View Full Version : General LSX Automobile Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Is it possible to put a HP limiter on a 02 SS?
  2. BG Ram Air mod
  3. Coolant Overflow Tank
  4. wind/air defector
  5. Tail Light issues...
  6. bad clutch switch?!
  7. I have the WORST rattle, is my rear exploding?
  8. Are LSA ex. manifolds shorter than trucks?
  9. LS vs LM
  10. 07 LQ4 question
  11. 370ci or 383 stroker
  12. Rustproofing - Let's discuss..
  13. LY6 build
  14. is a 98 exhaust manifold compatible w/ an 02 manifold/exhaust system?
  15. need help on nitros kit 4 my ls1
  16. 02 3.8 converter to ls1
  17. Looking for head and cam advice..
  18. C5 or cammed 2006 GTO?
  19. Why did the LS2 have a short production life?
  20. HELP! Race in 12 hrs and car is running wierd
  21. building LS1 OR LS2
  22. Lq9
  23. Build #'s
  24. lq4 year
  25. ''lsx'' meaning question
  26. New Motor Problems!
  27. Sell 2 vehicles... Get one... Opinions
  28. Coil Cover?
  29. Rear facing car seat! seat delete? or hump?
  30. How Much Lower Does an LS7 sit?
  31. Aeroforce interceptor gauge owners...
  32. Pistons for a 454 stroker ls2
  33. rollbar and insurance ?
  34. squeezing out horsepower.. cheap?
  35. o2 sensor help
  36. Need your help guys!
  37. Trouble Getting in Gear
  38. Help me remember a parts website.
  39. Open headers?
  40. Step forward or walk away
  41. Question about inspection
  42. HELP!!!! anyone know what this black box is??
  43. 9 inch in a ta without traction control
  44. I thought I killed my T/A Tonight.. A Good Scare.
  45. anyone still buy used cats
  46. Might be buying my first LS1
  47. Double roller timing chain spacers
  48. LSx Swap, needing general engine suggestions
  49. Buying my first ss
  50. 6.0L Ls2 vss output testing?
  51. Fitting a hatch in a Camaro?
  52. Installed Magnaflow high flow cats lost power
  53. Help please
  54. ... I need a car lift.
  55. Made a real newb mistake....
  56. Buying a modified car. Q's?
  57. Is it possible to reduce 500lb for a daily use T/A ?
  58. Headers and Headaches
  59. Replacing connectors on wiring harness?
  60. Elevation- loss of power/need retuned? Help
  61. hurst short shifter
  62. Building Hot Rod Power Tour LS1
  63. corsa clone exhaust tips
  64. Installed 222/226 cam and ls6 intake ls6 did nothing for me
  65. What happened to my post????????
  66. Car alittle sluggish from a roll???
  67. Online parts catalog
  68. Need T/A Headlamp Rings
  69. So How torque are these? =)
  70. alternator Help
  71. anything is possible?
  72. Whats it like driving a cammed full bolt-on LS1?
  73. And off it goes!...
  74. Friends ls1 won't start. Any help?
  75. Thunder Racing
  76. Adding another LS car!!!
  77. Cooling Fan Always On - Any Suggestions
  78. Which to do first exhaust/cam or 12 bolt
  79. LS3 in a 4th gen
  80. O2 Sensor
  81. Viper GTS...theoretical proposition
  82. strange thumping when under power.. need help
  83. Glass packs vs Bullets
  84. Bezel around cig lighter size?
  85. MPG Question
  86. Anyone know how to tell what brand headers you have?
  87. Finally back in a trans am!
  88. Penzoil Plat. 5w or 10w-30
  89. General automotive: Why is the differential geared down?
  90. LQ4 oil fill relocation
  91. GERMAN Castrol VS. Penzoil Plat.
  92. Getting tuned on 2.73's and then swpaping gears. Will the car shift properly?
  93. C5 Keyless Entry loses programming
  94. pacesetter lt's and tsp ory pipe????;
  95. Help! My ls1 runs too cold.
  96. What part# for Denso o2's?
  97. computer/injector help please for sc5.3
  98. True duals with bullets on daily drivers?
  99. Throttle body question
  100. Where to get this molding and tips?
  101. porting throttlebottle
  102. 5.3 heads 228r cam
  103. 418 ls3
  104. How did you wire your wideband?
  105. installed new springs and shocks and my fronts are making an awful noise
  106. Tracking delivery of a new car.
  107. i installed lowering springs and my ass end is much lower than the front
  108. anyone ever use the crank pulley install tool off ebay?
  109. anybody have pacesetters not on their car yet?
  110. LS1 Gas mileage/temperature problem
  111. Custom Y pipe.
  112. Anybody making 500 rwhp with cats
  113. low power during acceleration
  114. Source for steering shaft u joints
  115. miss fire questions
  116. slp header collector leak... help!
  117. not sure where this goes!!
  118. LS3 fuel regulator?
  119. Gauge cluster and radio not working
  120. Did they make a convertible zo6 from 97-2003?
  121. catalytic converters and exhaust noise levels
  122. Bad cam bearings
  123. 08 silverado without tach!!!
