View Full Version : Automatic Transmission
  1. 4l60e from a 99 z28 in a old school????? help
  2. 1998 Camaro ss A4 to T56 Conversion HELP
  3. TH400 stall "cam only+N2O"
  4. parking pawl
  5. I just placed an order for 2817 on rock auto but.
  6. Couple of Pics-Rear Mounted Cooler
  7. stall question for tranny builders only!!
  8. Shift kit
  9. Mind starts to wander!
  10. just put in stall now a tanny code???
  11. Experts on Stall, Chime in. Yank.
  12. launch problems
  13. did your flexplate have a weight on it?
  14. T400 SWAP DRIVE SHAFT. WHAT YOKE DO YOU NEED t350 vs T400
  15. 99 Wrangler LS1 / 4l60e
  16. 4L80E cooler line adapter question
  17. My Performabuilt Trans
  18. 2010 camaro 6L80 converter
  19. need some help
  20. 6L80E Is It Possible?
  21. Vigi and Tranny help?
  22. Practice what you Preach
  23. Why tranny act up after I run on top end?
  24. Transgo shift kit question
  25. Little Help Please
  26. Harsh 1-2 shift, what can I do?
  27. 4L60e trans crossmember bolts ?
  28. New Sponsor On Ls1 Tech , Fti Competition Converters
  29. Tranny cooler ?
  30. I think I might have a transmission problem??
  31. Is my transmission trashed?
  32. Suggestions
  33. What should I do to my car?
  34. 2nd to 3rd gear shift lags
  35. th400 manual valve body
  36. Need Help Trans Will Not Shift Into 3rd After Tuning And Installing 4k Vig Stall
  37. Need help guys dont got second and it takes forever to shift out of first
  38. TH400 destruction in my 5.3 Turbo Truck
  39. A4 Shifter Stuck?
  40. 4L60E guru's - need some technical assitance
  41. need help
  42. Does converter need sent?
  43. Problems Help Pls
  44. Torque Converter Bolts
  45. no 1st gear
  46. the first look at the new 2.84 first gear planet for the 4l60e/4l65e
  47. What is the optimal stall for a MS3
  48. Whats the trans mount part # anchor
  49. Output Shaft Play
  50. hard shifting 4L60
  51. A4 shifter option
  52. This is what Happens when you throw 13lbs of boost and a 75 Shot at a FLT 60E
  53. 4L60e only has 2nd and 3rd gear
  54. 350TH Issues, any tranny experts? HELP!!!
  55. Performabuilt: 2 Word Review : Top Notch
  56. got a trans prob - need a little help.
  57. a4...... fun times
  58. Full Access to Installation Information
  59. 4L80E Slip Yoke
  60. I need a list of donor vehicles that have a 4l80e trans that is compatible in my 99 t
  61. tranny slipping at high rpms
  62. shift kit for the 4l60?
  63. Am I going to be thumbing it home???
  64. A4+t-brake+3disc Verter,anyone????
  65. Swapped from A4 to Th350
  66. Getting headache reading thru this stuff..need to know what 4l80e transmissions will
  67. clanking noise when going from 1st to 2nd
  68. Circle D - Hurricane Ike
  69. 93 Camaro Transmission Issue
  70. coolers
  71. 4l60e or 4l80e?
  72. trans feels weird
  73. Vibration at Certain RPM
  74. Stock Trans Tuning Advice
  75. P0785 Shift/Timing Solenoid Malfunction
  76. Cheetah shifter
  77. M6 to TH350 swap....gearing/rpm questions
  78. yank or vig
  79. Monster Converter
  80. Best way to cut a good 60' (A4)
  81. TH400 issues, need opinions
  82. Torx Plus 50 to remove bellhousing bolts?
  83. READ THIS , its a big deal this is for the trans company guys
  84. Who makes a TH400 that can be downshifted at higher speeds?
  85. Weird 1-2 upshift. HELP
  86. what GM vehicles have the 4L80E tranny??
  87. Good Choice...??? Convertor
  88. Need tune help with new stall!!
  89. TH350C converter lock up solenoid
  90. Trans and stall question
  91. Just bought RPM level 5!!
  92. Torq Converter Stall
  93. This a quality 700R4 rebuilt kit?
  94. 4L60E shift problems
  95. 4l60e
  96. Gear ratio?
  97. Need opinions on Munsinger Converters
  98. Need help Picking a converter.
  99. 4-2, 3-2 downshift flashes/slips, np w/upshifts
  100. a4 swap question
  101. Stock 4L80E stronger than built 4L60E?
  102. Severe transmission issues.
  103. Vig converters for Turbo 350/400 any good
  104. F-Body 4L60-E the same as '04 LS1 GTO 4L60-E?
  105. lockup converters tranny reliability
  106. B&M Pro Rachet
  107. performa built owners
  108. SS3600 Question?
  109. Stalled Auto with Street Tires
  110. transmission fluid question
  111. where does the torque arm relocation bracket go?
