View Full Version : Automatic Transmission
  1. what is m6 and a4
  2. could this be my converter ???
  3. tci 3500 or 3000 (repost)
  4. Yank SS4000
  5. New Converter or tranny went broken?
  6. ET/MPH Gain going from Vig 2800 to Yank SS4000
  7. Converter or transmission problem?
  8. how to make 4l60e full manual shifted
  9. Anyone Experience this with their 4l60e?
  10. 400 turbo in f body???
  11. started as flare 2-3 WOT, now won't go at all
  12. ? on my Fluid
  13. opinions on yank tt300 and pi2800
  14. TCI stalled guys please enter
  15. fuddle converters.. whats the word?
  16. cooler line fitting Size????
  17. 04 Silverado tranny problems
  18. Why do i ALWAYS bounce off the revlimiter.
  19. What's the deal with the Fuddle "stock style" converters?
  20. shift silenoid stuck open
  21. Is this a bad converter from Yank?
  22. What to do?
  23. guys, ive tried everything, im at my breaking point with this car, please help
  24. Q about tranny
  25. Bouncing off of the rev limiter..help
  26. mph drops bad after first pass at the track? normal?
  27. Vig rebuild how long?
  28. help: loud vibrating noise when in gear
  29. can you still use the transgo washers with the Pinless Accumulator Pistons???
  30. Torque converter bolt size for a TCI converter?
  31. Trans Help! 4L60E!
  32. trying to find flexplate and converter for th400
  33. Just drove the TCI3000!!!!!
  34. Which shifter for t-400?
  35. how much trans fluid do you need to put into a new converter?
  36. 4L60E issues...
  37. Help: 99 t.a. trans
  38. Need info TCI 3000 in a GTO.....
  39. Neutral Safety/ Backup Lights
  40. Which auto for boosted application?
  41. will any th400 converter work or do i need one specific for a4-th400 conversion?
  42. slippin clutch only in reverse ?
  43. Built 4L60E?
  44. idle problems
  45. reprogramming???
  46. th350 and 12 bolt drive shaft lenght?
  47. 1-2 Clutch Pack
  48. Difference in strength between TH350 and TH350C Lockup converter
  49. 4L80E with trans brake?
  50. Having a problem with the Hurst tranny swap kit>>
  51. TCI Rebuild kit
  52. 700r4 transmission
  53. ? about my th350 stall bolting up.
  54. GM six-speed automatic transmission
  55. Th350 in and running
  56. 2002 Gmc Sierra Transmission Question
  57. Roll racing in a SS4000.....
  58. Tuning for 3600 stall?
  59. What Stall For My Setup???
  60. 4L60E - Cold shifting question
  61. BIG PROBLEM from france
  62. Stall install
  63. Torque Converter Question
  64. A4 tranny strongest cheapest
  65. Yank SC3000 going in tomorrow 4/14 HELP!!!
  66. lokking for a 200-r4
  67. same converter different power levels
  68. how much power is too much for a stock a4?
  69. Just ordered my SS4000!
  70. What all is needed for T350 swap?
  71. Guys that run a stall bigger than 4400, come inside!
  72. 4L60E No Overdrive
  73. Rubbing noise???? Help!
  74. cant do a burnout???!!!
  75. how soon do i need a tune after installing a 3500 TCI
  76. Where to lock up YankPT4000
  77. GM media PICs of the 2006 6L80E
  78. help fast please!!!!!!!!!!!!!1
  79. Valvebody Working Right? Help
  80. dipstick tube.......
  81. at what point do the 4l60s have problems?
  82. 4l65e
  83. Stall STR and High End Effeciency.
  84. ?????????????
  85. Who builds a strong 4L60E?
  86. Auto not shifting right.......
  87. What RPM does your A4 shift at during WOT?
  88. converter help
  89. aftermarket transmission pan
  90. Who builds the best auto
  91. who is ed wright??
  92. hurst quarter stick console mount? th350
  93. What's This Noise?: Loud ticking after converter install (long)
  94. PermaCool Dual Cooler with fan? TRANS AM 1996 - trans. & engine cooling - NEED HELP!
  95. Biggest Stall? (Daily Driver)
  96. MY TCI 3000 stall review
  97. Need help installing my trans cooler on my 98 TA
  98. i have mods what tranny do i need to get?
  99. Why does the center console/shifter area jerk up whenever my car makes the 2-3 shift?
  100. M6 to A3(th400) What speed sensor do I need?
  101. all th400 people inside:need help
  102. torque converter install
  103. automatic th400?
  104. Red Alto
  105. Poly Trans Mount good idea?
  106. Which rebuild kit
  107. Quick Question
  108. Vig. Multi-Disc.
  109. Downshifting TH400
  110. Hard shift from 1-2
  111. Help.....NO OD??!!
  112. ssf3500 less pull more punch
  113. what trans fluid
  114. th 400 installed price?
  115. 4L60E SES Code
  116. TH-400 slipping
  117. TH-400 or TH-300 w/ Current Set-up
  118. Do I need a deep tranny pan?
  119. will this tranny hold?
  120. It's BACK the "SUPER YANK 3500"
  121. 2 to 3 shift problem
  122. lockup solenoid question
  123. torque arm mount for 4l60-e
  124. 94 to 95+ A4 swap
  125. converter stalling at idle?
