View Full Version : Automatic Transmission
- FLP LVL IV Vacuum Mod Help
- Hee guys, need help quick...
- Vig 2800...
- anyone running
- what happens when...
- looking for more opinions on what to base shift points on, torque or horsepower
- Tci Ssf 3800
- what is the "stall" on this converter? (chart)
- To TH350 or not
- Need help picking T/C for my application...
- Pt4000 2.7
- Is this normal?
- Vig 3200 question???
- non gm automatic tranny questin i really need some help
- Want more mph(more efficient convertor)
- Broke tailshaft housing on dyno. Any consensus on solution
- Any Yank PT dyno graphs?
- Opinion on TCI converter...for TH400
- 4L60E Dies Again
- R is N, P is R
- Shifting out of Park
- Crossmember for TH350
- Trying not to have a "forsale" add about it but..
- Ultrabell Works!
- 200-4R converter and stall opinions needed
- Turbo conv input...
- 4L80E Discussion
- will converter benefit me on freeway run
- Opinions on ATI Transmissions?
- length of driveshaft with th400 and 9 inch
- Need Info. Please!!
- 4L60 down, need input
- Shifter Changes
- i think yank missed the mark on my stall, got some questions.
- Need HELP ASAP!
- ss4000, is it spray worthy!
- ratios
- Tranny cooler??
- Killed my first 4L60E :(
- Vigilante Multidisc users...need input
- converter question
- Spraying a PT4200...
- T56 to TH400 conversion
- 700r4 to th350
- is it worth spraying my st-4000?
- Tranny pros HELP!
- Anyone try a Lenko
- A4
- SS4000 Driving impressions
- tapping sound
- N2O Stall....
- Tranny Swap
- Is there a difference reg/nos/super t/c
- i need stroonger 1, 2 and 3 shifts
- New TCI SSF3500...Is this normal???
- 200-4r
- how well does the 200r...
- external precautions to extend tranny life?
- MidWest TC vs Others
- How tight can you restall a 9 inch converter?
- Transmission Cooler
- Transmission experts please advise on tow/haul mode.
- Factory tranny cooler lines question
- Paging Texas Speed
- Lockup Control
- 4L65E/LS6 questions?
- LT1 TC on A LS1 4l60e
- B&M Shift Plus Shift Improver for 1993-98 4L60E
- What should i do?
- rant
- PCM pressure learn?
- Better 60 ft. times...
- 4L60E F body Flexplates
- Tranny size?
- Need Advice!
- Shift kits?
- Anyone have dyno#'s before and after TC install
- no start?
- 6 speed auto
- Anyone running the Yank PT4200?
- need a 700-r4
- DR's required for a converter?
- gear install
- Where can a tranny leak from?
- SS4000 users inside please.
- How much does a 4L60E weigh?
- Anyone have a part number...
- Need Help Fast Please with New Torque Converter
- Dynoed w/ PT4400...What happened?
- 700r4
- Tranny rebuild
- where to purchase the ssf3500?
- Asking for trouble?
- I need some advice
- Need Transgo help ASAP!
- Which Trans Mount?
- 4L65-E in the C6
- what to rev a pt4400 at?
- 4l80e question?
- shift points on a 3500 tci
- Comparing Speed Inc Level 2, Level 3 and FLP Level 4 transmissions.
- Vacuum modulated shifts vs computer controlled
- transmission shift kit
- Those with aftermarket converters...
- Does TCI Charge to Restall a Converter?
- hurst cable and bm shifter
- shirfter cable??
- Question from new guy on trans
- tranny not shifting into 3rd at track
- 2000 Camaro SS
- How are such high stall converters these days pulling such good gas mileage?
- I need better 60ft's?
- B&M shifter adjust
- Trans mount? Poly Trans?
- speedo prob
- Where is the Link to Dope Tran cooler install
- TCS Phoenix Super Pro = what exactly?
- stock shifter sucks...please help me....
- Need a little advise. What would U do?
- help w/puttin lines back on!!!
- th400 conversion? Converter suggestions?
- Brake stall vs. loading clutch w/ line lock.
- Stall guys...when do you want Lockup??
- anyone ???????????
- 3000 or 3500 tci stall
- Will Yank come out with diffrent converters 04?
- Dope Tranny Cooler Install
- finding transmission manufacture date?
- transmission oil change?
- Has anyone ever done this?
