View Full Version : General LSX Automobile Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Somebody talk some sense into me....
  2. ls1 VS ls6 visual difference?
  3. SS or GTO
  4. first time running the 1/8th
  5. Heads
  6. iron block ls1
  7. Is there a way to bypass the BCM?
  8. Rare or not?
  9. 98 Trans Am
  10. best way back into fbody and being a 2nd vehicle
  11. ls1 camaro ls6 heads and cam
  12. 6.0L iron block
  13. Ok...which ones get the axe?
  14. No MAF?
  15. passanger window switch swap with door lock?
  16. My experience installing poly engine mounts
  17. Sell old parts back for core charge?
  18. No SES light after !AIR!.. why??
  19. 5.3
  20. Stall or gears?
  21. Assembly line pix?
  22. Should i trade my 00 Z28 for a Mustang GT??
  23. Check Out My New Car....
  24. advice on forging a cast 6.0L
  25. Stock Fuel Pump question?
  26. I need to get some keys made...Must I get raped by the dealership?
  27. Those with 180o Tstat, what temp does ur car really run at?
  28. My Facepalm moment!!! Due to my newbish mistake...
  29. what should i do??
  30. Carfax requests are not allow. A second request will result in a ban.
  31. T-Top shades
  32. hitting 11's passing california smog
  33. Pass side window needs to go up 1/8 to 1/4 inch higher .
  34. 1le question
  35. which truck should i buy?
  36. Next Mod?
  37. Ls1 stock what cam???
  38. Can someone please tell me what this is called and where i can find them?
  39. *Oil Pressure Sensor Relocation*
  40. LSI Block Casting #'s & Head # Identification
  41. I told you so!!! lol......good bye ls engines.
  42. More $ into my 98 or a 11 SS?
  43. Next mod?? Up to you guys!!
  44. More Mods!
  45. LS1 Pull & Install advice
  46. 450-400 rwhp daily driver?
  47. [NON LSX] - Broken E-Brake, how should I fix?
  48. Deer decided to give my ws6 a facelift
  49. 5.3 Fuel lines routing
  50. Issue with coolant temp gauge
  51. Largest Calif. Smog Legal Cam ??
  52. 2001 ws6 cooling fans inop
  53. 6.0 liter iron heads?
  54. Need help with supporting mod
  55. 4th Gen LS1 MPG's?
  56. need help i have a random misfire and i cant figure out why
  57. well I screwed up.... battery problems. electronics wont work
  58. Running an LS to about 7500 RPMs
  59. My experience with open Long tube headers on an ls1
  60. 98+ T/A headlight part question
  61. 427/454 LS Build Advice. New To LS World
  62. exhaust cut outs
  63. Wires under the air box
  64. Stripped Starter bolt threads...What to do??
  65. Okay seriously, where the hell is this coolant leak coming from?!
  66. The history of the ls1
  67. First night with the Z06... WOW!
  68. GM dealer screwed me over!
  69. LS1 are LQ4
  70. procharger vs h/c/fast
  71. Where can i pull 5volts from? for Sensor installation?
  72. SFC's, Body Mounted Tq. Arm's, & alignments racks don't mix
  73. What to get with my tax money?
  74. Oil filter and Tranny pan Magnets from filter MAG ?
  75. Is the LS1 market still strong?
  76. If you had a $120 gift card, what would you get?
  77. How does power loss occur in a low mileage ls1 engine.
  78. z06 / ls1 fbody
  79. fender bender, 2 VFN replacement hood questions
  80. Good times for my pretty much stock car?
  81. Firestarter (Maybe)
  82. street tires
  83. Roll Cage install...
  84. Anyone elses car lower when you put it in reverse?
  85. PCM/O2 sensors question
  86. HELP ASAP Fuel pump prime connector 99
  87. Programming The Right Key Fob
  88. Finally back on the road...next logical step?
  89. My newest LSX powered vehicle
  90. ls6 2.5 vs trick flow 225
  91. 2002 lt1 ???
  92. Weird problem, car barely idles after sitting a week
  93. Going to look at a motor... wat should i look for?
  94. Lq4 on a 94 z28
  95. Windshield Shade
  96. 161,000 and I'm seeing some issues
  97. pushrod length problem with new harland sharp rockers
  98. Test Drove a GTO for the first time
  99. Line Locks
  100. How to determine interior color of 2002 Camaro?
  101. specs for ls1
  102. Clear daytime running lights?
  103. i have an extra $2500 to spend what should i buy?
  104. opening hatch without power
  105. Engine Leaking coolant
  106. Exhaust ORY support bar to hold it up?
  107. Parts from Year One
  108. GM 243 CNC Stage II Heads or Patriot 243 Stage III
  109. Questions and Doubts
  110. storing an assembled short block??
  111. Need help please.
  112. cruise control
  113. What size is the stock C6Z intake ducting?
  114. Modified car insurance?
  115. Spun Rod Bearing, or something up top??? Video...
  116. Starting to get expensive again...
  117. How to get the bird off the rear filler panel?
  118. Questions on a possible WS6 Buy
  119. New Pro 5.0 shifter.
  120. Will a 02 Vet LS1 drop into a 98 Z28
  121. rpmspeed
  122. 5.3 LS with N20
  123. high mileage????
