- How much will the stall change with more hp?
- Can't keep flexplate from turning>>>
- Anyone here run their TH350/TH400 in drive?
- Tranny shops in Mid-Michigan
- How much $$ to install torque converter
- 4l60E transbrake
- To make your TH350 Speedo work...
- Need help choosing a converter for my TH400
- TCI tranny controller
- Turbo 400 for 1200fwhp
- Let's discuss STR...
- neutral safety switch,REV lights
- all around converter
- Towing a jet ski and long skinny trailer with Fbody
- 4L60E w/4600UY or TH400 w/4600&T-brake?
- vacume modulator?
- torque converter a bad idea????
- yank ss4000 on a T-rex sound ok?
- how hard to install?
- Shift Kit: Good or Bad Idea?
- T-rex guys inside!
- Can't keep tranny cool, please help!
- 224/224 581 lift 112 lsa & just stock converter???
- used SY3500 tc?
- Pro Built Automatics..
- stall
- 12 pin or 13 pin
- Which Stall To Buy!!
- How do u like your SS4000?
- Torque converter lock up temperature
- 3000 stall
- What kind of milage can i expect out of a converter?
- Neal Chance converters????
- synthetic or blend atf
- sppedo sensor
- 6l80
- 3500 stall converter?????
- rebuild question
- Vig 3800 stall for a stock engine????
- How long could a 4l60E with 510 RWHP NA last?
- Looking for a deep pan for my 4L60E - Recomendations?
- Anyone using this?
- Locking TC on Dyno
- Third gear sometimes leaves.
- shifter question
- th400 sprag
- Need help from a trans builder on 2-3 shift
- 4L60E Rebuild Questions?
- Which is the best converter on the highway
- 3000,3500??streetracing stall??
- who here runs a niel chance vert?
- 2-3 clunk
- Vigilante PI website
- does a 3600 vig act more like a 3800-4000?
- will 700r4 hold?
- Transmission slipping Bad... What's the deal?
- what model and where to get it?
- stall install price
- Info needed
- shifter reccomendations inside
- Swapping from 6 speed to TH350
- Cracked Flywheel
- cooler?
- Dowel pin in end of crank
- YANK'S new line of transmission crossmembers
- Moroso filtered trans cooler??
- 4l60e limp mode question
- Inspection shield for TH400
- Any ideas at all?????
- TH400 trans cooler recommendations - best one avail?
- Conflicting info: 3500 stall is to big for bolt-on daily driver?
- can someone help me? my gpa is dying.. please read
- Removing the Torque Converter prccedure?
- Time for a bigger converter?
- shifter question
- Newbie To Stall Converters
- Servo's
- Its been a min and a day, GM has done their thing with rebuilding only 1600!!!!
- vaccum modulated 4l60e
- Questions on A4 for street race, Please....
- whats a good 4K converter? please?
- trans service
- Yank Pricing
- Transmission locating dowels
- question on the converter I ordered
- Th350
- blew up 4l60
- transgo shift kits.
- 4L60E retrofit Fbody>>>Truck
- line pres. gauge & vac. mod. ?????
- converter
- 4L60E cant take the abuse!!!!!!
- converter
- Will an LS1 4L60e work with an LT1 - are they the same?
- Who built your 200R4.
- Just dropped pan on tranny, and have a few questions.
- Magic stick v.3 cam with stock converter?
- will a d/s from an m6 fit into an a4 car?
- 350 swap?
- vibration sf3000
- A4 Lockup question?
- Manual vs Auto
- Torq Converter Bolt Head Size
- Car jumps when i start the car!!!
- Power Shifting A Stock 4l60e
- Seeking some TC recommendations
- genral motors is doing something right, 60e is off the chain!!
- Tranny problems after converter install
- old school transmission question
- Servo questions
- Lockup switch on a 700r4
- My stock 04 GTO shifts much firmer than other GM autos..why?
- soon to rebuild my 4L60E, need a converter
- 4L60E & Code P1870
- My hats off to GM, very pleased with rebuilt 3yr 50k warranty? Unheard of!!!!
- Questions on the Vig Multi-disk
- To jaxosxon, Thanks for everything, u 2 dave at rock.
- broke 4l60e
- Help
- trans will not shift,stays in drive
- TH350/TH400 peeps, any regrets?
- Trans Lines?
- torque spects on trans pan??
- 4l60 doesnt like the new setup
- 3-2 downshift vs 2-3 up
- Need ur help choosing clutchs!
