- Which IS the right Torque Convertor?
- tc?
- Where to get an 4L60E
- PT4000 2.7 vs. SS4000 2.6
- Torque Converter & TransGo Shift Kit (long)
- Tranny Cooler Line Size
- which stall to get?
- Does the tranny shift at MPH or RPM in OD?
- TCI Flexplate or stay stock?
- YPT selection 4000 - 4600?
- SS3600 and everyday driving?
- Dyno questions with a stall
- Tranny slipping up high
- Moderator Announcements: Raughammer and Derty are now in this forum
- Will a VIG 3200 out of my 2002 Trans am work in a C5?
- Is the '99 4L60E any good?
- Which Tranny Fluid?
- Need Help chosing Converter
- Torque Converter installation...
- Article about 4L65E in Super Chevy!
- shift pts with heads & cam?
- curious about tuning
- Paddle Shifter on Steering Wheel
- Needing some converter info/autotap results
- Anyone sprating a Vig Multidisc, from 3000 to 4000 stall????
- The new 4L65E
- could 1le mount change pinion angle...?
- console
- Did i choose the right converter for my setup?
- Tci3800
- tci3500?
- Vig 3600
- Anyone ever dyno there cars before and after a TH400 swap?
- What size Hex head on stock converter bolts.
- TCI 3500 acting strange.....im lost
- Do I really have a Midwest 3400?
- Rearend gears in automatics
- B&M cooler question
- Where to get Tranny Mount?
- new trans, new problem
- Restalling a Vigi 2800
- JW reccomends a TH400
- Easy Quicky
- tranny conversion questoins
- trans trouble
- a4 sliping?
- P0751 code after FLP install can I delete it?
- stall ?'s
- Fluid level
- ? Upshifting after downshifting problem?
- Is this mod safe??
- People running TH350 or TH400???/
- FLP LVL IV Vacuum Mod Help
- Hee guys, need help quick...
- Vig 2800...
- anyone running
- what happens when...
- looking for more opinions on what to base shift points on, torque or horsepower
- Tci Ssf 3800
- what is the "stall" on this converter? (chart)
- To TH350 or not
- Need help picking T/C for my application...
- Pt4000 2.7
- Is this normal?
- Vig 3200 question???
- non gm automatic tranny questin i really need some help
- Want more mph(more efficient convertor)
- Broke tailshaft housing on dyno. Any consensus on solution
- Any Yank PT dyno graphs?
- Opinion on TCI converter...for TH400
- 4L60E Dies Again
- R is N, P is R
- Shifting out of Park
- Crossmember for TH350
- Trying not to have a "forsale" add about it but..
- Ultrabell Works!
- 200-4R converter and stall opinions needed
- Turbo conv input...
- 4L80E Discussion
- will converter benefit me on freeway run
- Opinions on ATI Transmissions?
- length of driveshaft with th400 and 9 inch
- Need Info. Please!!
- 4L60 down, need input
- Shifter Changes
- i think yank missed the mark on my stall, got some questions.
- Need HELP ASAP!
- ss4000, is it spray worthy!
- ratios
- Tranny cooler??
- Killed my first 4L60E :(
- Vigilante Multidisc users...need input
- converter question
- Spraying a PT4200...
- T56 to TH400 conversion
- 700r4 to th350
- is it worth spraying my st-4000?
- Tranny pros HELP!
- Anyone try a Lenko
- A4
- SS4000 Driving impressions
- tapping sound
- N2O Stall....
- Tranny Swap
- Is there a difference reg/nos/super t/c
- i need stroonger 1, 2 and 3 shifts
- New TCI SSF3500...Is this normal???
- 200-4r
- how well does the 200r...
- external precautions to extend tranny life?
- MidWest TC vs Others
- How tight can you restall a 9 inch converter?
- Transmission Cooler
- Transmission experts please advise on tow/haul mode.
- Factory tranny cooler lines question
- Paging Texas Speed
- Lockup Control
- 4L65E/LS6 questions?
- LT1 TC on A LS1 4l60e
- B&M Shift Plus Shift Improver for 1993-98 4L60E
- What should i do?
- rant
- PCM pressure learn?
- Better 60 ft. times...
- 4L60E F body Flexplates
- Tranny size?
- Need Advice!
- Shift kits?
- Anyone have dyno#'s before and after TC install
- no start?
- 6 speed auto
- Anyone running the Yank PT4200?
