PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
  1. vacuum modulator
  2. A4 Shifter Handle
  3. Yank Converter Stall Torque Ratio, Stall Speed Information
  4. thinking about a stall, need some info!
  5. In And out of lock up? Or dowshifting on it's own
  6. Shifter button...
  7. 4l60e AN transmission fittings
  8. what Stall would you recommend drag car
  9. Intermittent 3rd gear start and no first downshift
  10. Another 4L60E problem
  11. Need pictures of B&M tranny cooler instal.
  12. How Many Quarts does a 4L60E Take?
  13. TH 400 Intermediate clutch piston seal
  14. 95 4l60e into a 96 ss
  15. a3 to a4 shifter
  16. 4L80e Diagnosis...
  17. converter lock-up issues
  18. th400 swap
  19. Win a Yank custom SS converter!
  20. Performabuilt lever 2 or 3?
  21. Stall and FI
  22. Got a stall, next step ?
  23. STR, when shopping for a Stall Converter
  24. Shift points for ss4000 stall?
  25. Anyone got an old B&M Megashifter laying around?
  26. trans temp gauge
  27. banging the REV
  28. 4L60E torque convertor not locking up
  29. Strange Shifting Problem
  30. B&M Cooler # 70298 install?
  31. 4L60e Torque Converter alignment
  32. 4l60e housing
  33. Paddle shift or not?
  34. WTB: th400 speed sensor and reluctor wheel
  35. Got my Yank ss4000 on the way!!!
  36. Drive train Vibration Question?
  37. 4l60E 1-2 shift all over the place.
  38. Headed to the track for the first time with an auto.
  39. Need help on a stall install.
  40. What type of Trans do I have?
  41. For the record...
  42. Trouble putting trans in park
  43. anyone in melbourne fla who has hp tuners
  44. 4l60 shift problems on nitrous
  45. Newb to a4's any advice
  46. Very Hard 1-2 shift 4l60e????
  47. Stall Converter question?
  48. bigger tranny pan for lowered cars
  49. multiple 4l60e trouble codes! please help!
  50. 4l60e only shifting at 3200 rpms
  51. 4l80 in a 2010 camaro a6?
  52. please help!
  53. MAF 0100 Insufficient Activity code preventing 4l60e from running?
  54. E40D prpoblems after rebuild
  55. bellhousing bolts
  56. Yank SS3600 Advice
  57. need a part number or where to get one
  58. 1860 pwm tcc solenoid error code
  59. car got hot and had a random no forward or reverse
  60. I need help with 4L80 install with a Moser 9"
  61. transmission identification
  62. Transmission gear select linkage cable
  63. 700r4?
  64. anyone running a th400 and 3.23 gears
  65. Need help th400 install in a 97 LT1 firebird
  66. TH400 trans temp sender location?
  67. help wiring b&M shifter neutral switch
  68. 4l60e ?
  69. Tranny cooler Question????
  70. Will a 94 4L80 work with a ls1?
  71. high performance circle d 3200 stall 278mm
  72. Are C5 and lt1 convters interchangable?
  73. Yank is in! Question on it, see last post
  74. Upgrading to either the CircleD 5C or Yank SS4000
  75. What is needed to make custom transmission lines
  76. ATI Tree master non-lock up 8" race converter
  77. Pcm not reading if its on park/drive 4l60e help!!
  78. 4L80E swap question
  79. Flexplate option ? 99-00 6.0 related
  80. 4L80e bolt pattern
  81. 4l65E DRUM KEEPS BREAKING?
  82. Odd 6l80e issues
  83. wont shift out of 1st wot
  84. B&M Quicksilver and '04 2wd Automatic 4l60e Problems
  85. shift kit
  86. SS4000 Owners post your 60' times
  87. help me diagnose my problem!!!
  88. Need HELP Were is the PRNDL Switch Located
  89. Possible clogged cooler?
  90. stall and tune question
  91. how to identify 4l60e build date
  92. Tightest converter for the street? Recommendations??
  93. 1994 4l60e problems
  94. 4L60E lost all gears
  95. E38 and 4L80E
  96. transbrake malfunctioning
  97. th350 shifter installment... tried looking but cant find
  98. Transgo HD2-C Question
  99. Part# for truck pan for 4L60E ??
  100. Shifting Question.. 4L60E
  101. Tranny leak...coming from where??
  102. Lashway Motorsports now offering their Billet Series converters to LS1Tech members!
  103. Help!!! Tranny issues?
  104. Going to have the transmission out of the car.. What to replace? (seals etc)???
  105. lazy 2-3 shift
  106. Powerglide with Transbrake
  107. Stall converter question
  108. What is the maximum safe operating tempature on a 4L60e Trans
  109. Cut and clean for diesel?
  110. 700R4 Output shaft Sleeve (is it needed?) Help Car under knife and I'm ready to race)
  111. 4l60e bellhousing filling up with tranny fluid!!!
  112. 4l60e wont shift into 3rd
  113. vig 3600 to small for my setup?
  114. 4l60e swapped to a 700r4
  115. Difference between LS1 and LT1 4L60
  116. trans swap no start?
  117. Converter identification?
  118. Trans Slip from Part throttle to WOT...retune?
  119. First Impressions Yank PT4000
  120. Lockup question!!!
  121. 4l60e Transmission mount question
  122. 4l80e shifter
  123. 4l80 swap, have a few questions
  124. TransGo Shift Kit or Increase Line Pressure?
  125. 4l60 vibration with lockup?
