PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
  1. need clarity for TH400 behind LM7
  2. which trans cooler
  3. 4l65e shifting problem
  4. 4L60E Shifting Issue
  5. 4l60E Torque Management?
  6. racing shifter for 4l80e
  7. 3200 stall good for cam only car???
  8. cooler fittings
  9. No WOT 2>3, out of ideas
  10. devastated torque converter
  11. DD stall
  12. 45* -6AN fittings don't fit off trani?? Help!
  13. Lazy 2-3 shift.. How much time lost??
  14. WOT good- let off, out of gear
  15. 4L60E...will a 1998 tranny work in a 2001???
  16. B&M 70274 Cooler and Braided hose install!!
  17. hard shifting and banging
  18. Any 1 kno the Size of the threaded nipple on a energy suspension mount..
  19. manual valve body
  20. Converter unlocking more than usual in the last 1500 miles????
  21. Looking for vid of yank 3400-3800 stall or other brand 3400-3800 stall
  22. Yank ss4000
  23. Mixed up the trans lines.. Help..
  24. Where to get shiftlock and PNP switch wire pigtails for M6 to A4 swap
  25. Major mystery with two 6L80s
  26. TH350 Electronic Speedo Conversion
  27. New 4L80E question
  28. Can i send my 4l60 converter back to precison and get it redone for A TURBO 350
  29. Tune after stall?????
  30. hughes 2500 stall converter only preloads to 1300rpm, what gives?
  31. TC lockup
  32. HELP, need a powerglide crossmember FAST
  33. Flexplate for 4L80E Swap
  34. No reverse 4l60e after rebuild
  35. Circle D Sexiness
  36. Tranny Mount
  37. Trans shifting late and hard
  38. 4L80 Flex plate ?s
  39. Th400 whine after trans brake launches
  40. A6 trans in an L98 3rd gen?
  41. th400 problems
  42. which flexplate
  43. 4L60E Pump Grenade - Now What?
  44. Wheel spin at launch.
  45. TH400 with M6 crossmember?
  46. help me make a grocery list!!! 4l60e build
  47. Jake's Performance Summer Sale
  48. trans choices, 98 sierra.
  49. Transmission Cooler On Vortech Supercharged Car?
  50. stall
  51. 4l60 whining in neural/park but not in gear.
  52. Ported maf and line pressure
  53. How to diagnose 4l60e? VIDEO
  54. leak at front of trans?
  55. TH400 stall adapt to a 4.8?
  56. What ever happened to .......
  57. post pics of shifters
  58. Built 4L60E not upshifting at full throttle
  59. anybody know where i can find this flex plate
  60. Are the 1997 and down suburban 4L60E's the same as a LT1 camaro 4L60E?
  61. how does torque conv. unlock? 4l60e
  62. engine swap with (auto trans)
  63. Anyone help with my TH350 on my speedo
  64. Trans vibrates !!
  65. Flushing a Torque Converter?
  66. 4l60e issues
  67. 96 LT1 B-Body TC stall question
  68. Stall For A 228R Cam
  69. What Stall for 4L60E .... please .
  70. New converter?
  71. Custom trans mount?
  72. 4l60e with tci trand scat kit and servos 1>2,3>4
  73. Which hose is the pressure side of a 4L80E
  74. Anyone using the new th400 JW Ultra Bell ls1 bellhousing?
  75. 4L60E wont shift into park.
  76. stalls in dirt?
  77. identify this th400 shifter!
  78. 4l60 to 350 turbo
  79. 46l0E will not drop into gear
  80. what level 4l60e for 750 rwhp
  81. who uses b&m linkage for th350 few ?
  82. 4l60e th400 swap
  83. What shifter did you use for your 6L80?
  84. *6l80e*transmission for sale
  85. t56 to 4l80e power loss
  86. 4l60e or 4l80e
  87. Anyone still run vaccum modulator even with full mvb
  88. Cooler hose and fittings.
  89. 4l80e neutral safety switch help
  90. Daily use transmission for 850rwhp+ ??
  91. having a hard time installing my tranny cooler any good ideas
  92. Is my gear gonna hold an 427 stroker engine ?
  93. whats your opion on this stall
  94. circle d or yank?
  95. Does anyone use a stock 4L80e converter?
  96. SFI LS Flexplate special at Yank
  97. Bad Luck???
  98. Shift Kit or Electronic Shift Programmer?
  99. Pulling car to track with trailer (700r4)
  100. trans fluid and flush question
  101. WOT shifting (3rd to 4th)
  102. 4L80E output shaft question
  103. Torque Converter Shudder
  104. Fixed my tranny mount but still feels a nocking every time I step on the gas hard..
  105. External filter & cooler fittings?
  106. TC Disabled & Shifting Problems
  107. Will 1998 c2500 4l80e work with an ly6?
  108. Used tci super streetfighter help
  109. 6L80E fill plug/dipstick part number?
  110. Some questions on Hurst 1/4 stick
  111. arp flexplate bolt tq specs.
  112. Cross Contamination - 6L80E in a Truck with Corvette Driver Shift Control
  113. Ratchet shifter help!
  114. 1994 4l60E 1 2 upshift problem. No 2nd gear??
  115. issues after rebuild, got a ??
  116. Trans still short shifts ???????
  117. need someone to help me figure out my transmission issue
  118. Is there a best place to mount sending unit on tranny pan
  119. Gm Trans cooler lines
  120. shifting with trans brake
  121. 1995 LT1 Auto Trans pressure problem
  122. Questions bout torque converter
  123. Anyone heard of running John Deere fluid in a th350
  124. good 4l60 rebuild kit?