  126. how do you figure top speed in a stalled TH350?
  127. f-body 4l60e?
  128. 4l60e to 350 wiring issues help
  129. Torque arm options with t-400?
  130. Need Tranny Temp Options...
  131. Please Help, PRNDL switch question
  132. Re tune needed when going to a higher stall
  133. Will a 700r4 work with an LS1 if I use a LS1 torque converter
  134. another lock up problem
  135. STR--- what to get..
  136. Car wants to shift......but just kina sputters?
  137. top speed of th400
  138. vigi 3500?
  139. YANK's NEW PRODUCT LS/1 400 transmission
  140. lockup in 3rd + nitrous?
  141. What sort of stall to get?
  142. TCI Trans-Scat and other shift kit questions
  143. Flexplate advice?
  144. th350 aftermarket valvebodies???
  145. Tcissf
  146. 4l60e question
  147. ssf 4200 installed; few q's
  148. shifts high
  149. 4L60E won't upshift in drive at WOT
  150. 2000 Bird with 8k miles...change tranny fluid?
  151. trans and 1st gear?
  152. 228/230 + 373 Gears = What Stall Speed?
  153. Getting a converter in a couple of months...tranny fluid quesiton?
  154. Having my TCI SSF3500 installed tomorrow...
  155. TH400 - 1st gear hard to shift into 2nd after putting car in Park
  156. th350 driveshaft
  157. ls1, th400, and ford 9"
  158. TCI 4000 won't lock up??
  159. Trans rebuilders inside...
  160. Reverse in a TH400 - use t-brake???
  161. Do I need an A4 harness or can I re-wire my M6?
  162. what RPM to stall to>?
  163. Trans Brake guys...
  164. Quick question that you may not have thought of....
  165. problems with converter.
  166. no 3nd gear no lockup
  167. VDO Vehicle speed sensor for TH350-400
  168. custom driveshaft
  169. Th350?
  170. lost top end?
  171. TH400 to a 460LE
  172. Need Help Fast
  173. Rebuild or New
  174. transgo shift kit
  175. Performance & racing question
  176. drivability with a converter
  177. Thanks Dave@Yank, leaky Y3000 pics inside...
  178. which tranny should i chose???
  179. turbo 400
  180. Where to from here, I'm still doing research now...
  181. Problems with my TH400 PLEASE HELP
  182. NEW GM FLUID for 2006 Good news
  183. If the fluid in the tranny looks a little clear now...
  184. Flexplate, TCI or ATI?
  185. Another TH350 or TH400 thread
  186. Availability of 4L80's in northern ca
  187. 4L60E Help....
  188. 350 turbo output shaft
  189. 1998 Ta 4l60e
  190. Installed stall converter, now leaking?
  191. "Street Only" 4L60e Questions
  192. trans mount?
  193. overdrive
  194. Flexplate nicks back of engine at start up????
  195. steel pan vs aluminum pan
  196. 4L80e/TransGo Shift Kit/Line Pressure
  197. Trans wont reverse
  198. 3-1 downshift damage
  199. need 2nd opinion on vig converter
  200. Time for a new tranny...tell me what to get
  201. Any Bullet Proof 4 speed?
  202. speedometer recalibration
  203. is it possible to deleted 2nd gear through programming??
  204. cut a lil into driveshaft !
  205. What's the highest stall you'd go with bolt ons only?
  206. shifting hard, real hard
  207. which tranny cooler ?
  208. new tci converter!
  209. chatter
  210. need help after th400 install
  211. TQ converter install guides??
  212. Truck converter in car transmission?= explosion?????
  213. 3600 Vigilante
  214. pilot bearing help (doing A4->M6 swap)
  215. Who has problems or vibrations after a torque converter install?
  216. tc install thrown code
  217. Speedo / miles problem – am I going faster/slower in the same distance traveled
  218. Does anybodys tranny do this?
  219. 4.10's w/3500 stall?
  220. Converters the Same in LS1's and 4.3 Trail Blazers?
  221. Do OBD-I f-bodies (Pre-96) have Pulse Width Modulation?
  222. car wont shift to 4th! help!
  223. Rattle after TC Install
  224. got a big problem with a vacuum system
  225. Is my trasmission screwed?
  226. aftermarket flexplate t/c bolt hole?
  227. Fuddle install is done
  228. Downshift problem.. shaking..
  229. do i need a transgo to go w/ my TCI 3500
  230. B&M Precision Shift Control Gate 93-02 Camaro
  231. Why is my pan leaking??
  232. SS4000e!
  233. 2-3 or nuetral?
  234. Which Trans
  235. Do I have enough stall?
  236. TCI Streetfighter 3000 with 2.73's?
  237. 4l60-e
  238. Trans go downshifting?
  239. Weight of stock stall converter?
  240. E-clips own me
  241. Torque Converter Clutches
  242. Traction Control
  243. which of these three converters?
  244. 200 r4 street strip feedback
  245. 4L65E flexplate
  246. B&M Shift plus
  247. 02 WS6 need a flexplate upgrade with convertor?
  248. Better choice: TCI SF3000 or TCI SSF3500?
  249. oversized transmission pan? Filter?
  250. Track Events Auto vs. Manual
