View Full Version : Automatic Transmission
  1. Tranny fluid
  2. Yank Converters?
  3. fti install need help
  4. Clunking noise under Accel/Decel also over bumps!!!
  5. My DD T/A transmission is going out...
  6. Transmission feels like in Neutral
  7. 4t80e
  8. WOT shifting problems
  9. 4l60e bucking after rebuild, BUILDERS INSIDE.
  10. Shifts a little soft, took pressure readings, need advice
  11. Metal "tink" noise when going into gear
  12. Tranny only leaks when I hammer the car??
  13. tcc 04 gto
  14. Shift lever position
  15. Shift problems
  16. Transmission cooler W/Fan Wiring Questions?
  17. 4l80e problem on my first test drive
  18. Hurst Pro stick in a 6 spd console
  19. TH350 For Sale
  20. torque converter question inside
  21. couple ? with trans
  22. Is my tranny giving up??
  23. Replacement trans
  24. trans. fuild change ? on TC fuild
  25. '04 GTO A4......Corvette Servo?
  26. are neal chance converters worth it?
  27. pressure port an acurate place to measure trans temp
  28. Is my 4L60E dead?
  29. b&m shiftplus+ install?
  30. 4L80e Sun Gear Shaft Bushing(s)
  31. Newbie Question
  32. so who running tci 399753 with th400?
  33. i finally found the perfect 4l80 rear fitting
  34. Sufficient cooler?
  35. Line pressure issue?
  36. Tranny Similar To This For 4l60e?
  37. Keep 700-r4 or go to 4l60e?
  38. 1st gear is locked?
  39. The 4L60E "IMO" ...
  40. Broadcast codes..
  41. how often should trans. fuild be changed
  42. th400 Converter in a 4l60e?
  43. Thanks Chris- Circle-D
  44. First time out with the Yank SS4000
  45. 4l60e Pump vane clearance
  46. 305 TPI 700-R4 TV/detent cable
  47. my gear, with TH350?
  48. 9 days left on FTI converter SALE
  49. Having obd1 4l60e trans issues
  50. Anyone break a stock trans mount with poly motor mounts and relocated torque arm?
  51. Won't move with shifter in OD
  52. personal experiences with 3600stall
  53. Help Car doesn't move.
  54. No reverse lights after auto swap?
  55. delayed 2-3 shift..billet servos installed
  56. 4l80E into 97 Z28
  57. Hey you guys
  58. Thanks again to FLT trans and FTI verters
  59. Thanks Rossler Trans.
  60. Replacing my transmission, question about converter.
  61. Hard kick when putting in drive after LS1 swap...
  62. Tranny starts in 3rd sometimes?
  63. Looking for a good shift kit
  64. Is this normal for the tailshaft??**video included**
  65. Converter Won't Seat
  66. Blowing though the converter?
  67. Car on the lift in neutral, should the wheels spin?
  68. I need convertor selection
  69. Shifting problem
  70. Thanks PerformaBuilt T400 still tunning the car.
  71. What torque Convertor do i need
  72. G8 6L80E trans output shaft
  73. any builders have problems with torlon balls on old plate?
  74. wot shift into 4th?
  75. Broke shifter cable
  76. TH400 swap shifting early, help!!!
  77. lockup
  78. autozone flywheel?
  79. any ideas???
  80. Yank SS3600 or SS4000??
  81. 4L60E hanging in 2nd..
  82. Converting from older aluminum pistons in 4l60e?
  83. 4L60E Difference in 4.3's awd 4x4???
  84. shuddering after trans rebuild
  85. Trans Overdrive Issue
  86. Gear vendor speedo issue
  87. Ok guys I really need some suggestions
  88. Converter question
  89. No reverse when warm
  90. M6 to TH350
  91. tranny cooler question???
  92. Who's running an aftermarket TC+stock tranny?
  93. Lockup for Transgo 4L80E FMVB
  94. Big hp guys what trans mount are you running?
  95. New stall, my old oil cooler good enough?
  96. Hughes rebuild kit for a 4l60e
  97. New 4l60e and convertor. now stuck in between gears?????
  98. slow shift
  99. Aftermarket shifter or knob that works with auto console?
  100. need some ratings on a 2800 stall?
  101. What are you TH400 guys running??
  102. part number for transgo kit
  103. Shimming Coverter?
  104. Rev Limiter?
  105. th400 swap drive shaft ?
  106. LT1 4L60E Vs LS1 4L60E?
  107. vig 3200 and bolt ons, what to expect?
  108. M6 to 4L80e or Th400 (various questions)
  109. Switch to Yank results in three 151 MPH runs!
  110. Converter install?
  111. Stock gear ratio?
  112. Trans never starts off in 1st unless I manually start in 1
  113. 4l60e transbrake
  114. 4L60E manual lever position switch??
  115. new tranny jumps out of gear at WOT
  116. getting rebuild on 460lE
  117. Just ordered my new trans/converter combo from Performabuilt
  118. 4L80E Questions
  119. Curious about the rice..
  120. 4l65e beefup
  121. Tips? What converter?
  122. Need to know requirements to intall a 4L60E in a car equipped with a 4L60.
  123. A4 shifting question
  124. Thank You FLT and Yank!!!!!!!
  125. Transmission Issues
  126. the future...
