View Full Version : General Maintenance & Repairs
  1. Part # for T/A lenses (amber driving lights)
  2. Finally, an A4 shifter rattle fix!
  3. pcv valve, fuel filter, on v6 camaro
  4. Need help to remove the AC clutch on our 94 Camaro
  5. Could this be bad lifters
  6. Oil Change Light?
  7. Rearend Rattle - Driving me Crazy!
  8. Bleeding air from coolant?
  9. Windshield wiper won't come off, ideas?
  10. Thinking about pulling motor
  11. pound noise in the engine bay like if a engine mount is broken or lose
  12. Wiring harness question
  13. buzzing vents?
  14. Proper way to store car for two-three months?
  15. gas gauge not reading correctly
  16. Burping the Coolant System
  17. Spark Plugs/ Wires, questions
  18. freeze plug
  19. Leaking front turn signals...
  20. Headlight motors
  21. A/C condensation puddling on floor: where to unclog?
  22. Head gasket question...
  23. barking noise from underneath center console when accelerating
  24. Oil usage with synthetic.
  25. check gauge light (low Battery)
  26. Barking noise on 10%+ Acceleration
  27. Engine light on again
  28. SES light, MAF?
  29. GM Recalls?
  30. 99 Z wont start after shifter install
  31. Steering rack arm problem
  32. Hoses in back of engine bay?
  33. lost my nutsack please help (hood bolts)
  34. Dumb Newbie Question: Why won't my jack stands fit?
  35. Head light problem
  36. Discount Tire Messed up my car!!!!
  37. cooling fan issues
  38. intake gasket replacement
  39. Pop from front of car when turn wheel sharply
  40. window radio problem very weird
  41. Oil in Radiator
  42. Howling Sound from Rear
  43. HELP!!! Car is struggling
  44. Weird Sound
  45. o-ring was sucked into intake manifold...
  46. Frozen Belt Tensioner?
  47. Car won't start, ticking noise?
  48. Oil in Radiator
  49. cooling fans not running fast
  50. turn signal just hang'n out
  51. Plug for the Voltage regulator.
  52. intermittent high pitched moan from AC
  53. Strange-acting car (not starting)
  54. can't find plug-in and blower motor doesn't work
  55. a/c fuse question
  56. Turn Signal / daytime running light socket
  57. When and how to change clutch fluid?
  58. Third brake light replacement?
  59. Turn signal/wiper stock issue
  60. Should I Do Maintenance At 50k?
  61. Fluids
  62. Overheating, What is wrong?
  63. Steering wheel shake
  64. What is the part number for the TA Daytime Running Lights?
  65. banging/vibration of the whole car
  66. Car started overheating
  67. Steering wheel play...
  68. Distilled water???
  69. Instrument Cluster
  70. 01 Camaro SS overheating
  71. Squeak in the morning
  72. Window problems again
  73. car keeps overheating
  74. 50% done!!!
  75. No cruise control
  76. Any How To's on an AC leak
  77. turn signal fuse blowing
  78. grinding headlight
  79. AC compressor blown
  80. headlight pops up
  81. My car is being flooded help!
  82. Passengers side seatbelt broken
  83. Light out?
  84. Is synthetic oil necessary?
  85. Need of lights and window motor
  86. Problems while idling
  87. Air bag light
  88. low coolant light blinks on and off.....
  89. fuel gauge does not work on 98 trans am
  90. fender replacement
  91. Trunk Lid Won't Open
  92. AC Help
  93. steering wheel shakes pretty hard
  94. Have a short...
  95. dropping the tank
  96. Electrical Problems
  97. Fog Lamps
  98. plugs gapped to .020???
  99. Weird buzzing sound at higher speeds
  100. a/c compressor
  101. Replacing the weather stripping
  102. Warning lights
  103. help with removal of daytime light lens
  104. Power steering leak
  105. AC doesn't work
  106. Really bad rattling sound upon deceleration
  107. Headlight annoyances (95 trans am)
  108. Help! timing chain marks
  109. brake light
  110. corvette fog lights
  111. Nasty Sound on Idle
  112. electrical problems
  113. Time for a Change - Coolant
  114. vibration around 3500 rpms and up
  115. A/C Problems
  116. fuel filters
  117. Fuel System Cleaners
  118. Did my underdrive pulley cause my water pump to die?
  119. Oil Pressure Problems
  120. Wipers stay on no matter what?!?!
  121. Shudder
  122. best oil filter
  123. headlight motors are the devil
  124. A/C issue: not blowing cold, will not take more refrigerant. Suggestions?
  125. Clicking noise
  126. Fluids
  127. Seafoam Question....
  128. AC Recharge Nozzle?
  129. Corroded Battery/Cable... any TSBs on this?
  130. vibration problems
  131. 99 ta fluid spill
  132. Power steering pulley removal
  133. Cigarette Lighter fuse keeps blowing
  134. 3-4 cranks before start
  135. Brake lights stuck on
  136. Creaking noise
  137. Does this mean I need a new starter?
  138. Windshield washer nozzle
  139. Car spit fluid on garage floor
  140. Oil Pressure, how low can you go
  141. Brownish Coolant
  142. NGK Spark Plugs Worth $?
  143. 30k dealer major service - neccesary?