  124. Royal Purple ... Why do many dislike it?
  125. speedo problems!!!
  126. I dont know what to make of this
  127. whats the difference bet ls-2 6.0 & ls-26.0 marine
  128. Picking up a salvage LY6, quick question on damage??
  129. cheap budget upgrades??
  130. those that have upgraded to a 6.0l what did you spend?
  131. Upgrades and Plans
  132. 02 sensor's
  133. volant vs lid
  134. General help with mods.
  135. 2 good product reviews here
  136. Whats next for my car?
  137. which LSx car?
  138. Troubleshooting help needed- hot start problems
  139. do I have an lt1 style drive shaft
  140. how good are 5.3's
  141. Mice Damage!
  142. Is a lq4 from a 04 Yukon worth 1k? Anybody get a 6.0L just swap in a go or rebuild?
  143. SLP Options
  144. Tire seperation or a BLOWN motor??? lol
  145. Out of 15 LSX cars I think a motor is gone. Video inside
  146. Cleaning Air Conditioner
  147. Center Console Question
  148. Hail damage
  149. low octane engine build
  150. What the part number for the washer fluid thingies?
  151. Fluctuating RPM in Motion
  152. My lsx 454 is junk. Lsx454 lsx-454
  153. Turn signal question
  154. Issue with new motor build
  155. 5.3 ls Tahoe -02
  156. Just looking for some Tips/Help/Advice/Etc
  157. If you were to do it again...
  158. thermostat thought
  159. G8 GT or 05 CTS-V
  160. 4th Gen Memorabilia Question
  161. Car Model!!!!!!!!!!!!
  162. ....And the Idiots continue to create stories....LMFAO!!!
  163. LS6 vs LS3 ?
  164. Heat soak.
  165. ls6 swap is running
  166. everything in car is dead
  167. Anyone make a better than OEM A/C condenser?
  168. Maybe LS6 Intake?
  169. Excited for a new car!
  170. Burnout Methods?!
  171. Advice on an inexpensive oil cooler
  172. Stock alarm and horn beeps
  173. looking for a reputable engine builder
  174. 99 ls1 6 speed cruise control not working
  175. How many miles can a stock LS1 clutch take easy driving? Over 150k
  176. Whats the Difference?
  177. Do lsx crate engines have an engine #
  178. Need help!
  179. Adding gauges; wiring question
  180. fuel gauge and TCS issues
  181. CMS Head Rebuild
  182. ASA LS1 (Lingenfelter)
  183. motor swap help
  184. Throttle Stuck Open By Random Screw
  185. Lt VS LS1
  186. RPO Codes
  187. help
  188. Moving in ls1 forum soon
  189. Don't waste time with LM7 and go LQ?
  190. What do you think is the best LOOKING intake?
  191. do i need relocation brackets on the rear susp?
  192. Finally resolved EGR issues
  193. Wondering what to expect...
  194. Which Performance shop built this new Camaro?????
  195. General T-Top maintainence
  196. whats compatible with ls1?
  197. Header install, O2 qestions?
  198. Opinions on the 5.3l Trailblazer?
  199. high rpm problem?
  200. 853 heads
  201. o2 sensor question
  202. How do I know its a T/A from the vin?
  203. Looking into getting some heads/cam
  204. Sound right?
  205. New camaro Prices
  206. Need some advice
  207. What's the difference between these? (pics)
  208. Stupid MAF question.
  209. Why every car needs a PCV catch can
  210. my new ride
  211. Lost my t-top at 70.. (pics)
  212. EK DeCarbon shocks
  213. wot problem?
  214. who is Scott Settlemire
  215. Cam
  216. LS2 Throttle body question.
  217. Fbody or z06
  218. Need help locating a part
  219. Wheres a good place to get another engine?
  220. have a little gauge problem on my 98 ls1...
  221. Need Openions
  222. Factory cam prices
  223. Help
  224. Extending keyless entry?
  225. Wiring Questions
  226. Got a weird problem
  227. Power Steering Fluid Evaporating?
  228. My car keeps heating up after my volant intake??
  229. Torque specs
  230. Dynomax Bullet vs SLP Loudmouth
  231. What's the best way to clean your mass air flow sensor(MAF)?
  232. SOM SS on ebay
  233. LS1 Heads
  234. Stiff pedal with almost no brakes
  235. What is it you like about your 4th GEN? lol
  236. Sold Car- getting sued
  237. Rodney Dickman Review
  238. Need advice on complete build up. LS1 / LS2
  239. The LSx Fairy stopped to see me!! *pix* TSP ERL
  240. please help! little advice for an amateur. will this cam work?
  241. Sweet T/A Vert
  242. Check out all the T/A's at this junkyard
  243. Broken fitting on ls6 intake manifold. Best way to fix?
  244. Need Advice. Car Overheated
  245. 71chevelless ls1/sixspeed conversion
  246. need help with my 2001 trans am ws6 ram air
  247. Whining at ls1 intake.
  248. is this normal---pics inside
  249. T/A to Firebird exhaust
  250. What Magazine is this from?
