PDA
View Full Version : Advanced Engineering Tech
Pages : 1 2 3 4 [5] 6 7
  1. How many CFM of air per RWHP, roughly?
  2. Looking for BEST and most accurate camshaft tech articles.
  3. Video of inside a cylinder when firing
  4. msd 6LS ignition box, pre set timing curves
  5. How to determine amount of head flow to feed specific engine size?
  6. Inside look at the Internal Combustion Engine
  7. 2stroke
  8. The LS1 & E85
  9. Move Advanced Performance Tech???
  10. How much power does adding compression make?
  11. formula to calculate engine size?
  12. Homogoneous Charge Compression Ignition
  13. Calculating Restrictor Plate Sizes.
  14. hydraulic lifter operation & preload (technical)
  15. Direct Injection Compatible with Pushrods?
  16. Engine assembly: ring oil
  17. Question about a ELC and effects on EVO
  18. Cam Spec Differences.. EFI vs Carb'd
  19. Yamabond and Quench Distance Questions
  20. Vizard's LSA - CI/Inch Valve Diameter chart
  21. Designed my own cam, how do these valve events look? all data inside
  22. Why am I breaking valves???
  23. Can you tell if an LSx engine has VVT or AFM using the VIN? If not, how can I tell?
  24. Back pressure and torque
  25. Nano-boric acid makes motor oil more slippery
  26. Duration Vs. Lift on NA Motor
  27. Does traction increase as speed increases?
  28. Omni Valves
  29. Lobe seperation vs. dynamic compression
  30. Maximizing power under the curve
  31. detonation + gasket blow ?
  32. Any real world setups with SCE Titan self sealing gaskets - NOT ICS
  33. Home porting an intake manifold
  34. Anyone know how to find area above top ring on a piston?
  35. Oil Accumulators
  36. Second ring end gap?
  37. How much compression height needed to avoid oil ring support rails?
  38. An alternate fuel???
  39. OIL!!! cant seem to find out where its coming from!!
  40. Carb'd coil drive question.
  41. Squish Question
  42. How are you guys setting up your timing pointer
  43. intake/exhaust flow CFM
  44. Need advanced help, oil consumption
  45. To Cryo or not to Cryo, that is the question....
  46. 98 octane+how far can it go in hp
  47. parts/weight chart???
  48. Why port volume or cross-sectional area? Can we do better?
  49. .020 in the hole too much
  50. Wiring/programming an electric water pump
  51. Got some ETP LSX 6 bolt heads in today.
  52. understanding crank sensor signals
  53. Reading Material for Engine Design
  54. proper precedure for break in...multiple items
  55. gauge problem
  56. Is there possibility for too much intake airflow?
  57. Desmodromic VVA
  58. Flat/HO/Boxer OHV motor possible?
  59. Backpressure vs scavenging.....Which one do we want???
  60. home build Cam measuring device ?
  61. Who has cryo their block or parts?
  62. A C5 that can't... Baffling problem..FOUND!!!
  63. Tuning 101 Questions...
  64. High octane fuel question.
  65. what were they thinking ?? Theory behind LM II muffler design
  66. Soild Roller Lsx down on power
  67. relationship between rod ratio and port volume
  68. Stressed skin materials question
  69. 45mm ITB's too small?
  70. Still pushing water.
  71. Valvetrain weight concerns with Caddy lifters
  72. Flat Crank LS1?
  73. Emissions tech question: NOx and HC levels with dirty catalytic converter
  74. Baffling problem....My C5 can't be fixed?!?
  75. 2003 Z06 transaxle
  76. why not turbo diesel
  77. Cam not degreed
  78. Conserving heat energy
  79. Rods
  80. Cylinder head clamping force LSX/6.0 IRON/WORLD
  81. 100 horsepower per liter naturally aspirated
  82. Losing oil pressure after run
  83. Advantage of high-flow heads?
  84. Looking for an intelligent answer to a basic cam question.
  85. measurement for pulley to front cover
  86. valve drop measurement
  87. Advancing a cam for higher DCR.
  88. DCR vs. total duration in cam selection..
  89. any problem free gapless top ring users?
  90. Too Much Vacuum??
  91. SCR/DCR vs. Cranking compression.
  92. Why don't more supercars use transverse mid-engine layouts?
  93. lazy rev, 20to1 a/f at a slight rev
  94. Turbo single cylinder?
  95. Engine Awards.
  96. Highest CR on 93 Octane
  97. complex math and so???are skills
  98. gapless rings or not?
  99. Cranckcase Pressure Help
  100. wb o2 sensor after the cats
  101. Power Recovery System.
  102. LS Piston Experts- Using LS pstn in 1stGen 283
  103. LS1 solid lifter options and weights
  104. a few body/ aerodynamics qs
  105. Is tire width as important as we think it is?
  106. Need some springs, mass vs weight vs seat pressure
  107. Welding on the oil pan?? Help please
  108. GMPP vs Victor Jr. Carb Style.... runner length and peak HP question?
  109. valves vs spring pressures
  110. Jager Aluminum Rods
  111. Racelogic TC on 58x LS2
  112. Thought this was a pretty cool read
  113. Compression vs. Octane
  114. Horsepower Calculation
  115. carb vs. injection and fuel octane requirements
  116. turbine supercharger.
