- I bought a lift tell me what you think
- Code reader - harbor freight?
- FS: Craftsman/Gearwrench Tools
- Mig Welder
- Glass Bead Media
- Does any of the Tool Companies make a 2 inch 3/8 drive extension?
- Best type of oil filter wrench?
- English to Metric adapters
- How to make lifter retainer tool?
- Craftsman 60 gallon compressor
- Impact Wrench
- where to buy a Porter Cable?
- MAC Tools West Coast Choppers Toolbox
- where to buy rhino ramps??
- BIG tool boxes...
- Where is the best place buy a bolt-stretch angle socket?
- Where to get honing plate?
- Where to buy polishing wheels?
- NE1 use the new J-P-R Lifters rods...
- Does anyone know where I can get a CD about rebuilding LT4s?
- cutting exhaust pipe
- looking for air tools
- My cluttered garage...
- Kobalt 60gal Air Compressor at Lowes?
- air ratchet, butterfly impact, big standard wrenches
- Welding the exhaust...
- Time for new 3/8" flex head ratchet
- Does anyone have pics of the home made lifter tool?
- The new Miller DVI welder, good or bad??
- torque wrench ?
- What to put down on the garage floor help.
- Welding chromoly..
- Air compressor deal...
- o2 Removal/Install Help
- How about this to test engines with.
- Husky Warranty?
- $300. Need 1/4" and 3/8" torque wrenches and recommendations.
- matco vs snap on
- FS: Craftsman 20pc Stubby Wrench set
- Garage driving range
- Car Ramps
- Valve spring tool
- What Jack Can I Use?
- TIG welding help
- torque wrenches
- cam install rods? what size?
- Best way to fix stripped threads
- welder
- 1/2" carbide drill bit
- mig welder
- Cheapie TIG welder - more Chinese junk!
- 10.8Volt Lithium-Ion Cordless Dremel
- Z06 Steve's valve spring tool $26!shipped
- drill bit?
- die grinder?
- will a sawzall cut it??
- Tim's Valve Spring Tool Now Available
- cordless impact wrench
- First welder suggestions?
- Valve spring pressure tester
- TIG Welder
- looking for a certain kind of socket wrench
- LS1 Valve height mic
- piston ring filers
- Who makes a good 12v air compressor?
- welding stainless to carbon steel
- Those of you with trailers...
- Good home air compressor?
- Another BIG vote for the Harbor Freight Trans Jack
- autoxray vs. actron
- What are you guys paying for gas?
- Any Mechanics Out There? Need Tool Advice
- Anybody got a Miller Maxstar 140?
- FS: New Mac 3/8 torque Wrench with carrying case
- What size wire do you use to weld subframe connectors?
- Neighbor let out the hyd. fluid from car jack. How do you bleed a jack?
- Welder
- Welder help
- ARP head studs
- Cheap Lifts that can be installed in a standard garage?
- FS: welding wire
- Stripped allen head bolt
- Flywheel locking tool?
- FS: Milwaukee 1/2 in. Cordless Impact Wrench
- Where to buy Kent Moore flywheel tool?
- Sears 151 pc. mechanics tool set $51 off | 275 peice $100 off! AND MORE!
- What type of vehicle do you haul your car with?
- FYI for the Craftsman/Snap-On/Stanley Debates
- rachet adapter?
- Stanley Professional Grade
- Lincoln SP-255 Digital Mig Welder FOR SALE!!
- Mac Tools Heavy Duty Grease Pistol
- Beware of Cheap Air Quick Connects
- Mac Tools
- Impact Guns - Decent Purchase?
- How to determine value of used Snap On tools
- welding to the frame
- Pro Park-7 lift
- Valve Spring Compressor
- Tappered sleeve Ring Compressor??
- FS: Ingersoll-Rand 1/2 in. Impact Wrench, Titanium 1000 ft/lbs
- Okay, how about this compressor?
- Band Saws
- Tool to reinstall stock pulley
- What you think of his Hoist/Stand
- how to rear tires on ramps and jack up front?
- Garage banners/posters
- welding stainless
- Floor jack rebuild kits
- what socket sizes to get?
- Where to get 10+ gals of solvent / Parts wash
- Garage Floor paint/ epoxy and checkered
- Painting??
- Oil pump center sprocket removal tool??
- Craftsman Club is a RIP OFF!!!!!
- New Tools?
- How about this Air Compressor?
- Harbor Freight Tig?
- AC floor jack
- Trans fluid change - look Ma - no dip stick
- Engine stand bolts?
