View Full Version : Automatic Transmission
  1. shift extension question
  2. Baddest verter for 3.23s?
  3. whats wrong?
  4. Need pictures/tips on installing Trans cooler
  5. Who had to shim up their T400? (Using M6 crossmember)
  6. Anyone have the DOPE tranny cooler install?
  7. Vacuum Modulation in 4L60
  8. Looking for the DOPE Tranny cooler install.
  9. differences in single disc and multidisc Vigis..
  10. yank ss3600 or ss3800 for mostly street car???
  11. Adding a magnet to the B&M Deep trans pan.
  12. Difference between SS4000 and PT4000?
  13. Installing Built Trans...What Cooler to go with??!!
  14. what converter
  15. What gains from SY3500 to SS4000?
  16. TCI 3000,3500 guys in here please.
  17. Got my cmotorsports tranny today...
  18. has yank kicked precision back
  19. TCI 3000 or custom? Anyone have these?
  20. Changing transmission fluid...
  21. Shifting quick
  22. Can't get ahold of TCS...?
  23. Shift extensions
  24. brake stall ? please help
  25. What is my stock gear?
  26. Stand alone transmission computer?
  27. has anyone installed a tranny cooler that has its own fan?
  28. Change fluid when?
  29. Convertor question w/ 350,400 or PG to LS1
  30. How do you get the speedo to work with a Turbo 400?
  31. Flexplate install ????'s
  32. How to tell if my tranny is slipping?
  33. put 3200vig in and car shakes like hell ???
  34. New tranny pan?
  35. Convertor for 427
  36. more 4l60 shifting q's
  37. Shifting help
  38. tranny mount?
  39. typical gains from vig 2800?
  40. tci3500 w/3.73
  41. Tranny power loss
  42. Questions about Yank 4l60e crossmember
  43. What the HELL is going on?
  44. 3-4 Clutches Keep Burning up...........????
  45. What converter for 422 and occasional spray
  46. 2.73's and a big stall
  47. Has anybody ever used the SLP 2600 converter ????
  48. flexplate is cracked!
  49. tranny cooler mounting options...
  50. vig 3600 with new cam
  51. is there a way to calculate converter efficiency and STR?
  52. New TCS Tranny is in...Racing tonight!
  53. Results and impressions between TCS 4200 Vs. TCS 4400
  54. 4l80e rocks
  55. Ways to tighten converter with tuning?
  56. Anyone ever mount a Hurst Quarter Stick in our cars.........
  57. 4l60 e prob's
  58. Flywheel lock tool? How to lock flywheel for cam swap
  59. Best "built" 4L60
  60. shift kit
  61. Ford tranny in an F body???????
  62. Only cutting 1.8's, new converter or gears?
  63. Tbyrne stall converters group purchase
  64. what to use on big hp c5 for a trans
  65. Converter questions
  66. Transgo and B&M
  67. Busted Tranny mount?
  68. 97 z28 camaro
  69. How much RWHP will you lose with 27% converter slippage?
  70. No go in 4L60E
  71. Stall convertor ????
  72. Dyno on n20 shows much higher rpm vs speed than N/A???
  73. converter w/ cam
  74. Tranny chattering on decel
  75. what do i need to switch from a4 to th350
  76. HPP3 and edit ?'s
  77. DTC P0751
  78. Would I need tuning with a TCI 3500
  79. TH 400 converter
  80. High Voltage in Tranny (HELP)
  81. Stall speed Changed by torque?
  82. Why does the dyno graph with a Vig 3600 have a flat line?
  83. Upgrading to a SS36/3800 from a Vig 3600? worth it?
  84. 2-3 shift problem
  85. TCI Super Street Fighter 3500
  86. Whats it worth?
  87. hpp3
  88. TH350 vs TH400
  89. How bad is this: Converter Cycling?
  90. 99 M6ta swap to a 98camaroauto swap Q
  91. Flywheel Question??
  92. Vibration in 3rd
  93. Help me pick a converter for the new combo :)
  94. First impressions of my new Vigilante 3200
  95. won't kick down after gear swap
  96. Valvoline "MaxLife" ATF - better than standard?
  97. tranny swap, pinched a wire
  98. tranny swap
  99. whos got a pt4400 in a daily driver?
  100. Who here has had great luck with speed inc stage 2 or 3 4l60
  101. 1998 ta 4l60e problems
  102. Best fluid for a race T400?
  103. Just ordered a TCS Phoenix 4000 Converter
  104. Post Up,Pros/Cons, How Well Your Built A4 is Working
  105. LS1 SFI Approved Flexplates IN STOCK!!
  106. B&M Hi-Tek: Cooling system vs. Super coolers
  107. Anyone know a convert brand/model that stalls to 5000+
  108. Help!! Somthing is wrong with my A4!
  109. PO757?
  110. stock 4l60E how much hp?
  111. first impressions of TCS 3800
  112. NEED HELP WITH SHIFT POINTS (USING PREDATOR)
  113. what speed in each gear ?
  114. First time to track with PT4400
  115. 4L60-E with 3.23's
  116. Torque Converter
  117. Vig problem maybe??
  118. Is it a good idea to use mobil 1 atf in our transmissions?
  119. Where to order?
  120. To those that have converted from an M6 to an A4.
  121. Need Help with TH400
  122. th400 with od?