  117. Pistons with offset pins
  118. Arao 32 Valve heads?
  119. turbo/supercharger question
  120. Intake Port Volume vs. Fuel Type
  121. Ignition Problem....HELP!
  122. Internal Electical Circuit in GM's LS Ignition Coils
  123. Engine Stress/Mounts/Crash
  124. What determines the powerband of an engine via intake manifold design (Carb v. LS6)
  125. engine builders high rpm question bearing clearances?
  126. Heat vs. HP
  127. How does altitude change header pipe diameter needs?
  128. How to check if your rings are going bad?
  129. Lunati crank looks blue after cut?
  130. Qhat exactly is engine load, and how is it measured?
  131. Air-Fuel-Ratio vs. power
  132. methanol and Aluminum
  133. 6 bolts per cylinder?
  134. Head porting question.
  135. OHC vs Pushrod
  136. Ring flutter w/ deleted PCV??
  137. Tech information for the experts
  138. compression ratio and horsepower question
  139. Thoughts on Dexcool v.s. Green
  140. Can hp be calculated from cfm?
  141. addition rotating mass?
  142. Oil sprayers? DIY
  143. Engine Break in Theory
  144. Washing rings?
  145. High Torque vs High Horsepower.
  146. Advanced Guru's Only Please Respond! Copied From Nitrous Section
  147. Titanium Rods?
  148. Hand Porting Cylinder heads
  149. Need to know compression real quick.
  150. equation for displacement?
  151. cams and emissions
  152. Is E85 Really a Good Deal for Performance?
  153. Variable cam timing for performance applications
  154. Adjustable thermostat discussion
  155. nitrous vs. boost
  156. NASCAR rear differential - open?
  157. Some welding chemistry questions.
  158. Intake Manifold Runner lenght Calculations sheet
  159. Larsen Radax Engine
  160. Is there an equation to figure out dynamic compression ratio?
  161. Is overlap effectiveness rpm dependant?
  162. Gen II vs LS engine?
  163. E85 & Emissions?
  164. New GM NASCAR Small Block Debuts for 2007 Season
  165. how do you optimize your setup?
  166. Destructive forces inside the rear differential
  167. Different AFR in closed loop?
  168. Methanol LSx
  169. Educate me
  170. supercharged headers
  171. LS2 LS6 Or a built LS1
  172. Ssra cold pack.. Measurements
  173. Valvetrain Knocking sound, and Rocker Stud questions [PICS]
  174. Stabilizing LS2 Block Flex with Hard Block
  175. Shifter question.
  176. Converting An Ls7 To 6 Litres With A 96.9mm Bore
  177. Idea for MAF calibration
  178. milling/thinner head gasket - how much power leaving on the table?
  179. Big cubes for better gas mileage?
  180. Intake Flow, Head Flow, But What About Engine Flow??
  181. never seen this
  182. Clutch-by-wire
  183. Cam Design Theory from David Vizard
  184. Max Cam overlap with Cats?
  185. rising rpm
  186. Gains from intake manifold pressure on piston
  187. camshafts... semester 2...
  188. Valve Overlap Limits For Daily Driver
  189. Will this work?
  190. What breaks next?
  191. Demon Inline Induction
  192. Quench?
  193. Objectively comparing cylinder heads
  194. Efficiency...
  195. Manifold options
  196. carbed and efi cams, same or different?
  197. horsepower:torque relationship?
  198. Re: Octane booster
  199. Homemade Octane Boosters
  200. pre-load/lash adjustments
  201. Cam overlap... Help me understand
  202. electric vacuum pump
  203. LSx head flow theory.
  204. Evap System
  205. Cam Timer....discussion within
  206. Pretty good quench article
  207. Am I figuring this right?
  208. EDM Pin Oiling for High RPM?
  209. Which of these two cams are theoretically bigger?
  210. Questions on ramp rate and duration/lift
  211. DCR on 94 octane?
  212. Brake Specific Air Consumption
  213. Optimal Quench or DCR???
  214. DCR and boost
  215. Can you over throttlebody a efi motor
  216. Will Camshafts Soon Become Extinct?
  217. Does GMs VVT really do what they say it does?
  218. Continuously Variable Trannys for drag racing
  219. v-tec? how about rotary valve
  220. 6.0L v8 or 6.0L v12?
  221. cam position sensor
  222. Oil pressure in head
  223. Looking for a blueprint drawing of the LS1/6
  224. Boosted cyl. pressure?
  225. Question for flowbench junkies (Tony Mamo et al.)
  226. Anyone have experience LSx vs carb vs sheetmetal and how it affects power peak perIVC
  227. The Big Switch
  228. To double an engine output.
  229. Trade Intake Bias for Duration?
  230. Nitromethane as a power adder?
  231. Cam advance?
  232. 2.00" Crankpin Preferred Over 2.10"???
  233. Technical info on rotary valves?
  234. crank sensor voltage
  235. Why are valves circular?
  236. 1994 Z28 Lt1 To Ls2,ls6,or Ls7
  237. new valve design.
  238. Too much bearing clearance?
  239. O2 sensor. heated? 3 wire? 4? Signal? HeLp Please.
  240. m/a n t/b
  241. Drysump users?
  242. Question
  243. How concerned should I be with QUENCH, DCR and SCR
  244. Victr Jr. vs Fast 90mm for spray?
  245. Vic Jr. vs Performer RPM???
  246. Can someone clear up this "myth" for me.
  247. Dyno vs Track Validation
  248. Math Gurus Inside
  249. Deck Height Irregularities
  250. bob weight