  127. tranny & stall as well as rear fluids amount??
  128. 4l65????
  129. Transmission shift linkage
  130. 98 Z28 A4 shifter button sticking
  131. Input Drum Stuck
  132. Just Dropped off The Converter
  133. anybody have any luck stalling a high mile trans
  134. What gear ratio
  135. bad tranny
  136. how much to build up a 460 to handle 550 rwhp?
  137. Necessary To Trailer With T400 RMVB?
  138. 4L80E w/Transgo manual kit problems
  139. 4l65e behind 427ci engine
  140. 700r problems need help
  141. Multi-disc converter tune settings?
  142. gears and stall
  143. 4l60e to th350 coversion????
  144. 4l80 conversion U joint
  145. Wont shift from 1st!!!
  146. whats the hottest trans temps we've seen?
  147. Trans Gurus: cooling
  148. B&M Quick Silver pissing me off
  149. Trans issue 04 Silverado
  150. converter efficiency
  151. Bought a Circle D converter today!
  152. FTI Help put us in the top 10
  153. Top speed in an A4 car.
  154. 9.5 precision multi disks rattler
  155. Burnout - Possible Stall Question
  156. Aftermarket Shifter for 4L60E
  157. th400 vibrations....
  158. Change tranny fluid and filter?????
  159. Could this be the reason?
  160. 480LE not shifting problem, n00b help please!
  161. Hurst dual gate shifter in 95 A4
  162. trans help???
  163. Shifter Rattle..
  164. determining stall speed
  165. tips/tricks..
  166. Flexplate part number for 6L90 and LS376/480
  167. th400 trans brake question
  168. Sloppy shifts at part throttle, firm at WOT?
  169. what stall for my particular setup?
  170. quick race compilation after pfb lvl2 install..
  171. 3rd and 4th gears not working properly
  172. stall ?
  173. Fail Thread
  174. quick question
  175. Question for Permabuilt Lvl-II drivers
  176. th400 clearances?
  177. Need help identifying 4l60e convertor
  178. VRX3 with stock stall
  179. Strength on stock 80e?
  180. lookin at getting a shift kit
  181. How 2 make 4l60e last longer?
  182. 4l60e forward clutch pack
  183. Transmission temp guage
  184. Lost R,2,4 gears
  185. CSR Flexplate
  186. v6 to v8 4l60e
  187. M6 to 4L80 swap in progress... have a Q about flexplate spacers.
  188. tranny ?
  189. 4L60E - Drive vs. Overdrive and ASR vs. no ASR?
  190. gas mileage with a pt4400 and g5x2
  191. TH350 to LS1 question
  192. 8" 9" 10" converter size, what's the difference?
  193. Th400 lower than 60E?
  194. color wires for VSS on TH400 to stock harness???
  195. A few 4L80E Questions
  196. Is this converter slipping?
  197. th400 Pan gasket?
  198. M6 crossmember for 4l80 swap?
  199. 00 B4C Trans issue
  200. How much to repair this??
  201. Performance Switch?
  202. Converter or Trans issue?
  203. Will a 4L60e from a 98-02 Fbody work in a 94 Camaro?
  204. Alright you PRO trans guys, what breaks these parts?
  205. Trans break on 465LE?
  206. new trans installed
  207. 1994 4l60e Swap
  208. Speed Sensor Connector - TH400
  209. can a 4l80e be converted from 4x4 to 4x2?
  210. I got to buy a new flexplate.
  211. 4L60E Converter bolt sizes?
  212. torque specs on 4l60e tranny pan bolts??
  213. How do you know if your trans is slipping
  214. How much oil will fill the 4L80e and PY-3400 stall
  215. Sponsors...Need A Price On A Converter!
  216. Any pics of coolers w/ fans installed?
  217. stall question.
  218. 4L60e, 4L65e, 4L80e from 600-1000hp plus Stall Sale
  219. is this a good stall?
  220. Good converter
  221. stronger 4l60e
  222. Which speedometer gears do i need for my 700r4?
  223. 'Vette 4L60 issue
  224. 4L60E max HP
  225. blowing thru converter?
  226. Stock torque converter in a 2700lb car?
  227. what fluid to run in a fresh 4L80E?
  228. Converter Diagnosis?
  229. Transbrake solnoid spewing fluid?!?
  230. Slip Yoke Issue
  231. 700r4 in a 93
  232. trans problem
  233. th400 clutches and valvebody questions
  234. How to remove stock dipstick tube??
  235. 4l60e Shift linkage?
  236. performabuilt trans!
  237. Performabilt converters?
  238. Locking SS4000
  239. TCI manual valve body for 700r4
  240. Do i need to Cut N Clean?
  241. cooler questions
  242. 4l80E swap parts list..... what am I missing/forgetting.
  243. Tranny oil lines.
  244. 4l60E and 10 bolt death
  245. Tuning for better shifts with predator?
  246. PRNDL switch pigtail part number
  247. Stock a4's in the 12's???
  248. hughes converter, anybody got one?
  249. trans shop in stl?
  250. Is my 4l60e going bad?
