- lt1 4l60e in a ls1 car.
- th350 shifter
- Any 4L60e Quicktime bellhousing users?
- Transmission help PLEASE!!!
- Alot of money being spent. (Thoughts appreaciated)
- Transgo Install Question
- Transgo kit problem
- Vig. Converter
- 2-3 shift problem
- Performabuilt Level 2
- edge racing converters or any comparable company
- 99 Chevy Blaser 4l60e in 04 GTO
- Hayden 1405
- My car sucks on a roll. Stall time!
- Converting the speedo off a newer Auto to old school
- Converters
- second gear th350 ???
- Auto Transmission is about to crap out i think...
- Hey just a couple tips needed...
- My LQ9 Flexplate will not work with SBC TH350 converter and GM Adapter (Pics inside)
- Question about TM removal
- Anyone see any temp drops from running different fluids?
- Lock-up Clutch Questions
- Correct bolts for flexplate to Crank
- Braided Transmission Lines ?
- No 3rd/OD???
- th400 transpan selection
- Intermittent trans slipping WTF?
- 4l60e on casing
- TCI 4l60e converter ?
- 4l60e trans from 4.3 will it work
- what brand aftermarket 4l60 to go with?
- Th 350 guys! What stall are you running!
- What to know for tc install?
- how would this be for a tranny cooler
- YANK testing on the LS3 A6 with SS3600
- Trans Brake switch/button
- Trans.length question
- Hit rev limiter from 2-3 shift
- Add a fan to my trans cooler or buy a new cooler with a fan?
- Dragging Noise in First Gear
- Dexron VI is expensive stuff!
- Idle surge after stall swap...
- 4K+ stall on a LT1
- Auto swap tune
- Is This True About Putting Stall Converters In Stock 4l60e?
- which direction to install a few parts 4l80e
- Anyone know what this is (4L80E Plug)
- 4L65E shift issues
- Fresh 4l60e Taking a Dump?
- How to wire up clutch pedal for auto swap?
- 40 tooth reluctor ring(700R4 or 4L60E part number?
- 4000 stall and nitrous?
- NEW 4l60E No Second Gear 1-3-4(delay)-lockup HELP
- Possible Bad Converter?
- Need help I'm stumped
- TH400 Issues
- what tranny is this
- transmittion rebuit kit..
- Who should I buy from??
- converter install....any takers?
- How much is to much?
- Trans. tuning Question
- 4t60e
- Which bolts/nuts for SBC TH350 converter to flexplate?
- Built 4L60E questions
- TCI 6 speed Auto
- 4L80e swap help please...have I goofed up?
- VSS and related systems?
- starting off in 2nd
- Aftermarket Transmission Pans
- what size converter to get ls1 miata
- Rossler 4L80E converter won't lock
- How do I get rid of my "dead spots"?
- TH400 and gears for the street/highway
- dumb question but i need an answer
- Will a converter for a 700R4 work in a 4L60E?
- Transmission application question.....
- 1-2 Shift is rough briefly
- 6L80E to handle 1000hp
- pump bad???
- th400 shift kit
- Aftermarket shifters
- Another happy Yank customer
- TH400 VSS Pigtail HELP!!
- 408 camaro not running like it should
- Is It Normal For Shifting Firmness To Decrease With a 3500 Stall?
- no overdrive after fixing simple leak!!!!
- (C5) Shift Cable Replacement Procedure Question
- 94 LT1 TH400 Question, No Start.
- Tranny Swap question.
- paddle shifters
- Stock 4L60E strength?
- 3-4 clutches....what brands you guys using?
- Stall help ASAP !
- Torque Converter Bolts (4l80/yank)
- 4l60e Fresh Rebuild, but doesn't shift right
- Converter and tranny help
- Edumacate Me..
- TH400 Trans Brake ??????????????
- trans cooler location..(turbo car)
- Low Battery Voltage After 3500 Stall
- broke pump? torque converter?
- overdrive working intermittently 4l80 transmission
- Circle D 4c installed, results vs stock stall
- 4l60e Tranny
- Transmission not working, what's wrong?
- Who has pulled trannys out of junkyards and ran them?
- How far along have built 4L60Es come over the past 10 years?
- th350 shifts harder in drive?
- LS..... Coan TH 400/ TH 350 Converter
- downshift limits?
- New transmission question
- tranny service
- Powerloss through trans, which would have the least?
- 2.73 Gears and 3600 Stall
- Which Trans Brake for TH400?
- TH400 Driveshaft Length!
- torque converter problems.. i think..
- 4l60E trouble
- Trans Sponsors and Experts Enter
- Help On Sprag Installation
- Questions about a yank ss 4000
- stall
- braided line routing
- freshen up the tranny? Advice needed
- Transmission porblems...Is it an electrical issue?(Video inside)
- Monster in a box Kit?
