View Full Version : General LSX Automobile Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Best way to clean intake manifold?
  2. Need help with my 99 ta asap !!
  3. ls1 accessory brackets, help me please
  4. TSP True Duals? need opinions? Please
  5. Are these mods a mistake?
  6. Electrical/AC issue...PLEASE HELP.
  7. LS1 Firebird Tail Lights
  8. So ya. . . I was rearended. Pics inside!
  9. LS1 LS6 EGR Block off plate just installed LSX
  10. window motors
  11. Long tube exhaust headers
  12. Can't decided what to do.. Need input
  13. EGR/AIR Delete Question: Back Of Intake
  14. Lost power steering
  15. Girlfriend backed into my car!
  16. Finishing the car is on hold this year
  17. Inside the stock LS1 muffler
  18. idiot moment
  19. C/N questions
  20. Finally picked an oil/filter combo.
  21. 05 GTO LS2 Wiring Harness
  22. Need help from someone with a 4th gen camaro/firebird
  23. It's spring, what did you do to your F-body today?
  24. How often do you change your oil?
  25. New Engine for 99 WS6
  26. Cam Quest (software)
  27. New DS loop for TD's on my SS
  28. 2004 GTO ls1 motor
  29. 330,000 kilometer ls1...
  30. LQ9 = WHich LS
  31. BRAND-NEW FIREHAWK hood on eBay!!!
  32. Fuel consumption while coasting
  33. catback or stock exhaust w/ muffler delete??
  34. is there a difference???
  35. GTO or Camaro poll
  36. Please help
  37. What coolant are yall running?
  38. 00 ss with h/c/i 44k miles and oil smokes when Im down in it
  39. Oil
  40. Mph parts, legit company?
  41. ls3 valves how much can they take
  42. Fuel Pump?
  43. What oil are you running in your LS motor
  44. how many mpg do you guys usually get???
  45. Some LS1 Terms that i dont know about...
  46. engine jerking?
  47. whats so bad about 98' ls1 cars?
  48. switch for brake lights on/off
  49. From Magnaflow to TSP Rumbler
  50. Part throttle backfire and stumble HELP!
  51. buy parts or buy car?
  52. LS1's are better than LT1's
  53. ls1 and ls6 crankshaft question
  54. How do I turn off automatic headlights on a 99?
  55. GMVIS report
  56. is ls1 ausi made?
  57. UMI Subframe Installed At Competition GT
  58. buy a stock camaro or buy a roller and build
  59. Question on spoiler thread size?
  60. what is this?????
  61. What engine came in a ...
  62. Tranny Flush Question
  63. Kind of an odd question.
  64. Who has patriot extremes in stock.
  65. '10 Camaro running rough after storage, SES light
  66. Wrecked Camaro
  67. Probably a stupid question but...
  68. > > > Please help identify water jacket seal **pics inside**
  69. need info.....
  70. Headers
  71. Front Marker Lights/Camaro/Bulbs blowing/Burning sockets/Leaking/Is there a Fix?
  72. cheapest and fastest
  73. Where are all the torque specs?
  74. Would I benefit from an x-pipe????
  75. Wish I could afford this...
  76. L92 Gauging Interest
  77. Where to find STAGGERED Corsa clones??
  78. lsx swap
  79. Third Gen Camaro, Turbo or Big cube stroker?
  80. Finally bit the bullet
  81. Pump runs but no fuel???
  82. Is it normal for my Pacesetter ceramic coated LTs to rust like this? Already!?
  83. how will this exhaust combo sound?
  84. I'am fed up with my camaro! HELP!
  85. wideband info please??
  86. MSD wire not pulsing
  87. Why do rev limiters "bounce"?
  88. towing a car for the 1st time ---some questions
  89. New 2012 Camaro ZL1 Weight
  90. When Did Black Wheels Become A Fad?
  91. Terrible sound coming from passenger side rear end...
  92. seat belts
  93. V6 and V8 Fuel Pumps the Same?
  94. Higher mileage LS1 and Synthetic
  95. Wrecked my Ws6, need help and advice
  96. Rally a 4th gen F-body?
  97. Looking to move on...
  98. what did i break (pic included!)
  99. Help! just found out I bought a lemon, what can I do?
  100. cam spec opinion, turbo build, stock ls1 short block
  101. 5th Gen "F-Body"...
  102. need help 1998 trans am
  103. Gas Prices
  104. OEM Emissions Labels/Stickers
  105. 8.1l 496
  106. Help Me Find the HEader Install Writeup
  107. Ls parts interchange
  108. Lays over on the top
  109. Gmmg exhaust question
  110. WideBand
  111. The Salt Mod
  112. iron block lq4 6.0 weight
  113. cam only
  114. How long for springs to settle?
  115. Steering wheels
  116. How bad is the wind noise in 98-02 convertibles?
  117. How are these heads and cam?
  118. C5 project - heads/cam, etc.
  119. Need help fast!!! Broken bolt in head!
  120. Throttle body
  121. Gmmg question, help please
  122. Problems after dash removal
  123. Stick VS Auto, thoughts?
  124. Used motors...(sponsors come in too)
  125. Where is there a O-ring in the power steering pump set-up?
  126. Trans am to camaro... very happy, check out pics
  127. help with last min bolt ons :)
  128. Just swapped in a new oil pan, filter threads are different...
  129. Wife got a trans am!!
  130. 4th gen F-Body WITHOUT T-Tops..
