- Stall on 4l60-e??
- My SS3600 Converter Experience
- Top Speed in th400??
- Need a new shifter cable for my 93', which years will fit?
- Can it be done? And can I get some guidence?
- Edge Converters Any Input?
- More Fuddle Converter Results!
- 4l80e Crank Spacer
- Variable speed torque converter? Trans experts come in.
- B&M Super cooler guys (with fans)..I need help
- car will not come out of park !!!!
- 4L80 tune no longer *required*
- Urgent question for the torque converter professionals
- upgrade questions
- What changed on the 4L80E between 2003 and 2004?
- How do you remove the trans with solid mounts
- 4L80E swap with TCI controller; what are my speedometer options?
- th400 help!!
- 4L60E to TH350
- is a shift kit worth putting in.. newbie needs help!!
- ok well here goes another try at it..
- Tranny shifting hard 1-2, 2-3
- 2-3 Banging red at WoT
- lets play name those pieces of metal....
- TH350 Transbrake, FMRVB, rebuild kit?
- When you switched from m6 to auto how did it effect your mph and times?
- auto newb!! newb ?'s
- "transmission or speed scensor?"
- 4l60e no reverse
- How to control 4l60e on trans dyno?
- 6L80E upgrade
- Performabuilt stg2 4L60 guys..
- Ford to Chevy universal joint?
- will my 4L60e hold up
- vigilante converter mounting issues
- auto shifters
- anyone with a performance built level 2 or 3 wanna go 6 speed?
- 700r4 swap question
- upgrade for 4l60e
- Bending the dipstick tube
- car wont move
- car drives forward when i park :-(
- Transgo servo mod
- pt4400 install. Whine/Whistle!!
- TH350 noise?
- gearstar lev 4 4l85e pics
- tranny dipstick.... so stupid
- what year 4l60e?
- Tune and Stall question
- Stall ?
- Selector shaft seal
- 4l60e removal questions
- 4l60e and 4l80e... differences?!?!?
- Getting rid of my T56... Yank, TCI or Circle-D???
- If I'm just doing 1/8th mile wouldn't 2.5 STR converter be the best option
- Help! Need Info on wiring and running issue after doing a m6 to a4 swap?!?!?!?!?
- My VIG3200 just seems loose?
- How much TQ management on stock trans.
- How does your trans go plate look new?
- Shift Kits, Good or Bad
- Is This Bad for the Tranny?
- lock up switch
- Torque spec for tailshaft to housing bolts?
- Yank Converter Sale September
- 4l80E driveshaft/yoke question.
- c6 6l80e swap to a 4l60e has anyone done it?
- Interchangeable Flywheels??
- tci flexplate issues
- How do you change out the flexplate ? ? ?
- About to change to either a PG or th350, don't know which based on.....
- Built 4l60e
- Th400 shifer linkage?
- NON ls convertor to lQ4?
- 4l80 guts in a 60?
- What should I expect with my new stall and cam?
- New Best! FLT Level 7 and Yank PY3600 go 9.38@153.6
- This is a different PG, th350, th400 vs m6 question
- 4l80e guys come in!!!
- TH400..... problems.
- 4l60e question need an answer
- Do u need kickdown cable? and need part part numbers
- Question on a Th400 Swap into A4 GTO
- Very soft shifts after TC install
- Anyone running 390 gears in there LS1...
- what will brake??
- what size circle-D converter? 150-225 shot
- Circle D Restalled TB Converter
- 200 4r ball diagram
- 700r4 no 3rd ?
- Which 700r4 should buy for LS1??????
- shift kit worth it on a stockish car?
- Trans Issues??
- LS1 stall in an LT1 car??
- Couple of 4L60E MVB Questions...
- Shift kit?? & Torque Managment???
- Transmission interchange question
- No Drive Or Over Driver 4L60E
- auto shifter
- Gto trans
- 2004 Nissan Murano Transmission with crack in shift lever
- speedo?
- B&M shift kit...plug 3-4 clutch hole?
- Interesting Shifting Problem
- Recommend me a good LS1 flexplate..
- th400 VSS
- 97' 4L60E question
- TransGo seperator plate
- Lightly modded ws6 a4 ss4000 stall or no?
- tci th350
- Yank Stealth Thruster 2800
- transmission suggestion for build
- Ratchet shifter?????
- 4L60 questions
- need a trans please read
- TH400-what to tq trans pan bolts to?
- 97 4L80E Converter
- Do you see a problem with this?
- Trans fluid..Which is best for the buck?
- Stall question
- Summit TH350 Transmission?
- Stall and cam dilemma
- shipping a 6l80e
- what stall?
