View Full Version : Automatic Transmission
  1. Yank 4l60E
  2. Having trouble with new converter!Please help
  3. how much for this tranny
  4. Need to get part throtlte shifting right with 3.23s->4.10s
  5. Vig 4400 stall a good product?
  6. Lost 2nd gear only--possible cause?
  7. thoughts on using type-F fluid AND shift kit?
  8. Tranny Modding Advice
  9. Raising shift points in my A4
  10. Just put my converter in. Is this normal?
  11. To everyone that's ordered a TCI stall from Texas-Speed
  12. Tranny skipping gears
  13. 3500 stall users inside please. Lockup Q.
  14. Turbo LS1 4l60e
  15. wont 2-3 shift at WOT
  16. is it safe to...
  17. 4000 stall, no TCS, wet roads??
  18. Tranny cooler for SS3600?
  19. 4.10 gear, and the 1 to 2 shift is too harsh
  20. 1700 rpm at 55 in OD w/200-4R, 3.42s, & Yank SS4000, does that sound right?
  21. Traction Control Reversal Module
  22. just got new tranny installed
  23. Shift kit?
  24. What size stall can I run on street tires with 3:23's?
  25. TC Advice
  26. 3600 vigilante and hooker Lt's going in hp gain?
  27. Need serious help!
  28. Death Knell for my trans?
  29. rearend gear ratio
  30. What Temperature SHould the Tranny Run On Average?
  31. Reprogram computer for Converter?
  32. Those with 4000+ stall on daily drivers
  33. deep trans pan or not?
  34. new ray bestos z pak ???
  35. SS3600/3800 with stage 1 tranny
  36. Help with TC Lockup Switch
  37. PT4000: 3.23's vs. 3.73's
  38. wut stall to buy
  39. Blinking SES
  40. Tranny question
  41. how much for shift kit installed
  42. Tranny or Rear?
  43. any advice for trans. cooler install w/high cap. radiator?
  44. Should I "break in" the stall?
  45. Aftermarket converters eat up hp??
  46. M6 guy needs help w/ A4 w/ stall!!
  47. HP loss with TCI SSF
  48. Trans slipping Help!
  49. LS6 swap
  50. 5th time
  51. 4L60E, 4L80E, or keep T-56
  52. car wont run after th400 and 9 inch swap?
  53. Anyone spraying a tcs 4200
  54. Vig 3200 to a PT4200 results?
  55. When Should the Stall Unlock?
  56. Another Tranny Question
  57. lockup issues on dyno w/ vig 3200
  58. No Over Drive (4th Gear)
  59. FYI- TransGo mag. article
  60. Tt3000???
  61. Dumb lockup question???
  62. Torque converters and Efficiency
  63. Ordered The Tc Today
  64. Which direction should I go.
  65. where is the EPC screen
  66. What stall for a bolt on LT1 car?
  67. Break in Period on a TCI SSF 3500?
  68. Need help with Transgo Install(only got paper instructions)
  69. What would happen if...
  70. Need Help! Please
  71. Mod Marker
  72. Unnable to hold a stall
  73. Questions about a Rossler TH350.
  74. broke a solenoid on tranny need help badly.
  75. Anyone use Royal Purple ATF?
  76. anyone have pics of a B&M pro-stick installed?
  77. Anyone using a Coan coverter?
  78. launching a SSF 3500 on 16" nittos
  79. Roll races...what STR with my VIG 2800???
  80. 4l60e
  81. Who has a YPT in their daily driver?
  82. Trying to understand
  83. Converter ?'s
  84. What the hell is going on with my Z?
  85. is it slipping?
  86. Stock tranny and a PT4400 TC
  87. Big cam and vacuum modulation
  88. What parts for a performance rebuild?
  89. Who sells..
  90. installed built tranny and different converter, now shifts 500 rpms sooner??
  91. The other voices in my head made me ask this question:
  92. Trans Go, TCI 3500 and TM ??????????
  93. TCI street fighter 4l60E
  94. should i change to f type fluid?
  95. WWT: my fresh auto for T56.
  96. Is there a difference in converters?
  97. whats wrong with my tranny
  98. Art CarrTC's
  99. installing LS1 4L60E to a '96 4.3 V6
  100. Converter question
  101. How Much Transmission Fluid Needed?
  102. !@#!# 4l60
  103. Tranny Help!!
  104. th400 cluth engagement wires
  105. Trans removed - Transgo install q's
  106. whats flp charge to install trans?
  107. ????? Auto or manual ?????
  108. trans prob?
  109. New dry converter- loose/clank normal ?
  110. 3000 or 3500 stall?
  111. Vacuum Modulator Line
  112. Performance Automotive and Transmission Center....good , bad, ...?
  113. What is the proper way to launch in an auto?
  114. Why shouldn't I get on it in OD?
  115. tranny mount confusion...
  116. Trans. wouldnt shift into overdrive???
  117. 700R4 on a 99 LS1???
  118. Does a new converter need tuning?
  119. Shift Kit.. Is it a MUST?
  120. Launching with 3.73's & ssf3500
  121. 60' times with pt4400???
