View Full Version : Automatic Transmission
  1. WTF no OD on my 4L60e
  2. Pics of my TH350 in
  3. 4L60E Question
  4. Opinions on Yank SS3600 with 3.23 gears
  5. tubo 200 vs 4l60e
  6. 700R4 Tranny
  7. AWD 4l65e to 2wd
  8. tranny fluid
  9. Too much tranny fluid
  10. Swaping an A6 into an A4 Camaro?
  11. th400 RMVB
  12. School Project 4l60e Rebuild
  13. sunshell and sun gear question
  14. Quick Flywheel/Flexplate question
  15. building trans?
  16. yank conv. ?'s
  17. Circle-D 4C was here today so I snapped pics
  18. converter bolt pattern question
  19. tranny fluid
  20. YANK has a killer deal for you on SS3600 converters
  21. TH400 cable, which are you using...
  22. what parts do i need to build a tough 4l60e
  23. Going for trans fluid tomorrow
  24. speed inc flexplate and th400 help
  25. Specs on a RPM stage 5 4le60?
  26. Blown seal
  27. wiring harness
  28. TH400 and TCI flexplate
  29. Trans won't allow shift from park
  30. new to a glide...questions
  31. What Does a Torque Converter Do..
  32. Any real gain from gears?
  33. trans line question
  34. Order a Circle D 4L80 Stage III TQ today
  35. need a sfi flexplate
  36. temperature of mi trany
  37. TH400 problem in 72 vette
  38. after 2 years i broke it
  39. trans temp gauge
  40. Yank vs Edge
  41. Sensor on Trans Relating to Speedo?
  42. upgrades to 4l80e?
  43. Adjusting line pressure on 4l60E to correct slippage on kickdown
  44. 6 speed to 4l80e what do I need
  45. lockup on stalled TH400?
  46. 4l80e problems
  47. what do i need for 400
  48. Car moves in neutral when revved....wtf??
  49. pwm tcc solenoid help
  50. 700r4 ???
  51. Circle-D converter bolts
  52. Weird clinking sound after 4l80E install
  53. dam 4l80e 4th clutch
  54. Trans cooler lines
  55. Full manual Trans go kit
  56. Anyone Locking in second gear?
  57. Stock vs stalled
  58. 4 wheel drive 6L80E 6-speed
  59. trans not getting fluid?
  60. 4L60 speedo calibration help plz
  61. Installed used trans.. replaced 1-2 solenoid now shifts... but shakes !
  62. trans cooler location with APS TT
  63. 4l80e bonded pistons
  64. 4L60E Problem Need help, its my DD!
  65. Too much tranny fluid
  66. 3200 or 4000 stall for drag
  67. Ok, thinking of ditching the 4l60e, and going Th400
  68. Auto Trans Oil Pressure Switch
  69. 4L60-E: Unsure of what could have happened??
  70. What do you know about the 4L30E?
  71. Dont go to these transmission shops
  72. Lt1 /powerglide 4 1/8th mile racin'
  73. Hughes rebuild kits, opinions needed!
  74. Thank You TPTransmission
  75. Converter slip or gear?
  76. Atf
  77. Should I buy used Yank 3600 Converter
  78. will a 4l65e work in a 98 camaro?
  79. Changing Converter
  80. Gear Oil
  81. refreshing a yank converter
  82. Thoughts on this flexplate
  83. 4L80 pan wont fit after shift kit install !!!!
  84. 2004 & up tailshaft bushings
  85. New years 09 trasmission sale
  86. shifter setup,with 4l60,and six speed console?
  87. 4th Transmission just went out.
  88. TH350 help
  89. does anyone know about hemi
  90. Gain from a SS4000
  91. What size bolts for trans crossmember?
  92. Need 4L80 shift linkage ?
  93. 4l80e how strong.
  94. How Much Did You Pay For R&R Of Transmission?
  95. "older" 4l80e's
  96. Whats the difference in a 4l80 and 4l60 converter?
  97. My First A4 Question
  98. PT4000 gained .5 in the 1/8 (spinning)
  99. Shifting problem
  100. rpm difference question?
  101. trans ID tag
  102. WTF did i break?
  103. Servo Question
  104. Looking for converter recomendations
  105. Trans temp too cool?
  106. quick lock up question
  107. tranny or rear?
  108. Converter Install?
  109. Stall recommendations??
  110. anyone figure out how to mate a 6l80e to a fbody?
  111. TransGo HD2 Kit Impressions
  112. What STR do I want?
  113. flex plate help
  114. Question on TH350
  115. 4L60E shift kit installation question
  116. having issues after changing fluid and filter
  117. 4L80E vacuum modulator kit question.
