View Full Version : Automatic Transmission
  1. I need help finding parts!!!!
  2. e clips on trans lines
  3. 2009 4l70 question
  4. How do you identify what year vehicle a 4l80e came out of.
  5. new trans and converter
  6. A4 info
  7. glide costs
  8. Whats the best tranny cooler?
  9. Does my stall need to be refreshed? (4L60E w/3500 stall)
  10. installed new FTI converter
  11. Speedometer
  12. 4L60E Tranny Question
  13. What filter
  14. Just bought a stall. TCI? Auto guys help me out. Should i use a saw zaw??
  15. 4L60E problem?
  16. Just a few questions about stock and stalled ls1's.
  17. th400 and boost?
  18. th400 crossmember adapter?
  19. Lokar Dip Stick
  20. LU Solenoid problem?
  21. Trouble with bolting convertor to flexplate, th400 swap
  22. Tranny Rebuild
  23. Why does stalled auto feel slow compared to 6spd?
  24. whats the difference in a 94 4l80e and say a 2003?
  25. 4L60e question
  26. tranny rebuilt kits
  27. 3rd gear slows me down in my Th350
  28. Does it stay in limp mode?
  29. th350 build
  30. 4L60E is tempermental, any help???
  31. 4l80e conversion crossmember with torque arm mount
  32. Low RWHP...could it be the Vig?
  33. yank ss
  34. How big does your 4L80E trans cooler have to be?
  35. Looking for a 4l60e trans pan, with drain plug? advice
  36. Stock Temp Sensor Accurate?
  37. Need guidance...
  38. Question for RMS425 about TCI 6 sp auto
  39. 3.70 gear th400
  40. My Quarter Stick doesn't have a reverse light switch
  41. 4l603 stall trouble
  42. need help seperating bellhousing!!!
  43. Transmissions swap to 700R
  44. Transmission line?
  45. V6 vs V8 4l60e
  46. lauch alternative
  47. Circle D Transmission 6L80E Upgrades
  48. Anyone running a 4L80e with a 10bolt???
  49. Cant get shifter assembly inside trans back together
  50. Trans cooling lines
  51. replacing shift linkage seal in trans, now cant get linkage back how it was.
  52. Question about ratchet shifter install
  53. 4l80e with lq4 question about computer and custom harness and tuning
  54. Transmission problems, help please
  55. not sure what it's worth??
  56. What are these?
  57. In the market for a tranny and stall
  58. 5.3/powerglide question
  59. Anyone have pics of the wiring ???
  60. Simple Question
  61. 4l80e shifters
  62. 93-97 98-02 trans crossmember powerglide
  63. Launch & Shift RPM on A T400 Transbrake???
  64. Transmission Perform button and its relation to your gears
  65. th400 bellhousing bolt troubles...
  66. Transmission service question
  67. Shiftlock and pnp
  68. Fresh Trans Seems To Be Slipping... HELP
  69. 1995 impala ss ls1
  70. what trans fluid
  71. Transmission filters - Which one do you use?
  72. LQ4 Flywheel and spacer w/ 4L60E, will it work??
  73. ???~m6 to th400 why or why not~???
  74. order my converter
  75. RPM hovering / Converter locking up under WOT, not down shifting
  76. Rossler 60e manual
  77. Any Performance Tranny Shops In/Around Ft. Lauderdale?
  78. Thumbs Up Circle D!
  79. General 4l60e question
  80. Thoughts on 7500rpm shifting with 4l80e stg3 transgo
  81. 98 Z28s shifter button sticking?
  82. identification of 4l60e
  83. ls6 stall size
  84. need some advice please?
  85. Transmssion and torque converter LSx swap help
  86. refill the converter or not?
  87. TH350 or TH400 for LT1 Nitrous Camaro?
  88. tip and tricks
  89. Big stall + nitrous questions
  90. tranny help with driveshaft
  91. Borg-Warner high energy or Raybestos stage 1 frictions for 4l80?
  92. Getting new rad should I get one with internal cooler ?
  93. Any difference from an 02 4l80e to a 05 4l80e??
  94. 4l60e only shifts 1st and 2nd gear
  95. help what to do
  96. pnp switch
  97. TH400 what convertor should I use?
  98. Trans Fluid Help
  99. 10% off all RPM Transmissions and Differentials !! Free shipping !!!
  100. will th350 fit lq4
  101. what stall is best for me
  102. 4l65e Input and output shafts
  103. Need Performance parts 4L60E in my truck
  104. Tranny Mount
  105. 6L80E bellhousing
  106. Another P1870 Fix Question
  107. Looking to upgrade stall for street strip duty. Any advice??
  108. Stall.. Sponsors come on in.....
  109. Need a part number please.
  110. Which Torque Converter
  111. Need help
  112. SPONSORS, do you offer trans rebuild kits?
  113. hardened/billet input shaft for 4l80e and 800 rwhp?
  114. powerglide trans
  115. CAT Power flex plate bolt torque value
  116. vibration problem
  117. 4L80e TransGo HD2 shift firmness
  118. LQ4, Rebuild 4l60E?
  119. Can someone please explain the str rate
  120. th400 question
  121. Torque converter swap
  122. 95 4L60-E bolt up to a LS motor?