  131. How would driveability be with this:
  132. rear-end question
  133. looks like oil in power steering fluid and I don't have a power steering cooler
  134. just bought a cam need help
  135. door locks and interior lights problem please help!
  136. "Trim Design" sticker on my SS door jam
  137. My "tune" knob came off
  138. Ebay Headers...Need help with banging around after install
  139. catch can
  140. Madman Fuel and Intercooler Water Tank Combo
  141. How do I get this sensor out??
  142. Catch Can
  143. 5.3 to 6.0 swap in 2000 c1500
  144. Security system problem. Help!
  145. black zr1's or polished aluminum?
  146. my 2002 SS build is alive with sample video
  147. is this aftermarket?
  148. AC removal question
  149. Power steering pump. order with the reservoir or without?
  150. Blackwing lid!!
  151. Help windage tray
  152. 408 LQ4 stroker going in...which tranny?
  153. 2000 Trans Am Rear End Swaying at WOT
  154. ecu question
  155. Im thinking about a tbss...
  156. What gas mileage do you get with your 4.10 M6 car?
  157. Pushrod Question!
  158. USA to UK shipping
  159. did the 00 camaro have an obd II port
  160. Dana s60
  161. Looking at buying this Firehawk, need help!
  162. Anyone a member on YellowBullet?
  163. New motor... need help
  164. trans am vs ws6
  165. 95 Trans am LQ9/LS3 build thread..
  166. LSX Specs & Results
  167. Help goal of 6.8-6.9's in 1/8th
  168. Best oil for a stock ls3 in a offroad race car
  169. 241 heads on a 5.3L
  170. ehhh.... I hate to do this but... Shipping weight of a Iron short block...
  171. VMR VB3 Wheels test fitting, what size tires to run?
  172. Who is a car lighting sponsor anymore?
  173. Radio and Windows are cutting out
  174. Flowmaster Mufflers new contest - "Show us your flows"
  175. Help me decide: springs/shocks or 9" rear....
  176. 80MM TB to LS6 IM & IAC valve/TPS questions
  177. Freakin Static Shock
  178. fake Z06 converibles : how do you feel?
  179. Need help!!!! Pic request
  180. car will not start
  181. car running like crap after it died
  182. t-56 shifting problems(reverse)
  183. people
  184. Wiring Harness Swap Help
  185. Why are goat prices still high?
  186. Swapping ls1 for lt1 Question
  187. nostalgia
  188. misfires on cyl. 1 and 6
  189. help! my broken lsx 454. cylinder wall blows out. any suggestions?
  190. Where to buy firebird license plate cover?
  191. stock 1999 trans am seat dimensions
  192. 2010 Chevy Suburban CEL Scan says no data
  193. 178k miles. would you buy it?
  194. Magazines; which ones to you subscribe to?
  195. Help with title! >:O
  196. Help decide what to buy w/ tax $
  197. any one here using lucas gear oil ?
  198. C6 Corvette Wheels On 02 Trans Am
  199. opinion
  200. Interior Color by VIN
  201. Trans cooler = PS cooler?
  202. LS1/T56 car with 110k miles....concerns?
  203. Woo hoo! Headers!! :)
  204. LS3 Swap completed
  205. 418ci head choice ??s
  206. The new ZR1 is on Test Drive
  207. Cam Swap 2002 Camaro
  208. front suspension
  209. Water Pump Length
  210. What year is this LS1 motor from ?
  211. ideas for next upgrade
  212. Most hp on Stock Maniolds?
  213. whats the best cam for my car?
  214. humty dumpty dance in camaro; possible?
  215. i'm blocked from classifides.. wtf
  216. ls6 swap
  217. Will all 98-02 Camaro SS's be collectors in the future??
  218. 01 ls1 engine rebuild, suggestions?
  219. need help with cut harness
  220. Boost Gauges
  221. BUILD: 1999 TransAm Heads, Cam, Full Bolt-on's (LOTS OF PICS)
  222. LS6 cam questions
  223. LQ9 accessories on an LS3?
  224. Shocks & springs for a 2002 WS6
  225. eBay VC's...... Any decent??
  226. Heads for my new 5.3 conversion??
  227. Anyone else love driving when its cold out?
  228. Check out this nasty F350 for sale!!!
  229. NHRA LS1 Stocker
  230. 10 spoke ss wheels
  231. Here's a nice collector
  232. coolant looks weird - anyone know why?
  233. Idea that has been floating around my head....
  234. TAX RETURNS!!! What are you all buying?
  235. So what was your first Fbody wheelie like?
  236. Semi-budget motor
  237. You all are a bad influence!
  238. What do you think the best LS performance bargain is?
  239. Nuts and Bolts of OBD II
  240. Would you blatantly call someone out on a clone WS6/SS?
  241. Thinking about buying this LS1
  242. do lq4/9 408 strokers need different oil pans
  243. No carfax requests on this site!
  244. Lsx bare block weight
  245. Sometimes it's better if the cops DON'T find your stolen car...
  246. Help with my next car
  247. What to do... Rebuild ls1or build lq4/9
  248. i need help with traction control
  249. Cams!!!
  250. stroker kits...
