View Full Version : Automatic Transmission
  1. Wtb 4l60e tranny
  2. Transmission Troubles
  3. 4l60e 1-2 shift issue
  4. 4l60e removal
  5. 4l80e convertor
  6. 4l80e questions
  7. Hurst quarter stick install.. Any advice?
  8. Where to buy a built 6l80?
  9. 4l60/700r4
  10. Help with reconnecting trans lines 4l60
  11. TH400 Swap.....What yr TH400???
  12. Help needed.
  13. No gears help..
  14. Converter
  15. Problem with new rebuild and Circle D Converter
  16. Trans / TCC or Other Issue?
  17. RPM Transmission
  18. just installed a vig 3600 converter
  19. TH400 rebuild
  20. B&M transmission any advice?
  21. Torque converter visual inspection???
  22. Untuned with a converter question
  23. Help Please Needed!!! Would this be a Bad VSS????
  24. what stall should i go with
  25. TH350 Sale
  26. vig 3200 installed now car heavy?
  27. selling a transmission, need some info
  28. Need help on torque converter
  29. Technical Question
  30. performabuilt or rpm??
  31. 6L80E trans what shifter?
  32. Not shifting into Overdrive could that happen due to bad tunning??
  33. Tips on keeping TH350 alive behind high HP turbo motor?
  34. m.v.b 4l80e
  35. 6l80 convertors.. same from 2010 to 2012
  36. Bouncing off rev limiter at 6700-6800 rpms
  37. Those with A4 on stock stall/tune come inside
  38. WTF.....manually downshift to 3rd and 2nd and no change in rpm's
  39. a4 to m6 question!!
  40. Like RPM Transmissions on Facebook!
  41. buying a transmission
  42. MWC 80e xmember to bmr tq arm
  43. 80e yoke questions
  44. What Yoke for 4l80E in Nova?
  45. Sun Shells - Stock 2001, The Beast, Sonnax Smart Shell
  46. use for a old stock converter?
  47. Is it the converter?
  48. Where to buy MWC 80e crossmember?
  49. 4x4 6L80/90 to 4x2 6L80/90
  50. Had my 2000 camaro ss hp tuned yesturday and know it wont shift into 3rd gear
  51. why stall ??
  52. 4l80e rear speed sensor signal needed to build DIY cable-x.
  53. 4l60e no first or overdrive!!!
  54. Anyone have a custom Yank converter around 4800?
  55. TC Locup question!
  56. LS1 th350 flexplate question
  57. feels like no first gear please help.
  58. 4l60????
  59. 4L80E Rebuild Question
  60. Tail housing length?
  61. LS1 to 727 Torqueflite??? Help Please
  62. Installing tranny cooler
  63. 4L60E shift kit and no first gear
  64. trans build parts list, good?
  65. Who here is running or has ran a PTC converter
  66. Turbo 400 Trans Cooler Install Questions
  67. What cooler ; M6 C5 vette swapped to 4L60e 3800stall non lock up
  68. Billet 4L80E overdrive planetary carrier.
  69. Will a th400 fit 01ss
  70. Avg temp with stall
  71. dumb trans cooler question....
  72. TH400 and TH350 Converters
  73. yank converter
  74. Stock Trans Cooler HELP
  75. Quick console ?
  76. m6 to a4 help and stall suggestion
  77. stall converter
  78. Trans vibe solved, but still have a question
  79. Whats needed to put camaro 4l60e into vette?
  80. Ace Racing Transmission
  81. Modified T56 crossmember for 80e install?
  82. aftermarket shifter for 4l60 that fits ta console?
  83. 4l60e whith vacuum valvebody, how to hooke it up...
  84. What do I need! 4l80e
  85. Trans Cooler Question
  86. Jake?
  87. Variable Pitch Stator
  88. Stand alone TCM or use stock harness?
  89. Cheat Sheet for TH400 Drive Gears?
  90. Gear noise in trans
  91. Rebuilt 4L60E,What Went Wrong?
  92. Favorite Turbo 400 Shifter
  93. Where to buy shift cable bracket
  94. 4l60e auto
  95. do i need a new tune after a new 4000 stall?
  96. 60e. Help me :(
  97. another 4l60e problem please help. wierd problem
  98. Beast or stock sun shell?
  99. 3-4 Clutch - Is New Raybestos GPZ100 better than Z-Pak?
  100. No reverse
  101. Getting Built Tranny, which brand converter? Thinking about REVMAX??
  102. 4l60e out of a TA fit right up to 04 GTO?
  103. Best Transmission Cooler for 4l60e? please chime in
  104. Cooler line to trans fitting help. 80E
  105. 4l60e help?
  106. turbo 350 worth?
  107. Glass bead blasted my trans case - now what?
  108. 93-97 auto vs 98-02 auto
  109. 4l80e help never mess with automatic's
  110. stock converter facts
  111. FTI 2800 SRLS3082 feels loose
  112. 4L60E Help Asap Please
  113. 4L60E shifter
  114. why change the stall converter??
  115. jakes pro transbrake install help
  116. lt1 m6 cross member for th350 swap?
  117. Rubber seal on rear of 4l80e
  118. Found chunk of metal in 4L60E Pan
  119. 4l65e race transmission
  120. What Trans with Lq4 S480 Turbo
  121. 4L80E SFI bellhousings and conversions
  122. ACE Racing T-56 to 80E swap pics
  123. Ever wonder what goes into an ACE Racing 4l60E?
  124. 02 chevy truck wont come out of 1st
  125. putting in stall,vig,3600
  126. 4L60E Trans Issue (Won't shift out of First)
  127. What are the best 4l60e rebuild kits?
  128. 4l60e no gear at wot?? Other issue too..