  123. Help me choose converter
  124. Circle D 230mm 5000 stall VS Yank PT4400
  125. Yank stall come on in
  126. Aft VI?
  127. Circle D - We Want You! Tax Refund Sale
  128. Difference between 4l60e in 3.8 and ls1
  129. lock up in powerglide
  130. Looking for Stall under $700
  131. Cant Get Bellhousing Bolts
  132. shifting problems! HELP!!!!!!!!!
  133. 4l60e slipping in 3-4
  134. Aftermarket shifter for 4L60E? what are some options?
  135. 6L80E Factory Torque Converter Question
  136. Anything to replace when VB is out
  137. Manually shift a4
  138. 4l60e 96 to 94 conversion
  139. YANK converter Tax Return Specials
  140. vehicles that came stock with 4l80?
  141. What's my 60' potential?
  142. th-400 tranny temp sender?
  143. TH400 question about streetability
  144. Problem with torque converter/flywheel
  145. 4L60E wiring help
  146. Whast the fix ???
  147. th400 problems
  148. Should I swap my TH400 for a Powerglide?
  149. LQ4/4L80E in '85 Buick Regal
  150. 2-3 Shift Solenoid
  151. Is this a bad idea...
  152. 4l60 overhaul parts
  153. How does the back-up light switch work?
  154. 2002 Z28 A4 Acceleration Issue. Please Help!!!
  155. Getting ready for the 4l80e rebuild
  156. anyone used these? 4l80 mvd w/tb?
  157. Flexplate for LS/Powerglide
  158. couple questions?
  159. Powerglide or not?
  160. Driveshaft
  161. another noob 4l80e question
  162. Trans Brake in a 4L60E
  163. Need help with 4l60e...
  164. Anyone using a Yank torque arm relocation?
  165. need p/n for gm flexplate spacer bolts, 5.3 to th400
  166. Stall
  167. lockup slipping
  168. Who's got a 6 speed auto with aftermarket converter?
  169. 4l60e shift cale/rod
  170. Performabuilt 4L80e owners come in
  171. Powerglide question
  172. M6->TH350 swap - clutch switch wiring help needed
  173. Vig TCC Slipping?
  174. 4l60E W/Stall slips between shifts 1-2 2-3 @ WOT
  175. v6 auto = v8 auto?
  176. What Stall
  177. Free Th400 speedo, rear ABS?
  178. Ok trans gurus see how good ya are.
  179. PTC converters any good?
  180. ? About Tranny Temps!
  181. YANK SS4000 Install
  182. How to tell if a flywheel is warped or cracked??
  183. What cooler is better?? OEM fin type or tube type
  184. 4l60e from a v6 ?
  185. 99 Trans 4L60E won't go into gear
  186. need to know if this is right
  187. t-56,clutch and shifter for trade
  188. Converter unlocking?
  189. 3.73 gears
  190. 4l80e filter chg. fluid amount
  191. best converter for F-body's?
  192. How many types of pnp switchs on 4l60e???
  193. Transgo or B&M
  194. lock up converter?
  195. 4l65e problem
  196. No speedometer,odometer or trip
  197. stall or gears for DD?
  198. Which 4l80 is Best
  199. Best Tranny??
  200. Vote on what trans i should use in my 63 turbo nova
  201. Transmission gearing
  202. Trans cooler
  203. PATC 4L80e
  204. 4l60e rebuild
  205. 4l60e problem with pictures
  206. People with 400's running a blanket.
  207. prnd switch? 4l60e
  208. 6l80
  209. how do I install a mvb in a 4l60e?
  210. caution! 1-2 in th350
  211. please help 4l60e leak
  212. 98 Pontiac Trans Am Finish Line 4L60E Tranny issue
  213. Safe to tune out P0757 P0756
  214. 9.75 stall converter ?
  215. what tranny to run behind a 500hp LY6
  216. *VIDEO* Driving with a Yank PT4000 *VIDEO*
  217. 5K Stall to much???????????
  218. strange transmission leak please take a look thanks.
  219. Turbo 400 Long or Short Tail
  220. 4l60e problem
  221. How much fluid in a 4l60e?
  222. A4 auto trans wire harnes ?
  223. Locking dip stick
  224. 4L60E What type of fluids are you'll running
  225. once and for all... What power loss?
  226. Whats the largest stall for street
  227. can I tune for a converter using...
  228. 4l60e rebuild versus buying 29K mile 4l65e
  229. Tranny pump,where & is it part of rebuilding?
  230. Tranny??
  231. T-56 to TH400 swap need a converter
  232. Basic upgrade t400 handle?
  233. 3200 or ????
  234. looking for some opinions
  235. POWERGLIDE or TH350 TO LT1
  236. Swap in it ouT!
  237. Circle D 3200 torque converter
  238. well built 4l60e finally went out at 766rwtq....
  239. Cam to match 3400 stall?
  240. ?mvb in a 4l60e
  241. Car dies when put into D and R.
  242. in a dellema
  243. TH350. How much weight do I need to drop?
  244. ok so i have a problem....transmission i think
  245. Bellhousing bolts question.
  246. Anybody have a Yank SS4000?
  247. how long will it last
  248. 4L80E compatability
  249. stall size
  250. Want to give thanks to Greg@FTI
