View Full Version : Advanced Engineering Tech
Pages : [1] 2 3 4 5 6 7
  1. missing o2 sensor pug in header???
  2. LS1 Rear Mid-Engine AWD (C5 Corvette donor)
  3. this is a hard one 8.1 /allison
  4. X-pipe/Cut-out --> all in one
  5. how would this crazy exhaust design sound?
  6. Pressure and Horsepower
  7. JB Weld in Intake Ports?
  8. LSX Part Numbers
  9. Oil Temperature
  10. physics peeps in here...
  11. Gas Mileage Build Question
  12. Air lid Angle Issues Need help
  13. Wiring question!!!
  14. Calculating cylinder volume for EFI live
  15. Polishing Inside of Cast GM pan?
  16. Will this work????
  17. quench, effects of dished vs flat pistons
  18. Heavy crank vs lightweight crank
  19. LS2 with LS3 heads valve clearence question
  20. Oil Priming a new LSx engine after its installed in the car.....HOW..???
  21. Understanding Short Travel Hydraulic Lifters and Valvetrain Control
  22. More cubic inches affect VEs? focusing on IVC
  23. lightened rotating assembly advantage?
  24. LS Intake/Cylinder head drawings or measurements.
  25. push rod length
  26. Designing 180 degree headers-LS1
  27. Ceramic coating
  28. Lt1 overlap and Smog vs. Ls1 overlap and Smog
  29. Exhaust and engine accoustics for asthetics and performance.
  30. pollution test required
  31. Extrude Hone LT1 Heads
  32. viper upgrade
  33. water pump heater lines
  34. HP at altitude
  35. Head Port for MPG
  36. 3" versus 2.5" collectors on 1 3/4" primary headers
  37. DCR and pump gas question
  38. Shaving Cylinder Heads & Efficiency?
  39. Required CFM per HP
  40. Alright guys.....quench question
  41. Electronic trouble shooting
  42. Strange noise
  43. oil pressure problem
  44. Canbus Dash?
  45. Want to learn the finer details
  46. Help low oil pressure after 2 builds
  47. Changing the firing order of a motor?
  48. ttop to vert conversion
  49. P&p
  50. destroking a ls1
  51. 2012 IndyCar AutoCad?
  52. Camless engines...
  53. Service provider of broken bolt removal
  54. intake filter setup
  55. Stand-Alone controls stock guages?
  56. Forged rods for 4.8L
  57. ls1 maf to ls3 maf ? need tune ?
  58. Machining LS1 heads, help
  59. 40 mpg engine build
  60. Suspension Geometry & Weight Distribution
  61. Let's talk vavle spring rates
  62. don't x-pipes reduce cross-sectional area?
  63. hp to weight ratio max fuel economy
  64. Can a worn out harmonic damper lead to timing retard?
  65. How to avoid the double hump in torque often seen in dyno output?
  66. Female flare fitting bung ideas for aluminum fuel tank?
  67. E85
  68. New cbm whipple side mount throttle body adapter lsx
  69. C02 used for a cooling agent?
  70. Best primary length for 6500 rpms?
  71. Air to Water Intercooler using gas?
  72. Experimenting with inserts and clamping loads???
  73. removing the second spark?
  74. A\C compressor housing to mount vacuum pump
  75. why no nastier beehives
  76. Harlandsharp roller rockers brocke at the bearing
  77. Part from a needle bearing?? in the oilpan (from morel lifters or rollmaster timing)?
  78. A "fairer" dyno comparison
  79. pic: purpose of this plenum on intake duct ?
  80. Does Oil Pooling in the Heads Cool the Valves?
  81. Cam Design...
  82. lq9 coils. what does it mean that they are "better"?
  83. 2010 - 2011 Corvette Racing LS7-based engine
  84. Where does RPM come from?
  85. Bolt Pattern - C5/C6 torque tube to bellhousing
  86. Power to Starter?
  87. We have stepped primary headers but, no tapered primary headers..
  88. Looking for a book ls1
  89. Help with compression ratio
  90. motor issue smh...
  91. someone help with clearance issue
  92. Main seal, labor ? --- Help
  93. Exhaust Volume/Back Pressure Question
  94. What are these connectors for?
  95. Compressorless AC
  96. how much oil ?
  97. Welding LS anuminum oil pan
  98. torsion bars vs struts
  99. Can anyone ID this cam? cc p7088-09
  100. 4L60e disassembly knowledge needed
  101. Another Cad request(pistol grip shifter)
  102. turbo intake.
  103. moving engine back
  104. flat floor
  105. CAD Project Ideas
  106. Stretching ARP Rod Bolts. Weak Bolt?!?!?!
  107. 2 turbos
  108. Speed Density
  109. 5.3l with stock dish pistons
  110. racing with restrictors
  111. Rotating the 5.3 intake 180 degrees..??...
  112. carb to efi on a victor jr..need help
  113. Milling stock heads
  114. direct injection
  115. diesel rpms
  116. High Level Technical Information on Ignition Wires / Components
  117. camming for high altittude
  118. Inverted flow LS heads?
  119. air turbulance at entry ??
  120. Need Help computing Compression Ratio (DATA in THREAD)
  121. Nascar moves to EFI next season
  122. Virginia speed build...
  123. Question on what .050 duration will be after changing events
  124. LS Conversion
  125. a/c issues ?
  126. Combustor Can Anti-lag Systems.
  127. does this exist?