  123. Help Picking Stall speed(TH350)
  124. Park to Drive problem
  125. This TCS 4200 ROCKS!!!
  126. I need your opinion on this!!!!
  127. Trans shifting early at WOT
  128. How hard is it to switch pedals? (manual to auto)
  129. Anyone with pictures of elec connection to an A4
  130. TCI Super Street Fighter
  131. How much did you gain by locking your TCI3500?
  132. Stock converter problems on built Trans
  133. A4 guys, quick question?¿
  134. problem with trans !
  135. truck tranny
  136. Locking converter
  137. T350 Conversion
  138. what parts do i need for beefed up 4L60E?
  139. PLEASE HELP - Built 4L60e pops out of gear at WOT
  140. What is stock Torque Management setting on 01 Z28
  141. Flexplates: GM (OEM) vs. TCI vs. Madman
  142. Take rear w/3.42's out of formula for free???
  143. lock up conv questions
  144. Still hitting rev limiter between 2-3!!!
  145. Where to purchase TH400 kits?
  146. Non-computer controlled trannys...disadvantages/drawbacks?
  147. computer proplem
  148. Auto Trannys
  149. TH400 Pics Posted
  150. From TCI 3500 to Yank 4400 how much of a gain will i see?
  151. Fitting 15x10 rims, grinding calipers
  152. spraying the stock converter
  153. new converter=new vibes
  154. How difficult is it to do a 4L60e rebuild yourself?
  155. A4 to M6 trade in Texas area
  156. Effects of driving around with too much tranny fluid?
  157. Too much converter???
  158. truck flywheels?
  159. Driveshaft noise?? help
  160. cheaper alternative to Pro Yank 3600 Extreme
  161. the transmission is shaking at 3 gear
  162. I need everyone's take on TM??
  163. Porting the MAF and tranny probs.
  164. Trans mount question
  165. 4L80E
  166. converter choice
  167. Tci SFI approved Flexplate...Here it is!
  168. BIG PROBLEM
  169. 98 a4 for sale or trade for t 56 set up
  170. Dynoeing with Py3600E Verter
  171. dyno diff b/t locked/unlocked stock verter? alos, % loss??
  172. Vig converter, Lock-up or non ? Ways to tell ?
  173. is a flexplate the same as..
  174. TC Choice
  175. diagram of th350?
  176. new torq converter
  177. The new Transmission is in
  178. Converter locks up for a sec in 3rd during normal driving???
  179. how should i tune for new converter?
  180. does TCS have a website?
  181. TH400 Guys Need Help
  182. What is the stock stall?
  183. Who all makes aftermarket flexplates?
  184. STR and rear wheel torque, are they directly related?
  185. What is meant by shift extentions?
  186. I HOPE TO SEE YOU THERE?
  187. F-Body vs Truck 4L60E
  188. T-56 swap to 700 R4
  189. locking up the converter at top of 3rd...bad or not?
  190. ? about Vig restalls
  191. Tranny and Differential Fluid...which Fluid?
  192. 4l80e?? use 4th or not for racing
  193. Want to buy a new tranny!!!
  194. Converter install how hard?
  195. I need help
  196. a good stall converter for a a-4 w 3:42's w a 150 shot
  197. What to do?
  198. Vig 3600: Is it really that inefficient?
  199. Installed yank PT4400
  200. Installing new converter soon
  201. Converter? for 4L60E in light car
  202. Just installed tranny cooler...Help Fast!!
  203. Best way to check trans fluid?
  204. Suggestions: tc and gears
  205. i really need some suggestions before i torch it!!
  206. servos
  207. Trans cooler or no trans cooler?
  208. transgo installation
  209. Figured out my "wont shift" problem...
  210. tranny shift ?
  211. Questions about Yank Pro Thruster 4000
  212. 4L60 into a LS1...what all do i need ?
  213. 13 vane pump stock?
  214. Help,choosing the right stall.
  215. P0757 Shift Solenoid B Stuck On
  216. could this trans cooling idea work?
  217. when to lockup converter at the track
  218. LS1 4L60E ?
  219. Vig 3200 STR?
  220. AXODE stops shifting when hot
  221. got the midwest 3400 2.0 in and its worse then stock!!!
  222. Tranny temp gauge
  223. Computer Short Shifting?
  224. pics of aftermarket shifters for th350/400 in f-bods
  225. What driving tips, help keep a 4L60e alive?
  226. Where are you shifting your PT4400?
  227. What are your thoughts on the 200-R4?
  228. Yank Trans
  229. If I don't delete Tq Mgmt, will 4L60E hold against Heads/cam
  230. trans dipstick tube install!
  231. Poll: 4L60E, How Much is Too Much?
  232. People that have installed tranny coolers, IN HERE.
  233. Need advice/opinions
  234. vigalante have a phone number or something?
  235. TH400 on stock 10 bolt
  236. Couple of ?'s about my new Yank...
  237. Looking for Detroit F-Body with converter
  238. Best way to hook up extra cooler...
  239. Transmission Maintenance
  240. HELP...VIG 3200 is MUCH looser than my VIG 3600, WHY?
  241. Possible Tranny Problem??
  242. converter upgrade
  243. desperate now! Help!!!!!
  244. Tranny cooler install write up?
  245. AOD any one using them on their LS1???
  246. weird 1st-2nd shift?
  247. Maybe yall can help...
  248. opinions on the PY3400E from yank?
  249. How does this work?
  250. Bolt pattern Info Request