  124. new to ls1
  125. Lokar throttle cable question
  126. pushrod rubbing my head.....help
  127. Fixing cracked door panels
  128. Reverse style water pump?
  129. LQ4 with cam package VS. LS2
  130. How long do you think my 10 bolt last?
  131. eBay parts!!!
  132. Backpressure issues?
  133. Had car down over winter, should I drain gas tank?
  134. Best power adder for a DD
  135. Rasp exhaust!!!!! ANY HELP
  136. should i use a 160 deg thermostat?
  137. 2007 LS2 Vette A6 or 2001 LS1 Camaro M6
  138. Dimension wise how do LS motors compare to other smallblocks?
  139. Intake swap. Dirt under intake
  140. Quick question on a grounding wire and oil pressure sensor
  141. need a dyno tune
  142. Why doesn't TSP offer free shipping?
  143. Low Oil Light On but Dipstick Level and Oil Pressure Fine???
  144. Where can i get these parts?
  145. Help, Lifting up car in the front.
  146. Is This Texas Speed? or Knock off?
  147. i want to sell my car ?
  148. Finally got the headers installed!
  149. Fuel rail inlet size? on factory LS3
  150. Sponsor sales on widebands?
  151. Need to clean alternator internals
  152. gauge problem in 2000 z28 HELP!
  153. Anybody used Champion radiators? Good or bad.
  154. feelings about the T56
  155. 6.0L cylinder head and intake question
  156. Stalling when slowing down + EGR error code (PO405)
  157. Bad gas mileage (o2 sensor?)
  158. sluggish launch
  159. Complete LS2 403 Stroker?
  160. Decisions decisions.
  161. Yes I know I shouldn't of went to Jiffy Lube, but I had a gift card....
  162. 98 LS1 with a MS4 running rich with Squeak coming out of the exhaust
  163. Dropping motor from bottom
  164. Windshield wiper arm busted?
  165. Sponsors please read.
  166. ideal exhaust size
  167. Might get a 1998 z/28 please help!!
  168. Head advice
  169. Would you dyno tune it?
  170. missfire pending
  171. 2002 Lq4 into a 2000 camaro
  172. The set up for the summer.. Just need a cam..
  173. Time spent on a heads/cam swap
  174. OK to Start Engine Flywheel Only?
  175. Spring is here!
  176. fast or 410s
  177. Downshifting to lowest gear quick reference table
  178. Can this block be repaired?
  179. If I were looking to go from a GEN-III ECM to a GEN-IV....
  180. Water pump outlet size?
  181. Spun bearing and thrown rod....
  182. 500 mile road trip
  183. 2001 Camaro side mirror removal
  184. If things weren't bad enough!!!
  185. Firewall grommets
  186. How to identify an L33
  187. Check this out...you could win a free lightweight battery!
  188. How rare?
  189. Keyless Remote part number needed thanks!!!
  190. 11.1 CR and N20 what plugs?
  191. A picture is worth....
  192. true duels best setup?
  193. Main Cap Bolts?
  194. Second hand LS1?
  195. Overhaul Kit
  196. need help...
  197. Dogs in a F-body...
  198. M6 vs. A4
  199. How does ASR work?
  200. I need a Roll Cage welder in Central Texas ???
  201. Tick Performance Master Cylinder Issue
  202. Advice on WS9 Hood
  203. homemade rams air system
  204. TSP got more of my money! :)
  205. 98 Z instrument cluster problems
  206. Trans Am door panels in a Camaro
  207. Has Anyone Ever "Wrapped" a Header to Attenuate Noise?
  208. Hood not flush
  209. exhaust help
  210. Chrs1313 Ram Air post PICS if you got em!
  211. Rear end question
  212. LS4 exhaust stock vs. aftermarket
  213. Is it just me or is my exhaust kinda quiet?
  214. need to vent
  215. LQ9 cylinder pictures good/bad ?
  216. Dropped my motor
  217. oil puddle surrounding rear rocker
  218. 97 vette
  219. Guy wants to trade me a 421 Camaro SS with 75 MM Turbo
  220. fiero
  221. SS spoiler?
  222. quick MAF questions
  223. X Wife Ride..... Stroker LS 404 ci
  224. Building a Budget
  225. car cutting out at wot
  226. Need help with heads cam stuff
  227. anyone know a O2 sensor part #?
  228. LS3 - Radiators
  229. Sad day for my Z
  230. Remove center tail piece on T/A?
  231. Would you guys ever swap out the LS1 ws6 TA front for an LT1 front?
  232. LS3 Purchase
  233. Water pump
  234. HELP! What would YOU do?!?
  235. Car wont Start.
  236. WS.6 heads cam questions
  237. How much should I expect to pay for used Ls1 and T65.?
  238. itching to pull the car out of winter storage
  239. Contemplating H/C/I/E on a 100k LS1 & Trans
  240. Help Weird engine noise
  241. 2002 avalanche LS2?
  242. what size pushrod do i need
  243. ...so is my fuel pump about to shit the bed?
  244. Ordered 222/226 EPS whith dual springs,pushrods,retainers
  245. Lifting engine onto engine stand
  246. Need help ASAP! Locked keys in the car.
  247. lQ4 need help!!!!!!
  248. Help Me Build My SS!
  249. LS1 Camaro/Firebird fan CFM's?
  250. new cam installed-there a relearn needed for the ecm?
