View Full Version : Automatic Transmission
  1. 4l60e v8 to v6
  2. what diameter are stall converters
  3. new tci ssf3500 installed question
  4. Trans Problems
  5. no od
  6. VIgilante Convertor??
  7. converter decision?
  8. TH400 w/GV Overdrive
  9. question about VIG 3600
  10. shift kit recomendation
  11. rebuild4L60E or speed inc stage 2 or TH400??
  12. Trans Jerking After TC Install
  13. HELP! Vacuum Modulation Install
  14. Th350 is in & it works!
  15. Rattling shifter
  16. why not a 4l80e over a 4l60e
  17. Can someone explain to my why an unlocked converter dynos low?
  18. Pump rotor breakage
  19. A4 not shifting into 3rd
  20. Please explain Torque Mangement!
  21. T-56 - th350 crossmember pics.
  22. Best trans?
  23. Vig 3600 on the way
  24. What to ask and look for in a trans shop?
  25. help ASAP ..!!!
  26. Is the Vigi3200 right for my nitrous setup?
  27. what the hell
  28. Pictures of your th400 Shifters
  29. Vacuum Plate??
  30. Certified shop 4L60E
  31. Blowing through converter?
  32. Trans Cooler question
  33. Anyone ever broke a Rossler 4L60E?
  34. Tranny break in.....
  35. questions bout t56 to th400 swap.
  36. An A4 with a 3.73 is like what gear with an M6?
  37. How much are u guys payin for conv. install
  38. Turbo400 Swap, What To Do About Ses Codes?
  39. 3rd 4l80 now
  40. 4L60E Rear Seal Leak?
  41. Stall - Confusion
  42. 4l60e 4WD vs non 4wd 4l60e ,,,2002
  43. Torque Management?
  44. Drive vs D3?
  45. transmission angle question (TH400)
  46. Shift Kit
  47. Converter Questions
  48. Question on High stall (3000-3500) on Stock Heads/cam
  49. need help asap
  50. Aftermarket Tranny Mount??
  51. Freaky problem
  52. torque convertor?
  53. Oh my god.
  54. Will a 4L60E out of a 2002 4x4 Truck Bolt to a 1998 Tahoe 4x4
  55. torque converter?
  56. tranny mounts
  57. Where to buy Lokar trans dipstick?
  58. Not shifting into 2nd till 4-5Krpm?
  59. TCI tranny controller
  60. Going to ask the NEWBest ? ever
  61. Anybody run a coan convertor
  62. T-56 to TH400 swap weights inside
  63. tranny life question
  64. 4-L60e how much HP can it take?
  65. Yank SS3600 lockup behavior
  66. How much HP can a 4-L-60e handle?
  67. what is it worth? sy3500
  68. doing M6 to A4 swap ?
  69. Wierd Trans problem....screen shot inside
  70. Vaccum module unit from FLP
  71. Rev limiter...
  72. Th350 dipstick?
  73. Pics of m6 crossmember with plate for th350? Help
  74. tc downshift problem true?
  75. whats a fair price?
  76. which converter is for me?
  77. My A4 Broke at the track today :(
  78. TH400 brake??
  79. What kind of sound..
  80. 4l60E Owns
  81. 2nd gear starts
  82. 200-4r questions
  83. 4.3 V6 stall in a camaro
  84. A4 internals
  85. ?P0741 Torque Converter Clutch Circuit Performance or Stuck Off?
  86. TQ Management Question here
  87. Some advice PLEASE. A4 with plenty of cam questions.
  88. who has a speed inc transmission?
  89. would this stall work for me?
  90. 4L60 interchange
  91. Rear end drops down when put into D
  92. Hard shifting...
  93. Yank SS3200
  94. Need help with TH400???????????
  95. New stuff
  96. Where can I buy a powerglide?
  97. should i go to a powerglide?
  98. Trans problem? All trans expets inside please
  99. kickdown solenoid
  100. How often does a th350 low roller go bad?
  101. TCI th400 and speedometer sensor
  102. tranny is making wierd noises
  103. wheel Hop or ?
  104. vid. car on dyno..issues?
  105. I need a new transmission
  106. Need a Pick of a BMR F-Body Torque Arm Relocation mount
  107. 4l60e woes
  108. How to fix
  109. Tranny won't lock up and other problems???
  110. How much will the stall change with more hp?
  111. Can't keep flexplate from turning>>>
  112. Anyone here run their TH350/TH400 in drive?
  113. Tranny shops in Mid-Michigan
  114. How much $$ to install torque converter
  115. 4l60E transbrake
  116. To make your TH350 Speedo work...
  117. Need help choosing a converter for my TH400
  118. TCI tranny controller
  119. Turbo 400 for 1200fwhp
  120. Let's discuss STR...
  121. neutral safety switch,REV lights
  122. all around converter
  123. Towing a jet ski and long skinny trailer with Fbody
  124. 4L60E w/4600UY or TH400 w/4600&T-brake?
