View Full Version : Automatic Transmission
  1. YANK stall
  2. Need Pro advice AGAIN lol
  3. TH350 speedo problem
  4. What stall need help!!!
  5. What stall need help!!!
  6. any write ups on removing/installing a 4l60e
  7. Im tied between the two..
  8. 65000 mile a4...stall or not???
  9. torque arm bolts just spinning
  10. auto to manual pedal assembly, brake stiffer?
  11. Yank SS4000 for 4L80E for sale
  12. return line
  13. Help New trans/converter wont hold fluid
  14. stall or trans bad
  15. Have a PT4000 Converter, But want a converter that hits hard & gas milage!
  16. rev limiter?
  17. stall without tune
  18. good turbo converter around 3200 stall?
  19. shift kit debate.
  20. 4L80E swap isn't working correctly...need help.
  21. Where can transmission pan magnets be purchased??
  22. Is this normal???
  23. 3-4 clutch pack ?
  24. Okay to drive with leak???
  25. Help with picking a stall
  26. Help with choosing stall speed
  27. How do you feel about your current/past stall? Real World driving, not just strip!
  28. Dipstick Tube??!!
  29. Need help selecting stall speed 2.73 6l80e
  30. 4l60e to 4l65e
  31. Trans Temp Sending Unit
  32. opened up a 2 yr old FLT trans :)
  33. 700R A4 question
  34. 4L80E - IRS driveshaft question
  35. 6l80e
  36. turbo 400/4l80e SFI flywheel
  37. Quick convertor questions
  38. possible transmission problem...
  39. Bbody tranny swap question...
  40. Stock Torque Converter Question
  41. Stall Converter Bolts
  42. Changing convertors, do I need to retune?
  43. 4l60e electrical seal?
  44. Shopping for stall... (what would you get?)
  45. th400 w/ no stall??
  46. Newbie question about shift kits
  47. Need a convertor. New or restall mine
  48. Lost tranny fluid!!!
  49. Will an electric trans pump work with the engine off
  50. Question about 4.10's
  51. Fuddle Converter?
  52. Shift Points?
  53. converter problems
  54. I need serious insight on 6l80e before purchasing
  55. Engine braking A4 = TCC Death?
  56. 4l60e problem - Help!
  57. building a powerglide
  58. What rebuild kit for my 4L60E?
  59. best current price on billet putput shaft?
  60. 4l60e worn check ball symptoms
  61. The 4l60e
  62. FLT have a tech question for ya
  63. stall questions
  64. Killed 3rd gear in my 4L60E today
  65. Quick shift kit qeustion
  66. B&M Magnum Grip Pro Stick Shifters with electrical shfiter soleniod!
  67. What is the problem?
  68. What stall and what company?
  69. Got the SS4000 Installed.
  70. Would you consider this a loose converter?
  71. Rebuilt 4L60E with New Converter Problems
  72. Stall too big
  73. Transmission experts I think I got my first problem
  74. Tranny experts A6 tranny sound.. please help
  75. Help with crazy mechanic
  76. When you go with a high stall, should you change the seperator plate hole sizes?
  77. 1994 60-e in a 99
  78. parts necessary for a stronger 4l60e
  79. got the 4l80e switched back to auto mod
  80. 4l60e stall question
  81. FLT come inside please!
  82. wtf 4l60e acting up!!!!!!
  83. can i use a truck flexplate
  84. Tuff Decision: free 4L60E or not free 4L80E...
  85. Drive Shaft Sponsor
  86. 4L60 or 4L80 behind L92? need help deciding
  87. TCI flexplate, th400, aftermarket TC, TC bolt head protrusion ?'s
  88. 4l80 in camaro
  89. 4L60E vent
  90. Trans stuck to the Engine
  91. Transmission Install
  92. TH400 robbing hp?
  93. diff between 94-96 and 98-02 4l60e?
  94. help me diagnose auto tranny problem
  95. 8" race converter and street driving
  96. Re-stall
  97. Source of Transmission fluid leak?
  98. 4L80E question - can I move the vehicle around?
  99. Transmission/Converter R&R How-To/Write Up
  100. 4L60E shifters ?
  101. TCI torque converter issues?
  102. converter locking in 2nd & 3rd @ WOT...EFILive
  103. Should i replace my Flexplate?
  104. Tranny acting up on trips in OD
  105. 4l60e transmission shift problems 1-2, 2-3, 3-OD
  106. what could be wrong?
  107. converter locked up when i start car. brand new
  108. torque converter and . . .
  109. Questions about my dipstick th400
  110. 4L80, from 4WD to 2WD, what do I need?
  111. Short Tale TH400
  112. TCI vs Yank
  113. Which Flexplate is right for my DD?
  114. 4l80e vibration when giving any kind of real load
  115. 2-3 shift hittin limiter @ WOT, brought shift point down
  116. 370, PT88, TH400, what converter?
  117. 700r4 speedo?
  118. Big thanks to APF, Circle-D and SpeedInc.
  119. Anyone use the B&M Starshifter? Couple questions...
  120. 4L60E identification ???????
  121. Lokar dipstick tube question
  122. Turbo 350 to 6.0L
  123. u joints
  124. 4L60E longevity questions - NON Fbody
  125. th400 install questions. pcm, limp mode, and driving...
