antifreeze smell when heater is on
  137. engine won't turn over
  138. Bad Rear End Banging
  139. Door Lock button not working, but remote does work
  140. fuel filter
  141. replacing bulbs in radio controls and door buttons?
  142. Steering Problem. HELP!!
  143. Hatch release hardware preinstalled?
  144. Lug bolt not coming loose
  145. Trans or Drive shaft banging.
  146. Solid Motor mounts
  147. Problem with my Z! help!
  148. ses light how do i reset it
  149. Cruise control module
  150. Shifter Boots
  151. "STRANGE" light switch
  152. Z28 A4 shifter knob removal
  153. Driver side headlight is halfway down...
  154. Gas pump auto shut off?
  155. AC compressor, $700 - WHAT??
  156. Day Light module?
  157. !!HOWLING!! making me crazy
  158. Left turn arrow is solid green with no flashing noise; right one works fine?
  159. air pump and O2 sensors
  160. Possible Electrical Problem?
  161. A/C not blowing through upper vents
  162. Rainy weather problems
  163. Shell Helix Ultra
  164. Big Problem!!! Overrev!!!
  165. 05 gto Pulling to the right
  166. GTO - 2nd & 3rd gear chatter at 5000 rpm, and pulling to the right
  167. car idles high
  168. How do you stop side view mirror shake?
  169. Switched to Mobil 1 now change oil light comes on, is this normal?
  170. hood leak
  171. belt tensioner
  172. belt squeak
  173. Window motor or switch?
  174. Hatch Rattle
  175. Check Engine Light Came On
  176. Rattle/clinking noise help me out plz
  177. starting problem
  178. So simple, and yet so frustrating !
  179. Very weird noise
  180. SES Light
  181. turn signal not blinking
  182. good replacement for power window motor?
  183. seat belt buckles don't match?
  184. oil pan
  185. Good Battery?
  186. Electrical Problem?
  187. Winter gas killing milage
  188. My cruise control lags....
  189. Coolent Bubbling?
  190. what does GC 0w-30 look like
  191. Power windows
  192. gauge needle help!
  193. Blue Smoke
  194. oil change intervals?
  195. front bumper...?
  196. Is this MAF related?
  197. dad's van misfiring
  198. coolent smell
  199. Ticking Or Tapping Noise Coming from Engine
  200. Random misfire
  201. Stripped lug nuts
  202. yet another plug question?
  203. Squeak when turning wheel
  204. first oil change
  205. Car won't stay running after knock sensor replacement
  206. Car starts and shuts off after 2 seconds!
  207. car starts but shuts off after 2 seconds
  208. Where is the switch/sensor that tells the car the driver's door is open?
  209. GM alternator help
  210. Lucas Fuel Injector Cleaner, thick goo?
  211. Rattling front drivers side
  212. Post-Hibernation REVIVAL! (Just bought a mint WS6!)
  213. anyone know if you could fix these cheapo turnsignals to feel more rubbery?
  214. Whats you flavor?
  215. Left front brake Bird like chirping?
  216. Help! Gas Won't Go IN Tank!
  217. Driver Side miror is hanging down ?
  218. Vibrating Headlights!!
  219. The wheel shop screwed up my car!
  220. Rear taillight assembly
  221. T/A Fog Light Bulb Install Tip......
  222. Help!! Stripped my oil drain bolt
  223. car started smoking and leaking tonight
  224. 99 WS6 Low Coolant Light?
  225. need a new power steering pump?
  226. SES light, poor gas mileage
  227. Hole in Pcv hose
  228. Antifreeze??
  229. Bad Alternator??
  230. What kind of AC?
  231. Electric problem QUESTION?
  232. should i do a write up (how to) on a oil and rear change?
  233. what oil to use?
  234. oil pressure gauge slowed/off
  235. temperature
  236. GM Warranty help! Car has "extended warranty"
  237. Car Won't Start
  238. How much play should the driveshaft have?
  239. idle
  240. What to do with used oil?
  241. Resetting seatbelt light.
  242. O2 Sensor rattle?
  243. Chicago Guys In Here
  244. problems with drivers side running light, and a leak
  245. Window Motor Help
  246. Trip counter resseting by itself??
  247. Changing DRL Bulb
  248. rear end fluid change?
  249. LS-1 Fog Light Bulb Part # ??
  250. Please help me before i off my self