  125. vacume modulator?
  126. torque converter a bad idea????
  127. yank ss4000 on a T-rex sound ok?
  128. how hard to install?
  129. Shift Kit: Good or Bad Idea?
  130. T-rex guys inside!
  131. Can't keep tranny cool, please help!
  132. 224/224 581 lift 112 lsa & just stock converter???
  133. used SY3500 tc?
  134. Pro Built Automatics..
  135. stall
  136. 12 pin or 13 pin
  137. Which Stall To Buy!!
  138. How do u like your SS4000?
  139. Torque converter lock up temperature
  140. 3000 stall
  141. What kind of milage can i expect out of a converter?
  142. Neal Chance converters????
  143. synthetic or blend atf
  144. sppedo sensor
  145. 6l80
  146. 3500 stall converter?????
  147. rebuild question
  148. Vig 3800 stall for a stock engine????
  149. How long could a 4l60E with 510 RWHP NA last?
  150. Looking for a deep pan for my 4L60E - Recomendations?
  151. Anyone using this?
  152. Locking TC on Dyno
  153. Third gear sometimes leaves.
  154. shifter question
  155. th400 sprag
  156. Need help from a trans builder on 2-3 shift
  157. 4L60E Rebuild Questions?
  158. Which is the best converter on the highway
  159. 3000,3500??streetracing stall??
  160. who here runs a niel chance vert?
  161. 2-3 clunk
  162. Vigilante PI website
  163. does a 3600 vig act more like a 3800-4000?
  164. will 700r4 hold?
  165. Transmission slipping Bad... What's the deal?
  166. what model and where to get it?
  167. stall install price
  168. Info needed
  169. shifter reccomendations inside
  170. Swapping from 6 speed to TH350
  171. Cracked Flywheel
  172. cooler?
  173. Dowel pin in end of crank
  174. YANK'S new line of transmission crossmembers
  175. Moroso filtered trans cooler??
  176. 4l60e limp mode question
  177. Inspection shield for TH400
  178. Any ideas at all?????
  179. TH400 trans cooler recommendations - best one avail?
  180. Conflicting info: 3500 stall is to big for bolt-on daily driver?
  181. can someone help me? my gpa is dying.. please read
  182. Removing the Torque Converter prccedure?
  183. Time for a bigger converter?
  184. shifter question
  185. Newbie To Stall Converters
  186. Servo's
  187. Its been a min and a day, GM has done their thing with rebuilding only 1600!!!!
  188. vaccum modulated 4l60e
  189. Questions on A4 for street race, Please....
  190. whats a good 4K converter? please?
  191. trans service
  192. Yank Pricing
  193. Transmission locating dowels
  194. question on the converter I ordered
  195. Th350
  196. blew up 4l60
  197. transgo shift kits.
  198. 4L60E retrofit Fbody>>>Truck
  199. line pres. gauge & vac. mod. ?????
  200. converter
  201. 4L60E cant take the abuse!!!!!!
  202. converter
  203. Will an LS1 4L60e work with an LT1 - are they the same?
  204. Who built your 200R4.
  205. Just dropped pan on tranny, and have a few questions.
  206. Magic stick v.3 cam with stock converter?
  207. will a d/s from an m6 fit into an a4 car?
  208. 350 swap?
  209. vibration sf3000
  210. A4 Lockup question?
  211. Manual vs Auto
  212. Torq Converter Bolt Head Size
  213. Car jumps when i start the car!!!
  214. Power Shifting A Stock 4l60e
  215. Seeking some TC recommendations
  216. genral motors is doing something right, 60e is off the chain!!
  217. Tranny problems after converter install
  218. old school transmission question
  219. Servo questions
  220. Lockup switch on a 700r4
  221. My stock 04 GTO shifts much firmer than other GM autos..why?
  222. soon to rebuild my 4L60E, need a converter
  223. 4L60E & Code P1870
  224. My hats off to GM, very pleased with rebuilt 3yr 50k warranty? Unheard of!!!!
  225. Questions on the Vig Multi-disk
  226. To jaxosxon, Thanks for everything, u 2 dave at rock.
  227. broke 4l60e
  228. Help
  229. trans will not shift,stays in drive
  230. TH350/TH400 peeps, any regrets?
  231. Trans Lines?
  232. torque spects on trans pan??
  233. 4l60 doesnt like the new setup
  234. 3-2 downshift vs 2-3 up
  235. Need ur help choosing clutchs!
  236. TC ?- mayb if someone answers it this way
  237. Another "P0757 SSBS0" Problem
  238. Question about slippage
  239. What I learned swapping to a TH350
  240. TH350, TH400 and 200 Questions
  241. 4l60-4l65 swap
  242. What transmission do i have?
  243. Tranny help???
  244. A4; 4L60E or 4L80E
  245. Need Some Advice
  246. B&M Shift Plus??
  247. Rebuild or shift kit???
  248. driveshaft swapping?
  249. tci ssf3800
  250. Transmission is dieing?
