View Full Version : General Maintenance & Repairs
  1. Changing rack and pinion, few Qs.
  2. Evans NGP+ Coolant
  3. Vibration?
  4. Question on neutral safety switch
  5. New Gauge cluster box
  6. parking for winter
  7. Oil?
  8. Taking off the center console in a 98 firebird formula
  9. Oil pan removal
  10. got the car dyno tested and now have ABS/ASR problems
  11. Clunking
  12. Coolant Leak!
  13. rear main seal
  14. Speedometer Switch Question
  15. Coolant fan doesnt work!! Help!!
  16. Where is my parking lamp relay located on a 98 trans am?
  17. Clunking noise from steering wheel
  18. removed door = car wont start
  19. ticking noise from where the driveshaft meets the rear end
  20. headlight trouble
  21. Burning Coolant
  22. fuel pump going out?
  23. Correct procedure for setting the car on jack stands?
  24. Coolant reservoir
  25. very strange fan noise
  26. Rattle in Door
  27. How many gallons of gas can our tanks hold?
  28. Amsoil oil pre charger
  29. fans problem
  30. TPS Sensor!
  31. thermostat question
  32. Threw a 430 code...
  33. VERY strange electrical issues, need help before everything goes
  34. Lights flickering when driving or idle
  35. Leaky intake manifold -- did I fix it??
  36. Easier to Work On: LT1 vs. LS1
  37. Trans Am Horn doesn't work
  38. I couldn't get my car in gear this morning, but later it worked okay - why?
  39. No Oil Pressure!
  40. driver side window sounds "loose" when half-way down
  41. Help! Leak!!
  42. Strange Leak
  43. fuel pump power supply?
  44. U-Joint
  45. Problem: Driver's side window...
  46. Air bags?? horn problem
  47. Please Help. Bad oil pressure problem
  48. easiest way to remove a/c compressor?
  49. Changing window motor
  50. Is my tensioner bad?
  51. Cooling problems
  52. Bad Ignition?
  53. Need Help .. Wire Hanging
  54. rough idle on a 91 corolla
  55. LT1 chokes at about 4000 rpm when accel.
  56. Problem starting; also sputters sometimes at 2k rpm
  57. weird sound from driver-side door
  58. Tail light trouble
  59. Mobil 1 truck and suv?
  60. Which oil weight?
  61. So I'm leaking coolant... and more problems
  62. Squeaking noise from wheel
  63. spark plug change problem
  64. Pop up headlights
  65. z06 having idle misfires after clutch install
  66. wow explain this one....
  67. bad heater core??
  68. underside of hood started hitting the performance lid... why?
  69. SEA FOAM! (in the spray can)
  70. car randomly does not start
  71. Can anyone figure this out?
  72. New Engine, Now Hear 'Click Click'
  73. getting into the steering column area?
  74. blinker control assembly
  75. replacing 94 ford ranger 4cyl power steering pump?
  76. Bad miss after about 1-2 min of running...
  77. Weird issue after track runs last night. Some kind of vibration
  78. Do i need to rebuild my calipers?
  79. LT1 Security Light is on, but car starts normally
  80. Rt side turn signal
  81. Installed a new starter, still have a problem..
  82. What is the Opti Spark I hear about LT1's?
  83. Pulsing lights??
  84. car won't start (but turns over)
  85. ABS, BRAKE, and TRAC CONTROL lights after washing engine bay
  86. pcv hose question
  87. Fan Fuses Keep Blowing
  88. How to remove seat belt?
  89. headlights wont go on bright 02 ws6.
  90. Car shakes all over when coming to a stop -- is this normal?
  91. installing/resetting an Airbag system
  92. General Maintenance
  93. normal operating temp??
  94. electrical (ground) issue or alternator issue?
  95. every time I hit a puddle, alternator gets wet and car starts to die
  96. replacing positive battery cable?
  97. heater only blows cold
  98. car acting weird
  99. changing water pump on lt1?
  100. LS1 Knock at low rpms
  101. Having problems starting when hot??
  102. Battery died today...
  103. odomoter ghost
  104. Need OEM Part numbers for headlight actuators
  105. Brake lights
  106. additives
  107. Key will not turn in Ignition!
  108. how to check water pump
  109. slap sound when cold
  110. problems at part throttle
  111. Vibration/Rattle from transmission or rear end or..?
  112. Has anyone replaced your blower motor?
  113. Marvel Mystery Oil???
  114. battery won't hold charge, what's a decent cheap replacement?
  115. resurfacing rubber rim on t-tops?
  116. Speedometer Repair Opinions?
  117. Size of our Gas Tanks?
  118. hard jerking when shifting from park to drive
  119. replacing L front turn signal
  120. Headlight Gear Broke
  121. Severe Idle Vibration
  122. Amsoil Oil
  123. sound of air leaking
  124. Speedo Replacement Question
  125. Truck with remote start installed won't start now
  126. Chattering/knocking noise from engine
  127. steering wheel cocked
  128. WTF! Car wont start.
  129. Rattle From Engine At Low Throttle
  130. 2001 KX125 motorcycle problems
  131. driver side seatbelt assembly rattling? piece from sunvisor mount above headliner?
