- Cheap Aluminum 4l60e trans. pan
- where to find tq arm mount nut?
- Which STR on new billet verter?
- Who's running a sponsor tranny???
- old school 700r4 blues
- tail housing blues...
- 4L60e Stage 1 weird noise
- is my tq converter bad??
- 4L60E Problems
- Estimate my drivetrain loss
- what all need th350 swap
- Effin trans! Again!
- Yank 2010 camaro 6L80E converter
- Bad torque converter?
- Worth????
- Another suggest converter thread
- aftermarket shifter
- corvette servo upgrade (help)
- quick question- will a 98 4l60e bolt up behind a 99 trans am???
- best flexplate adaptor
- ls1 swapped 1990camaro w/ 4l60e questions!!!
- truck to car tranny
- Big thanks to FTI and PWTR02SS
- big question on th400/th350 swap
- Anyone used goodfellas tranny's???
- Bad Torque Converter
- Converter seat problem. NEED HELP FAST PLEASE
- Average price for a converter install?
- really improtant GEAR COOLER
- LQ4 engine 4l60-e
- What would my crank HP be?
- 4L65E suggestions
- help
- Stall,what do I need?
- Where to buy Tranny Parts?
- 4L60E not shifting right????
- info on corvette servo
- dipstick tube bolt
- th350 or th400. help
- T 56 Removal Question
- 4L80E: complete swap info wanted - sticky?
- Locking converter at wot
- how to lock up a TCC manually
- Shift Solenoid Problem
- Is this a transmission problem
- quick 4l80e question - where is tcc solenoid connector located?
- Tail shaft housing... stupid Q... T56 tail housing = 4L60e/4L80e tail housing?
- problem
- My 1000 mile torque converter is taking a shit
- Shift point drop again...
- Getting the 4L60 to act right or switch it
- got a little trak time in today
- got a little trak tome in today
- lock up issue?
- On the fence: Upgrade SS3600 to PT4000?
- Trans cooler, before or after the radiator?
- OD lockup hits pretty hard?
- Time to shift gears!
- Turbo350 in a 67 camaro LS1
- Vig Vert on ebay for cheap!
- Yank PT4000 results are in, 1.05 second improvement!
- Dipstick problem?
- Things to consider when picking a converter.?.?.?.?
- SS3600 results are in!
- torque conv fluid...does trans provide via shaft?
- Converter & gears
- How much fluid?
- Powerglide
- what can it be
- dipstick tube bolt size
- 4l80e swap..Driveline
- FLT/PT4400 very consistent!
- Tranny hard line size
- Proline 2500 powerglide vs performabuilts level 2 4l60e
- New convertor
- 4L60E kit
- Turbo 350 (short shaft or long shaft?)
- street driving a cheetah?
- Sonnax?
- Ss4000
- What tranny fluid? Please help!
- stock fly wheel with th350?
- TH350 and B&M Pro Ratchet
- 4l60 Broken! Gurus please help!
- Circle D or Yank?
- TBSS convertor in Camaro?
- cheap place to get servos/ other parts?
- converter question
- Flexplate & Cooler Install Questions!!!
- Sponsors that sell built 4L80-Es?
- Speedometer Gear help??
- New 4l60e transmission, loses speedometer randomly and then wont shit
- URGENT: Transmission service with Vig converter
- I need help, any ideas?
- benefits of deleting lockup in drive?
- Launch!
- 4l80E swap
- Should I? M6->TH400
- Questions; need to make a decision th400 of 4L803
- Toughest auto?
- quarter stick install with th400
- Car wont shift out of 1st at WOT
- Tranny Help
- Need recommendation for converter. 370ci/pt88 Turbo/TH400
- built tranny viberations? help?
- Anybody have the Trinity 4L80E Transbrake?
- stock flex plate and th400??
- 4L60E controller?
- how much fluid
- Trans swap in my 99 camaro
- Pin out for MLPS
- th400 kickdown
- How do I rotate or push in the stall once bell housing is bolted up?
- Tranny Issue
- help with tranny cooler
- Need a 4L60E rebuilt in/near Dover DE
- Weird High Speed Noise........ Need Help!
- what do you think i should run
- Crosmeber question
- didnt seat my converter all the way and messed up my pump
- Transgo 4l60E-HD2
- Trans Slipping and bad smell inside car WOT! 02T/A
- Code 83
- Where did you put your tranny temp sensor?