- TC ?- mayb if someone answers it this way
- Another "P0757 SSBS0" Problem
- Question about slippage
- What I learned swapping to a TH350
- TH350, TH400 and 200 Questions
- 4l60-4l65 swap
- What transmission do i have?
- Tranny help???
- A4; 4L60E or 4L80E
- Need Some Advice
- B&M Shift Plus??
- Rebuild or shift kit???
- driveshaft swapping?
- tci ssf3800
- Transmission is dieing?
- Midplate or solid mounts
- TH400 cooler question
- Converter problem?
- Anyone know the problem here??
- Ok, questions to simple to get a answer? Heres 1 that I dont think is simple....
- Is this a converter issue?
- 4L60E is killing me, and my tranny guy#$^#
- trans go shift kit andtci ssf 3500 what fluid and how much?
- I wonder who is really responding to post here?
- 700r4 swap, electrical connections???
- Torque Converter Won't Lock Completely
- HELP 2000 silverado with 4l80e
- 93 vette engine, no forward
- TRANS WONT BOLT/MATE BACK UP.. wtf???? 98 4l60e
- A quick question on trans install, first timer here!
- Where can I find a used 4L80e Yank PY converter?
- Which would be better with my future combo?
- First Time installing a trans, yes it happened to be 4x4 lol!
- What would it cost to ship a Trans.
- 700R4's???
- need a parts list for TH400 swap.
- 4l60E + heads and cam....
- shift kit
- TCI Flexplate Bolts
- Powerglide gear selection
- what is the cheapest i can do?
- Lokar shifter on 4L60E???
- is there anything special to putting in a trans go shift kit??
- Torque converter problem
- Mos complete rebuild kit for 4L60E (Impalla SS)?
- looking for tq converter?
- Installing a shift kit in a 4l80e
- does midwest torque converter have website
- after a rebuild, should u change fluid out after a few break in miles?
- time to get a real trans. suggestions?
- Weak points in 350 turbo
- 4L60E, no 3 or od
- need advice on what to buy
- How to Connect 24 pin connector?!?
- Superior shift kit?
- TH400 question, need help picking tranny
- shift problems please help me!!!
- F/S 383 H/C w/black zr1s
- Flushing a tranny cooler?
- TH350 endplay problems
- what converter to get ???
- tranny problems
- YANK'S NEW 350/400 converters (look)
- th400 w/high stall?
- I have a A4 Harness for a conversion
- dumb question
- TH350 swap
- car makes tickin sound when goes in gear
- Anyone running a Yank SS3800??
- th-400 adapter spacer question
- A4 Help
- Automatic Trans Slipping.....Help!
- Not a LS1...but I've got a 4l60e problem
- diff between nonlock up and lockup
- 4L60 ? Hollander interchange
- Vig 3200 or TCI SSF 3500?
- Advise: Does a stall converter make a differance in mid and top end or just at a stop
- Talked with Precision Industries about changing Torque convertor..
- Hard Shift
- [b]shift kit or programmer[/b]
- Anyone know anything???!!!???
- TH400 Vs. TH350 tranny crossmember?
- th400-forward vs reverse valve body
- Trans Acting Up
- Trans Temp question
- How difficult is it to put a 4l80e in a 4th gen f-body?
- 4L60E Swap - What years will fit
- tranny cooler install
- Dipstick tube
- pics of progress
- what are the best upgrades to do to my A4 while i have it out
- What will a TCI 3500 stall do?
- ? about a stall
- TH400 converters... What's good? Who's got what?
- A4 Tranny Help Please... Quick
- Installing new 3500 verter. What trany fluid sould I use
- What to upgrade in a 360rwhp 4l60
- Looking to buy a new converter
- hesitation during 2-3 shift
- transgo?
- TH 350 Swap
- Manual shift body for 4l60e ?
- Horribile Downshift during a WOT pass
- Are 5 pinion planetaries necessary?
- GTO 4L60E Difference?
- shifter questions
- I know this is vague, but fluid everywhere
- locking converter on the dyno....
- HPP3 Question
- Transmission Question
- Attention anyone from YANK!!!!
- Lookin for help on removal and Installing trans. (first timer)
- Shift Extensions: TCI 4000 vs 4400
- Anyone know 700r4 tranny well help!?
- keep the auto, or switch to m6
- Coverter Bolts?
- Trans Problem
- 2001 ss-----1996 camaro
- Any difference in the truck and f-body 4l60s
- used converter question
- Turbo 350.. will it last?
- NEED HELP TC randomly unlocks after rebuild
- Hey jxaxsxoxn, now quick question on droppin trans and install new???
- anyone else have this problem.
