- Converter Question Daily Street Driver?
- 3600 stall
- converter problem
- How to tell which Super Yank you have
- Any Literature For Bullet Proofing 4L60E?
- Which aftermarket shifter for 4L60E?
- Trans cooler install ?
- 4L60E Vacuum modulator ??
- ST3500 Questions
- TH350 conversion, need help
- Got Spec stage III installed today.. a few ?'s
- Thinking of making the Cannibal an A4 ;)
- will an st3500 hold up with more mods
- Car stalls out after converter install
- Transgo shift kit?
- 12-bolt install questions
- Newbie Converter Question
- TH400 Conversion Q's
- Turbo 400
- 4L60E Slipping @ 1-2 and 2-3 shifts.
- What are possible signs of when a converter takes a dump
- I have a TH-350 converter question
- tuning and high stall convertor
- How much to stall? Vig 3200!
- weird response from tranny shop about converter install.
- Converter Problem
- Tranny Question... A4
- Front Pump Install..
- YANK 3600, SES LITE... GOES INTO LIMP HOME MODE?
- A4 to M6 swap done
- what else do i need to install th350??
- How much space between the torque converter and the pump
- What is needed to install T400 into A4 car?
- 3.73's in A4 cut down top MPH too much??
- Which trans..FLP or LS1 Speed stage 3?
- Converter / Drivability Question
- Big Problems with Vigilante 3600
- driveability of high stall convertors
- Quick Converter install question
- need install tips for B&M hammer shifter
- huge converter causes stress on bottom end?
- HELP, my tranny or my Vigi3200 may be fried
- Need Help Choosing A Stall Speed
- Vig 3200 ?
- t.c.s. rocks
- Who's running a vig3600 and how do you like it?
- McLeod Rev-Lok II - Install Questions
- Is this converter good enough?
- adj master pedal pressure
- A4 Electrical Tranny Problem?
- Where do I fill my TH350 too?? help!
- Converter not locking consistently
- my first cam and converter, what should I expect guys???
- Stall verter causes LOSS in trap speed??
- VIG 3600, PROBLEMS W/SES LITE....
- Got Yank SS3600 last night.
- A4 guys inside please,,, Need help on what gears i have,,,bought used
- how built is my th350 gonna have to be??
- prices??
- how much will 4.10's help my A4?
- 4L80-E Discussion
- Gains from vig 3200 to 3600?
- Installed Vigilante 3600 - few questions & issues
- bmr th400 trans x member is JUNK!!!!
- Automatic Vs. 6-speed
- mounting my tranny cooler.
- Acceptable Tranny temps?
- Vig3200... 2000 corvette compatible?
- Spec Stage II Install Results...
- How much oil will leak out of the pan on my a4 when I pull it?
- A4 shifting prob...
- my verter
- trans cooler necessity
- Converter Swap from Camaro to Vette
- moser 12 bolt install?
- Problems with my A4 not down shifting, help
- best holding power "AND" longest lasting 4l60E?
- Any differences between LT1 and LS1 converter swap?
- Installing new slave in my '98 formula
- A4 to M6 swap, help
- Did i make a mistake buying a Yank SS3600??
- Convertor Question driveability
- converter only guys !!!!
- Any C5's with TCI verter?
- removing the input shaft checkball w/ converter swap?
- A4 to M6 swap info...
- Anyone have a tranny cooler write-up...
- Urgent! Tranny Install problems
- Moser 9" install, any good sites???
- can 4l60 be put behind ford engine?
- What size tranny cooler?
- Tranny just went, is FLP still the way to go?
- Question about a 700R4
- converter stall?
- converter?
- A4 with 4.10s ROCK!
- spec installed
- A4 problem after cooler blew a line
- 4L60E to T350 what tuning for computer.
- Break in time on newly built A4 transmission?
- locking converter in 2nd???
- How do you open a torque converter? Want to take pics.
- "OD" vs. "3rd" or "D" for WOT 4L60E driving, which do you use?
- Just Installed Spec Stage 3 clucth... damm hard!
- 4L60E Insanity
- TH350 and stock shifter
- Noise coming from the flexplate, looks fine to me? (EDIT: pics included!!)
- trans temp sensor
- Owners of A4 with 3.73's need to know
- A4 tranny issues
- vacuum modulator for 4l60e
- i need Directions for A4 Transmission removal
- Vig 3600 installed (SWEET)
- TH350 LS1 Swap: Will standard TH350 converter bolt right up to flexplate???
- Trans temp guage questions.
- A4 to M6 swap questions....
- how to be SURE converter is in all the way
- trans fluid! what to buy for th400
- 4L60E to TH350/TH400?
- converter and SES code 1870
- TP4400 + BIG cam vs ST3500 + BIG cam...??
- Any alternatives to hose clamps for trans cooler?
- Install Yank 3000 and now setting a misfire code?
- Please help me decide on my vig restall.
- Need advice on TH400 setup???
