- Tranny not shifting?
- 3200(vig) - 4.10s - A4?
- 4L60E-Which Clutch Set?
- 4L60E / 1-2 Shifting when Hot
- New intake.... Tranny problems?
- V6 tranny?
- possible problem
- Dacco Converters
- Teamtrip Q ........2k xcab
- converter
- A4 and ET Streets
- TransGo Help
- Yank SS or TCI SF
- i need some help
- What do I need to know about a Stall Install?
- 4l60e no od or d
- launchin with 4L60E question....and what is recommended to beefen up the tranny?
- Shifter knob
- Shifter for 4l80e????????
- just installed rock on 4l60e
- tranny won't work
- Tranny Temp Gauge
- TC Install/Swap Guide
- 323s to 342s
- harsh reverse engagement
- 200-4R and 700R4 transmission?
- Some questions about FLP's Stage 4 4L60E Tranny
- Trans Leak
- temp gauge?
- Why would transmission stay in 2nd when in 3rd?
- 4L60E or 4L80E?
- Tuner says bad converter??
- How much tranny fluid for 4L60E with a deep pan
- Please help me pick a stall converter!
- Converter stall question
- 04 silverado 5.3 4l60e
- tci ssf3500 or yank ss4000
- Clunking / Delay...
- Got a great deal on built tranny w/3k stall!
- What to replace 4l60E with???
- Converter confusion: higher STR or steeper gears?
- Looking for new Transmission
- 1-2 shift problem PLEASE HELP
- help choose a converter help!
- Serious Problems After Transgo Install
- Where can I find swap how to?
- Cost of Complete Turbo 400
- Which stall for 125/150 NX, SS4000e or PYE3600
- TCI SF 3000 and N20?
- Servo Q??
- 400 turbo ?
- tsp 231/237,a4,3.42
- Check out my trans cooler setup
- Which Transmission should I go with?
- What cam with 4000-4400 stall?
- Thanks To Dave At Rock On
- FLP 4L60E ROCKS-Thanks to CHUCK-
- Tranny Heat.
- Need help with tranny sell
- Shifts?
- shift question
- 4l60e rebuild
- need help removing tailshaft seal
- cooler line clip part #
- Tranny gone? Need help please!
- HD U-joints?
- 4L60E interchange
- 97 700r4 To 01 4l60e Conversion
- 4L60E Performance rebuild worth it?
- Trouble with 4L60E
- Truck pan w/ drain plug question
- How fast can you spin the 4L80e ??
- Yank TH 350,How much is it going to Cost me,and what Rpm will I have @ 70 mph?
- Question about using 4L65e in truck
- 4L80 question...
- What 60' times are people getting with a TCI SF3000
- 98 4l60E in a 2000 Ta
- Spaying stock and stalled...
- I think it's time for a rebuild
- Tranny problems please help!!
- Need help...
- Shift Solenoid Stuck On... HELP!
- what happens when you get short tailshaft th400?
- SHift Kit?
- Fresh 4L60E and Yank SS4000 verter Synthetic or not?
- truck tranny4l60e
- TCI SSF3500 Install Finished
- Vaccum Modulated 4L60E
- Any guesses on what my shift extension might be?
- Do i have a 3500 or not?
- Ut-oh did I blow my 4L60E tranny?Help
- Trans is slipping in 1st help!
- TCI 3000 vs. Yank SS3600
- Which stall for my application?
- how to hook up speedo???
- Rock on 4l60e
- Few questions about Th400 swap
- Help Tranny acting up
- A4 Flywheel Torque specs and use locktight or anti seize??
- Need to soften 4L60E 1-2 shift - has shift kit
- When you speak of tune.....
- Flp Stage 4 (4l60e)
- 4l60e Woes
- Could a trans blow out because of an engine prob.?
- daily driver question (GTP A4)
- New A4 owner and humming noise at idle
- torque management issues on my 98??!
- Converter install ?
- Converters - how many miles
- which tci to get???
- I think I have a problem
- Where can I buy a used 4l60e Valve body
- TH350 rebuild parts??
- Fact or fiction: Do Yank converters really come with 1 free restall?
- ls1 th 400 what yolk do i need?
- what mph does your a4 shift into 4th gear?
- Can someone tell me WTF this is?
- Diffrent Torque converter = more hp?
- Getting ready for the Glide
- do I need a tune w/ SSF3500, Trans Go, cooler
- Hey Yank ! "Thanks "
- 4L60E swap help
- Tranny Diagnosis..
- help choose a torque converter
- PY3400E Dyno
- Part number for stock tranny cooler lines??
- Tranny Question?
- Anyone have a Derale fan mounted trans cooler?
- TH400 coversion questions????