- Transmission fluid change
- HP loss between th400 and 4l60e?
- anyone know what gears are in diff transmissions?
- HP Lost Due to Stall?
- Best tranny for...
- Torque Management?
- Torque Converters!
- Local flush or send converter back to Yank??
- 4l60e
- who makes the strongest 4l60e???
- What's involved on converting an M6 to an A4?
- How to properly measure driveshaft length?
- Problem with AL driveshaft
- Sloppy 2 to 3rd shift
- Any body with a manual shift
- 4L60E shifter
- Convertor / Transmission Combo
- 1st impressions of TCI SSF 3800
- 4L60E pressure regulator boost valve?
- Trans shifting into 2nd after cam install???
- Which converter???
- Specs on a PT4400 made on 3/02?
- how do you get the a4 shifter knob off?
- lt1 stall into an ls1
- TCI SSF3500 Converter
- tranny removal tips?
- TCI Street Fighter or Super Street fighter?
- 4000+ stall owners...Need tuning advice
- tc plug?
- 2-3 Shift Solenoid?
- Car hesitates after WOT shifts
- Concerned about A4 after being rearended
- Installing Tranny Cooler...
- A-4 has flywheel or flexplate
- SY3500 or SS3500 ?
- SS4000E, TCI SFI Flexplate, Yank Crossmember installed.
- Which Tranny Cooler
- Converter advice => TCI SSF3500
- 2nd- 3rd shift???
- PT4400, worth the money?
- Question about tow/haul mode
- TCI shift kit question?
- Tranny cooler install pictures?
- Midwest 3400 w/ 2.0 str w/ 3.42 gears
- Finally figured out what was wrong
- yank tq. thruster 2800
- Difficulty shifting A4 out of park
- early shifting with converter?
- Is there a break-in period for an automatic transmission?
- Upgrade for Tq Arm mount Braket ( Clam Shell )
- No WOT Downshift from 3rd
- Want info on T-Brake for a 4L60e...
- Cheetah Install?
- Lightweight Flexplate
- tailshaft overdrive
- 4-3 kickdown probs -- Need HELP!!!
- Question for Kevin At TCI.
- A4 to Turbo 350/400 How to wire Neutral Safety Switch?
- FTRA and Tranny Cooler
- flywheel?
- how much power can a stock 4l80e take with just a shift kit?
- What converters are green?
- Trans experts, give your thoughts on this (WOT downshifting)...
- 2-3 shift not right
- Received SS4000 today!!! I have a few questions.
- Trans. Temp. 2: dual coolers or big single?
- I searched....how to check tranny fluid level a4
- how to determine the stall of a converter?
- Tranny problems !
- 4L80E shift problems
- shift kits.good or bad.?
- ss3800 break-in period q's
- Need help with shift points: Colonel, Anyone
- Two Step Info For Transbrake
- Can someone explain shift extension?
- B&M Hammer install pics
- TCI 3500 with what gear combo?
- Other converters than Yank, Protorque for Corvette?
- Post Vids of Driving with you Converter
- TH350/400, 700R4 w/ LS1
- Help with Swapping TH400 into LS1.
- TCC Duty Cycle ????
- guys with TH350
- Car went to the shop today...
- flp tranny
- Flp Level 4 Tranny
- 4L65E/Vig 3200 installed!
- Multi disc or not?
- Won't downshift in 4th over 60 MPH
- mods for the stock shifter/th350
- Ordering from yank?
- need some help
- Christmas comes early!
- Lockup the converter with Diablo Predator??
- Going on tranny #4
- higher stall converters and freeway racing
- Problems with VSS
- Options. What to ask for during a rebuild??
- N2O with TCI SSF 3500
- yank exchange possible??
- SSF 3500 + SuperCharger
- please explain
- Anyone Spraying a TCI 3500 converter?
- converter feels loose
- Need Trans Swap Info Quick Please
- Need Help With Converter Choice
- Help: How to properly read trans dipstick to check fluid level???
- TH350/TH400 vs 200-4R
- Vacuum modulated 4L60e users, need info
- Pulled trans pan and found aluminum shavings
- swap to TH350 any HP lose
- trans pressure
- Converter Lockup?
- Before and After dyno
- PRI Show, converter info and other stuff
- Cam/Converter question
- Converter shudder....PLEASE HELP
- tranny lines
- Lost 3and 4 --
- level10 rebuild kits?