- stock auto tranny ratio
- is it ok to leave torque convertor attached to flywheel
- Need Tci and midwest converter times!
- Installing converter Monday-Phone help?
- Whats the verdict on line pressure.
- Revs to leave line @ with Vig 3200
- converter?
- 4L80E, has anyone done this yet?
- T400/ Automatic Valve Body Q's?
- 2nd 4L60E Failure in 3 Months
- Converter not locking...
- Poly engine mount installed on DR side... impressions:
- gear install
- Pro 5.0 install help Please!!!!
- too much stall
- Basically Stock w/Yank ST3500 --Opinions
- Any H/C/converter guys on stock 4L60-E?
- Install moser 12bolt rear feel really stiff now
- CONVERTER QUESTION
- What is the correct way to install a Yank SS-3800?
- How to Dyno a Car with vig 3200 stall
- Paging TH400 guys options questions within
- Converter Bolts Too Long
- Anyone running a lockup converter in TH400?
- Yank SS owners how are they doing?
- Converter Gurus inside please!!!
- newbie to this converter stuff.. few ??'s
- anyone ever have a Midwest3600??
- Let’s talk about life expectancy of a built 4L60E…
- Who here is running a TCS converter?
- Installed type F Ford fluid with good results
- Some TH400 questions...
- turbo 350 install cost?
- H/C Go in, A4 tranny goes out
- weight difference b/w MN6 and A4 trannys?
- TCI converters vs Yank - comparos?
- Autotap and line pressure
- Converter... Cut and Clean or new?
- TH400 swap guys, where to find...
- How to empty torque converter of fluid?
- Where do I need to put my tranny cooler???
- Tranny Cooler install
- 4:10's in an A4 with a Hi-Stall
- High Stall guys, how do you dyno your cars?
- Considering a change from a Vig3200 to a PT4400
- converter shudder
- SY3500
- A4 gear ratios (4th)
- how loose is your th400 convertor
- How can I tell which gear my a4 is in?
- A4 help:lost my D and OD?
- Are all 4th gen torque convertors the same?
- th400 want 1.3-1.4 60' yank? COAN???
- Thanks to East Coast Supercharging for installing my 12 bolt!
- SS converters
- transgo install costs
- Hi-Perf Associates 4L60E is AMAZING!
- 4L60E Rebuild Parts List... Need Suggestions
- A4/Converter guys.....what do u race in?
- Getting new converter what should I try? YTP4000 or Phoenix 3800 or MW 3400
- what converter
- Just got my 4l60E rebuilt...
- Someone help...TH400
- Tranny Temp Guage
- What cam for Vig 3600 bolt-on car?
- Yank Trans Went Out
- where to get convertor installed???
- Trans cooler
- Vigilante converters' TRUE stalls?
- Vig 3200
- A4 rear end gear movement, how much is normal?
- What TH-350/400 converter is everyone using?
- Flushing a trans cooler
- Th350 rebuild in Houston area
- verter install cost
- Guide to building your own Pressure Bleeder!!
- Need a converter
- which built 4l60e
- Question for those with Yank 4L60E crossmember for mounting stock TA on it...
- Diff Fluid for SLP-installed Auburn Hi-Torque
- Stock stall? And shift kit question.
- To do or not to do Torque Converter
- Need HELP! Should I get a yank SS 36 or 3800!?!?
- Which converter
- Tranny/verter GURU's needed
- Converter Install
- 2800 stall
- colonel converter
- th400/ use rad & OR trans cooler?
- th400 which trans mount?
- Where to put a Trany cooler?
- GM Techs - M6 to A4 wiring?
- Does anyone here use an ATI trans or converter?
- No more 4L60E, what are my options 700/200R
- How many quarts of ATF does the 4L60e take?
- Converter Question help please
- How much power/abuse did your stock 4L60-E take?
- 3000 Vigilante Converter, 1st gear pull off
- Converter / Trans Problems
- How much heavyer is a th400 to a 4l60e
- gear and converter questions
- Rebuilt 4L60, want go into OD and lock-up and no 1st gear with 3000 Vigilante HELP?
- No nothin about a Stall
- A4 Aftermarket Shifters
- Tranny help-Late shifting when cold 4L60E
- A4 guys...do you race in D or OD?
- which converter
- How Difficult is a Converter Install
- I need HELP on a B&M hammer shifter install ASAP
- Midwest 3000 stall 2.5str now I hit the rev limter sometimes
- possible m6 to a4 swap. Any advice?
- Art Carr Trans.& Converters in So. Cal.
- How to drain torque converter
- TECH ARTICLE ON INSTALLING 12-BOLT?
- M6 to A4 tranny swap is done...
- Variable Pitch Converters
- Location of trans temp sensor
- Can someone explain unlocked and locked to me?
- MAX street performance converters
- stall converter
- Speed Sensor for TH400???
- Problems with VIG 3200..
- converter / tranny / dif issues . need input for the night.
- 12bolt installed now a slight tranny whine M6 under accel