- need a 700-r4
- DR's required for a converter?
- gear install
- Where can a tranny leak from?
- SS4000 users inside please.
- How much does a 4L60E weigh?
- Anyone have a part number...
- Need Help Fast Please with New Torque Converter
- Dynoed w/ PT4400...What happened?
- 700r4
- Tranny rebuild
- where to purchase the ssf3500?
- Asking for trouble?
- I need some advice
- Need Transgo help ASAP!
- Which Trans Mount?
- 4L65-E in the C6
- what to rev a pt4400 at?
- 4l80e question?
- shift points on a 3500 tci
- Comparing Speed Inc Level 2, Level 3 and FLP Level 4 transmissions.
- Vacuum modulated shifts vs computer controlled
- transmission shift kit
- Those with aftermarket converters...
- Does TCI Charge to Restall a Converter?
- hurst cable and bm shifter
- shirfter cable??
- Question from new guy on trans
- tranny not shifting into 3rd at track
- 2000 Camaro SS
- How are such high stall converters these days pulling such good gas mileage?
- I need better 60ft's?
- B&M shifter adjust
- Trans mount? Poly Trans?
- speedo prob
- Where is the Link to Dope Tran cooler install
- TCS Phoenix Super Pro = what exactly?
- stock shifter sucks...please help me....
- Need a little advise. What would U do?
- help w/puttin lines back on!!!
- th400 conversion? Converter suggestions?
- Brake stall vs. loading clutch w/ line lock.
- Stall guys...when do you want Lockup??
- anyone ???????????
- 3000 or 3500 tci stall
- Will Yank come out with diffrent converters 04?
- Dope Tranny Cooler Install
- finding transmission manufacture date?
- transmission oil change?
- Has anyone ever done this?
- Transmission fluid change
- HP loss between th400 and 4l60e?
- anyone know what gears are in diff transmissions?
- HP Lost Due to Stall?
- Best tranny for...
- Torque Management?
- Torque Converters!
- Local flush or send converter back to Yank??
- 4l60e
- who makes the strongest 4l60e???
- What's involved on converting an M6 to an A4?
- How to properly measure driveshaft length?
- Problem with AL driveshaft
- Sloppy 2 to 3rd shift
- Any body with a manual shift
- 4L60E shifter
- Convertor / Transmission Combo
- 1st impressions of TCI SSF 3800
- 4L60E pressure regulator boost valve?
- Trans shifting into 2nd after cam install???
- Which converter???
- Specs on a PT4400 made on 3/02?
- how do you get the a4 shifter knob off?
- lt1 stall into an ls1
- TCI SSF3500 Converter
- tranny removal tips?
- TCI Street Fighter or Super Street fighter?
- 4000+ stall owners...Need tuning advice
- tc plug?
- 2-3 Shift Solenoid?
- Car hesitates after WOT shifts
- Concerned about A4 after being rearended
- Installing Tranny Cooler...
- A-4 has flywheel or flexplate
- SY3500 or SS3500 ?
- SS4000E, TCI SFI Flexplate, Yank Crossmember installed.
- Which Tranny Cooler
- Converter advice => TCI SSF3500
- 2nd- 3rd shift???
- PT4400, worth the money?
- Question about tow/haul mode
- TCI shift kit question?
- Tranny cooler install pictures?
- Midwest 3400 w/ 2.0 str w/ 3.42 gears
- Finally figured out what was wrong
- yank tq. thruster 2800
- Difficulty shifting A4 out of park
- early shifting with converter?
- Is there a break-in period for an automatic transmission?
- Upgrade for Tq Arm mount Braket ( Clam Shell )
- No WOT Downshift from 3rd
- Want info on T-Brake for a 4L60e...
- Cheetah Install?
- Lightweight Flexplate
- tailshaft overdrive
- 4-3 kickdown probs -- Need HELP!!!
- Question for Kevin At TCI.
- A4 to Turbo 350/400 How to wire Neutral Safety Switch?
- FTRA and Tranny Cooler
- flywheel?
- how much power can a stock 4l80e take with just a shift kit?
- What converters are green?
- Trans experts, give your thoughts on this (WOT downshifting)...
- 2-3 shift not right
- Received SS4000 today!!! I have a few questions.
- Trans. Temp. 2: dual coolers or big single?
- I searched....how to check tranny fluid level a4
- how to determine the stall of a converter?
