- Jake's Performance Holiday Sale, Two weeks left
- shift kit
- Any interest in TH400 automatic transbrake valve body?
- Xtreme Transmissions New Year Sale + New 6L80E Converter
- what a good torque converter to buy
- Anybody have a circle d 1c 245mm? Trying to make decision
- 6L80E / 6L90E tow haul mode?
- TV cable plug?
- 4l65e conversion
- Circle D converters
- Dipstick ? for th350
- 6L80 w/cruise for those who said it couldn't be done!
- Power Glide Question???
- Need to drain trans fluid from torque converter to ship it
- 4L80E Stall On 6L80E?
- tranny is being weird
- Anyone using this transmission mount?
- jake brake install questions
- 4l60e ?
- 4l60e no top gear
- Truck trans/housing will it fit in an fbody?
- 4l80E Full manual VB Q
- WTF no 3rd gear?
- adjustable shift settings on the fly via Jet power shift for 4L60e auto tranny
- Need some converter help, SPONSORS
- Yank SS3600 or Yank SS4000 with set up?
- th400 questions...
- 4l60 crap!!!
- 4L80e ?'s
- th400 install help!
- 4l60e/4l80e what is the difference?
- 4L60E Shift Kit or NO?
- 4l60e valve body?
- 4l80e HELP!!!
- 4L60E Problem
- performa built converter ?
- Different year 4l60e swap
- 4l60E tail housing question
- 04 GTO trans i put in 99 TA broke last night...
- Downshift MPH Settings
- 4L80e vs TH400 - Which one is faster?
- Convertor question
- New Year Stall Specials?
- Transmission troubles
- GTO trans cooler input needed..
- Circle D A+++++
- 4l80 Trans brakes/mvb ??
- Trans Cooler Questions
- D and OD feel like Neutral in my 98 A4, help...
- '95 Caddy Fltwd Brghm(RWD)
- New built transmission w/new converter question
- FTI Trans rebuild? or are they just converters?
- Convertor for my setup
- 3400 stall
- 4L65E Problems :*TCC Solenoid refuses to disengage*
- 4L60e Trans Rebuild
- TCC not locking, 95 rebuilt trans
- Tranny issues
- th400 dipstick?
- FLT level 4 or performabuilt level 2 ?????
- 4L60E problums
- 4L80e---race in Drive or OD
- Torque converter bolts
- 4l60e trouble
- Putting a used 4l60e in
- Any of you guys running a Yank PY3600 Converter? Just loking for opinions
- Looking for shifter linkage solution: C5 shifter to auto trans
- Th400
- Decisions, desisions...
- 4L65 w/trany cooler only
- Any Head and Cam cars running a SS3200
- is anyone using this shifter with their 4l80e swap
- 6 cyclinder convertor
- 4L65E with no provision for 3-2 solenoid
- M6 to A4 conversion backup light/pn switch question
- 700r4 into 2000 formula A4
- how much quicker are you on a trans brake then foot brake?
- Torque Converter With Stock Transmission
- Stupid question - LY6 to 4L60e
- Switching from 4l60e to 400 turbo. need ideas!!!!!!!!!!!!!!!!!!!!!!!!!!
- Help...4l60e not engaging!
- What kit to rebuild a 4L80E trans?
- Best 4L60E REBUILD KIT???
- 99ss lq4 m6 to th350 ?????'s
- ???'s about auto shifter in stock m6 console
- 3200 stall what cooler?
- 4l60e ls1 tail shaft
- Tranny swap cause high idle
- No start after new tranny install
- TCI RMVB for 4L80
- Tailshaft bushing
- 4l60e interchange
- Finish Line Transmission Holiday Special!
- Help me fix my 4L60E!
- 4l80 questions
- Which stall is tighter?
- Pulled my tranny!!
- turbo 400 in a 95camaro ls1 car?
- Automatic safety switch?
- 4l60e interchangeability question
- 4L80 out of a 93 suburban
- Glide or Th350
- Help with mystery meat stall
- TH400 Swap Overwhelming
- Introduction! Jake's Performance
- Anyone using an optishift?
- Shifts into overdrive too soon, bogs, won't downshift
- light-weight th400?
- Now offering Automatic trans Rebuilds on ANYTHING GM (General Motors)
- I need a reaction carrier assy. for a TH400
- tci th 350 and percision stall for ls engines
- P0741 code on 07 silverado NNBS with perforabuilt converter
- 4l60E Tranny For Sale
- Dangers of a trans that has sat???
- Converter unlocking/locking as I crusie down the highway
- building a 4l80e parts questions????
- Driving with a 5600 stall... vid inside
- Does GM make a version of their 6L80E/6L90E for European OEMs?
- converter clutch acts normal at sealevel and shitty at high alt.