  144. Lack of power during w.o.t.
  145. Nology Plug Wires
  146. Loud noise from back of car
  147. Car has a rough idle after it gets warmed up
  148. water temperature gauge malfunction
  149. My AC is leaking inside of the car
  150. Signal Lights
  151. Door coming apart repair!
  152. Best Oil to Use?
  153. HVAC problem....
  154. Passenger window doesn't go all the way up.
  155. Weird problem with car.
  156. Wipers are dead
  157. loose fuse?
  158. Replacing Alternator
  159. Traction control will not work
  160. Headlight wobble?
  161. torque arm mount install-please help
  162. replacing Turn Signal bulb on 98 Camaro?
  163. driver window doesnt want to go up!
  164. major problem - thud, console shaking
  165. Headlight Problem! WTF!!!
  166. problem recharging battery when running
  167. Change Oil light on?? don't know why?
  168. how to remove rivets from window motor?
  169. Just Changed the Oil on my New LS1
  170. mangled in an accident - can it be fixed?
  171. O2 sensors question.
  172. T-Top handle mechanism is stiff/rusted?
  173. Typical A/C problems in mid-summer (why me).
  174. Hatch won't open while car is running
  175. Oil Change. When there is a will...
  176. Changing HO2S Bank 1 Sensor 1
  177. Noticed a little smoke last night
  178. cruise control
  179. A/C evaporator/pulling dash
  180. problems starting..
  181. My baby is overheating!!!
  182. is my car running too hot?
  183. photo of how wipers/headlights switch connects?
  184. Best Spark Plugs?
  185. Lights dimming in and out?
  186. Replaced window motor last week now it doesn't work??
  187. High mileage maintenance?
  188. High mileage maintenance?
  189. Non-oiled filter suggestions?
  190. Is 20w-50 Oil Ok For My Car?
  191. Alright, Now I'm mad
  192. A/C only blows out warm air. Does not work.
  193. A/C only blows out warm air. Does not work.
  194. '01 T/A Headlight Motor Bad?
  195. water pump replacement?
  196. Hesitant to start sometimes...
  197. Need help guys
  198. How to test an ICM
  199. headlight motors, turn signal
  200. E-Brake light won't turn off. Combination Valve....
  201. hmmm..... i think i killed my battery
  202. these TA pop-up headlights suck!! Heeeeelp!!!
  203. Window motor repair possible?
  204. How to remover rear seats (TA) & window tint
  205. power steering nightmare continues :(
  206. AC Vents f'ed up?
  207. What is this part called
  208. What to torque the Tie Rod End nuts to?
  209. secondary air injection system malfunction
  210. Here We Go - Fixing Everything
  211. $207 for a Water Pump Install?!?!
  212. car dying...
  213. please help find weatherstripping
  214. gas cap or alternator?
  215. Failed Inspection Because Computer Couldn't Be Read?
  216. Highbeam switch?
  217. Weird problem, electrical system?
  218. oil filter testing....where is the website?
  219. Headlight / rain / Keyfob issue?
  220. Last time I let someone drive my car...
  221. A/C Woes Part II (What am I doing Wrong?)
  222. I think I blew a head gasket
  223. A few questions, Thermostat and Electrical
  224. A/C compressor problem
  225. Recharging A/C - where is the low side port?
  226. I'm Officially an F-body Guy - Changed Flasher and Turn Signal Bulbs
  227. Best fuel injection cleaner & plug wires
  228. Here's a weird question ..
  229. power steering
  230. What plug wires are you having good luck with?
  231. Oil Level and Gauge
  232. rear tail pipe hangers
  233. rear suspension problem i think
  234. Help with another Pontiac
  235. extremely high pitched whine
  236. PVC Valve on a Trans Am Question
  237. Smelling Gas outside of car
  238. 1999 Trans Am LS1 with A/C Problem
  239. Alternator plug/wire?
  240. what is this?
  241. HELP my car is all messed up now!!
  242. GM power steering fluid part number
  243. Another Window Question
  244. I love autozone.
  245. Anyone know the part number for driver-side sun visor?
  246. Rear Wheel Cylinders?
  247. Major Problem In The Dash
  248. door hinge replacement
  249. bubbles on oil dipstick?
  250. fix a radiator by pissing in it?