  128. Engine coolant temps vs HP vs MPG
  129. What effect does fuel line size have on a fuel pump's ability to support HP?
  130. checking cylinder volume
  131. Water injection to silence exhaust
  132. EVAP Question
  133. Desmodromic V8
  134. LS3 Sensor Pin Outs
  135. Valvetrain Geometry Question
  136. D585 Coil Specs
  137. wheels fiting over brakes
  138. sensors???
  139. wrong heads and cam?
  140. Hydrogen powered car guide..pros n cons
  141. school me on radial engines
  142. Electrical question
  143. please explain the difference in the two.
  144. GM LSA Calibration
  145. Bearing clearances
  146. Front tire width
  147. Laser beam spark plugs? It looks like it may very well happen
  148. 950+ hp??????
  149. LSX Heads
  150. What size of gears to use on a dry sump system?
  151. Max redline on 3.662" stroke Eagle crank w/forged rods
  152. Electrical question about multiple horns
  153. lobe separation, and how it affects low end
  154. Natural Gas Conversion?
  155. Dry sump pump placement question
  156. Am asking for "advanced knowledge" based replies, engine bearings
  157. Fuel BTU
  158. Timing, AFR, Knock
  159. 383 stroker / 6.125" vs 6.000" / 2.100 vs. 2.000
  160. @@ Lobe Dynamics @@
  161. Folks who build their own 12 bolt and run a M6 trans please come in.
  162. Wheel machining help please.
  163. Momentary engine cut module for WOT shifts
  164. cranks but wont start?
  165. LONG: Faster revs, not more revs...
  166. Magic AFR heads from damage
  167. Need Help! Balancer broke!
  168. Iron 6.0L bore question.
  169. idea for EMC motor,destroked 6.0
  170. HELP installing gauges how to
  171. No T-Stat leads to overheating
  172. Machinists: LSX block lightening
  173. auto ignition point fuel??
  174. What if you designed a striaght 8 LSX???
  175. I am baffled?
  176. Timing Chain Dampener Material?
  177. RHS tall deck intake adapter
  178. Stepped exhaust vs smooth transition??
  179. does brown gas work?
  180. 6l80 controls
  181. Cam bearing install post?
  182. Bearing damage caused by short stroke and high torque?
  183. stock ls1 airflow numbers
  184. -AN Coolant Lines in Black?
  185. Stroke Only = HP?
  186. DCR/SCR in relationship to motor "sluggishness"
  187. Requesting information: LS1 heads on Ford engine blocks
  188. Using a longer duration on exhaust lobe to use a smaller primary manifold?
  189. Fuel Injector Timing as Compared to Engine Cycle
  190. The LS7: How was it created?
  191. Fel-Pro 1074 Head Gaskets and nitrous
  192. ls1 gps tracking
  193. Long Term Effects of Mileage on Forged Motor
  194. vats
  195. transmissions help?? skip shift
  196. ls1 intake angle question
  197. JE Pistons Asymmetrical Skirts
  198. Electrical Gurus Help - Stand Alone fan controller system.
  199. "help" "need" "help" (badd)!!!!!!! Please.....
  200. Who here has over 100% VE and how did you get there.
  201. ECT Sensor problem
  202. Negative effects of negative offset wheels?
  203. bad back fire
  204. Transonic Combustion
  205. VJ on Dart 225 heads??
  206. PTV clearance with 58cc heads and stroker cam
  207. ITB's for LS engines
  208. big snout vs small snout?
  209. strangest problem ive ever seen HELP!
  210. need help inHg vac
  211. Looking for Factory Intake Runner Specs
  212. ls1/ls6 intake flanges
  213. O2 Sensors....NTK L1H1 vs. L2H2 vs. LHA.....anybody have any info??
  214. Titan oil pumps. What's the big deal?
  215. Higher compression
  216. How can I convert my 24x cps to read 3ppr
  217. natural supercharging
  218. ls2 harness question
  219. porting cylinder heads = better mpg
  220. Spark Plug Discussion....serious motor guys what do you think?
  221. Seeking advice
  222. Converting LS1 heads to reverse flow cooling....
  223. effect of race weight?
  224. High duration/low lift VS Low duration/high lift
  225. totally one-off 3800 build research
  226. Formula for exhaust density relative to temp.
  227. 96/97 lt1? and theory, trying to figure out distributor signals and such
  228. Electric Go-Kart and a Fuel Efficient Vehicle
  229. Need experienced feedback regarding Clevite Tri-Armor bearings
  230. Crankshaft end play?
  231. Deleting ac airbox while keeping Heater assembly??
  232. bore vs stroke
  233. 180 crossover headers
  234. Alternative to reluctor wheel?
  235. LS2 TB Butterfly Axle...
  236. Unusual OHC Chevy?
  237. Tune/wear/power/lost/ how 2 engine act questions
  238. Exhaust Cutout
  239. 4th Gen Camaro Solidworks Model?
  240. Belt part number needed
  241. Break in - New Engine Deceleration - under own vacuum or drivetrain brake?
  242. Break in ( not sure there is right area)
  243. Fuel Vaporization + Adiabatic Engine?
  244. Clipping the heads - CC per thousandth
  245. R07 parts on LS?
  246. without reluctor wheel
  247. X, H, balance, or none ?
  248. Why combinations need different amounts of timing
  249. High amperage control cuircut relay?
  250. New Generation Ls motor?
