View Full Version : Automatic Transmission
  1. TC questions.
  2. Most efficient verter in the 2600-2800 Variety
  3. shifter for t-400
  4. Converter is really loose in first gear
  5. Torque converter and top end
  6. TH400 converter for nitrous - 4000 too high for a 250 shot?
  7. Shift solenoid?
  8. Looking to buy a converter for my A4. Help me!
  9. Difference between converter for LT1 and LS1?
  10. How long will it hold?
  11. M6 to A4 swap
  12. 4l60e 93 truck tranny
  13. results from tci 4000
  14. Who is/has used nitrous on a Vig multidisc 4000 stall???
  15. Upshifting/Downshifting
  16. Shift Kit
  17. 4l60e: "Corvette servo"?
  18. Need advice on stall rpm
  19. Vig. 3600 or Similar Yank?
  20. Help.. I need a quick question answered :)
  21. B&M LS1 Converter (results)
  22. 4L60E: please help me to get the big picture
  23. Help! I think I killed my trans or verter
  24. How trans brake works
  25. p1870 code
  26. p1870 code
  27. Rubber or Metal Line to Tranny Cooler
  28. 98 flexplate
  29. manual lockup switch???
  30. 4l80e flex shield and tranny shield
  31. how
  32. Can you spray on a Yank PT4400? Has anyone done this?
  33. a4-400 swap, what all needed??
  34. Installed converter now the car wont move
  35. Aftermarket A4 Shifters...
  36. 4L60E Auto
  37. Team trip Question
  38. Metal tube on the top of a 4L60E
  39. Glide or T400
  40. short shifting
  41. 4l60e servo
  42. Shift extension on PT4200 question.
  43. Whos Yanks new owner?
  44. Tranny/Converter Issues After New Cam Install
  45. 4l60e probrems help
  46. WOT at 5600RPM car shuts off/backfire HELP!!
  47. tranny temp gauge install
  48. New PT4200 is in!
  49. 4l60e
  50. Yank SS 3600: to do or not to do?
  51. MAF ends or In need of shift kit?
  52. Nice 700R4 Find...
  53. Trans fluid change to come soon!
  54. converter question
  55. A4 install with PT4000, problems...
  56. yank re-stall quesiton
  57. the yank is in
  58. t-56>A4 swap, now code p1860...
  59. Down shifting harder after TC install.
  60. Transgo Shift Kit. Anything I need to think about before installing?
  61. Newbie ?: What gear do u race in?
  62. TH-350 help, Shift kit Help, and stall converter help
  63. Wanna guess !?
  64. TCI Converters?
  65. tranny cooler
  66. tranny type and torqe conv???
  67. What gear in 1\4
  68. B&M LS1 Converter
  69. Who uses a 4l80 with BIG horsepower???? T-brake?
  70. Midwest vs TCI vs Vig
  71. Please Help Me, Noises From Tranny?
  72. auto/man
  73. tranny or converter?
  74. what rear gear are you th400 (semi street) guys using?
  75. fewST3500 questions
  76. 4l80e stock converter in Z28?
  77. Problems installing transmission cooler
  78. Shudder at deceleration
  79. Lockin the Torque Converter....
  80. Rattling Shifter
  81. A4 snapping like twigs!!!
  82. Stall Converter Help!
  83. Which tci converter for me????
  84. Need Immediate Speed Inc. Tranny help!
  85. LT4 Hot Cam Timing
  86. Which T/C for Boosted car??
  87. Shift Kit Question
  88. Which ART CARR, SO-CAL or TEXAS?
  89. 4l60e woes :(
  90. Cheetah SCS part numbers 70073B and 70002B, do I need both?
  91. vig 3200 problem
  92. quick vaccum line question
  93. replaced 2-3 solenoid but still having problems??????
  94. tci 3000 track results
  95. WTF is wrong with this damn tranny
  96. Tranny wont shift out of first gear! Help!
  97. WHO here on this forum, REALLY knows transmissions, converters & dyno's?
  98. What would be the gains from a ST3500 to a SS4000
  99. stall converter bolt lenght
  100. tailshaft ext. housing
  101. can I use an LT1 trans mount on a LS1
  102. A4 from LT1 go into an LS1
  103. How much is too much?
  104. Car dies in reverse. After stall.
  105. Shift Extension
  106. 4l80e install in a 67chevy ll
  107. best convertor combo for pure street driving
  108. Problems blocking off trans cooler lines???
  109. T-56 vs TH400
  110. Shift point adjustment...going from 26's to 28's need help...
  111. 00 z28 converter
  112. parts for a a4 to a3
  113. I want to upgrade my Yank ST3500. Please help.
  114. TCI Flexplate trouble
  115. LS1 Bellhousing
  116. 2nd gear gone!
  117. Shift light installe question
  118. love my rock-on!
  119. which tranny/stall for ATI D-1SC Procharger?
  120. Wiring on a 96' 4l60e Fbod the same...
  121. Recall???
  122. Turbo-400, people who has done this help me out.
  123. 1st gear only, whats up????
  124. Im f***ing pissed
  125. Tailshaft length for a 400
  126. What Vehicles Come With 4L80e?
  127. looking for LS1 to 200r4 or 700r4 adaptor
  128. New converter, slippin trans.
  129. P0757 2-3 solenoid stuck on ..
  130. LS1 guys with 373 gears, at 45 mph at WOT you still get that screaming performace?
  131. need info
  132. 4L65, sliding 1-2 shift.
