- Poly Mount - Did I screw up?
- FLT guys in person.....
- Electric Shifter - What RPM Activator?
- stand alone cooler routing matter?
- need help with vss in mustang with th400
- 4L60E vs 4L80E
- 3200 vig and 3.73 gear ...good match ?
- A-4
- Help 4l60e shift problem
- Torque Conveter kicked my A**
- th400 (driveshaft) question
- 6l80 loss of pressure on hard launch
- HELP 4L60E and weird shifting issue
- TH 400 stall speed
- Vibration with new th400 install.
- Midwest converter sale? Should I?
- Does anyone have any pictures of a Yank Converter cut open?
- 4L60e Anybody running RPM level V ?
- Tranny cooler question
- Most power through a 4L60E
- 2600 stall?
- comp cams torque converter?
- WHAT TCI part # for turbo400 tranny?
- What flexplate for my 4l60e
- all you a4 guys
- My trans wont shift at WOT
- broken pump rotor
- m4 swap connecting reverse lights
- Cooler time
- turbo 98 camaro, build up a 4l60E? or swap to 4l80E?
- Just bought a Yank...
- I need some advice please. Flexplate to block clearance issues LS1/th400
- 4l60e? will it work?
- Flexplate locking tool (4L60e)
- What is a complete M6 to A4 swap worth?
- Looking for a glide
- 4L65 to 4L80 swap, wiring?
- stalled 100k+ guys
- Drive VS Overdrive
- 700r4 into 01 TA help
- TH400 Guys(help)come in again!!!
- Rossler "little Black Box"
- 4L80E needs some help!
- ? on TH 350
- 4l60e problem
- Speedo parts for my turbo 350 in my turbo 370LS SBlazer???
- 2000 firebird formula?
- possible 4L60E problem causing car to bog down?
- Tranny Wont kick down
- Midwest chassis torque arm
- HELP!!!! What Stall Is this? Was told a Vigallante
- tci flexplate
- will this tranny cooler fit?
- too much clearence= no 3-4 shift?
- building a 4l60e
- Help! 3000rpm @ 50-60mph??? 01 T/A Auto
- How to identify what valve body is in car? 4L60
- Will a 4l65e fit?
- tci kit? clutch pack clearance?
- Circle D converters
- hard lockup
- Bolt Size Question
- th400 filter tube thing?
- Yank ss4000 for 4l80e for sale
- ROSSLER 350t installed, (COOLER QUESTION)
- Stock 4L60E and a stall
- Ok guys I have a very serious question concerning my trans and a loan
- converter question?
- TH400 transbrake problems
- trans filter change on 95 z28 HELP
- Tailshaft lenghts on TH400
- Got a new TOY today, pics inside!
- what would be a good stall for my car?
- Can a Gen4-LSx PCM manual shift a 4l60e/4L65e??
- Could I swap a built 97 4L60e/converter into 98-02 LS1 car?
- Oh permormabuilt!!!!!
- 4L65E Lockup Issues... Please help
- 4l60e manual VB
- 3 speed shifter in a4 console
- Converter group buy???
- Torque Converter Question
- 6l80e cooling lines.
- converter info?
- 4l65e slipping
- 4L60E Issues
- buying a tranny that has been sitting?
- 347 c.i. ms4 cam stall help
- 94-4l60e pinout diagram of plug
- Possible transmission problems?
- How much do u stall at the line?
- B&M QuickSilver
- ATF change when putting in stall
- 4L80 Interchangable years?
- 4l60 trans build
- tranny problems please help!
- Anybody know what flexplate tp use with the LQ4?
- vac modulator in 4L60E =.9 MORE LEAN ?
- 02 4l60e diferences
- I have a 4L80e... will a T400 ScatterShield fit? Or a blanket?
- which auto is the smallest width and dont need a computer to control it?
- Will this B&M Tranny bracket work with the factory shifter cable?
- 4L60, fitting, cooler line?? HELP please
- Which flexplate do I need? 02 6.0, yank, and 4L80E
- What hose to use with trans cooler???
- Shift Kits
- Chattering with shifter in 3
- Th400 help!! Car doesnt move???
- I wish I had gotten a cooler with fan
- TH 400 converter question
- have a few questions before i dive into the tranny cooler install
- Corvette Servo???
- Need help, PCS TCM unit (M6 to auto conversion)
- 4l60e transmission pan???
- 4l60 HELP PLEASE!
- 4l60e trans removal HELP!!! Please guys !
- T400 Temp Sensor Pan Mounting???
- Need help asap!
- Turning off the INOP, Brake light, Service Vehicle, Security Light???
- What's involved/changed during a transmission tune??
- 4L60E output shaft swap
- 4l60e pump questions
- 6L80E in a 4th gen with an LQ9?
- help th400 wiring
- Brake light switch connectors, need explaination PIC
- Whats wrong with my 4L60E?
