- Anybody know of a better input sprag???
- Th-400 W Brake And Extras
- whistling/whining sound
- Aftermarket TC's are the only way to go with an A4.
- Small problem w/ TCI 3800
- tired of this shitty A4, what about a th350
- FINAL ANSWER...Which trans cooler line is return?
- Who has busted a 10 bolt and what did you have?
- SS4000 drivability v/s TCI 3500 within!...
- Do I have a bad converter or ...
- Manual Torque Convertor Lock Up Switch
- Those that have converter from an M6, did you install park lock?
- Tci Ss 3500?
- Installing Yank, have question about flywheel????
- need a4 to th400 wiring help
- Stock Tranny Cooler
- B & M Shift Plus
- Where to find TCI shift kit online?
- anyone ever change the gears of a 4L60E?
- trans cooler part # to use with ftra
- Would you switch A4 to manual tranny if you could and if you had a 427 C5R motor?
- If you had a big HP 427 LS6 C5R motor would you convert to stick if you had a A4?
- Front pump blew out
- Which AN fittings and hose to use for trans cooler
- How is your Turbo 350 holding up?
- Best MPH'in Yank Converter??????
- Did I receive the correct pedal assembly?
- Got my upgrade A4 upgrade parts
- TCI or Vig
- Installation cost
- Converter Lockup?
- 4L60E Question...
- Trans Mount?
- Transgo shift kit ?
- Any Converter Swap How To's???
- What converter for a 400hp lt1?
- Update on Yank PS Series???
- a4 experts inside plz...
- 4L60E rebuilt
- building a TH400 what do i need
- New trans for my conversion?
- FbodyTrans.com
- TH400 driveshaft length????
- torque convert problems
- To Much Stall?
- tranny vibration
- Speedometer Gears
- bmr th400 cross member info
- Help with E-clips on 4l60e
- Daily driver 20,000 miles a year. What converter?
- Why Does my car Suck from a roll?
- Vibration
- Yank converters, so many series, how to choose?
- 2-step use without a T-brake
- How long does a 4L60E last?
- LS1 and LT1 Converters
- What one to get?
- Are you thinking about a converter?
- i have searched, help with TH350 speedo
- Shift kit for an auto?
- broke flywheel ??!!
- Fabbing TH350 Crossmember from M6 piece
- tq
- TCI shift kit initial thoughs
- to big of a stall???
- TCI custom 3200 track results
- A4 swap it or keep it
- diameter of 98+ VSS sensor
- Torque Converter ??
- just ordered at Yank SS 3800
- A4 Brake Pedal Assembly, Pt. 2
- Tuning after stall swap
- TH350 without adaptor plate?
- filter replacement procedure
- Need help clearing something up
- Car bucks/surges in OD?
- Manually Locking Converter Question, Not The Usual Though...
- Highway rpm w/3.73's?
- Friend of mine wants TCI 3000 2.1 str
- Modified Torque convertor
- Where to mount tranny cooler?
- Shift kit install and help please
- Please Help Shift kit
- Which A4 tranny for 700 rwhp?
- Problem, Please Help! With A4!!!!!
- Welcome to last month.
- Need break down of an automatic in terms of the shifter.
- question about STR
- what would it cost to make my m6 an auto?
- New tranny, new problem
- vig install gone awry
- do i need to go bigger(TC)
- Converter help
- Stall questions
- How do I know if I need a higher stall converter
- My car has a vibration @ 70 mph
- 200-4R users, what dipstick are you using?
- How many of you are running a B&M 28K GVW tranny cooler?
- DIY Mods to increase durability of 4l60E
- Who builds the STRONGEST 4L60E's out there??
- What Converter Next? (Currently TCS PP 3200/2.5)
- TH350 users, what part number for the tranny mount
- TCI converter owners, flash stall or brake stall launch?
- Another stupid question
- 4l60E interchangeable??
- need help with tranny
- Driving in D or OD?
- snap ring pliars?
- A-4 Trouble with the 1 - 2 shift!
- What should I expect?
- Autometer help.
- Vibration in Third
- How/Where to install Electronic Tranny Temp Gauge?
- Anyone have experience with the PT4600
- Would a regular plate type cooler be enough?
- Tranny mount recommendations.
- What is a good maintenance schedule for an ATF change?
- Transmission Swap
- Any write ups on TQ swap on 4L60E
- What converter brand
- Gear selector 3 vs D holding power for 3'rd gear Difference?
- 4L60E information
- GOING IN AND OUT OF LOCKUP
- Torque converter.Is a cam neccesary
- TSP Dyno Results From TCI 3500 Install
- Disconnecting transmission lines...
