- trans mods???
- Need a OEM Transmission Mount
- Heeelllllppp Transgo install problem?
- Want to trade
- wanting a stall....
- need advice on trans problen
- whats going on??
- vacuum modulator vs no vacuum modulator
- trans fluid question
- Th200r4
- Soft 1-2 need advice
- different transgo shift kits?
- FS: Ac Delco 3-4 shift selenoid for 4l60e
- Tci 3600
- can i rebuild?
- 2002 Z28, bouncing off rev limiter.
- Is this a sign of time for a rebuild?
- TH400 as adaily driver, advise?
- Schaffer shift control for a-4
- Trans tuner
- Trans go shift kit
- Bolts for TCI SSF3500
- 4l60e housing
- Banging noise
- most desirable 4L60e
- 4L60E Foward clutch pack
- Was a TCI ssf 3500 a good choice?
- 1-2 shift problems
- Paging Dave@Rock-On......
- 80e strength
- Tranny cooler question
- Help w/ md 3600
- Midwest Stall and spray
- HELP!!!Tranny dipstick...
- Need help picking a trans
- Transgo Install Question
- Everyone with the TCI SSF3500, question?
- HELP(asap), Fuddle TC installed = problems
- Finally got the 80e in my formula
- A4 shift problem, please help.
- crashed 94 tranny
- Is a Predator programer enough to tune a Converter?
- NEW Dexron - VI
- help.....how many quarts does a 4l80e hold?
- Help Me Pic An Str Ratio.
- throttle sensor
- Bigger stall in a stock 4L60E?
- what stall converter to go with MTI G1 ?which stall is the righ 1 ?
- RPM Questions from a newbie
- changing converter
- YANK'S crossmember with t/a mount 350/PG
- Installed Vig 2800 and "check engine oil level" light came on.
- vig3200 or vig3600 for TNT150 shot?
- Changing Shifter Handle
- 700r4 in my '98 Z28
- Is this normal?
- torque converter question?
- Low/Reverse clutch stack 700R4
- Problem launching after TC install.
- more HP to turn a 4l65e than a 4l60e ??
- tranny woes
- midwest converter
- Just got a built tranny now ????
- Plastic Accumulator
- Automatic Transmission Lost First Gear - Help!!!
- Trans Temp Discrepencies
- 4l60e question:
- deep pan? or not to deep pan?
- O Ring MAdness
- Stall - Torque Ratio
- Trans Oil Cooling Line Connections
- TCI SSF 3500 question
- T350 tailshaft/driveshaft questions
- who makes powerglides for a ls1
- I think my "bullit proof" 4L80e is hurt
- vigilante bolt length PLEASE
- Tranny Cooler
- Locking Up The Converter?
- Help finding a shifter for 1998 TA
- Stage 3 4L60E
- Rattling Noise Coming From Converter
- Need help w/ selecting a stall and brand
- TCI Converter Issues
- I Need A True No Nonsense Answer!!!!
- converter accessories 5 basic questions!!!
- Anyone drop in a Fuddle Racing TC yet?
- Future Looks
- 2800 B&M Stall
- Stock Flexplate
- Wiring for a TH400/TH350 swap...
- Str vs stall please explain.
- Need TH350 Help!
- Where can I find a th400
- Any LUCK with HUGHES 60E
- Pro Stick VS. Pro Ratchet shifters?
- Converters
- What exactly does a stall do?
- 4L80E Questions...
- My M6 to TH350 swap with pics
- Stall Rating?
- 4L60E 3-4 clutch pack
- LS1/Powerglide. What must I do????
- th350 swap problems
- PY4000E for f14 cam and nitrous? or smaller
- One last question before I buy the TC
- TCI new 4l60e
- Will a 2000 LS1 4l60E go in a 98 v6 camaro?
- When Removing Center Console?
- TransGO shift kit install.. Initial impressions.
- B&M MEGASHIFTER WITH TUBRO400
- Transmission Cooler decision
- tranny ?'s
- Shift Kit in a 700-R4
- Is 3000 the right stall?
- Best TC to buy.
- vigilante tc ??
- Recommended mods for a 4L60E?
- stall quote
- flywheel/flexplate bolts. torque specs, help!
- servos only instead of shift kit???
- lost 2nd gear for 2nd time
- Help!!! My tranny (A4) rolls off when in Park! Drives in Neutral!
- Where should I look on the tranny for the "Pump Stator"?
- Is this EXACTLY what will prolong tranny life?