  133. converter quest
  134. Torque Converter Bolts???
  135. "plastic bushings" in 4L60E ?
  136. is it possible that my tps voltage is low, causing my trans not to downshift at WOT?
  137. New TCI 4000 stall SSF converter
  138. Restalling a converter, who's good & fair priced????
  139. 4L80E questions
  140. how to replace my 2-3 shift solenoid
  141. TCI SSF 3500 slipping bad & chattering
  142. TC Questions...
  143. Need help bad, Tranny not working.
  144. do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
  145. Tranny Help!
  146. Th 350?
  147. restall or sell Y3000 ?
  148. Anyone in Phila or S. Jersey have the FLP Level IV tranny?
  149. FLP Level IV users..........
  150. 4l80e Problems
  151. Just took my friend for a ride in my "slow auto"
  152. question on stock convertor
  153. Trans Temp Gauge Install
  154. Looking for converter recommendations!
  155. 1350 yoke for 4L60E?
  156. Trans. went out today.
  157. what stall ??????
  158. Flywheel/flexplate bolt size, thread, etc...
  159. Damn 4L60E
  160. Need help with potential converter problem/drivability issue
  161. B&M deep tranny pan installed...
  162. First Experience With ST3500 Stall Converter
  163. trans go
  164. Transmission lines on stock cooler
  165. shifting problems. help
  166. corvette servo
  167. Tranny Swap Question
  168. tranny has started slipping... rebuild time...
  169. Daily Driver Mod Recommendations Please
  170. Where to get my Turbo 400 rebuilt in CA
  171. anyone uses the deep trans pan for their Ls1's, if so how many total quarts to use?
  172. converter hub too freaking short????
  173. $300 to convert my SS4000 to a PT4400, what do you think about that?
  174. ultimate street converter for a stroker/superstroker?
  175. new car, new problem
  176. th-350 inspection cover..
  177. want to buy tci ssf 3500 but read some horror story's
  178. How much is this gonna suck?
  179. Stall RPM question with STS turbo....
  180. Tranny problem
  181. Here's a website for all your trans needs...
  182. ?questions?
  183. Neutral safety switch
  184. help!! trans mount problem
  185. Need some opinions on SY3500 & Y3200
  186. TC and tuning transmission
  187. Screaching sound
  188. self 4L60E attempt.
  189. Good Transmission Shop in Denver
  190. No Downshift to lowest gear at WOT
  191. T-56 to Th400 swap PLEASE HELP. Or 4l80
  192. 4L80E Vs. Built4l60e Vs. TH400 ??
  193. Good verter for an FM11 cam?
  194. 2-3 shift clunk with transgo
  195. 4000 Stall Question
  196. My tranny feels like its slipping when I stall it up?
  197. Anyone know how the Trailblazer I6 TC would do in a Whippled 5.3?
  198. Heres one for the experts....
  199. Fourth Yank Converter in 4 Years!
  200. 4l80 How strong?????????
  201. TH350 using clutch take off?
  202. Need some advice on a converter
  203. Help me find the right shifter!
  204. How much do you think..
  205. can it be done??
  206. 350 vs 400 turbo
  207. Oversize 3-4 clutch pack/input drum anyone tried it??
  208. Broken Tail shaft on the dyno today.
  209. torque converter?
  210. Anyone familiar with 6 pinion planetaries for a 4L60E?
  211. What parts do i need to make my A4 stronger?
  212. will my stock 10 bolt hold up to this?
  213. are these 2 tci ssf converters the same? please help
  214. s-10 4.3 radiator trans coolant lines witch in and out???
  215. Does this sound like a Vig 3200
  216. Converter Lockup = KR
  217. Tranny Help!
  218. How much am I leaving on the table? SS4000 vs PT4200
  219. tc from a roll
  220. info for A4 to 6 speed swap
  221. Trans is acting up
  222. LT1 vs. LS1 4L60E ?
  223. Shift point question
  224. changed stall on my verter, now i have a small problem
  225. just ordered my vig 3600 & trans go
  226. HELP!! SY3500 troubles.
  227. Lt1 Transgo Shiftkit in LS1
  228. Trouble with B&M Shift improver kit
  229. how much difference in a TCI 3000 vs. 3500 please help
  230. 4L60E Question HELP!
  231. Cant find "fbodytrans.com"
  232. Overkill?
  233. other add ons i will need with a stall and gear??
  234. 2005 1500 truck transmissions
  235. Max hp and torque a stock 4L60e can hold
  236. suggestions about a stall
  237. Did I screw myself with a TCS verter???
  238. Performance Tranny Parts
  239. just had converter installed i have a question
  240. where to find cheetah shifter, and how much?
  241. 4l60e's interchangeable from 1997-2000
  242. trany ? help please
  243. TH400 guys, do you regret NOT getting the Gear Vendors OD unit?
  244. 4l60e And Cryo Smart Techs Please Read
  245. 2-3 servo issues???
  246. Procharger + Converter:
  247. How much RWHP will 4l60E handle Rebuilt!
  248. what holds the output shaft steady in a 4l60e?
  249. need professional help on converter selection
  250. th350-400 conversion kit?
