- stall and gear combinations
- What do you think???
- Installing converter in 98 T/A
- Trex cam and Vacuum Modultor??
- which gear with 3000tci stall
- 2.73's and big stalls? (4000+)
- Shifter Help
- [B]Tuning or Trans??[/B]
- Tranny says KKKLUNKKK!!
- Please Help a Newbie Understand What the Stator Number Means
- Which converter do you prefer and why?
- gm 6 speed auto ????
- Please help with simple problem!
- 4L65E Information??? My trans went out on me ;(
- What gains going from 3.23 to 4.10 in a4
- ShiftPlus
- Flexplate breakdown information.....
- What's involved for LS1/Turbo 400 hook up?
- TRANSGO -features!!!!!
- 70R4 Questions
- Granatelli Trans Tuner
- Neal converters?
- F-Body transmission in a C5????
- Am I running the right converter???
- 4L60E shift solenoid question
- Main input hub, stronger available??????/
- Stall suggestions please
- torque converter q'sss
- Can't keep 3rd gear!
- Advice on stall speed
- Trans. Problem!!!!!!!
- wheres cheapest 3200 vigilante converter
- Getting Trans Rebuilt, TransGo Shift Kit, any suggestions?
- Difference between Overdrive/Drive
- ? for non-locking converter guys
- Please Read.
- Vig 3600 to SS4000 swap done,WOW
- Newbe auto shifter question
- What converter should I get?
- burnout
- shifting ques.
- Those Mostly street drivers with a TC come in
- need help ....please
- gauging interest in A4 to M6 swap
- need help with th350 swap
- Time for a Tranny,Suggestions??
- But it isn't a manual! How to shut up fools?
- What else?
- Uninstalled 4L60e takes a dump in the floor...suggestions?
- trans convertion
- what's next?
- What stalls / converters to avoid with an 02?
- Trans Flush, A Bad Thing???
- B&M Shift Kit questions!!
- Gas Mileage Poll!
- Gonna order Transgo. Need some help.
- Belt sqealing when comming off WOT
- Is my Tranny broken?????
- Question about TCI ssf3500??
- Transbrake and Fluid change??
- Torque converter rebuild
- Stall And other opinions please!
- when will i lock-up?
- anything else?
- Launching with a TCI 4400..
- What gains w/SY3500 and 3.73's
- Dyno The Bird TC Question
- Is my tranny hosed?
- HELP - WTF is that noise from under my car???
- 3200 Vigi to 4200 YTP swap impressions
- Tci Th400 ?
- Does anyone have a parts breakdown or service manual for the 4L60E (PDF or Graphics)
- T56 vs 4L60E size
- Transmission Life and High Stalls
- Need help ASAP! What are the Torque Wrench specs for a fliud and filter change?!
- 4l60e not shifting right
- Converter Recomendations
- FLP Trans life
- turbo 400 flywheel
- 700R4 Torque Converter HELP.
- 700r4/4l60
- Converter installation....almost there, but 1 question...
- What stall with a4 and 3.73's
- transmission not shifting
- Car doesnt shift hard??
- is vig converters purple?
- 4L60/e versus 700R4
- Can you explain somthing to me plzz
- 4L80E differences...
- will an ls1 4l60e fit into my 94 4.3l s10 4x4(auto)?
- times with my pt4400
- Vacuum modulated line pressure
- High Stall TC
- install questions
- To flush or not to flush!!
- Transgo shiftkit setting?
- what parts for a refresh
- locked/unlocked dyno numbers...how big of a difference?
- Anyone Near Houston that will do 4L60E to 4L80 Swap?
- just got my vig3200
- 4L60E manuals?
- factory TC
- Torque Drive & 5 Pinion Planetaries & other ?
- electronic shifting?
- 4L60-E dead again
- O.K., now what?
- how to get the shift handle off of auto?????
- 4L60E Parts
- monster motorsports 4L60E??????
- Thinking about a new 4L60E? Go with FLP!
- Synthetic transmission fluid??!!
- I have no reverse after shift kit install.
- What do you think about this combo.?
- Drivetrain Vibration!?!
- m6 to auto swap, what do I need to know?
- What STR?
- Need Help!!!!!
- Which TH400? (Yank, Rossler, Coan, etc...)
- transmission problems?
- 4l80e planatery gears
- my troublesome 4L60E
- Any tips/tricks or ideas for trans fluid reading?
- 4l60e rebuild kit which one
- M6 console in an a4 car
- PY3600E and TransGo install questions
- MIDWEST T-Cs
- SS3800...what gears?