- Break in procedure for craftsman air compressor?
- 110 Mig Welders
- pinion depth gauge how to?
- Great Tool For Changing Torque Converters And Trans Fluid
- Tool for ac compressor removal?
- TB porting...
- MityVac Vacuum Pump
- Spring Compressors
- This Campbell Hausfeld compressor looks to be a good deal - 26gal/6.25hp/150psi/$229
- Special Editon Camaro Tool Box!!!!
- 3 armed pulley puller
- Snap On Special Edition Camaro Tool Box!!!!!
- Crank Pulley installation tool
- Plug socket???
- Engine hoist folding - Sam's - $179???
- Screwdrivers of choice?
- Everything involved with a lift....
- anyone use this Valvespring tool?
- Gas pump restore
- Snap-on micro tool boxes
- Rod/Piston hone... anyone want one?
- powder coating at home?
- questions about installing a lift
- How much to put garage door.
- Make shift paint booth?
- How much did it cost to buld your garage?
- craftsman welder gas conversion kit
- pinion depth tool
- Central Pneumatic... harbor freight
- Thread chasers/taps
- Engine building tools?
- 4 post lifts for sale cheap...
- How do you hold up your engine when the tranny is out?
- Pocket Knives
- What size power inverter would I need?
- GM spark plug wrench, is this worth it???
- Need help deciding garage breaker size
- Cleaning polished hand tools
- Anyone engraved their handtools?
- Looking For A Mig!
- Need a set of stubby wrenches
- which is the best torque wrench
- A/c Auto Refrigerant Repair Equipment R134/r12
- What is the best tool and best way to remove a broken tap?
- GM Parts CDs?
- Big thumbs UP for SK Tools
- 3000lb Aluminum Jack
- OTC Jackstands - Floorjacks
- FS: Really BIG Matco tool box
- Ratcheting wrench set
- What's your oldest tool?
- Better tool for porting TB???
- Snap-on wrench guide
- Anyone use the snap on valve spring compressor?
- Precision screwdirvers
- LS1 engine hoist/stand
- Floor Jack
- Balancer Install Tool 2001 F-Body LS-1 ?
- Tig Welder - Where To Buy?
- MORE Valvespring tool and JPR Cam Tool
- Big Tool box for sale
- anyone here run a natural gas heater in their home garage?
- Gearwrench vortex
- Duralast tools
- What's the best pocket knife?
- Tool Set options
- welding bench
- windsheild washer tester
- Parts Washer Fluid
- Any one here use a fluid vacuum?
- What's the smallest, thin ratchet you have found?
- Looking for a 220v tig welder
- Suggestions on new tools!?
- wanted spring tool
- Anybody use Crane's new valve spring tool yet?
- coveralls?
- Looking for individual plastic socket rails
- Shock top rod socket?
- big tool box
- J41480: just a straight edge?
- Does anybody have any Pittsburgh tools?
- Texas pawn shops - tools for sale!
- Epoxy Floor Coatings???
- tools (general)
- Best in-car valvespring compressor?
- Crank Holding Tool II
- Request
- Lift questions
- Those that use a lift, need some help with jack stands
- Welding stainless tip to iron exhaust pipe
- Too bad we can't get a tool salesman as a sponsor
- rent your flycutting tool?
- Reconditioned Hobart welder?
- Look what Santa brought
- How many... (lift)
- helms manual for 2000 M6 Z28?
- What is "flank drive?"
- Ryobi 10 inch drill press
- Heater for a 3 car garage..
- Large-sized socket set
- What tools did you get for Christmas
- Snap-on tool year guide
- Shipping an engine block
- Organizing sockets
- hand porting
- Lincoln MIG welder 5/16 @120V - Sears
- Clarke welders - OK or junk?
- Tools 4 Sale
- FS: OTC Genisys Scan Tool
- Suggestion on Mig welder.
- Ok guys hows this for a starter kit?
- tons of SNAP ON @ %50
- Ls1 crank holding tool
- I found the BEST three-jaw puller finally
- What does everyone think of this craftsman set?
- Just got some stuff
- special socket
- AutoXray scanner owners!
- Chiltons or haynes? (not for my fbody)
- Black chrome plated sockets and wrenches
- Body working tools
- Where to get a 1/2" drive 8mm socket?
- Torque Wrench Question
- Sears Coupons
- Shortage On Craftsman Hex Bit Sockets?
- My rant for the year: disgusted with Snap-On
- Great Deal on Craftsman Hydraulic Jack
- Huge allen wrenches - were are they sold?
