View Full Version : Automatic Transmission
  1. th350 torque convertor
  2. Speedo conversion for your TH350?
  3. Converter question regarding efficency?
  4. 4l60e Help!!
  5. Converter unlocking under VERY light acceleration
  6. choices for autos w/ OD
  7. Wanted: stock ls1 auto flywheel
  8. my car is shaking badly
  9. will a yank ss 3800e be good for n/a?
  10. DIY 4L60E rebuild possible??
  11. Yank SS3800E and 200 shot.
  12. tc for 3.07:1 gears??
  13. thinking about doing a tc
  14. Which TC to use with cam?
  15. I need opinions on what this could be??
  16. tranny guage in air vent??
  17. top speed
  18. Tranny cooler in front of A/C, engine temp??
  19. Fluid Level after Cooler install
  20. Trans Temp gauge install
  21. TC and flywheel
  22. auto shifter cable hook up problem plz help
  23. urgent: tc over 3400 is bad!! PCM??
  24. TCS t/c
  25. Bigger TC bad for tranny?
  26. Vibs felt in drive only
  27. Can someone give me an opinion on this
  28. Vigilante 3200
  29. ???????????????
  30. Best prices on extremeduty 4L65E parts?
  31. SS4000 or PT 4000?
  32. Not shifting to OD
  33. what the hell is rattling
  34. Can you spray with a YPT4400?
  35. Going from a Vig 2800 to a Yank SS 3600 help?
  36. Speed Inc. Pure Evil Tranny feedback wanted.
  37. Transbrake on a 200-4R
  38. question from a manual guy
  39. Traction Control vs Torque Management
  40. 4L80E problems
  41. Need Help! Won't Idle...Transmission Related???
  42. Tranny Cooler Size
  43. 02 owners, TCI 3500?
  44. Changing from Vig 2800 to TCI 4400
  45. 4L60E Checkballs
  46. tci converters what you guys think?
  47. torque "dip" and optimum shift points
  48. any tc out there that wont destroy mpg?
  49. Fluid change
  50. tool for pump?
  51. TCi 3500 to Yank 4000 gains??
  52. Anybody put a non lock up converter in a 4L60E?
  53. does locking a TC based on MPH hurt performance?
  54. What size converter? Supercharged
  55. BMR now offers Trans K-member for 4L80E conversion!!
  56. What trans temp are u getting with Yank SS400?
  57. what do codes mean?
  58. And why is my tranny fluid turning purple?
  59. Trans temp gauge help.
  60. drivetrain clunk is it normal?
  61. trans slipping?
  62. new torque converter
  63. Is 3000 stall too low?
  64. Wait!! I use less throttle after SSF3500 stall?? HUH
  65. 4L60E TC's Diffrent???
  66. Turbo 400
  67. SES P1870 and my converter doesn't seem to lock?
  68. Convertor choice for H/C and 150 Shot.
  69. SSF 3500 guys inside.Got Q Im going to the track soon.
  70. installing my ssf3500 tomorrow
  71. Paging Kevin Winstead @ Tci
  72. why wont it shift right away WOT??
  73. Finally I Feel At Home Here...blown Tranny
  74. stupid question
  75. Need suggestion with 4L60E from my LT1 into my 00' LS1.
  76. temp gauge installed....question?
  77. 4l60e/Powerglide swap crossmember
  78. Transmission slips only when TC locked... tranny or TC problem?
  79. What size converter for a daily driven camaro.
  80. Yank email address not working
  81. How big of a stall?
  82. vig 3200 guys with tuning...come on in
  83. Driveing in 2 past 55mph Im I in trouble?
  84. tcs converter..six mounting lugs??
  85. Yank's ultimate drag converter?
  86. Where to get Transgo, Vette servo, accumulator, etc.
  87. Hard/quick shifts. WTF?
  88. Why is 3rd gear so long?
  89. shift kit, yea or na?
  90. TH350-What converter for LS1 with LS6 cam
  91. TCC lock during shift question?
  92. question about flashing a stall..?
  93. trans after cam install
  94. Anybody buy a PTC converter?
  95. SES codes and idle surge after PT4400 install..
  96. installing ssf3500. keep 4.10 or drop to 3.23
  97. 4L80E? Or anything strong
  98. weak tq numbers, 3500 stall/bolt on guys, what did you dyno?
  99. SSF 3500 went in yesterday......LOTS of info inside
  100. Stall question?
  101. What's the best value in converter right now?
  102. Yank SS4000 vs SS4000E what's the diff?
  103. help w/4l80 yank converter/flywheel issue
  104. 2 Torque Converter bolts sripped????? I need help asap PLEASE
  105. Shift knob for stock 4l60e shifter?
  106. Look Ma - no dipstick tube from factory?
  107. everyone who knos about converters please help
  108. What makes an 8 inch converter unstreetable?
  109. "Catch Can" to solve venting problem? Anyone done this?
  110. Jiffy Boob - cooked slush box?
  111. New C7 vette - sealed slush box
  112. Misfire/knock from a 3600 stall???
  113. Filling a sealed auto tranny??
  114. Converter choice. HELP!!
  115. ss3600 vs viper in video section
  116. Best Way To Raise Line Pressure
  117. What fluid to use and where to get a cooler at
  118. Changing a converter on a Vette...
  119. Problems ? within
  120. PG w/ LS1??
  121. loud "clunk" sound from under car
  122. Ordering TC soon: Vig or Yank
  123. From:Vig3200 to Midwest4000 to Yank PT4400 impressions
  124. 4L60E Converters
  125. 200-4R Converters the same as 4L60E?