- 4400 Stall ?s
- driving with a stall
- Few pics of my trans rebuild
- Bellhousing bolts torque spec ?
- 4L60E...450 lb-ft?
- This Might Sound Really Stupid
- yank sportsman pro tranny
- lock up switch?
- trans-temp guage??
- Yank SS4000E finally installed!
- TCI 3800 Props to Kevin winstead (TCI)
- Stock Converter bolts???
- Hughes Performance
- What TC for H/C and TNT 100-150 shot?
- Shift Solenoid Code?????
- Witch clutches are better blue plate or alto red
- To Transgo or No
- Need shift points for a TCI 3500 w/ 3.42's
- Doin a th400 in a 4l60E
- tuning a vig3200
- with my Vig3200.....
- Need new transmission or what??
- New converter Long trip No Tranny Cooler Question
- powerbrake
- How to change TCC lockup speed with edit
- Racing an automatic
- T/C in,now tranny slips.
- Delted Torque Management wiped 1-2 in my trans only basic bolt-ons
- When did GM start using Corvette servo in A4?
- how much power
- Yank PT 4000
- Coan Convertor
- Converter Shaking - Help
- Converter very hard to turn (4L60E)
- transgo kit a must?
- whats the most streetable??
- question on durability
- Help, Input shaft restrictor
- Yank SS3600/SS3800 VS. TCI SSF3500/3800, and a gear choice question...
- 4l60e to th350 swap
- transgo and servos
- TCS 4200 converter questions inside?
- Which line off the radiator goes to cooler?
- Help-tranny slipping and shuddering?
- alignment, engine oil, trans. oil, and wax the car!!
- TCI vs. YANK
- transgo help
- 4l60e Vs. 4l80e
- How to launch with a pt4000
- A4 Blues; What's broke?
- How are activating your transbrake/nitrous?
- Case is not cracked Whoohooo!
- M6 to Auto?
- ? for TH400 guys
- A4 torque converter newbie questions:
- I need emergency help
- Fluid from the front of the differential
- Nitrous and converter help.
- upgraded parts, worth it?
- Skip shift delete
- How long will stock auto hold up?
- How much will this help?
- gains from a SSF 3500?
- going from tcs 3500 to a vig 4400 what kind of times
- COMMENTS ON THE B&M trans pack
- friend installed flywheel backwards on his 93 vette, what can be done?
- A4 or M6 on Z28 - what is most fun to drive??
- WS6 guys...
- Help Funky Sound from TQ Converter
- B&M shift improver?
- 11 sec n/a stock internal question
- Problems after 3200 Vig and Gears
- Fastener sizes for TQ Converter and Flexplate
- How much power can it take
- Help on what size TC
- Need information on th400 please
- Driveline free-play 'clunk'.
- Anyone Get a trans from here
- From 3600 Vig to SS4000 Gains?
- What gears do I have?
- Anyone running a 4L80-E?
- What cooler for dope style install?
- What torque convertor?
- 2800 vigilante
- Hard clank from under my car???
- TC Installation
- Need to know whats leaking
- Need help about swapping transmission
- Anybody running a Quicksilver?
- What is the great size for street and…?
- Mail order tuning and Shift/Lock up points
- Street racing i think i have a problem
- Can you lockup a SS4000 at WOT and is it ok to do so?
- Intalling TC
- Looking for input gear/convertor
- Installing Torque Converter
- Are all billet servo's created equal?
- down shifting
- How do you remove the 4L60E dipsick tube?
- Does this sound like a tranny problem???? please help!!
- spraying a built 4L60E?
- Track results inside w/the new setup, but something isnt right. Please help!
- 4l60e cooler lines, what is thread....
- Need help from TCI ssf3500 users
- Yank 4l60E
- Having trouble with new converter!Please help
- how much for this tranny
- Need to get part throtlte shifting right with 3.23s->4.10s
- Vig 4400 stall a good product?
- Lost 2nd gear only--possible cause?
- thoughts on using type-F fluid AND shift kit?
- Tranny Modding Advice
- Raising shift points in my A4
- Just put my converter in. Is this normal?
- To everyone that's ordered a TCI stall from Texas-Speed
- Tranny skipping gears
- 3500 stall users inside please. Lockup Q.
- Turbo LS1 4l60e
- wont 2-3 shift at WOT
- is it safe to...
- 4000 stall, no TCS, wet roads??
- Tranny cooler for SS3600?
- 4.10 gear, and the 1 to 2 shift is too harsh