  118. 93z28 auto question please help
  119. torqe specs for flexplate
  120. Stock LS1 flexplate
  121. best converter for my set up
  122. Gains from a 2500 stall on a stock 99 ws6?
  123. where to mount cooler
  124. Broke 4L60E HELP!!!!!
  125. 4l60 bolts
  126. Changing a M6 to a A4?
  127. TCC pressure modulator help
  128. TH400 swap..Torque converter question
  129. Need some help...
  130. Transmission Problem
  131. Deep transmission pan suggestion for 4L60
  132. How long do i have left?
  133. A4 Tranny Problems
  134. problem with auto shifter "safety switch" or in steering column?
  135. bye bye t-56
  136. Who do I use now****Update
  137. 4L60E life expectancy?
  138. m6 to a4 swap wiring question
  139. FTI TH400 and 4000 stall Review
  140. 01 Formula Bird Tranny Wisdom Sought
  141. Corvette A6 Tranny
  142. buy from a sponsor or local?
  143. got issues, need help pls.
  144. Emergency Transmission Problem
  145. check engine light on and stuck in 3rd?
  146. Yank ST3000
  147. What are some symptoms for a failing torque converter??
  148. Vigilante 2600
  149. what tranny and fly wheel is this
  150. stall question
  151. New Sponsor, Trinity Transmission
  152. Speedo reading wrong on TH400 Swap in 05 GTO
  153. what size stall no cam
  154. 93 Trans Am auto
  155. Who is Running a 5c converter from Circle D
  156. ms4?????
  157. Transgo spacers
  158. Separating 4l60e from motor?
  159. i think i lost 3 and 4 gears
  160. Ordered my circle D converter today
  161. Transmission temps
  162. need converter help
  163. Converter Question
  164. Full time lube mod
  165. selling my FLT4 trans/converter
  166. 700R-4 Question
  167. TH 400 ...conversion..tried search,,help please
  168. stall speed for my setup
  169. TH350 FAQ was wrong
  170. 3200 stall temp question
  171. need a part number or name for driveshaft balancer
  172. M6 crossmemebr for turbo 400 swap
  173. T-brake wiring?
  174. Where do you all put your coolers?
  175. Installed 4l80e and speedometer and tach dont work.
  176. Which converter?
  177. torquer2 vs ms3
  178. 3rd Gear Dies AGAiN!!!!! After repair lot of parts 10 month later it dies again..
  179. whats a good stall
  180. Shif kit or .490" boost valve?
  181. will this work guys
  182. mechanical transmission to electrical speedometer
  183. budget beef up
  184. Those With Performabilt..
  185. Are the tci converters good for 4l60e
  186. Manual vs Auto(locked)
  187. Is My Tranny Going???
  188. Should you bump shift an A4 4L60E?
  189. Tranny Temp gauge problem
  190. just to check before I start
  191. Removing Converter Bolts?
  192. tune with a small stall
  193. Cooler question
  194. Stall Question
  195. LT1 w/4l60e woes
  196. What should I expect to spend on Built trans?
  197. Modify stock shifter for drag racing(instead of B&M or the like)
  198. Question for Yank.
  199. 4l80e direct clutch failure
  200. Grinding
  201. Stall question
  202. stuck valve in valve body
  203. video of their TH400 while daily?
  204. witch to choose
  205. m6 aluminum ds in a4
  206. th350 in boosted car
  207. Yank SBS 3800 is in....HOLY HELL
  208. Need some guidance
  209. '98 Z28 Programmers and tranny problems.
  210. About to install my Vig 3600! Need a tune?
  211. transmission filter?
  212. Looking into an Ptc converter for my c5
  213. WOT 2-3 shift wont go 4l80e tuning or trans?
  214. How long have you had your stall on your daily driven car?
  215. Got me VIG 3600 today!!
  216. FTI does it again
  217. Stall with stock gears
  218. What tranny is this?
  219. electronic items needed for 80e swap
  220. For those who did a t56 to a 4l60..
  221. Sorry for this question
  222. Washers on ARP flexplate bolts?
  223. 4l80e rear (yoke) seal question
  224. Art Carr Extreme TH200-4R... How Do I Know This One Is Genuine??
  225. Who do I use now??
  226. intermittent 3/4 issues (a4)
  227. what size for my setup
  228. vibration in drive
  229. transmission replacement
  230. tranny fluid
  231. LSX to 700r4????
  232. rebuilding the 4l60e
  233. Downshift problem
  234. A6 swap?
  235. Converter or not?
  236. No 4th gear 4l60e
  237. Wrong flexplate for th350
  238. Anyone used this piece to make Speedo work with TH350
  239. Stepping it UP!
  240. Make Lock Up on every gear?
  241. What stall to get or what to do
  242. 4l80e work with lt1?
  243. 4L60e - Endplay issues
  244. HP rating on a Rossler 350
  245. differance between B&M trans pack and TransGO??
  246. third gen newby tranny question...
  247. Rebuild a 4l603
  248. will an ls1 4L60E fit an lt1????
  249. 4L603 1st and 2nd slipping
  250. inspection covers?