- Nitrious on a Vig 3600?
- trannies?????
- bigger Stall....
- What Converter for my Heads Cam 150 shot Combo?
- TCI transmission experiences?????
- Help w/ trans temp guage!
- Converter lockup ?
- Yank Pro Stock 4400 results
- Top end w/ SSF 3500
- Converter Problems???
- A4 Stock Tranny + Turbo
- Just installed my TCI SSF
- How many quarts for dry 4L60E w/deep trans pan?
- Will this fit w/o any problems?
- Broke it again
- Is my tranny overheating?
- 4l60e problems.. what to do?
- Everyone with TCS 4200s, please come in
- M6 to 700r4....what drawbacks?
- What size stall?
- would/could a converter get you closer to failing emissions?
- TCI 3500 shift points
- Custom TCI 3200 converter installed
- what is a blown A4 02 tranny worth with 23k miles
- A4 shifter?
- East Side Performance SFI Flexplates
- Precision Industries Rocks!
- A4 trans slipping??
- 98-02 A4 interchangeable?
- Patrick Guerra
- Question for Conveter gurus
- M6 to TH400 swap questions
- Guys with the T400 or T350
- Transmission Mount Nut Part Number?
- 700r4 problem
- Yank Crossmember & Dipstick
- Loud Thump during 1-2 shift
- NE1 using a B&M cooling system? (cooler w/fan)
- Tranny mount questions.
- How to hook up vacuum modulator?
- TCI....are you making a manual 4L60E valvebody??
- Tranny will not downshift manually..................
- TCI break in
- Blew my tranny...what to do?
- Yank ST3500 problems
- vacuum modulated line pressure
- Swapped to T400....now tach won't work
- B&M SHIFT PLUS
- ASM headers
- How long does it take you car to shift after command point ?
- TCI 3500 ??? please help....
- Thinking of swapping from M6 to A4 .. Got Questions
- Please help me decide which tranny & rear gear
- What shift points should i use.
- TCI, is there going to be any upcoming new converters?
- AAARRRGGGG dam 2-3 and 3-4 shift gone...
- TCI Streetfighter 3000
- Installation Price
- WHAT DO I NEED ??
- PT4000 Launching Techniques....I suck...
- Soft Shifts with Converter?
- wrong tailshaft for TH350 swap? (9")
- need help bad trans problem
- Some Trans Questions
- TC in a Stock A4?
- Why not spray a 4000+ stall with a big shot?'s
- Got my TCI shift kit today :)
- Yank Exposed Part II
- HELP.....Grrr tranny or vert or both problems??
- Tranny/ torque convertor problems
- ESP SFI flex plates $139.95
- FS: NEW TH350, converter, and shifter
- Want feedback on Fbody trans.com tranny
- 4L60E Rebuild
- Need help completing the 'list'. M6 to A4
- 3200 pro yank
- where to get tails housing for 4l60e...don't ask :)
- changes for a4 from truck to fbody
- Built 4L60E who makes the best??
- Which trans mount should I go with
- What should i do?
- READ!! Magnaflow cat-back on Suburban Z71 *DELETED*
- WHICH TC AND STALL?
- Yank Exposed *DELETED*
- Shift Kit worth the $$ with Torque Management ???
- best shift kit
- TC from a roll
- Phoenix return?
- Torque Converter is Slipping By 300 RPM: Whats the FIX?
- Thunder Racing
- VIG3600 and 3.73s
- exactly what do you need to swap 3.42's into 2.73 A4
- S3 TCI shift kit on a stock tranny?
- Does Hypertech delete TM?
- 99 LS1 with Th400
- LT1 and LS1 4L60e trannys interchangeable?
- Best place for tranny cooler w/ SSRA?
- 4l80 install
- How did you hook up your tranny cooler
- Tranny exploded at the track.
- 200-4r swap from a 6spd
- New trans and new converter, car does not move in gear?
- what converter with these mods
- SY3500 STR
- 700r4 lock up function only electronics, better right?
- new tranny
- TCI decision
- first trip to track w/PT4000
- ordered my TCI 3500 stall vert last night :)
- what stall with gears?
- 4L60E 3-4 Gone.....AGAIN!!!!
- TCI VS. YANK
- spraying an ss 36-3800 in a truck
- SS, PS, and PT Yank converters. This is what I learned...
- which TCI converter is best for me?
- Question about lock up.
- What gears to run on Yank SS 3800 Stall?
- P0751 1-2 Shift solenoid performance...
- People who know inter workings of the 4l60e inside
- Any problems with Yank TP series?
- GM 4L60E or performance rebuild? *DELETED*
- Converter swap question
- JUST ORDERED A TCI4400
