View Full Version : Automatic Transmission
  1. 4l60e shifting kit installed but shifting is slower
  2. transmission differences
  3. What size bolts for bellhousing/tail shaft?
  4. wanting to swap manual to auto
  5. Toast 4L60E
  6. its this a good tranny oil?why is it this color?
  7. Missing reverse
  8. Are all 4l80e's the same ?
  9. reverse connector... where is it?
  10. Will a v6 4l60e work?
  11. 4L80 build time, help me decide manual or auto VB
  12. th350 speedo gear?
  13. B&M pro stick feels...weird when shifting
  14. TH400 is building lots of pressure.
  15. Does your stalled auto unlock when coasting?
  16. How will my stall affect my dyno results?
  17. strangest problem I've ever seen, HELP!!!!
  18. 93 Diesel 4L80E with 2002 4.8?
  19. 2 coolers? is it okay
  20. ms3 cam which stall
  21. confusion on stall converters
  22. Help with key parts for 800hp safe th400 build
  23. 4l80e Video of some funky noise after pull
  24. Car will not move
  25. Jiffy-tite Quick Connect Fittings?
  26. To bypass or not to bypass....?
  27. What are deciding factors between 245 and 258 mm converters?
  28. Freshly rebuilt tranny makes clicking noise, no D or R
  29. M6 to TH400 swap needs???
  30. Question about trans temp sender unit and fluids
  31. 4L60E truck trans
  32. Help diag. transmission slip or is it the converter?
  33. Help diag'ng 4l60e reverse issue.
  34. Stock or aftermarket shifters...?
  35. Which u-joints for the Ls1?
  36. HELP. Service engine soon light??? What will fix this
  37. B&M Trans Pak?
  38. Built 6l90e?
  39. how to use a 4l60e/4l80e with a carb'ed 6.0 LQ4
  40. Stall experts step inside
  41. First time auto..
  42. Service Engine Light
  43. shift button broke..
  44. Will a stall make me faster from a roll?
  45. Gearing of '01 Z28
  46. What year 4L80E
  47. Is my trans on its way out?
  48. transmission ?
  49. newb question - how can I reduce my rpms on the highway without a gear vendors unit?
  50. Trinity Trans Brake...Help me Please
  51. Driveshaft is shafting my project!
  52. Tuning after new trans and converter?
  53. Need help with stall size - car w/driver 2750lbs
  54. How much did your 4L80E hurt your 60' N/A?
  55. Dex6 ftw!
  56. Do new converters need to have a brake in period?
  57. 4l60e-shift kit, now no overdrive
  58. Is a 4000 Stall To Much For A Stock LS1/LS6?
  59. th 400 flywheel problem
  60. 4L80E tranny temps = adding a second cooler!
  61. Fti converters=a+++
  62. PerformaBuilt Tranny and TQ Converter... Which flexplate?
  63. Drivline pro lem
  64. help! 98 t/a wont shift into park
  65. Trouble code P0757 4l60e
  66. Who sells parts?
  67. m6 to a4 swap done
  68. 4L60E problems
  69. Tranny Mount Writeups?
  70. Where did you mount your tranny cooler?
  71. A4 swap help?
  72. Yanks phone number?
  73. 4L80E Transbrake Install Instructions
  74. 4l60e shiftlock question
  75. servo help
  76. Stripped converter bolt
  77. Street/Road Course/Canyons/AutoX?
  78. Question for guys with FLT transmissions
  79. help lq4/4l80 swap converter help with sfi flexplate
  80. Another P0751 code question
  81. Help! Trans Pressure in 4L60E
  82. How do you replace the auto shifter handle?
  83. 4L80E accumulator valve spring=harsh shifts?
  84. stripped bolt head for bellhousing!
  85. 4L60e just went out (again)
  86. How High Are You Shifting Your 4L60E
  87. tail housing height
  88. any tips for trans removal, poly engine mounts?
  89. 4L60-E Banner Kit
  90. Trans Shakes Violently????
  91. Should I increase my stall
  92. dosent it seem kinda stupid? (higher stall+stock 10 bolt and tranny)
  93. swap complete m6 to th400... ?
  94. Need ideas on whats going on with my swap to an auto
  95. I need 4l80e TC education
  96. FLT - July (Level 4) Sale
  97. Help plz. Which line is pressure line on late 4L80?
  98. 3600 or 4000 stall????
  99. 5.3 / 4l60e Bolts
  100. Gto VS F-body tail shaft housing
  101. is their anyone who sales a package for 4l80e swaps into f body
  102. high temps with thae AC on
  103. bad track times may be trans or converter
  104. Rossler transmission 4l60 update modification
  105. can u loose your shift points
  106. Just ordered my circle d4c converter!!!
  107. Simple Dexron III ATF Question
  108. Race kit for 4l60e
  109. Swapping trannies, help me understand the RPM effects please
  110. need help choosing stall size and brand
  111. Temps High. Cooler Position
  112. Regain power loss from auto trans?
  113. A4 shift problems after ported TB install
  114. 4l80e into 2nd gen f
  115. R&R of 4L60E
  116. Upgraded my drive shaft.... again! The right way this time!!!
  117. 4L60E Cooler Line keeps popping off
  118. AEM box...will it control my 4l80e
  119. i need an honest tranny builder that builds a badass 4l60
  120. 4l60e is not shifting out of 2 or 3 ?
  121. powerglide people
  122. Will a V6 4L60e bolt to an LS1 if I change the bell housing?
  123. Car wont launch or 60ft
  124. stalled auto from a roll?