- I have no 1st or 2nd gear!!!!
- Gear recommendations
- pics of 6L80E
- Anyone tried Red Line ATF
- wiring diagram for a 4L60E
- Think I solved the misterious TC unlock problem(long)
- stall \ str suggestions
- converter lockup
- Do i need a tranny?
- 2nd to 3rd RPM flare
- 4L60E question
- TH 350 Guys look here
- SS3800 or SS3600 for a f14 cam
- fluid flush and change.
- Vig 4400 stall
- Best launch technique for YPT4400 and 4.10's
- What times for a full bolt on car minus TC
- quarter stick for a 4l60e
- Plug in Trans shift improver
- what about the ValveBody !!
- They said it couldnt be done Megashifter
- 3-4 shift hits the rev limiter unless I let up a bit, prob with tune or shift kit??
- Tubro 400 dipstick
- Where to get 4L80
- CRAZY CRAZY 4L60E question for you..........
- do not use this trans shop
- Can the shaking of the motor cause problems with the tranny?
- Help changed tranny and getting alot of trouble codes
- Torque Converter?
- 1-2 shift gets worse after tune
- TRADE my A4 for your T56, i need T56
- Another shift slipping question - no search answers:(
- Synthetic ATF?
- Questions about Yank ST3500
- 3-4 clutch pack
- I need help
- Anyone have a cheap source for the transgo 4L60E vacuum modulator??
- No lockup, what does this hurt?
- unsure of stall size.
- yank TT3000 3.0str..thoughts? pls...
- Slipping during shift...
- Seating the torque converter?
- How bad is this?
- a4 newbie questions
- WTF is going on
- Ultrabell.... tranny bolts?
- doing a th400 conversion, what should I expect
- pics/instructions for sonnax valve conversion
- Need Help Asap !!
- Transmission Fluid ?
- Strongest 4L60E
- Where to get billet servos
- Transmission Problem
- help me find the leak in my tranny
- Transgo shift kit instructional video question
- Fuddle.. Whats The Verdict????
- How good are Tci converters?
- How much abuse can a stock A4 take?
- Two questions...
- how much $ to transfer to th400
- How long of plate needed?
- I searched lots, but still have several TH400 questions (auto valve body?)
- stall question
- Fuddle Racing TC
- 3.42 shift points HPPIII, what are your settings?
- Trans / ABS problem
- is this a decent setup?
- Is a 4400 stall to big
- Shift solenoid questions?
- Need input on 4l60e that can handle 650 rwhp
- Fuel economy with a stall
- newbie question on stalls
- 4L60E Question
- Tranny Cooler Install Help
- dealerships, bullshit, etc
- Is a 3500+stall and 373s a good combo?
- 3400 Yank and stock flexplate
- Midwest Racing Converters...
- ive got a problem
- 700R4 Planetaries?
- 1-2 shift problem???
- Looking for TH-400 advice from builders
- Stall or gears?
- V8 torque converter on V6?
- has anyone had any track time with a fuddle converter?
- 3rd gear or Drive?
- Is D more powerul than OD?
- 1st to 4th?
- shifting from 2nd to 3rd while racing IS SLOW
- Jasper Transmissions
- 4L60E vs 4L80E
- TH400 drive shaft length?
- Who here runs a PTC converter
- shift points
- Trans SLip.. or electrical?
- i need help!!! converter problems
- 4l60e doesnt shift right need help wtf?
- LT1 4L60E in 98 Trans Am?
- Tci Ssf 3000
- Converter tuning-yes or no?
- Shift kit(s) questions
- 1st or not
- How long untill my tranny goes BOOM?
- Yes! It's here!!
- TH400 vs. TH350 converters.....
- Flexplate differences?
- Tci Software ..some One Please!
- Tranny making funny noises.... please help!
- What 4L60e Convertor for 9sec Turbo Setup?
- WOT Shift Issue
- cheap 4l60e????
- Which rear end gears for TH400
- what is m6 and a4
- could this be my converter ???
- tci 3500 or 3000 (repost)
- Yank SS4000
- New Converter or tranny went broken?
- ET/MPH Gain going from Vig 2800 to Yank SS4000
- Converter or transmission problem?
- how to make 4l60e full manual shifted
- Anyone Experience this with their 4l60e?
- 400 turbo in f body???
- started as flare 2-3 WOT, now won't go at all
- ? on my Fluid
- opinions on yank tt300 and pi2800
- TCI stalled guys please enter
