- average cost to rebuild
- Upgrade from Yank SS3600??
- Shift by RPM instead of MPH
- tranny cooler/location
- Plz help 4l60e ????
- Help, it seems that 2nd is my only forward gear
- Sonnax Servo
- TCI converters???
- 1st to 2nd shift issue 98 Camaro
- installing aftermarket automatic shifter
- Should I Rebuild?
- lock up at wot
- Yank 3000
- vig 3200 and spray
- Problem... 2nd to 3rd no shift...
- trans slip questions.
- Questions about bypassing stock trans cooler
- 29.5 vs 28 in tire
- Converter Screwed up did it take the whole tranny with it?
- 6 speed to 350 question
- What's going on with my Tranny??!?!?
- pt3800
- Cross Member
- Restall a Vig3600 to 4000 vs. Yank SS4000
- gear vendors
- Tranny questions
- TCI TH400 shield
- Converter shutter, narrowing it down...
- What TC???
- anybody know the cooler port thread pitch? (4l60e)
- 6 bolt tailhousing 4L60e converter ?'s
- Fuddle stall
- What should line pressure be?
- Bolt on A4 shift points
- Which transmission to choose? (Performabuilt,RPM,FLT)
- 4L80E in a 98-02 F Body Question
- Experiencing Intermittent Lockup
- 2002 auto vs 2010 auto questions
- Extended Sale! Due To Overwhelming Response
- 4L80e acting strange on the dyno...need some ideas
- Listen guys....
- Finish Line Transmissions (FLT) Winter Holiday Sale With New Policies
- Trans dipstick has fluid spurting out?
- torque conv. not staying locked
- 1st to 2nd shift problem!
- FLT level 3 F-Body 9.87 @135+ 1.363 60ft.
- FLT 4l60e in the 9's with Video/Pic's
- Car idles up and powers when in gear...?
- P1870 transmission slipping code. converter won't lock.
- A4 to TH400 CROSSMEMBER
- Torque Arm Relocation
- L O N G T A I L th400 going in the camaro
- Tranny cooler
- 4L65E SWAP to TH400
- not shifting
- My 4L60 Carnage Pics!!
- fuddle 3600 chattering
- Transmission shifting problems, Help?
- GM transmission controller
- Burning 4th, Vette 94.
- Year update: FLT/Yank combo produces yet again!!!
- 4L60E Conversion Question
- shift kit question
- 6180e without transfer case question
- What rebuild kit to buy????
- Transmission Slipping
- Getting 3200 stall and shift kit installed very soon
- Flares going into third gear
- Thanks to Circle D converters!!!!
- Transmission Problem - Need Help
- tranny fluid ?
- '98 Z28 A4 Rattling noise, u joints or transmission problem?
- Any thoughts?
- sponsor built TH400
- TH-400 brake options and install synopsis
- 4l80e man. shift-which shift firmness size hole
- TH400 and a 4000rpm stall from FTI on the way
- i have a th350 conversion question ???
- Just dropped off the trans
- How much power am I losing
- Tranny Fluids?
- fastest radial tire cars in america
- Torque Management?
- At WOT shifts will bounce of rev. limiter???
- 3200 Vig and Shift Kit Question
- Speed Inc Flexplate.
- How to tell if converter is being commanded to lockup or unlock
- Question for my girls Mustang
- another 4l60E or T56
- 94 4l80 to 5.3
- Anyone that know this?
- 4L60E a couple of quick questions, not technical
- Help tcc unlock
- procharged 4l80e
- vent tube puking tranny fluid?!?
- Quick shift kit question
- new trans installed.. car wont start
- Help!
- Converter not stalling properly?
- ONE WEEK LEFT FTI Oct converter specials
- Drove Home today
- TCI 399753 flywheel kit all thats needed to run a turbo 400?
- 4L80E Transmission Vaccum Modulator Kit
- Everyones favorite question...
- th350
- need basic 4L60e tips please
- accidently into reverse while driving
- rebuilt 4l60e slipping
- 4l80e guys what setting to put TA at?
- glide
- Will the 6l80 take FI?
- what does a slipping trans feel like?
- FLT 4L60E GOES 9.25 @ 146 IN JR's C5 TODAY!
- TH-350 Swap
- Where to install temp sensor on TH400?
- P0748 code lost my gears
- 4l60e problem
- Anyone have experience with 4L60E and aftermarket paddle shifter?
- s10 4L60 question
- Ok Now This Is Just Getting Effin Annoying!
- Which 4L60e will work in my 98 Z28?
- ---->GLENN AND PAVEL FROM KELLY CHEVROLET BLEW A PERFORMABUILT TRANSMISSION IN 6mi!!!