  132. headlights make grinding noise when I shut them down
  133. Is my alternator bad?
  134. Lost Keys For 91 Z28
  135. Broken window
  136. 130k miles - seafoam treatment; which oil weight?
  137. oil pressure
  138. Window track problem fix
  139. Cold Starts
  140. windows make clunking noise after motor replacement
  141. Ford Antifreeze?
  142. what specifications of car battery do I need?
  143. Mystery oil leak on LT1
  144. shudder
  145. i think i have a miss
  146. noise from rear when compresed?
  147. removing engine
  148. why does it take more effort to steer my car?
  149. Symptoms of bad wheel bearing
  150. jerking at low RPMs, stubborn O2 problems
  151. oil filter
  152. Headlight motor screwed... again.
  153. How do you remove old threadlocker (loctite) from threads?
  154. Car sometimes has trouble starting after it dies
  155. Clicking noise when I turn my heater on?
  156. Odd problem in the rain (SES light)
  157. LS1 service schedule??
  158. Spark Plugs
  159. Swapped Positive Lead, Car Dies When Braking
  160. Overheating- Coolant Leak
  161. Squeaking, E-Brake Not Engaging on an 02 Z28, etc
  162. what fluids to use?; headlight motor
  163. 65+ on highway car starts to vibrate
  164. BCM help! Doorlocks broken
  165. Spoiler light '02 TA
  166. Oil Pressure and Temperature readings
  167. 5w40 syn
  168. terrible screeching noise with smoke coming from alternator side of engine (LT1)
  169. Intermittent rattling
  170. HVAC actuator valves
  171. Color of your oil?
  172. What Spark Plugs Should I Use?
  173. Change Oil Light Reset
  174. Tie Rod Replacement?
  175. She's Leaking!
  176. Headlight motor question
  177. Strange electrical issues
  178. Lots of "clunks" from the drivetrain...
  179. Low Oil Light?
  180. No Brake Lights
  181. Fuel Filter / Pump Problem?
  182. Where can I get a headlight motor?
  183. defroster = AC
  184. LT1 ques need help asap, how do i repress the studs in the axle, how can i take itoff
  185. Riddle me this Batman
  186. The brake light is on?
  187. Unknown part?
  188. Scheduled Maintenances
  189. Need part numbers for starter, gasket, seals...
  190. strange sound from rear
  191. How to fix Rear Defroster?
  192. No headlights
  193. How to take out passenger window? (2000 Camaro)
  194. Clunka-Clunka from rear end
  195. Rear bumper corner not lining up? Any clues.
  196. Compressing Caliper Pistons
  197. where can I buy this part?
  198. Tick when A/C's on
  199. Steering wheel off center
  200. Prob Starting help
  201. Power locks not working
  202. Fed up with power windows.
  203. stripped negative battery terminal bolt
  204. 1990 K1500 truck - won't accelerate well, has steady knock
  205. Strange Tire Wear
  206. Removing center console from 01 Z28 M6?
  207. dex cool vs regular antifreeze
  208. Need a new wiper arm
  209. U-joint cost repair
  210. my windows don't work sometimes
  211. So, Wal-Mart sucks more... (refused oil change)
  212. Headlight turns on, but doesn't pop up, no grinding noise
  213. Front fender bulge
  214. Winterization??
  215. Wiper fluid problem Maybe motor?
  216. replacing vent
  217. Putting my SS away for the winter - battery?
  218. floor boards soaked
  219. Weird ticking noise coming from engine
  220. Rattles under accelration
  221. noise while turning?
  222. noise from front end is driving me crazy
  223. Cruise Control Cable
  224. 1997 firebird 3.8L V6 auto, shutters and studders while accelerating
  225. my horn stopped working
  226. could use some help
  227. You know those little lights...
  228. what type of oil?
  229. Alarm and Headlight Problem
  230. Help me find my rattle!
  231. still having low coolant light problems
  232. Ignition Problem
  233. Blinker problem? Don't blink stay solid?
  234. Best oil for the '05 GT?
  235. Weird noise in front
  236. horrible squeal!
  237. Alternator died
  238. engine shakes to a stop ofter ignition kill
  239. starts and stalls
  240. Overheating? Water pump?
  241. Cruise Control
  242. Possessed 95 TA, Bad Key Or What?
  243. A Case of the Ticks.
  244. problems starting LT1
  245. Rattling noise under car.. Please help..
  246. coolant level sensor
  247. little light
  248. storing car in the winter?
  249. Didn't put oil in oil filter; is that bad?
  250. LT1 oil leak!