  126. trans is starting to run hot.....
  127. connect t-cooler to radiator??
  128. Found Problem with 4L60
  129. Tci4400 Vs Pt4000
  130. dowel pins came off with tranny
  131. Tranmission problems
  132. How much RWHP before the stock 4l60e goes boom?
  133. 1-2 Late Shift
  134. When to switch to OD
  135. 4L60E rebuild.
  136. Should output shaft have play?
  137. TCI SSF 3500 40 meg video "City driving" as promised.
  138. tranny overheat please help !!!
  139. Is this common with 3.73's and a 3600+ stall?
  140. Question on backing a converter off the motor?
  141. Not sure about this.
  142. Need help: braided line, AN fitting parts list
  143. locking crankshaft for converter
  144. vig3200 guys come on in!
  145. Troublesome Trickshift?
  146. Can a tranny cooler get hot?
  147. TransGo Shift Kit
  148. Need Help with trans problem!!!!
  149. a4 tranny having problems with stall
  150. stall w/o shift kit?
  151. NFG to the whoel conveter thing
  152. TCI 3500 problems help!
  153. Tc and 60's..
  154. VIG guys inside plz
  155. B@M Tranny cooler w/fan @ thermostat, need wiring instructions.
  156. Rattle/Ting From Under The Car, Any Ideas?
  157. Torque Coverter-new cam?
  158. POS tranny stuck, can't break loose
  159. tranny rebuild
  160. Alternative Tranny Cooler
  161. Torque management deleted...?
  162. Convertor Adapter.
  163. Just finished swap VIG3800 to YTP4200.
  164. help ASAP: Tranny lines; reverse thread or not?
  165. TH350 Torque converters: LT1 != LS1
  166. Permacool Install What A Pain!
  167. TT3000 is locking and locking on 1 to 2 and 3 to 4 upshift...
  168. Converter locking, unlocking, locking, unlocking
  169. 2-3 shift problem
  170. TruCool or B&M Transmission coolers?
  171. TH400 Swap -Fact page??
  172. Rear end, gear questions
  173. Counting the cost:
  174. Converter Lock-Up?
  175. Converter came loose?
  176. Transbrake
  177. why not the 200-4R instead of the pop TH400?
  178. Shift extension of the Yank TP series....
  179. A4 c5 will not WOT shift after 3.15 gear and P1870 code
  180. Altering Shift Points for 4L60E
  181. 4L60E wont shift into 2nd
  182. TCI tranny (Street Fighter 4L60E)
  183. Desired shift time...
  184. Converter Choice Help!!!!!
  185. What size transcooler and where to mount it
  186. Who has decent prices on 4000 up converters??
  187. can i fit another cooler?
  188. No shift on WOT
  189. Hesitation in 1st gear start?
  190. Should I swap from T-56 to 4L60E
  191. well crap my flywheel is cracked
  192. TC for daily driving, hot weather & heavy caprice
  193. Coverters??
  194. who makes a driveshaft for an m6 to th400 conversion?
  195. precision Industries
  196. Tranny help
  197. Trans temp sender
  198. converter with t-rex cam?
  199. which converter
  200. ST3500 vs. PT4200
  201. how to m ake an A4 shift quicker and crisper
  202. SS3800 Doubters, come on in
  203. am i forgetting anything
  204. fast question
  205. Any Good Allison trans Tips!!!
  206. Just installed a TCI 3500 need some help
  207. TC: how much power??
  208. A couple of ? for those switched from low stall to a higher stall
  209. Help with M6 to TH400 Swap
  210. Speedo hookup from manual to 200r4??
  211. Paint cure smell ?
  212. help with verter choise
  213. Powerglide dipstick
  214. Driving a higher STALL converter description
  215. M6 guy asking an A4 question... long
  216. Tranny Flushing??
  217. Locking up PT4400 in 3rd gear
  218. output shaft play
  219. checking tq converter
  220. Who has a TCI Comp 4000?
  221. SSF3500 good for nitrous?
  222. what is the stall on a stock converter
  223. TransGo Problem
  224. Anyone heard of or use this transmission?
  225. FLP = Serious Customer Service
  226. 4l60e
  227. F/S Built 4L60E
  228. Quick question on convertors....
  229. tranny clinking
  230. which converter / anyone with a converter
  231. Fresh rebuilt 4L60E has a "whine"..??
  232. nitrous and converter balooning
  233. TC question
  234. Help! Anybody know stock shift points in 99A T/A?
  235. help, quick
  236. Anyone run Maual VB 400 and NO shift lite?
  237. Car won't take off after cam
  238. H/C plus 150 shot w/3.73's - Which TC?
  239. LT1 4L60E into a LS1 ?
  240. changing trans fluid ?
  241. Going back to stock conveter with a cam?
  242. tranny rebuild... again
  243. Who has NOT had problems w/ 4L60E?
  244. A4 diagram
  245. Coming shortly: A video of the TCI SSF 3500
  246. who builds the best 4L60E??
  247. Corvette Transmission
  248. Shift Kits?????
  249. diff questions
  250. Is the Trans Go Shift Kit worth it????