  129. Need Some Stall & Trans Rebuild Adive!
  130. 99 Firebird *Identify this Button*
  131. Affordable 4L60E Output Shaft??
  132. TH400 Tailshaft Length??
  133. finish line transmissions??
  134. In the market for a new trans, looking for advice.
  135. URGENT question low fluid?
  136. SY3500 vs SS3600 opinions
  137. 71 Chevelle LS3/4L65E noise issue
  138. 4L80E Questions
  139. 4L80 Help.
  140. Where to install transbrake button?
  141. Reverse issue after new transmission install
  142. 4L60e corvette servo?
  143. Need Help 350T spraying fluid....
  144. Re-tune for higher stall converter?
  145. Advice on Transmission
  146. 4l60e Driveshaft Siezed onto trans output shaft.. need ideas
  147. Huron Speed Torque Converters!
  148. th400, pro ratchet, cable seem to be in a slight bind
  149. car dragging, shift solenoid b stuck, new tranny and stall
  150. Trans Fluid Recommendation
  151. Ptc 4l60e 3200 stall thoughts and computer tuning?
  152. Need help verifying a torque converter issue
  153. Line pressure question.
  154. 4l80e shift kit
  155. Lq4 & th350 bolt up
  156. Lq4 & th350 bolt up
  157. 4l60e Power holding in a lighter car?
  158. TH400 Trans Brake
  159. 4L60e vibration
  160. 700r4 build
  161. Any tips on flushing trans cooler?
  162. 4L60 disassembly help needed
  163. any good driving videos of th400?
  164. Question about differences between ls1 4l60e and 3.8L v6 4l60e?
  165. 4l80e 750hp
  166. A4 TCC lock up issue?????
  167. TH350 Build
  168. Which drive an speedo gears do I need????
  169. 98 Z28 Tranmission Clink when shifting from R to P
  170. cooler line part number
  171. How does the stator effect stall, str, tightness, and efficiency?
  172. Line pressure question.
  173. how much "spline" is there on a 4L80E output shaft?
  174. Combo Setup
  175. 4l80e shifting, man. vs elect.
  176. Need 4L60E tools # Where can i get them?
  177. video of transmission slip
  178. Cam/Stall Match Opinion
  179. Budget transmission that will hold power?
  180. InstallUniversity TH400 conversion from M6: Follow along
  181. stock trans with tc.slipping 1st 3rd or OD
  182. F body 4l60e in a C5?
  183. Best warranty
  184. Well its TAX time
  185. Source for rebuilt 3.8 4L60E?
  186. 4l60e transmission slipping at wide open throttle
  187. Clunk when the car downshifts to 1st
  188. Trans-Go hd2.....Yes or No
  189. 4l60e new trans vibration in 3rd only.
  190. Manual control for 4L80E
  191. Switching from a 60E to new 6 speed auto
  192. Turbo 350 question
  193. 02 LQ4 and 98 4l80e What Do I Need?
  194. Flex plate quetion
  195. Effect on Dyno
  196. Broke an Alto Kevlar Wide Band, wth?
  197. End play on a 4L60E
  198. snap ring came loose in reverse input drum on 4l60e. builders please look
  199. LT1 shift button
  200. Am I the only one who has bad luck with trans?
  201. New TH400 Automatic Shift Transbrake
  202. 97 m6 to 01 ls1 4l60e ???
  203. New TH400 Auto Shift Transbrakes
  204. Best 4L80e swap xmember out ther MWC!!
  205. 4L80e housings, PLEASE help
  206. Low voltage causes trans to not shift?
  207. Here's an interesting idea. Variable stall.
  208. Does anyone have a torque converter lying around???
  209. Thanks to FLT!!!
  210. Avalanche 4L60e into 96 Trans Am?
  211. 4l60e heavy duty monster transmission
  212. Slippage
  213. Cheapest way to get speedo reading from th400
  214. Opinions of shift kits?
  215. 4l60e home rebuild with hd-3 and mod 46
  216. m6->a4, wont shift out of 1st
  217. What size tranny lines?
  218. In need of a converter!!!
  219. Just orderd a PerformaBuilt Trans
  220. Anyone did flappy paddles in a fbody?
  221. Where to buy 4L80E pump to case bolts?
  222. 4l80e No Od
  223. 2001 lq4 to 4l80e flexplate?
  224. Brake on a stock 4l80e
  225. 4l80e transmission mount
  226. T56 swap to 4L60E
  227. REVMAX 3600 stall video
  228. And my 4L80E swap begins
  229. Check Ball Seats
  230. WTB: Torque Converter
  231. Converter efficiency from a roll?
  232. TH400 VSS Pigtail
  233. 4L70E if anyone is interested.
  234. th400 dd questions
  235. How do I replace reverse servo piston? Cant find anywhere!
  236. Problem with the converter being to tight in the crankshaft.
  237. Tell me how this happens....4L60E...**UPDATE** for those interested
  238. Soft shifting 4L80E
  239. 4l60 E yoke interchangeablity
  240. Getting the Transmission rebuilt
  241. Jake's Performance Tax Time Special
  242. WS6 Auto Trans!!!!!
  243. YANK'S Tax Refund sale.
  244. Manual Shifting 4l60e
  245. GTO with a4. want to change filter/fluid and have questions!
  246. 4l60e to 4l80e swap complete, now no reverse! Googled it and I need help desperately!
  247. 4l60E no Reverse, 2nd, or Overdrive???
  248. 150 shot with 4000 stall users..
  249. G8, 6l80, 150 shot. What stall?
  250. Built Tranny Problems
