PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
  1. 4L60E No OD
  2. B&M 28,000 GVW fittings.
  3. Who has an ATI flexplate?
  4. C5 Tranny fluid change question
  5. How much space was between your Fuddle and the bellhousing holes?
  6. I shouldn't loose e.t. should I ?
  7. What is needed for a 98 TC swap?
  8. how much would a 3800/2.0 help
  9. Removing Tranmission dipstick...
  10. Question? Trouble with rebuilding on 4T60E GM Transaxel
  11. Anyone using the Gear Vendors overdrive?
  12. trans temp gauge worth it?
  13. Console Question
  14. How hard is this gonna be to do.
  15. Would you buy a used stall?
  16. 4l60e or turbo?
  17. any lightweight flexplates?
  18. Tranny problems.
  19. need advise on 4L60E
  20. 4l60e for trade
  21. Flexplate: LS1 Fbody Vs. V6 Fbody?
  22. A4 tranny shift MPH & RPM Points
  23. Cam Driveability question
  24. Anyone make a non computer controlled 4L60E?
  25. Should I take off Torque Management?
  26. Help quick th350 questions
  27. Would this be a good TC?
  28. guys with 4k stall what cams yall running?
  29. Stumped as to which stall to get
  30. stall or gears?
  31. TH400 speedo hook up, this is what is required
  32. stock flexplate weight?
  33. Tried my Vig. 3200 out with slicks
  34. Is a tune needed for a 2500 or 2800 stall?
  35. Century Transmission
  36. Where should I go to get a TH400?
  37. What is lock-up?
  38. A4 Fustration
  39. LS1/th350, best to space or correct converter?
  40. wheel spin vs revlimiter???
  41. what size stall would i need
  42. dry clutch automatic
  43. 9 bolt stronger than 7.625?
  44. Have a question about my built trans
  45. Billet OD Servo problems in 4L60E
  46. what shifter for th400?
  47. Looks like RockOn is now a sponsor!
  48. What did i do? car shaking...
  49. Front Pump Removal
  50. Newbie with question
  51. Checking fluid level with trans cooler
  52. problem after rebuild
  53. stall converter
  54. stall converter
  55. Folks with FI and Vacuum modulated trannies inside, please
  56. lockup problem
  57. Does an increase in STR make more RWTQ?
  58. Check Valve On Input Shaft?
  59. never in a thousand years!!!!
  60. Help!!!!! no 1st or 4th
  61. my BRAND NEW! A4 tranny shifts at 4K rpms...why?
  62. shift problems
  63. I need converter advice for my TH-350
  64. well i bought myself a X-mas present...
  65. question
  66. what stall for th400?
  67. black02, anyone 11's SI INSIDE PLEASE!!
  68. Funny shifting when its cold
  69. Is everything right with my A4?
  70. trans problems, but not the usual...
  71. Lock up or Non-Lock up
  72. What's the best option to cool my tranny.
  73. Fuddle 3000 stall review. long/detailed
  74. th350 swap
  75. billet cover?
  76. M6 guys that made the change.
  77. Shift Points
  78. rev limiter?
  79. Those with TH400's, how do mount your shifter?
  80. Stock stall
  81. Shift cable bracket help.
  82. Best pan gasket
  83. shifting problem
  84. How does this TH400 sound?
  85. A4 slipping issues
  86. Fuddle TC doesn't fit over pump...
  87. Won't go into park
  88. tailshaft seal
  89. looking for a flexplate
  90. Does a 4l60e have a shifter linkage adjustment???
  91. 98 z28 is stuck in park PLEASE HELP
  92. This may be a dumb question
  93. Transmission problem? Need help!
  94. Mad Dog 4L60E??
  95. Tq Converter Adapter???
  96. huge tranny leak
  97. Truck 4L60e, built by who?
  98. Do i need a shift kit with a new converter even though i have LT1 Edit
  99. Stall w/turbo
  100. Where to get a 4L80E?
  101. Tourqe Converter
  102. Lighter Flexplate
  103. changing stalls!!
  104. Question about Drivability..
  105. going to a 4l80e
  106. Would this work well together?
  107. Opinions of Yank's SS3400
  108. Shifting Question....
  109. problems with my fuddle possibly
  110. LS1 and LT1 4L60E tranny - how different?
  111. help quick? inside TH400 owners
  112. Tranny Coolant Lines
  113. HP tuners and the 4L60E
  114. how much power can a stock a4 trans take?