- 4L80E w/ stock 10 bolts....question for you
- What 4l60e's fit the ls1 Trans ams.
- Tranny Coolers
- Help! Trans won't downshift at WOT and TC won't lock up
- rebuilt 4l60e acting weird help!!!!!!!!
- Trans Mount
- Transgo 4l80e man. shift kit buyers
- Won't shift
- Speed Inc. SFI approved flexplate?
- shift knob?
- Flexplate
- Who can do a torque converter cut and clean - how much???
- Reuse or send off?
- Lots of gray sludge - are my converter and tranny junk??? PLEASE HELP!!!
- clunk when shifting
- 4L80E in a Street Rod project...
- Swapping gears
- Second Thoughts On Buyin a Built 4L60E
- How Many Quarts?
- Data logged my N20 pass... Question about converter and Trans.
- traction?
- Thinking about going manual valve body
- Swapping gears
- Flex plate with TH400
- Stall/TC selction ?'s
- Lokar Dipstick
- new tranny break in period
- Circle D - New Street Series Billet Converters!!
- M6>>A4 Shifter cable hole?
- My own fan?
- 4WD 4l80E??? sorry im new to this
- anyone to determine slipping?
- I just got Yanked....
- Limp Mode Under 70degrees Outside???
- adjust kickdown
- 6l80 questions... i searched
- 4l60e dipstick hole
- Rebuilding Trans
- Code p0753 but it runs great ????
- Driving in "3".
- So what did I break in my 4L60E?
- i need help...
- only 1st gear
- Beefing up the 4l60e
- Tranny Removal
- Shift kit
- -8 tranny cooler lines too large????
- finally!!!!!!!
- Keep getting P0757
- Third and forth went out, what now?
- V6 Firebird 4L60E bolt pattern
- Hesitating and/or slipping when downshifting to second
- Which one should I chose? (oil cooler)
- Best bang for the buck converter for a 400 rwhp ls1 fbody street car
- Does cold tranny temp affect shifting?
- Is my converter cooked?
- It'll buff right out.....Right?!
- Royal Purple MaxATF on the cheap
- Fuddle Racing
- How much stall.....and what cam...
- How long will a tranny swap take in my garage???
- Slow Auto
- 4L80e slipping on Dyno....
- A4
- Tranny not engaging in OD, D, 2, 1 or R - please help!!!
- Tranny cooler??
- 4L60E question
- David Childress wins LSX shootout with YANK
- Happy Birthday Frank at Performabuilt!
- 4L80 where,what,year....?
- No 2-3 shift at WOT?!?!?!
- Auto WS6
- AN fittings for transmissions
- 4l60e tranny build....
- 4L60E out of a 90's model truck???=car?
- vibration
- 700R4 stall in a 4L60E?
- Any shops building STRONG A6`s????
- Need help! Anyone in b.c. have a auto tranny for a 94 trans-am, lt1
- 4l80e slip yoke length?
- Anyone regret your 4L80E swap
- Transmission Coolers with Fans
- torque converter?? i have no clue
- 2002 camaro trany tunes with new converter....?
- Paging Performabuilt
- Transgo dh2
- what the hell why is this trans mount on back order?
- tranny problems
- Transmission acting strange
- Frank at Performabuilt!!
- Oil cooler? is it good, this one exactly....
- installing line pressure and temp guage
- 2002 camaro converter question
- 05 GTO stall converter Help
- best of the best
- 4l80e manuel shift/auto conversion
- Torque Converter Lockup Problem..
- 700r4 - 4l60e converter difference??
- fittings from hardline to braided hose? help?
- a4 shifter
- Procharger & Fuddle Hp/street 3600
- school me on TCs
- Is my trans shot?
- help
- 200r4?HELP!!!!!
- v6 cts tranny question/problem
- 700R4 Speedo Question
- 4L60E Hard Line Question
- More trans problems - advice please - 418ci motor
- whats the difference?
- FLT modulator>>?
- More 4L60E Problems
- transmission selection
- Performabuilt lvl 2 trans. and vig 3600!
- Vehicle stability...
- 4l80e w/lock up converter & boost
- I need 4L60E to 95 LT1 bellhousing to engine bolts
- 6-speed to an 4L60 swap
- Whats the best transmission oil to use?
- what stall
- who makes the strongest th350
- th350 and th400 stall converters
- tranny swap
- will it make it?
- FLT60E Goes 9.88@140.86 in a Truck - With Video and Dyno Results
- 4l80e install. BMR crossmember problems
- Tranny Problems??
- 4l65e