  126. TH350 swap, need a new driveshaft?
  127. Shift solenoid question?
  128. 4l60e question
  129. 4l80e-switching from man. to auto
  130. Finish Line Trans Shipping Special
  131. High RPM Vibration
  132. Z06 or any C5 M6 to A4 conversions
  133. stall speed on stock converter??
  134. Picking the right stall/ company
  135. Need help with TH350
  136. LS2 to 4l60E Ouestions??
  137. GTO with Speedometer issue after TH400 swap
  138. Thanks PerformaBuilt!!!!!!!!!
  139. Need stall speed opinions
  140. stall question
  141. Delay in downshift when in D vs OD
  142. lots of play in my rear shaft on a 4L60e
  143. Who has the best price on LS1 4L80 crossmember ?
  144. 4l60e to 4l65e swap question
  145. 4l60E ???'s
  146. New trans question
  147. Help get rid of my stall wall plz!
  148. what trans is right for me?
  149. Second Overdrive in a 4L70E
  150. FLT Props again
  151. rebuild or new ?
  152. Scared to go from Yank SS to the PT
  153. need torque arm / exhaust mount
  154. what years work with my 2005 6.0 truck engine
  155. 228R and stock stall
  156. One bolt left before trans can come out - PLEASE HELP!!!
  157. Help me piece together a 4L60 build
  158. Flywheel or converter causing vibration
  159. 4L60E Rebuilt Transmission sticking when shifting into First Gear
  160. anybody running Art Carr converter?
  161. wow my new bmr stuff is so purdy you almost dont wanna put it on LOL
  162. Big thanks to FLT and FTI
  163. Cracked flexplate :(
  164. 4L60E servos...which ones?
  165. Slack in tranny
  166. Help please
  167. Which converter?
  168. stock cam and stahl
  169. Do i need a trans cooler with stall
  170. noob question.. WOT-shift into 4th w/4l80e
  171. Trans Fluid
  172. Should i Stall My Stock 4l60e Or Not????
  173. Calling all datamaster/tuning trans gurus to help. Can somebody check out my datalog?
  174. Please help....shifter problems?
  175. stock stall??????????????
  176. 4l80e converter lock-up question!
  177. FAST/TCI Trans Controller
  178. 4l60e problems
  179. A few transmission problems "4L60E stock"
  180. Should I get a stall converter?
  181. 4l60E 3.23 Gears Shift points?
  182. Stock stall number?
  183. Gears with a Glide and N2O
  184. How much stall-stock ls1 converter?
  185. Trans failure?
  186. 4L60e to a truck 4L65E
  187. transmission help needed!!!
  188. Custom stall help
  189. Need a REAL race converter
  190. Trinity 4l80 brake and pcs controller ordered
  191. too much clearance
  192. Silverado Trans to Z28
  193. m6 to a4 swap
  194. 4L60E problem or comp problem? HELP!!
  195. FMVB 4L80 guys
  196. light clunk, knock, tap, noise while cruising and giving gas . .
  197. Looking for stock, to low stall, converter. Are these OK?
  198. fbody 4l60e questions
  199. Changing Shift pattern... HELP! (please...)
  200. New converter, new problems?
  201. Setting Base Line Pressure
  202. shift problems with drag radials only
  203. Will a 9.5 inch converter fit in a stock 4l60e
  204. Quick Question
  205. 4L60E whats differant 01-05
  206. Crank Spacer
  207. Anyone using a transbrake with 4L60?
  208. Cirlce-D 4C just installed
  209. IS it broke?
  210. *prototype th350 crossmember*
  211. Shift Solenoid or worse??
  212. New converter + HD2 kit, slipping like a mofo
  213. Help with transmission!!!
  214. another gear tire question
  215. 100k plus miles --Service trans ????
  216. Driveline play
  217. Interesting smell...
  218. Trans Issue????
  219. Those of you using a PI 4l80e converter
  220. FLT power levels?
  221. Yank Warranty/Rebuild Options?
  222. Kolene steels?
  223. Converter help, mid 10 sec all motor LT1
  224. Which converter???
  225. Ordered ths SS4000 Friday
  226. torque converter
  227. Pump failure - any idea what caused it???
  228. F**K prothane tranny mounts!!!
  229. Ordered a yank ss3600 last week, have some questions
  230. wiring up a TH 400
  231. Did you like your switch from A4 to M6 or M6 to A4
  232. Shift Pattern Reverse or Foward
  233. wich stall is best for me ?
  234. stock drivetrain? stall? 400hp?
  235. What would cause 4th gear (OD) to not engage ?
  236. TCI 6 Speed Auto
  237. shift cable need adjusting?
  238. Ever had problem with TC bolts? Striped! lots of grinding!!!
  239. torque converter shutter/problem
  240. Converter hard apply
  241. flexplate install
  242. Flexplate??? Internal/external/zero balanced, which one?
  243. converter bolt broke off... WTF?
  244. what tranny fluid to use?
  245. 4l60e Help And ???? please help
  246. Need a 1998 ls1 4l60e vin for reflash.
  247. Which trans cooler should I use?
  248. Line flush help
  249. Yank is updating its website today
  250. TH400 VSS plan