- trans cooler inlet/outlet lines same as 4l80E?
- Hard 1-2 shifts
- torque converter and dyno
- Question about 0verdrive and Drive....
- TC unlocks at 50mph?
- Good idea to dyno before chosing stall and gears?
- does anybody have a slow 2-1 gear shift?
- FLP level 4
- Flashing your converter!!
- Mw 3400 2.0 str impressions
- just put my Rossler trani in and......HELP ME
- quick tranny question
- anyone street drive a reverse-manual TH350/TH400?
- Anyone go from a 3500 stall to a 4000+...??
- Converter size
- Suggestions for a converter Plz help!
- when to lock up converter while racing?
- Core Charge
- Transmission fluid?
- Stock tranny's with nitrous and high mileage.
- Vig 3600 vs TCI/Yank 4000+
- Trans mount
- Kevin - TCI, TCU VSS question...
- Drove my car out of town this weekend with the TH400. what is everyone talking about?
- Yank TT3000
- Help With Shift Kit
- My tranny = WTF is happening?!?!
- is it time for a 4400 tci
- Cheapest way to relocate torque arm to crossmember?
- Has anyone ordered and recieved anything from Yank...?
- Diablo Tuner owners.....auto shift MPH and RPM question.
- Torque Converter lockup and unlocking and 2-3 shift miss
- Tci 3600
- TH-350 Question
- TransGo Shift kit users looky here.....
- Why is my car hitting the rev limiter on the shifts......????
- Art Car
- 2600-2800 Tc
- Anyway to find out if i have a shiftkit?
- Transmission cooler with AN fittings
- ssf3500 stall speed?
- T-rex cam converter????
- Shift Cable Rubber Boot
- Transmission problem?
- Which shift kit, TransGo or TCI?
- TH400: To upgrade or not (first gear)
- 2001 Lincoln LS 3.0 -5R55N Tranny
- ? for PT4000 owners
- dipstick tube question
- Torque convertor bolts? Size? Thread pitch?
- Best tc to replace my vig with?
- How does a 4L65E take 800ftlbs? Experts.
- Changing Dipstick Tube
- Vig.3800 Exactly how do they work?
- Driveline vibration?
- Need info on tranny swap and convertor selection.
- Please help me make my Final decision plz.
- cooler install how to?
- Which converter is right for me?
- rmoving shift knob???????????
- got the tc installed
- Hitting rev limiter in all gears even after edit
- thinking of different convertor
- Yank SS4000 Cause a surge when stop at a light?
- Efficiency of Vig Stalls
- Mileage and durability pt4000
- Blown up 2 Yanks in the past 6 months
- Open loop tuning messing with shift points?
- gear install ?
- no 4th, code 1870 ??
- 3300/2.2 Str
- Dyno stock converter vs. TCI 3800
- Strength of 4L60E
- older, but new SLP converter, good idea?
- Vote: Best Yank Model TC for Me:
- 4L80E - 2x4 & 4x4 swap
- Need an answer quick!!! TCI 3500 question
- Converter Question??
- TCS Phoenix Torque Converters?
- SSF3500, what RPM range to get graph on dyno
- Makeing 4L60-E to TH400 Swap, 3 last min questions.
- Torque arm for TH400
- Shift Pressure?
- part throttle shifts????
- PY3600E for a TH400???
- new verter = no traction... Please Help!
- Repairs on 4L60E worth it?
- Fix shift points?
- converter ? can i do it?
- Advice on choosing converter, LS1 420BHP, TH350, 3.73's.
- Speed Inc Transmissions?
- Suggest the best convertor for my TA plz...
- a4 vs. m6 from a roll
- just installed SSF 3500. WOW!!!
- got 224 cam and stage 2 heads stock a4 t
- *Help* Trans Go install sheet needed
- Vibration when verter's locked...
- 2 second delay before the trans kiks down...?
- SLP Shift Improvement Module
- What brand is this ?
- Good 4l60E Tanny Guys
- LS1 TH350 with spacer kit using standard A4 flexplate
- Stock shifter with TH400
- Need 4L60E tailshaft
- Benefits from aftermarket flexplate?
- New Th400 Price $900 Good/bad
- Super Street Raptor
- Push-Lok Tranny Lines?
- Need help with TH-400 - will not shift 1 to 2
- problems with 1-2 shift...
- A4 road course shift tuning
- powerglide questions .
- TC slipping????
- tranny goes from 1 to 4 sometimes???
- On the Road Again
- PLEASE HELP! My cars not shifting right
- tranny setup
- 230+/600+ Cam--What Stall?
- my review of the tci3000 street fighter
- ssf 3500 owners I got a quick question?
- Need Advice