  122. which Poly Trany Mount for TH400/BMR Crossmember
  123. Are the converters swappable from a truck to Fbody?
  124. Help
  125. Changing converter, What all is needed.
  126. Best way to change trans fluid
  127. The M6 guy's are gonna kill me.
  128. Will this Cam/Converter Combination Work?
  129. Where to get fittings, braided lines, etc. for B&M 28k GVW tranny cooler?
  130. LS1 Trans dip stick readings...
  131. How Many Qts in a 2000 WS6 Automatic trans?
  132. Trans. Temp. Problems.......
  133. Tranny Life
  134. who has used the yank crossmember?
  135. WOO HOO!! Finaly Here
  136. what the heck is goin on?
  137. guru needed!!!!
  138. convertor install question
  139. TC install
  140. tranny question
  141. in this day & age, customer services counts!!
  142. Built 4l60e
  143. Another satisfied PT4000 owner
  144. Loud "clunk" after Vig and Transgo Install
  145. Accumulator Piston ????
  146. convert 4l60e to 4l65e
  147. Will it be ok not to use a trans. dust/shield?
  148. Need a new tranny
  149. 2-Step in Auto?
  150. Torque converter dyno results from Yank?
  151. Those using the TCI 29.1 SFI approved flexplate, inside please.
  152. OK To Use Type F Trans Fluid?
  153. What Do You Think?? Tci 3500
  154. Tranny Install
  155. th400 users...speedo question
  156. Need Your Advice: '01Z, 3.23, Daily Driver
  157. manual 6spd to automatic 4l60e
  158. Just ordered my Torque Converter
  159. Is there more than 1 way to install a tranny temp. guage?
  160. Transmission Temp. sensor?
  161. 95 v6 car..help
  162. 2500 or 2800
  163. Thoughts about 4L60 & 4L80
  164. M6 to Th350 Swap
  165. Yank Stealth converters
  166. Non f-body trans??
  167. 2 tranny coolers
  168. what gears, shift kit?
  169. Stock Gear Ratio A4???
  170. Trans. Temp?????
  171. A good deal?
  172. SFI Flexplate available for LS1/Th400 ?
  173. 3.4' gears
  174. HVAC controlls stopped working?
  175. Is it Tough to Install a shift Kit?
  176. Midwest 4000/ 2.5 str opinions
  177. What caused all this?
  178. Converter stall and brake stall?
  179. what converter will i need
  180. th400 swap questions
  181. About to spend $1500 and need some advice
  182. 4l60e and 10s
  183. What is wrong with my transmission (A4)? Is it about to go boom?
  184. what about this kit?
  185. Who sells a built 2004R for 4 Gen fbodies?
  186. Stall converter on daily driver?
  187. 4L80E Swap?
  188. How streetable?
  189. Just Ordered My Tci 3500 Today
  190. Which tranny cooler should I get?
  191. yank SS 3800 on stock
  192. Torque converter?
  193. SS3600 or SS3800
  194. TransGo PSK vs HP kits? (quick q)
  195. Anyone else sparying with a ssf3500?
  196. lightweight th400 vs th350
  197. 3500 too high for me.
  198. Vig 2800 to Vig 3200
  199. Best TC for my 2002 Z28
  200. Pics of Tranny Coolers installed pease
  201. how do i fix this problem ???
  202. Leaking 4l60e, bad news?
  203. Neutral Saftety Switch problem (A4 to TH350)
  204. TCI Flexplate With yank?
  205. Whats the best material to use for the lines on the tranny cooler?
  206. Those that are in the process or thinking about doing a 200-4R conversion...
  207. Do any 4th gen 4L60E's lockup at wot without a switch?
  208. How 2 disable neutral safety switch, wire up back up lights, & wire up lockup switch?
  209. How long do you think your A4 will last
  210. 4th gone, 3rd kinda gone?
  211. tranny slippin???
  212. Changing Vig Converter
  213. Does TCI make a 4400 converter too?
  214. Planetary damage?
  215. what hapens if your lock up clutch slips and how much can it take?
  216. What tranny in old turbo ta's???
  217. will 3.73's alleviate verter looseness???
  218. ssf 3500 or ssf 3800
  219. Th400 users?
  220. SS 3600 or 3800 with moderate cam ?
  221. Changing my setup & need some input (Colonel)
  222. Proper shift extension drop in between gear?
  223. what rpm
  224. http://www.fbodytrans.com Tranny
  225. Pro Ratchet Install with M6 console
  226. which yank 4 me or anything else
  227. how about this setup?
  228. Going from 4000 to 4400 stall?
  229. Is Tuning Needed after a TC install?
  230. M6 to T400..gear selection
  231. Tranny Dying, Converter flush?
  232. Opinions on TCI Competition 3800
  233. Burned tranny cause odd running?
  234. Best Automatic Transmission Fluid?
  235. Derty,Raugh or Steve
  236. Tcc Lock Up Help
  237. TH400's
  238. The conversion has begun! I have a few questions.
  239. Anyone know weights of different TCs?
  240. will a 3200 tc shorten the tranny life
  241. Which tranny to get?
  242. Tranny Mount
  243. Poly mount vs stock mount
  244. Guys that got gears after converter-come in.
  245. Converter selection help for a oddball car
  246. ok to mix atf brands?
  247. Paging Derty: info about th400
  248. 4L80E Manual Valve Body
  249. everyday?
  250. Cam in stock 4l60e tranny...