- Transmission Problems. Please Help.
- Wich is the best overdrive trans
- Big thanks to......
- moving on up
- SS4000 results are in
- fly wheel
- TH350 converter/flexplate problem
- what you run
- Stall recommendation & STR
- t400 valve body 1 check ball?
- glide anyone?
- Help: Weird lock/unlock converter issue
- 4L60E 2 DTC Errors
- 4l60e shifting problems downshifting
- What ETs are you running with a Performabuilt level 2 and FLT level 3 tranny?
- Need help with my 4000SS
- Trans height
- 2000ss
- Steel dowel that fell out of tranny?
- Circle D Specialties
- What to do? 4l60e problems
- Two bad trans in a row or electrical?
- stock torque arm will not go back in - PLEASE HELP!!!
- Can Fluid Be Low ? Shifts softly...
- New TCI A6
- 700r4 to LS1
- What drive shaft?
- teflon vs rubber
- help me figure out my stall (pulled tranny)
- Thrust update.....converter not ballooned
- Yank Nitrous Friendly Converter
- Tru Cool Max inverted flare to AN???
- good auto transmision mechanic in houston
- Chirpin 3rd??
- hpp3 shift points
- switching to a th350
- lowering T400 cooler line pressure
- what size stall?
- Anyone know the factory torque ratio of an LT1 converter?
- What's better? Locked or Unlocked Converter?
- Need help
- Might be looking for a stall soon need some advice
- FTI Converter
- ls1 swap
- A few questions on running a 4L60E on a car that came with a 4L60...
- fore el sicks tea e
- Reverse not working?? HELP!!!
- C5 reverse issue!
- DD stall questions?
- What can I do???
- Line pressure increase by turning screw . . ?
- Shift Points?
- Which Transmission Should i go with
- Which Shift Kit
- LT1 transmission In LSx
- Redline Dexron 2 (two)?
- tran ?
- SFI Flexplate Needed? Or Stay Stock?
- Is a stall converter nessecary
- think i exploded my tranny today!!
- Fan on Trans Cooler
- Vibration at high speeds, and jolts when coming to a stop?
- Thread's on 4l60e shifter? Wanting to buy a shifter knob.
- HP difference with a stall on dyno compared to track times....
- Which brand converter
- 4l60
- I just bought this to convert my car to auto. I think it might be a v6 trans.
- Poly Trans Bushings
- Tr230/336 112
- Having issues with my 4l60e
- 6l80 which port return from cooler?
- need input ...stall ,tranny/cooler
- Hardcore tech question
- ordering my FLT on friday
- lowering car without torque arm
- Thanks Circle D
- 4l60e to 350th
- Scraping sound from transmission near torque converter area
- Should I turn all the tq abuse modes off?
- installed py3400, now i have a problem
- Will the 4l60E live?
- WANTED: Detailed converter swap thread
- Who sales 4L80e valve bodys
- Need a 2wd 4L60e output shaft (98 or later)
- Does a RMVB need a Reverse shifter?
- which trans blanket for 4L60e
- $l80 new build problems HELP!!!!
- Tci tcu
- New anouncement from PerformaBuilt Transmissions
- No Forward Gears. Just reverse.
- Regulator valve and boost valve
- Lock up on 2-3 shift?
- 4L80 cooler fittings
- Trouble with upgraded iso-conv valve
- Ultrabell on a LSX
- Damage to torque converter.
- need help picking
- how does the condition of this stall look to you?
- PT4000 owners.. need some advice
- Explain to me loss of HP though a slipping A4
- Am I the first person to go from a T56 to a 4L80E?
- 4L60e Rebuild... What caused my failure?
- trans temps
- guys with th350
- 1-2 Shift solenoid..not the same?
- 700r4 help please!
- Performa trans Yank stall.....problems.
- Need input FAST !! Tranny in limp, not working
- YANK stall
- Need Pro advice AGAIN lol
- TH350 speedo problem
- What stall need help!!!
- any write ups on removing/installing a 4l60e
- Im tied between the two..
- 65000 mile a4...stall or not???
- torque arm bolts just spinning
- auto to manual pedal assembly, brake stiffer?
- Yank SS4000 for 4L80E for sale
- return line
- Help New trans/converter wont hold fluid
- stall or trans bad
- Have a PT4000 Converter, But want a converter that hits hard & gas milage!
- rev limiter?
- stall without tune