  115. Need help
  116. No second gear after normal driving.
  117. 4l60e
  118. Bellhousing bolt size on 5.3 block
  119. Transmission died
  120. Tranny won't shift out of 3rd gear
  121. flywheel weight ??'s
  122. Aftermarket shifter install's. post your pics
  123. Might be picking up a 98 Z28 w/ turbo and blown tranny...need tranny advice (A4)
  124. Converter for TH400?
  125. Help me Choose a TC
  126. convertor question
  127. Stall questions
  128. Choosing a Transmission --- Help
  129. Transmission Perform Button?
  130. Occasional hard shifting
  131. Need Spline Count/Size for 4L60E DS Slip Yoke
  132. What Stall??
  133. Trans Whine
  134. Tranny cooler
  135. 700r4 shift points
  136. 3rd and 4th gone
  137. Thinking of going back to electronic shift...
  138. Got my Fuddle in
  139. Tranny swap???
  140. Stall Setup?
  141. Paging 1jfuddle
  142. HELP PLEASE!! NO Second Gear
  143. stock gears and TC in a 94 T/A
  144. just bought my transgo s/k
  145. Trans fluid additives & flush
  146. those who are thinking of getting a fuddle converter
  147. The NEW YANK PE4400!!!!
  148. Will increased power and torque change stall points and shift extension upwards?
  149. NE1 using BMR TA Relocation with TH350 ?
  150. what do i need....
  151. I Need Help Bad
  152. tranny launching help
  153. Tranny Coolers
  154. A new one?
  155. LT1 vs. LS1 Torque converters
  156. what brand stall
  157. Whats the best trans cooler for a 05 GTO with a 3200 Vig
  158. What TC's to use for TH350 & LS1?
  159. BW high energy 3-4 sucks, one step backwards
  160. lock-up or no lock-uo for my 350??
  161. stall question
  162. ss3200 owners in here please!
  163. Disadvantages with a th400 over a 4L60E?
  164. Which aftermarket pan is everyone using
  165. stupid converter question
  166. help with a converter
  167. Built 4L60E vs. TH400?
  168. Emergency neutral with a RMVB?
  169. Is changing Transmision fluid an easy task ???
  170. trans wont shift
  171. transmission drip
  172. Clicking from TC.....NEED HELP ASAP
  173. 4l60e HELP
  174. new tranny and still 3rd gear vibration!
  175. stuck
  176. TC or Gears
  177. What too look for in pan?
  178. (hitting Rev Limiter) Need Help!!!!
  179. Need Tranny Help: Space between TC and flywheel: Need washers?????????
  180. Who all makes Flexplates for LS1 w/ TH350???
  181. How much hp can stock motor adn tranny handle
  182. 4l60 vs 4l60e?
  183. Problems.. need help
  184. Drivability of the SS3600
  185. Quick question about my cable modulated 700r4
  186. 2nd gear gone in my A4?
  187. How well would a yankss 4400 stall do on a stock ls1?
  188. Red warning light on dash after TC install
  189. C5 Torque converter install
  190. Will a Trans Go shift kit aleviate a p1870 code?
  191. trans temp gauge
  192. New to TC's...Lil Help!
  193. Torque converter won't lock up, Can I drive it?
  194. need some help....
  195. Got my New Yank SE4400 Today!
  196. What does sticking in 2nd gear mean?
  197. No 3rd or 4th gear
  198. Converter Condition
  199. 700R4 Help
  200. dipstick for th400?
  201. Is a tranny temp gauge needed after installing higher stall converter???
  202. No 2nd or 4th gear
  203. No 4th Gear
  204. Shifting
  205. What would cause...
  206. Gears on A4 thrown off
  207. Hardest launching method
  208. Getting ready to order.... Which company?
  209. TH400 Help
  210. why is my tranny whining?
  211. B&M cooler and fittings leaking
  212. its time to rebuild the ol' 4l60e
  213. 4L60-E Build Up
  214. 4l80e bolt right up to an LS1?
  215. Probuilt I have a question
  216. looking for a web site/guide to...
  217. turbo 400 ?
  218. Need a Transmission Shop
  219. Hayden trans cooler question?
  220. Another 4l60e problem
  221. 4l60 will not separate HELP!!!
  222. C5 automatic ?s
  223. Do you take the bellhousing off to pull the pump on a 4L60E?
  224. fuddle VS. TCI
  225. Torque converter lockup cycling
  226. Converter for a lighter car (~2500lbs)
  227. Do I really need a lock-up converter?
  228. Lockup coverter (multi plate) problems
  229. TCI Converter and 3-4 upgrades, now bad 2-3 flare
  230. Post your 60ft times and what stall
  231. Can i fit a th350 in a 01 Ls1 camaro and how?
  232. 4l80E build-up help
  233. Input Shaft/Housing Differences
  234. Want To Get Of Hold Of Trans King
  235. Red Lining ????
  236. converter not locking up
  237. how low a stall can i go?
  238. converter?
  239. Shift kit help
  240. Anybody know the stock converter specs?..
  241. Q:trans shop owners /builders
  242. What do I need to swap to TH400?
  243. Those with TCi deep pan
  244. Do I have automatic trans problems with a p1870 code??
  245. 98-00 vs. 01-02 Flexplate ?
  246. Th350 Tail
  247. need 4l60e rebuild help
  248. Car threw a p1870 Code.
  249. WTF would make a ticking sound from trans
  250. Installing converter without removing exhaust
