- hughes converter, anybody got one?
- trans shop in stl?
- Is my 4l60e going bad?
- What is the going rate for a new vig?
- Joined the no 3rd or 4th club...
- What is the easiest way to drain a transmission?
- tranny problems
- TH400 Conversion
- 4L60E Help
- SS3600 to PT4000 will 60ft suffer?
- Shifter pic's
- Need help asap
- transmission horror stories?
- Trans Fluid ?
- 9.52@148.95 and only the 5th pass of the Year. FLT60E!
- stall and gears
- Loud screeching
- FTI 4400 stall....amazing
- Powerglide question
- th400 vs 4l60 vss ??
- Question about Performabuilt core return
- pcs 4l80e trans controller / guys help
- What to charge friend for transmission removal/install?
- Whats a cracked flexplate sound like?
- Anyone else experience this? What could be causing it?
- vaccum at dipstick? help???
- Recommendations
- Thinking of switching stalls?Vig3400 to SS4000.Sponsors chime in
- gears & stall
- 3600 converter on stock tranny and rear end..
- Thanks FLT and Circle-D.....
- Who makes stalls that can handle 700hp
- B&M SFI Tranny Shield ???
- Vig 4000/spray/4.10s
- blown rans need help!!
- th400 transbrake for reverse
- Street manners of SS4000 or PY4000
- 4l65e?
- Is it me or my stall??
- shift speed on auto trans
- weird 4l60e problem!
- Extreme Performance Tranmissions 4l60e if u got 1 or know someone then come in
- trans am shift nob?
- need help with tranny
- TH400 and VSS harness
- How many Of you Guys got a Precision Industries Vigalauntes are Black?
- What's a good speed for roll racing in an A4?
- Problems after converter install... in and out of lock-up... any input?
- Filter Extension or Truck filter?
- 4l60e wont rev past 2k.
- How Much Did You Pay For Your Trans
- th400 vs 4l80e swap???
- Lock a stock 4L80E converter on chassis dyno?
- Has anyone riged up a lock up switch?
- Would the TP4000 be a waste for street only?
- hopefully ive got plenty of cooling...
- 3200 stall on stock tranny?
- Tranny problem
- help m6-a4 swap car wont start..
- U joint cap diameter
- All the Steps to Convert 6speed to Auto?
- Bellhousing Bolt Size
- Went to the track
- Pro Yank 3400
- Converter Bolts
- Converter won't lock!
- Converter co. input please
- th350 transmission problem
- Dipstick Tube
- tcc solenoid and wiring harness?
- modifying stock shifter for TH400 RMVB
- FTI. thanks. i like the converter
- a whine?
- yank th350 crossmember
- What kind of stall, Where to build my 4L60e
- stock A4 shifter removal
- can the 4l60e be swapped to a 6l60e
- Need answer ASAFP...4L60E install
- where can i buy a reman trans pump for 98z28
- ptc stall converter- 4l60e ?
- Sudden Loss of 4th Gear
- Is it normal to hear a slight clunk when going from N to D...
- Pictures of stock modified shifter for TH400???
- Did my first transmission removal on the F-body.
- Using a A4 harness on a 6 speed
- newb question on trans cooler
- trans problems need help please
- new servo and no overdrive
- Thanks FLT! 5-22-09
- what stall for a 402
- how much rwhp can a 4l60e trans hold?
- 6L80E TCC Question.
- shift kit or improver??? hmm
- tranny gauge on a 4l60e?
- Newly Designed Dipstick Tubes On Sale Now!
- Where To Buy Teflon Bushing & Triple-Lip Vamac Seal?
- Car won't start or shift out of park
- ##7 apply ring 3-4 clutch pack/installing z-pak
- help: built trans, no 4th (no OD)
- Trans plug?
- anyone rebuild a 4l60E themselves?
- !!! Still leaking... Need Help !!!
- TH400 for my LT1
- TH350C - Do I need to connect the electronic connector?
- shifter not moving....after swap??
- 4l60e lockup question
- TH350- Fluid Out The Vent Tube?
- Turbo 350 swap question?
- got my line pressure gauge today....
- 4l80 N 06 gto
- Intermittent soft 1-2 shifts at part-throttle
- Trans repair
- yank and perforabuilt perform well
- TH400 questions
- TH350 remote oil filter
- Can't stall converter at the track.
- Help with 4l80
- 98 4L60E 1-2 shift
- TH 400 Linkage Adjustment
- Thanks LS1tech
- About to buy a tranny cooler
- Yank is the best!
- Gear shift hesitations
- Trans choice for 67 Chevy II Swap - 4L60 or 80E?