  125. 98 4L60E lockup on/off switch, benefits??
  126. 4l60e won't reverse until 1500rpm
  127. What would cause....
  128. 200-4r question
  129. transmission mount ?
  130. 05 GTO wont go into gear
  131. Starter Grinding on new flywheel...
  132. question on converter
  133. 4L60E, 2 questions
  134. Got 70k miles on the converter...
  135. Th350 Speedometer Cable Block Off?
  136. Jake's Performance dyno
  137. PTC converters
  138. 5.3 w/TB converter whats needed?
  139. Putting my 4l60 back together and everything is going well but...
  140. So I blew my cooler line going down the highway
  141. Transmission Problems 99 Trans Am **VIDEO INSIDE**
  142. 3600 Sound about right for me...
  143. Torque Arm Relocation with 4l80e
  144. hurst shiffter for a4 4l60
  145. 97 Z28 Camaro Help
  146. What stall for ms3
  147. 4l65E
  148. is my transmission slipping?
  149. How much power will a stock 4l60 hold?
  150. Need opinions on what to do (TH400 or built 4L60E
  151. trans short shifts to 2nd ???????
  152. Temporarily lost 1st gear?(4L60E)
  153. Transmission lost 2nd gear, what internally would cause this?
  154. Trans doesn't shift
  155. What Speed Sensor?
  156. Started my 4l80e Rebuild 2 night! 6/10/2011
  157. 4l60e stall in a 4l65 will it work?
  158. Shifter Cable for TH350/Ls1! Where can i buy one!?
  159. older 4l80e to ls1 bolt pattern
  160. Installing 700r4 and yank converter
  161. TH350 questions..
  162. Speedo stops working then trans shifts funny
  163. Going to power glide...does anything need to be done to PCM?
  164. Tranny cooler question
  165. Re-mounted my trans cooler
  166. Strange 4L60E Issue
  167. 4L60E shift solenoid bore
  168. 4l60e stage 4 yank ss 4000 problems
  169. 4l80 ?
  170. Stall a high mileage transmission?
  171. FTI converter results
  172. fluid pricing
  173. Thinkin about goin to an Auto..
  174. M6 to A4: Using a M6 harness with an A4 trans?
  175. Shifter Cable Linkage Issue
  176. What stall and size converter for DD
  177. warped flexplate, aftermarket replacement ops?
  178. 150 miles enough for brake in on new stall?
  179. questions about stalls
  180. overdrive problems?
  181. 98-02Fbody trans cooler lines
  182. Stock Stall speeds
  183. Torque Arm and a TH350
  184. shift kit capacity questions 4l60e
  185. Help rpms shoot to 3,000 and drop back down for no reason
  186. rear end issue possibly..due to OD?
  187. a4 Trans am Shift points
  188. trans cooler lines
  189. Most miles on 4L60E
  190. Please step in, th400, lock up issues
  191. horsepower difference between 4l60e and 700r4
  192. flt level4 binding up
  193. 1995 Z28 Transmission pressure problem
  194. 4L60e Vent Tube?
  195. Th400 help asap
  196. s-10 4l60
  197. 4L60E - No 1st Gear...??
  198. 4L60e what happened and what do I have to replace?
  199. Boosting in Overdrive?
  200. 4l60e no line pressure?
  201. Part number for pigtail adapters for shiftlock/pnp on T56 -> A4 swap
  202. Truck tailshaft housing swap questions
  203. th400 swap
  204. Circle D - Custom LS Flexplate
  205. Full manual on an early 4L60E
  206. issue after 4l80e
  207. Who sells slip yoke (stock U-joint, stock alum DS, 4L60E, 2001/2002 F-car)
  208. Circle D - ALS Charity Event
  209. 4L60E Woes.... P0758 Help!?
  210. Boosted line pressure w/ built 4L60e
  211. Need help with 5v reference for the VSS
  212. new rpm trans?
  213. ratchet shifter
  214. 4l80e question
  215. installing converter it wont *Lock* in
  216. new member question
  217. 4l60e leaking from rear??
  218. Urgent!!!! Powerglide to lq4 problem---SOLVED---
  219. how's my ddipstick 4L60E
  220. A4 Trans mount
  221. need some th400 help
  222. cause of flexplate holes getting bigger
  223. RPM 4l65 limits
  224. problem with trans after new motor
  225. transmission fluid low....am i missing something
  226. A4 Burning up?...
  227. Best auto for my car?
  228. 2-3 upshift flare
  229. Sponsor Installed A4's come in
  230. went non lock up have questions
  231. trans mount shot. question about polly mount
  232. DD Stall
  233. 3rd Gear TCC lockup and TCC Lock
  234. Jake's Performance Memorial Weekend Sale
  235. anyone ever use this kit?
  236. Opinion on this rebuild kit.....
  237. Automatic shifter knob removal?
  238. 4l60e
  239. Question for the MVB 4L80E experts
  240. Will a 93-97 4l60 work in my 98
  241. shimming the converter
  242. 4L80e/Transgo experts inside please
  243. 4l80E dipstick *please add this to the sticky*
  244. Is my A4 toast?
  245. Circle D - Facebook
  246. Best deal on a yank or circle d converter?
  247. Turbo 400 stuck in gear
  248. 4l65e Upgrades
  249. Maybe my tranny?
  250. Every single flexplate bolt broke onto crank.....