  125. Stuck In Drive
  126. which one of these converters would you get
  127. Dumb question
  128. Help me make my mind up on switching to an A4
  129. please help with transmission problems. slipping in all gears under hard acceleration
  130. Looking to upgrade your A6 transmission? Well the wait might finally be over!
  131. How much converter for a 1.8 60ft. time?
  132. Trans leak... where can it be from?
  133. What to do??
  134. 4l60e problem(serious)
  135. Tranny keeps getting hot
  136. Transmission acting wierd occasionally
  137. 2004 gto 4l65e problem
  138. detroit trans shop
  139. need help with stall size
  140. Modified 6L80
  141. 4l60e whines when hot
  142. straight cut gears
  143. auto shiftin prob (4L60)
  144. Baumann controller for the 4L80E???
  145. 4th gen drive shaft on 3rd gen?
  146. PerformaBuilt VS. RPM Trans VS. Everything Else
  147. short shifting
  148. Any clearence issues with the following trans?
  149. 4L60e reaction shaft on 4L65e planetary??
  150. wanting to do an auto to 6 speed swap!
  151. What converter for big block TH400 Chevelle?
  152. RMVB / Transbrake / TH400: All gears go forward.... :(
  153. How to get a speedo reading from a th400
  154. 4L60E Identification
  155. Is that normal or should i be worried?
  156. Tuned then tranny stopped working
  157. How to be sure if converter is fully seated?
  158. 4l60e
  159. I have to give a big shout out to PTC and Thunder Racing! Thanks
  160. Will this tranny cooler be ok?
  161. flexplate bolts????
  162. TH400 Swap Qs w Hurts Q Stick
  163. Transmission Tail Shaft housing.
  164. 700r4 instead of a 4l60e wtf!
  165. could a 4L80e be stuck in second IF>>>
  166. flexplate ?
  167. Putting a '97 4L60E in a '95 Z auto car
  168. T-56 to 4L60E swap help
  169. Help with Tranny Swap
  170. $200 4l80e
  171. Transmission Swap T-56 to 4L60E
  172. found a 4l80e for sale, but.......
  173. Glide vs TH400
  174. Yank Converter Question
  175. 4l60e problems and ???????s please help
  176. 4L60E bottomed out.....
  177. need help figuring out which flexplate to use
  178. need some advice
  179. Shifter cable ?
  180. Is the picture of this solenoid a TCC solenoid?
  181. torque converter sponsors
  182. how much can my 4l60e take?
  183. Which Stall For My lt1 3200 3600 ???
  184. Will a stall from an '05 gto work on a '99 ws6?
  185. 4L80E with Transbrake?
  186. th350 quick fix NEED HELP ASAP
  187. Auto Trans Mount
  188. 4l80e manual
  189. 4L60E running hot at wot, what to check for?
  190. Anyone have any feedback on Coan stalls?
  191. TH400 w/ VSS
  192. whats a good trans cooler for a decnt price
  193. Everything you need to know about tranny coolers (4l60E F-Body)
  194. Have you broken anything since installing a high stall tc?
  195. th350/700r4 question
  196. Help with 4.3 to 5.3 trans swap.
  197. trans cooler
  198. stalling when wot
  199. Stall Slipping?
  200. What Can Cause A Stall Converter To Brake ??
  201. 4L80e guys, Where to get SFI flexplate for normal 4l80 converter?
  202. Trans Temp gets hot under full throttle, whats wrong???
  203. blowing through the converter
  204. I need some advice
  205. HELP!! dumping trans fluid
  206. So, looks like I could use a bigger stall?
  207. hypertech programmer
  208. Looking for a 4L60E tail shaft housing
  209. swaping in the th400, driveshaft modifying?
  210. Whats a 4l80e worth!
  211. Which fluid?
  212. Turbo LSx TH400 - noise coming from the trans area
  213. 4K Stall w TH400 on MS4 cam car...
  214. My py 3400 e converter some observations and questions?
  215. T56 to 4l80 swap now no speedometer/odometer?
  216. TCI flexplate and Circle D Tq Converter Question
  217. Need a vin for pcm swap... 99^ls1 auto prefer 02.
  218. Help with my TH350!!!
  219. looking for a pic and or a part number (tranny related)
  220. TCI 378000 trans pan... need filter extension or no?
  221. 4L60E not wanting to shift into 2nd.
  222. Looing for opinions
  223. Rebuild the old tranny or buy a new one?
  224. Trans lines
  225. I'm a new member of the Circle-D club
  226. tranny temps
  227. Is my 4L60E on its last leg?
  228. dumb question
  229. trans cooler fan
  230. Line Loc mount
  231. how can i tell if my transmission has been "built"
  232. 4l60e vacuum modulated?
  233. ran with low fluid at felt the trans slip slightly going home from track...
  234. '95 4L60E Valve body in '94?
  235. Help!!---Is my trans toast or is it just my tune???
  236. th350 swap and now RPM and mileage dont work
  237. 4l60e won't shift into 3rd or 4th! Won't get any readings under dash
  238. I need advice!
  239. Hit me with everything you know!!!
  240. Will the car weight affect how much power a tranny will hold?
  241. Cost to fix valve body on 4l80e transgo st3
  242. How hard is it?????
  243. Bolt patt?
  244. 4l80e Flexplate??
  245. What trans is in a 07 Buick Lucerne?
  246. bad valve body????
  247. Performabuilt Stall
  248. trans and a tune?
  249. RMVB shifter for 4L80????!!
  250. good 4l80 rebuild parts?