- Swapping transmission's, 08 yukon into an 03 silverado v6?
- (Rossler) Tranny 4L60 CLUNK in drive????
- TH400 conversion. Speedo question!
- Loud noise when car is in Reverse..?
- My New Circle D Converter, Wow!!!
- JR's FLT 4L60E GOES 151 AT BYRON!!
- 4l60e extension housing
- street/drag car trans??
- how long did ur trans last after your 355/383/396
- LT1 Stall Question?
- truck deep pan for 4L60E part # need
- 6 speed to th400 swap drive shaft problem
- TC / Flexplate Gap
- stock style flexplate for 400?
- Torque management question
- 1350 u joints stock rear?
- FTI conv/4L80E
- Bad 2-3 shift solenoid!! WTF!! HELP!
- tranny died what happened?
- 3rd trans looking for a new trans builder
- Do you regret going to TH400?
- help my car wont move
- Which lokar dipstick and tube for 80E conversion?
- TCI 3500 Converter Repair
- stock verter bolts suck. any advice?
- New to the Auto world
- OD or just D for daily drive.
- Thanks Circle-D
- what size cooler???
- Couple of questions about 4l60e internals
- Looking forward to a new Performabuilt level II!
- Stall Install?
- What transmission is this???
- How much power can your trans take
- OD burnout leads to weird tranny action in 4L60E?
- Tight stall??
- Transmission Sponsors and BG products trans fluid
- 93 4L60E interchange question???
- Decided on my H/C setup, need to pick what stall
- Milky transmission fluid
- '94 4L60E Question/concern
- Stock stall????????
- 4l60e vs 4l80e ?
- Anyone wish they had an M6?
- Type of trans fluid
- 700r4 stall question
- 6l80 in a First Gen F-body
- i now know why i have no reverse
- Stalls Speeds and Horsepower
- Using 4WD 4L60E trans with LS1 for 2WD application (car is NOT f-body)
- Who has sent a Vigilante back for clean/restall?
- Bang on part-throttle downshift, bad trans mount?
- Figuring out which converter to order
- converter
- th400 shifting problems
- SK4L60E (transgo kit) 1870 code fix
- 4L60e with a 74 350?
- Transmission Specialties
- 4l60e twisted input shaft splines out of the drum
- 4L60e Rebuild Kit
- still no reverse update..
- LS engine to powerglide
- 4l60 Tranny mount? good or bad
- All 700R4s the same?
- 4l60 to 4l65
- 4l80e
- Frank from Cahall, anybody else have trouble contacting him?
- Fmv 4l60
- stall?
- tcc pwm question
- scatter shield?
- Th400 Conversion
- stall problems
- p0740 code?
- will a 4l60e from an lt1 car bolt up to a 2000 v6?
- Torque Converter Confusion
- Unplugged ASR (traction Control) box.. will it mess with ABS?
- TH350/Driveshaft question
- stall speed help
- converter not spinning freely
- Stock pan with drain plug ?
- 4l60e to 4l80e swap not shifting right on highway??
- is my stall to big?
- I cant get the level of the fluid to be right.
- help!! melted wire loom ???? 4l80e
- th400 long tail question
- 4L60E Fittings
- th400 swap converter problem?
- Tranny Servo Upgrade- Stock or Aftermarket ?
- reprogrammed it- shifting weird- plz help
- Help diagnosing a possible problem.
- Big thanks to FTI and FLT
- switch from 4l60 to TH350
- converter unlocking....advice
- 98 LS1 Th350 kickdown cable attachment??
- 4l80e gear ratio
- 4l60e hd
- cracked flexplate
- OK new trans problem
- Does this look right??
- stall & stock tranny...
- Shifting Problems - Not downshifting or upshifting at times!
- Some testing on Yank converters
- How much is my 4l60e and vig3200 worth?
- Best 3-4 clutch pack
- So I think I just blew my input sprag??? Any advice? :(
- 1995 4l60e rebuild kit
- Make me feel better about owning an A4
- new trans soon!
- Just ordered my Yank
- 4l60e help. please
- Proper flexplate info?
- Vss 4l80e swap
- Shifter Problems
- 100K....So What Next?
- Jacked Up 4l60e
- 6L80E question
- have a question, hoping for answer.
- Full competition 8" converters for 4L60E
- Pulling transmission by myself, whats the easiest way to do it?
- Speed Inc Flexplate???
- 2nd gear downshift hesitating and/or slipping, flywheel making ticking sound
- Yank vs BMR Crossmember for a TH400?
- finally ordered it Performabuilt!
- What kind of tranny oil should i use??
- P1870 help
