View Full Version : Automatic Transmission
  1. Does anyone use a stock 4L80e converter?
  2. SFI LS Flexplate special at Yank
  3. Bad Luck???
  4. Shift Kit or Electronic Shift Programmer?
  5. Pulling car to track with trailer (700r4)
  6. trans fluid and flush question
  7. WOT shifting (3rd to 4th)
  8. 4L80E output shaft question
  9. Torque Converter Shudder
  10. Fixed my tranny mount but still feels a nocking every time I step on the gas hard..
  11. External filter & cooler fittings?
  12. TC Disabled & Shifting Problems
  13. Will 1998 c2500 4l80e work with an ly6?
  14. Used tci super streetfighter help
  15. 6L80E fill plug/dipstick part number?
  16. transmission fluid shoots out of dipstick
  17. Some questions on Hurst 1/4 stick
  18. arp flexplate bolt tq specs.
  19. Cross Contamination - 6L80E in a Truck with Corvette Driver Shift Control
  20. Ratchet shifter help!
  21. 1994 4l60E 1 2 upshift problem. No 2nd gear??
  22. issues after rebuild, got a ??
  23. Trans still short shifts ???????
  24. need someone to help me figure out my transmission issue
  25. Is there a best place to mount sending unit on tranny pan
  26. Gm Trans cooler lines
  27. shifting with trans brake
  28. 1995 LT1 Auto Trans pressure problem
  29. Questions bout torque converter
  30. Anyone heard of running John Deere fluid in a th350
  31. good 4l60 rebuild kit?
  32. 98 4L60E lockup on/off switch, benefits??
  33. 4l60e won't reverse until 1500rpm
  34. RPM Transmissions Fathers Day Sale!!! Amazing deals Look inside!
  35. What would cause....
  36. 200-4r question
  37. transmission mount ?
  38. 05 GTO wont go into gear
  39. Starter Grinding on new flywheel...
  40. question on converter
  41. 4L60E, 2 questions
  42. Got 70k miles on the converter...
  43. Th350 Speedometer Cable Block Off?
  44. Jake's Performance dyno
  45. PTC converters
  46. 5.3 w/TB converter whats needed?
  47. Putting my 4l60 back together and everything is going well but...
  48. So I blew my cooler line going down the highway
  49. Transmission Problems 99 Trans Am **VIDEO INSIDE**
  50. 3600 Sound about right for me...
  51. Torque Arm Relocation with 4l80e
  52. hurst shiffter for a4 4l60
  53. 97 Z28 Camaro Help
  54. What stall for ms3
  55. 4l65E
  56. is my transmission slipping?
  57. How much power will a stock 4l60 hold?
  58. Need opinions on what to do (TH400 or built 4L60E
  59. trans short shifts to 2nd ???????
  60. Temporarily lost 1st gear?(4L60E)
  61. Transmission lost 2nd gear, what internally would cause this?
  62. Trans doesn't shift
  63. What Speed Sensor?
  64. Started my 4l80e Rebuild 2 night! 6/10/2011
  65. 4l60e stall in a 4l65 will it work?
  66. Shifter Cable for TH350/Ls1! Where can i buy one!?
  67. older 4l80e to ls1 bolt pattern
  68. Installing 700r4 and yank converter
  69. TH350 questions..
  70. Speedo stops working then trans shifts funny
  71. Going to power glide...does anything need to be done to PCM?
  72. Tranny cooler question
  73. Re-mounted my trans cooler
  74. Strange 4L60E Issue
  75. 4L60E shift solenoid bore
  76. 4l60e stage 4 yank ss 4000 problems
  77. 4l80 ?
  78. Stall a high mileage transmission?
  79. FTI converter results
  80. fluid pricing
  81. Thinkin about goin to an Auto..
  82. M6 to A4: Using a M6 harness with an A4 trans?
  83. Shifter Cable Linkage Issue
  84. What stall and size converter for DD
  85. warped flexplate, aftermarket replacement ops?
  86. 150 miles enough for brake in on new stall?
  87. questions about stalls
  88. overdrive problems?
  89. 98-02Fbody trans cooler lines
  90. Stock Stall speeds
  91. Torque Arm and a TH350
  92. shift kit capacity questions 4l60e
  93. Help rpms shoot to 3,000 and drop back down for no reason
  94. rear end issue possibly..due to OD?
  95. a4 Trans am Shift points
  96. trans cooler lines
  97. Most miles on 4L60E
  98. Please step in, th400, lock up issues
  99. horsepower difference between 4l60e and 700r4
  100. flt level4 binding up
  101. 1995 Z28 Transmission pressure problem
  102. 4L60e Vent Tube?
  103. Th400 help asap
  104. s-10 4l60
  105. 4L60E - No 1st Gear...??
  106. 4L60e what happened and what do I have to replace?
  107. Boosting in Overdrive?
  108. 4l60e no line pressure?
  109. Part number for pigtail adapters for shiftlock/pnp on T56 -> A4 swap
  110. Truck tailshaft housing swap questions
  111. th400 swap
  112. Circle D - Custom LS Flexplate
  113. Full manual on an early 4L60E
  114. issue after 4l80e
  115. Who sells slip yoke (stock U-joint, stock alum DS, 4L60E, 2001/2002 F-car)
  116. Circle D - ALS Charity Event
  117. 4L60E Woes.... P0758 Help!?
  118. Boosted line pressure w/ built 4L60e
  119. Need help with 5v reference for the VSS
  120. new rpm trans?
  121. ratchet shifter
  122. 4l80e question
  123. installing converter it wont *Lock* in
  124. new member question
  125. 4l60e leaking from rear??