- Cooler Lines Leaking
- strange sound/vibration when shifting
- Fti bolt together lock up converter
- Where can I get this fitting??
- Quick Clarification please on RMVB, TCI won't respond to my emails
- 4l60e LEAKING
- PerformaBuilt Post Labor Day Sale Now through Friday!
- fastest 60 ft on drag radails
- New Pro Yank 3600 and FLT-VII go 152.64Mph
- 4L80E Slip Yoke (I've read the stickies)
- What keeps a tranny from shifting before fuel cutoff & rev limiter?
- ATF leak at the output shaft; it's not the seal.
- cost of rebuild
- Auto Trans Question
- A4 crossmember and driveshaft questions
- 4l60e transmission line help
- T56 to a4 back to t56 question
- looks like my aps turbos outlasted my th350
- more trans problems please help.
- Problem came back
- Anyone using Rock-On Transmissions?
- 4L60 no first gear
- TCI flexplate Q....4L80 application
- Lt1 retune after stall ?
- SS3600 to SS4000
- 4l60e help funny in first gear and bad down shift
- ss4000 converter ?
- New torque converter whining
- yank 3600 VS 4000
- Drives in 1st and reverse only!
- LS1 4L60E Length
- wish i knew
- what do 3.23s run rpm wise at 70, mph?
- help with the converter on my turbo car, converter gurus????
- TC install, is this bad?
- P0751 Code Question
- TH400 tailshaft difference
- 4L60E/65E Longer Tailshaft?
- transgo hd2 shiftkit
- 4l60e Camaro question,
- Question about clutch packs..
- Torque Converter
- south florida th400 800-1000hp tranny builder?
- torque converter lock up
- What stall would you recommend?
- Th400 Oil?
- Horrible stupid problem please help
- STILL having problems with this POS 4l60e
- how much power can a stock 6L80E take??????
- TH400 guys, what OTC fluid?
- trans cooler
- 408/Auto guys come in....
- 03' 4L80E what upgrades do I need to do?
- t56 or built 4l60e with 3400 tc. which is faster and which do u recomend
- clicking sound
- 4l60e low roller cluch? limp mode? or?
- 700r4 swap
- Continuously Variable Transmissions
- 4l80e or turbo 400????????
- 4T65, can it last?
- A cam with a stock 4L60E?? Crazy or not??
- used stall question
- a4: drive vs overdrive
- 4l80e Fluid level?
- 4.10s for a4?
- What does STR mean?
- Wont go into lockup!
- 4l80e swap on a 98 z28 camaro
- Vigilante Stall Question
- Is there a way to monitor transmission slip with a scantool?
- Done with the 6 speed.. Need info on parts for th400
- Fuddle converter guys, what do you trap (MPH) in the 1/4 mile?
- 400 trans rattle when turn car off
- tailshaft seal?
- trans feels like slipping after burnout
- T brake question and cooler suggestions
- tranny
- what flexplate for a th350?
- TH350 won't go into gear after pass unless I rev it
- WTB 700-R4 1990 K5 blazer
- Problems with a PI 4k
- circle d converters
- trasnmission problem
- Can I use a 700 trans with this engine?
- 4l60e or 700r4 need help !!!
- Building a TH400.. What's needed?
- What do YOU recommend?
- Need alittle assistance with center console
- Manual Valve Body Stock A4
- C.A.T. Power FP with ARP FP bolt- shimming FP questions
- TCC Slippage.
- another tranny problem
- New Gear ratios for the 4L60E from PATC !!
- Will a 700r4 converter fit my 4l65e !?
- torque converter doesnt fit t400 to lq4?
- 4l60e problems....any ideas?
- tranny help !
- 4l80e clutch kit opinions??
- Rossler man shift kit
- 2 step on an a4
- Home made teflon seal tool
- Trany Mount??
- 4L60e to TH350
- how long . . .
- How much slower is an A4 stock compared to M6?
- Shift points
- Attention attention
- 4L80E in LT1 TA
- 4l80 E HELP PLEASE
- Need shifter for a4
- Need ls1 sfi flywheel
- Those with aftermarket converters step in...
- Anyone use anything BESIDES Lines?
- Ive broken my Circle D Convertor..
- New idea(maybe) for trans cooler location
- 4l60e reverse problems!! Help
- Getting Tranny Beefed Up- HELP Quick!
- 13 pin connector on 4L60e? (TH400 swap)
- best turbo 350 converter
- Sprag Mod ?
- LQ4 bolted to old style 4L60E
- th350 high power build
- No forward gears
- 4l60e shifting issues
- Performabuilt Transmissions
- FlexPlate question with Th350..Help!
- How much does the stock ls1 flexplate weigh?? (2001 A4)