- th400 help
- What flexplate for 1000hp?
- Which transmissions are interchangable?
- Stall converter questions, please help!
- Transmission cooler questions
- Need Help
- Transmission fluid clean up......
- Possible trans failure
- converter wont unlock
- Weird noise
- 4L80E in a 1999 WS6
- TH400 to LY6 Gen IV
- excessive trans heat unlocked... Trans or Converter?
- stall recommendation
- Yank Install Question
- Tried d instead of od at the track
- Who's usin the b&m hi-tek super cooler?
- Converter slip problem?
- arp torque tables
- what kind of 60 ft can i expect?
- props to FTI Converters
- Thanks Chris @ Circle D
- 94 z28 4l60e reverse issue forward gears all work
- Aftermarket shifters in 4l60e
- car wont shift do I have a problem
- best thing, if anything, i can do to keep my tranny from failing?
- Broke now what
- 2wd 4L60e tailshaft housing needed
- 4L60E Rebuilt w/Drive Problem
- paddle shifted ls1 question
- New Fbody owner. Transmission question...
- Difference in early 4l80e and late 4l80e transmission?
- No Tcc with 4l80e
- HELP me diagnose a 4L60 issue please
- Stock Stall on 2002 Camaro SS
- Stall Converter sponsors.....whatcha got for me....
- Radiator Fan on constantly after stall/cooler
- 4l60e?
- TH400 swap question
- C5 4L60E need help - which is return & pressure?
- 4L80e lock up problems, bad converter?
- TH350, downshift 2-1
- TCI overhaul kit and shift boss review
- Hurst shifter for 4l60e???
- im planning on doing a th400 swap
- What size stall for 2.73 car?
- Twin 70264 Coolers
- 700r4 to ls1
- slipping during no throttle?
- will a 95 RWD van 4L60E fit a 04 GTO?
- 4L60e issues
- t56 to 400
- transmission cooler with rebuilt tranny
- nut to bolt down trans to cross member?
- What gear do you race your built 4l60e?
- anyone have stall converter that was like a wet noodle?
- Weird Issue at roll to WOT... I think
- 4L60E Problem
- 14,000 BTU enough for 3600 stall
- Is it slipping or something else?
- Trans Cooler Mounted "Dope" Style?!?!
- Starter Grinding on new TCI flexplate.. helppp
- 4l80e tailshaft question
- putting in auto in a m6 car..wiring question
- Pump splines chewed up
- Transmission is done
- th400/vss issue
- What B&M Trans Cooler
- th400 leaking but what is leaking from? (pics inside)
- Trying to pull trans got 7 bellhousing bolts but cant get one... %^#$%^#&
- Transgo Shift Kit 4L80E-HD2
- Replacing gear selector shaft?
- Need another tune with a 3200 stall
- Thanks to all
- lets see oics of your aftermarket A4 shifter install keeping the console
- delay going into gear and shifts
- Do I need a Filter Extension for B&M Deep Pan?
- milky fluid but not running through radiator
- Help! where/how to mount a trans temp sensor?
- Which is the best way to launch a 3,600 Stall Converter?
- 97 4l60e will bolted to ls1
- Converter too losse?
- Richmond, VA....all in one shop
- Thanks to Slow67 - 4l80e
- What size stall for bolt ons, future mods? Help
- flexplate on correctly?
- shift controllers
- Built 4l60e???
- rebuild 4l60e, wich parts?
- replace 2000 camaro flexplate w/ the new stall ?
- TH350 speedo
- Clunk/ under WOT
- tunning with new convertor
- How much for tc install
- Starter from a L92 with 6L80 work on a T-56?
- Today only promotion 100 off
- transmission leak
- 4l60e problem!
- yank ss3600 people come in
- Ok yank converter owners especially py 3400 owners come on in
- Pro Built Tranny Kits
- does this thing sound right to you guys?
- M6 to A4
- Turbo 400
- Help pulling 4L60E from 94 Formula!
- Trans Tweaking (HPTuner ppl enter)
- Im baaaaack!
- trans ?
- Taking Your A6 to The Next Level - Tuning to have the best of both worlds
- Trans cooler ?
- using washers for tc install
- TCI Flex plate question...
- The Circle D stork stopped by the house :)
- Circle D converter (the cheaper one)
- leaking trans oil
- a few "am i able to's"
- Transmission Gurus, sponsors, anyone?! TH400 problem
- Lokar 4L60e Trans Dipstick question
- Trans swap ?
- What Stall ??
- Ok to run a cam with stock converter?
- What do you guys think of this kit?