  126. broke my sprag
  127. FLT CIR D STALL. Can flexplate be installed backwards?
  128. whos running a stall on a stock tranny ?
  129. shift kits and torque management
  130. 4L60E Reverse only after hard launch
  131. Look what the brown truck brought me :) Thanks Dave@Yank
  132. th350 won't shift out of first
  133. Does anyone know?
  134. automatic shifter with 6 speed look?
  135. 4l60e no first gear
  136. 4l65e sun shell probs???
  137. 1998 computer and harness to what 4l60e???
  138. 4l80e NO 3rd HELP...
  139. 15hr poll help!!!!!
  140. No 4th after breaking rear......???
  141. lost 2nd gear???
  142. slip between 2 & 3??
  143. Tbss...
  144. 4L60E bellhousing question.
  145. New Rockwell tranny...sounds awesome....
  146. 4th gear slip
  147. Best clutches for 4l60e???
  148. Shift Extentions??
  149. cracked bell housing
  150. what converter should I run?
  151. Are the transmissions the same between v6 fbodies and v8's??
  152. 4L60E's the same between F-bodies and trucks
  153. BDR torque convertors??
  154. th400 crossmember vs 4l80
  155. PB Converter
  156. 4L80, how strong?
  157. What's all need for a new stall?
  158. th350problems
  159. TH350 converter/flexplate question????
  160. any 4L60E free mods???
  161. installing new converter.
  162. Th400 tranny filter?
  163. Trans not kicking down at WOT
  164. buy a nice converter for a stock trans?
  165. 4l60e
  166. Converter Shutter in O/D
  167. stall install ?
  168. shift kit info/questions
  169. Ls to th350 flexplate
  170. HELP!!! 3rd and 4th not catching
  171. Overdrive Issues after breaking rear
  172. 4L60E Transmission Crossmember Bolts???
  173. 4l60e shifting early WOT
  174. TransGo 4L60E-3 full manual reprogramming kit questions
  175. Just wanted to say thanks to YANK
  176. roadrunner converter in Phoenix any good?
  177. quick question about cooler fittings from 95 4l60e
  178. new tailshaft housing (performabuilt/frank???)
  179. 4L60E Shift Knob question
  180. out going cooler line
  181. Convertor/ShiftKit
  182. 4l60e sifts into 2nd then flares up and down?
  183. Noooo!!! Massive trans leak.
  184. options for transmission upgrade in a c5 corvette?
  185. 2003 cadillac escalade (calling SUV owners)
  186. Race built 4L60E in the 9's?
  187. stall problems
  188. TH 400 sealing rings
  189. Stall and gears
  190. TH400 RMVB of choice
  191. 97 S10 4l60E behind an LS1?
  192. Overdrive with a stall?
  193. 4l60E Rear planet bearing gone/splines seperated
  194. Hughes + ARP bolt length issue
  195. Aftermarket trans pan
  196. Quick question about a stall---all opinions welcome!
  197. Excessive line pressure? (4L60E)
  198. Used 4L60E Prep?
  199. new stall in a stock trans horrible idea?
  200. Powerglide wont shfit into 2nd
  201. 4l60e rebuild cost?
  202. Banging and horrible vibration when over 1/2 throttle.
  203. 3.8 to LS1 4l60e question
  204. braided transmission cooler lines
  205. performabuilt torque converters
  206. Why autos are prone to breaking
  207. lokar with dipstick gasket?
  208. 4L60E rebuild question
  209. Torque converter bolts
  210. which Tourque converter brand should i get?
  211. th350 dyno fill me in
  212. th400 and stock shifter problem
  213. 4000RPM stall?
  214. Impressions of Circle D +4c
  215. m6- th 400 swap.
  216. Tranny Pan Leak - Tried Everything - Any More Ideas
  217. 6.0L and TH400 quick question.
  218. Got gears, now it's stall time!! What size?
  219. th 350 mount
  220. Wiring Harness
  221. The 3200
  222. need quick input
  223. 4l60e no 4th gear with transgo hd3
  224. 1-2 WOT won't shift, and p0757
  225. Broke TailShaft Housing
  226. wanting to buy a new 4l60 where do i go to get a good deal
  227. 2-3 shift 3-4 shift bad need help
  228. Vacuum Port Thread
  229. trans????
  230. Pullin the trigger on a FLT Trans
  231. th400 swap question
  232. Torque Convertor not moving much
  233. 4l80e swap into a 98 camaro
  234. kinda shot myself in the foot
  235. torque converter wont lock up
  236. Fresh Rebuild with no 4th gear.
  237. cooler and fan?
  238. 98 4l60 drives but at stoplight it bangs an clangs an wont go
  239. Poly Mount - Did I screw up?
  240. FLT guys in person.....
  241. Electric Shifter - What RPM Activator?
  242. stand alone cooler routing matter?
  243. need help with vss in mustang with th400
  244. 4L60E vs 4L80E
  245. 3200 vig and 3.73 gear ...good match ?
  246. A-4
  247. Help 4l60e shift problem
  248. Torque Conveter kicked my A**
  249. th400 (driveshaft) question
  250. 6l80 loss of pressure on hard launch