  126. Urgent!!!! Powerglide to lq4 problem---SOLVED---
  127. how's my ddipstick 4L60E
  128. A4 Trans mount
  129. need some th400 help
  130. cause of flexplate holes getting bigger
  131. RPM 4l65 limits
  132. problem with trans after new motor
  133. transmission fluid low....am i missing something
  134. A4 Burning up?...
  135. Best auto for my car?
  136. 2-3 upshift flare
  137. Sponsor Installed A4's come in
  138. went non lock up have questions
  139. trans mount shot. question about polly mount
  140. DD Stall
  141. 3rd Gear TCC lockup and TCC Lock
  142. Jake's Performance Memorial Weekend Sale
  143. anyone ever use this kit?
  144. Opinion on this rebuild kit.....
  145. Automatic shifter knob removal?
  146. 4l60e
  147. Question for the MVB 4L80E experts
  148. Will a 93-97 4l60 work in my 98
  149. shimming the converter
  150. 4L80e/Transgo experts inside please
  151. 4l80E dipstick *please add this to the sticky*
  152. Is my A4 toast?
  153. Circle D - Facebook
  154. Best deal on a yank or circle d converter?
  155. Turbo 400 stuck in gear
  156. 4l65e Upgrades
  157. Maybe my tranny?
  158. Every single flexplate bolt broke onto crank.....
  159. 4l60e trouble, slipping in overdrive only.. computer issue?
  160. How Much Fluid Does the 4l60E Take?
  161. 4L60E Stall Question
  162. 4L60e from a 94' or 98' firebird to a 96' firebird?
  163. shifting problems
  164. Which kit? Tranny rebuild...help
  165. Anybody running a "remote" trans cooler?
  166. 4L60E Trans Brake
  167. please help 4l60e guys
  168. Stall converter
  169. slipping going into 3ed
  170. Whats everyone using for a trans mount?
  171. a 3600 with 3:73s sound good?
  172. Converter does not seem to seat all the way after rebuild
  173. typical mph loss with auto vs stick in the 1/4
  174. 700R4 help with electronic speedo sensor
  175. 4L60E to a TH350
  176. Anyone running a tranny cooler with a FTRA?
  177. New stall and trans ?
  178. 6L90e tune and cooler.
  179. 1-2 accumulator dual springs question
  180. Using 4l80-e from 2000 Suburban, 4wd?
  181. ss3600 and nitrous
  182. 1-2 Shift Issues After Converter
  183. Trailblazer converter
  184. 4l60e prob, help?
  185. output shaft only spins one way after servo install, now what?
  186. glide sat for a while, wont go into gear
  187. 4L80e to gen 1 sbc
  188. CDS LS Flexplate Comparison
  189. 4t80e to 4l60e conversion HELP PLEASE.
  190. Suggested stall size for a 2004 suburban 5.3?
  191. Im completely stumped :(
  192. flex plate moving issues
  193. WTB 3600 converter for 200-4R
  194. 4l80e parts ?
  195. Leaking trans
  196. 4000 Yank stall question
  197. Who used there stock flexplate with stall?
  198. Early 4L60E question
  199. Need a converter to handle fair amount of boost
  200. Transbrake issue.
  201. 3 converter bolts - enough for 1000HP with transbrake?
  202. 93 LT1 4L60 w/ major rpm drop & shudder, & fuel issues
  203. Torque Converter Clean Out
  204. RMVB th 350 Do's and donts?
  205. convert m6 to a4
  206. A4 transmission questions
  207. My 4l60e shifts way to early in crusing speeds
  208. Lt1 stall
  209. anyone have pics of modified stock a4 crossmember for th350 swap
  210. Corvette Servo
  211. Circle-D 3800 help.
  212. quick auto question
  213. Did I install my trans cooler right?
  214. Few tips I thought of for Yank ss install!
  215. stock auto shifter in a 98 6 speed car?
  216. 4l60e pump, only 1 spring inside of it.. shouldn't there be 2?
  217. I bought the wrong trans, can I make it work
  218. 3500 stall on a daily is this good?
  219. What bolts to use for Yank stall w/ stock flexplate?
  220. Driving TH400 on the street with RMVB. Questions...
  221. What is the safest way to do a burnout on a PB Level 3?
  222. best buit 4l60e
  223. Won't stay in OD after HD2, Hardened plate, billet 4th piston.
  224. Can I use the B&M tranny cooler kit?
  225. TH400 help
  226. Th350 Failure (video inside). Any guesses?
  227. PRW Industries SFI flexplate any good?
  228. Yank Shift Extension Question
  229. shifting problems
  230. cant trans to an fitting
  231. I need some help, im having major 4l80 problems
  232. Stall...
  233. FLT Sale
  234. 4l60 grinds in park and when stoped... Help
  235. Why does my Fugging TH400 xmsn run so hot???
  236. Need opinions on TC re-stall
  237. '96 Corvette 4L60E in a '96 Firebird?
  238. i think my tranny shifts weak!!!
  239. M6 -> 4L80E wiring info
  240. 95 T/A trans cooler lines leaking
  241. Need recomendation/opinion for a converter
  242. stock 4l60e
  243. having my 4l60e built hows this look?
  244. Trans wont shift helpp
  245. lq9 .. need cam advice
  246. Get a trans (4l60e) from Who?
  247. TH350 Torque Arm Relocation kits and Torque Arms?
  248. Leaking transmission fluid from electrical plug?
  249. Truck transmission in F-Body?
  250. TH400 builders/experts, ever seen this kind of issue?