- Bulletproof rear trans seal 4l60e
- driving in thrid
- 4l60e shopping for prices
- Cold shift bogging
- anybody heard anything good about these guys?
- Weird 4L60E 1-2 shift issue when footbraking off the line...
- Table for MPH Shifting
- keithz28 2001 camaroz28
- Stall and 2.73's
- debating on stall company...
- RPM Transmissions - Cyber Monday Sale!
- Circle D - Black Friday Sale
- 1994 4l60e with 1996 LT1
- 4L60E Issue - 1-2 Shift @ WOT
- will this 4l80e work?
- Anyone with circle d hp 278mm?
- Anybody with a 2800-3400 stall post up some vids plz!
- B&M Pro Stick Shifter
- th350+700rwhp+semi budget=what can i do?
- Starts in 3rd or 4th, No 1st at all
- 4l60e tps problem
- pickup converter
- 4L60e Parts
- For you TH350 guys, what brand TransBrake did you go with and why?
- YANK SS4000 new best 60ft 1.291 h/c/i na 346
- think my torque converter is goin.... help please
- 4l60e tailshaft housing?
- 2800/3200 Stall and Gear Vendors Overdrive
- what route to go? Damn transmissions
- th400 random slip in second
- Anybody go under 1.50 60ft with 4l60e?
- 4L80E conversion
- Built 4l60e not shifting 3rd at WOT
- what torque converter should i get
- How much did you pay...
- transmission cooler beneficial...?
- Need Help, TBSS won't shift automatically, shifts manually
- torque converter failure
- New Yank SS4000 Installed :)
- Need help with a "must have" parts list!
- Highway RPM
- tranny parts
- car goes retarded in reverse
- 6Spd T56 to Automatic
- corvette to f-body
- 2001 4l60e IS THIS POSSIBLE
- Shortening drive shaft to install TH400?
- SS3600 & 3.42's
- Early 4L60-E and carbed LS1 question
- Question about park/neutral switch on a 4l60e
- 4l80e red eagle and shift kit??...help
- No threads about Stall=drivetrain damage
- 4l60e - feed/return line
- th400 speedometer help
- how much for a ss3600 stall run me?
- no park reverse or neutral
- do i need the dust cover on the 4l80e
- Paddle shifter HELP
- Manual Valve Body Driveability
- Vig3600 vs SS3600
- quick question about a4 to m6 swap
- 700r4 into 1993 camaro
- Cracked Flexplate?
- Stall Problem?
- neutral safefty and gear selector switch
- Where are you guys buying TH400's and conversion parts?
- 700r4 shifting problems
- edge stall driveability?
- Anyone shorten the camaro auto shift knob?
- converting stock converter into stall?
- Help me ID this converter
- Thank you FTI
- TH400 problem need pros help.
- Yank SS line and Pro Yank Extreme
- silverado 4L60e different from regular cab to ext cab
- stall choice questions
- built 4l60e problem
- 97 4L60E bolt directly into a 95 car?
- 80 z28 4l80e??
- Tranny slips and then it doesn't??
- 4L60E 3rd gear problems
- TH400 going forward in all gears
- ANYONE really using a 4L60E with 600rwhp?
- Transmission guys inside. Is my tranny failing
- 6A or 6m trans. in a 4th gen?
- torque converter bolts?
- Transmission Slipping ALREADY
- Got the GTO trans in the TA...question about the shifts
- true or false?
- what does this code mean?
- Stall with Manual valve body 4L80E?
- What year LQ4s bolt to 4L80E
- 4L60E question.
- Torque converter questions?
- Tranny slipping? not sure
- 4l60e vs 4l80
- 4L60E shifter questions
- What used 4L60e to buy.
- 1st gear shifting late part throttle
- TH350 Transmission Line Question
- Temp gauge install best place for sending unit
- do yank converters come in black?
- Some questions about th350 conversion
- How is the MadMan Th350 dipstick supposed seal to the transmission?
- 700r4 into a 93 maro
- stuck in 3rd
- manual shifting 4l60E?
- My Story with 4l60e
- 4L80E to 4L60E
- New 4l60 and ABS problems???
- 2006 trailblazer transmission ?'s
- lt1 4l60e 0n 99 ls1
- Suggestions on which stall I should run.
- Hot after highway cruise?
- 4l60e 4x4 to 2wd
- Th400 question
- Trans line
- 4L80E overdrive?
- WTB 4l65e transmission or trade t56 spec 4 plus
- any updated 4L80E assemb. info
- any "Budget" trans controllers
- 2nd gear lagging or is it just me!!!???
- Transmission took a dump
- I need a rebuildable 1995 4l60e
- LT1 and LS1 Stall Converter
- Broke TCI flexplate?????
- My performabuilt 4L60E with LS3 427
- Cleaning inside of transmission
- converter installed all the way?
- Leak won't go away
- 2002 SS Transmission?