- 4l60e band
- 4l60E-3 trans go no mod 46 instructions
- B&M Trans Cooler 70264
- Yank Converters April Sale starts now!
- 4L6EDVD-servo cover blow off during dyno run
- What do you think broke?
- 4L60E issue
- My 4L60e Fail & Rebuild Thread - Lots Of Pics
- th 400 questions
- will a 4L80E Fit F-body
- LQ4 flexplate???
- 4L60E In Limp Mode
- 4L60E shift problem.
- Not sure I like this 3200 stall
- please help 4l80 line fittings
- Rebuilding pics of Corvette auto trans
- Torque Converter for TH400???
- Which auto tranny? Cheap and durable.
- 3200 stall for 700r4
- 3800 stall for a 4l60E. Will this work in my 2009 4.8L Chevy truck?
- Multi-disk converter
- flex plate
- 2800 stall
- 2-3 Shift Problems at WOT on A4 4L60E
- 3500 stall and rev limiter!!!
- two trans coolers?
- Speedo recal for TH400 with speed sensor
- whirring/whining noise...wtf?
- Did your stall improve your "Roll" races??
- Shifter cable bracket question....
- builders help please!! 4l60e problem
- question about the rev limit
- Looking at a TCI 242937 converter, any input?
- GTO M6 to A4 swap (have both gtos), Experts needed
- Anyone running a PerformaBuilt Level 3 4L60E come in please
- lol 6k m6 swap...?
- Weight difference between CAT flexplate and stock flexplate?
- 4L80E harness with 4L60E trans?
- Overdrive problems
- Looking at stalls, anbody use the Boss Hog?
- TCI Converter Question
- 4L60E to Th350? Gurus come in.
- 60ft times with stall
- What happens if my gauge does't get a full 12v?
- ready to have my vig 4000 rebuilt
- th400 into 95' z28
- Built 4L60E question
- what to do for a kickdown cable
- 4l60e not going in revers good and 3rd
- TH400 People Come in
- Two questions
- BMR th400 crossmember?
- vacuum issue with th350
- Won't Shift into 4th
- car wont move
- How long will my stock automatic tranny last
- how much power can the th400 trans take?
- switching over to TH400
- will a 94-97 4l60 work on an ls1?
- looking for flexplate 4l80e
- 4l60E gurus needed!
- Quick tranny question
- 3rd and 4th slipping after rebuild and stall? why is it acting like this?
- Dexron VI?
- Part Number Question
- sprang a leak!
- 4L60 Manual Valve body
- Just put in new stall and now have a lock up question
- 700R4/4L60 no line pressure increase while driving
- What fitting will allow me to go from the stock tranny cooler lines to AN?
- Pump Body Bushing Replacement?
- 02 camaro stall v. trailblazer stall
- VehicleSpeedSensor concerns 4L60E
- torque converter question
- orificed cup plug
- something broke???
- 1992 4l80
- Autometer sensor in the pressure port help
- B&M ShiftPlus Electronic Shift Improver Kits
- th350 to 5.3 problems.
- Stalled Daily Drivers plz come in...
- 4L80E Slip Yokes (Backordered)
- Coolers....
- 4L80E crossmember question
- Anyone ever use an ACC Boss Hog tc?
- Someone just explain to me what i have to do to support 500HP
- my car is thorwing a code
- 4l60e major tranny PROBLEMS need help
- shift kit question
- Can a 5 or 6 speed auto be fabbed for 4th gen FBody's?
- Dumb Question. Pilot Bearing?
- 4L60e Question
- Trans cooler for 4L80E?
- Trans cooler mounted under car?
- 1400rwhp 4l80e
- 4L80E swap, best mounting solution
- 4L80E? or 4L60E?
- stall + 120,000 miles
- might be a really dumb th400 Question
- No Second Gear in My 4L60
- FTI'S new WEBSITE IS LIVE Check it out!!!
- M6 to A4 question about speed sensor and stall
- Stall install advice
- Any one using the "The Beast" sun shell?
- Are there any good high hp transmission rebuilders near 62401 IL area?
- Another 4l60e problem
- Broken input shaft?
- Need a trans...
- will a stall eat my tires off?
- proper line cooler routing for my 4l80
- best place to take trans temp from? What gage?
- Does your shift kit do this
- those with fan on trans cooler
- How hard is it
- converter bolts dont fit???
- Need ur opinion
- Anyone install their own Trans-go stage 3 kit?
- Finally got my car Yanked!
- 4L60 Transbrake Drama's
- 4l60E transbrake by TCI
- Where the hell is C200 Pin E???--- m6 to A4 swap
- Pulling the tranny
- Anybody run a powerglide in a heavy car?
- Opinions on TH350 build
- Shift lock wiring and PNP?? Searched stickies and have a question