  112. easiest way to drain tranny
  113. 4l80e fitting question
  114. trans swap from truck
  115. 4L60-E converter in 700R4?
  116. ? About single,3c,4c,5c T-Converters
  117. Transmission Lines
  118. 4l60e
  119. So again! Manually shifting an auto is a "no no" ? This review says otherwise.
  120. 4l60 slipping in second
  121. transmission acting weird
  122. 4L60 no O/D & reverse.
  123. The most efficient A4/A6 torque converters....
  124. torque converter
  125. how cheap can you go TH400
  126. does anybody make this fitting???
  127. anybody go cross country with there built trans?
  128. wont shift under wot shift points or rev limiter problem????
  129. 4l60e with gears
  130. Temp gauge pics...
  131. Trans Issues
  132. TH350 Questions
  133. Which torque converterStall ,brand)
  134. Check Ball Placement
  135. 4L60e neutralizing...?
  136. T400 Cross Brace. Cheap One
  137. T400 how do you still use your stock shifter and driveshaft length
  138. How long will it last?
  139. converter change after gear swap?
  140. Why do I keep cracking Torque Converter hubs?
  141. Tranny is not engaging...
  142. 4l80 into my trans am
  143. Weak 60'... not enough converter?
  144. new stall ?
  145. 27" tire, 4.56 gear,th400 convert???
  146. Trans brake question number 2....
  147. 4L65E output shaft spline count
  148. 4l60e worries
  149. yank ss3600
  150. 1998 Z-28
  151. tci flexplate and yank converter
  152. a4 1/4time?
  153. Anyone with Circle D or Pt 3800/4000 feedback?
  154. 480LE problems
  155. TH400 Converter recommendations
  156. 4L60e Pressure solenoid mod
  157. 4L80E or 400 w/gearvendors OD
  158. TransGo Shift Kit?
  159. converter
  160. Swapping in a 00 6.0
  161. What would cause...
  162. 3.8 V-6 Manual Valve Body
  163. 98 LS1 4L60E, will it fit in a 2wd 96 4.3L S10??
  164. Should I buy a trans cooler?
  165. 2000 trans am ws6
  166. A4 Newb Question
  167. trans brake question..............
  168. threw a code P1371 need help please!
  169. TH400 power loss?
  170. Should my car d/s at 60 in 3rd gear?
  171. Should my car d/s at 60 in 3rd gear?
  172. trans help!!!
  173. Pretty much a noob TC (Stall) question
  174. Passing gear?
  175. tranny is gone! now what?
  176. Remove tranny without removing exhaust?
  177. Wanting to swap a c5 manual for a c5 auto
  178. Help With Transmission Rebuilder
  179. Circle D initial impressions
  180. ss4000 with spray
  181. Hard to spin torque converter
  182. Torque Converter can't handle the power?
  183. mod the stock shifter
  184. Vibration question
  185. Stall size question?!
  186. Will this be the same?
  187. Any tips on tranny removal?
  188. 4L80E rebuild kit ?
  189. help high idle and long shift timing
  190. Level 1 or upgrade stock?
  191. Torque converter not locking up
  192. Powerglide no Reverse
  193. Tc ?
  194. Stalling a stock car
  195. No 4th gear after super servo install
  196. what auto trans for 1xxx hp?
  197. 4l60e to 700r4
  198. How long on average does your 4L60 last in your Fbodies?
  199. tranny temp gauge
  200. Trans, Stall Or Tune????
  201. lock up test
  202. Locating a 4L80E controller?
  203. dexron 3 / type 3 (H) tranny fluid
  204. Powerglide Swap
  205. What stall is right for me? Transbrake TH400 Converter.
  206. 4L60E shift points are way off
  207. 1997 4L80e to 2001 6.0l?
  208. Late 4th gen/silverado 4l60e in early 4th gen?
  209. 4L60E stays in 2nd gear
  210. Time For a Converter!
  211. Handle for auto f-body
  212. 2-3 gear shift on nitrous shift point and mph question
  213. WOW been gone awhile
  214. Break in period for Converter?
  215. Shift Brothers trans on ebay
  216. Who builds a bad A$$ NITROUS STALL for a t400
  217. How much trans cooler is needed
  218. Tranny Mount
  219. trans exploded
  220. Changing Stalls, Question.
  221. Broken Output Shaft!
  222. Who is actually locking the verter in 3rd at the track?
  223. 1998 m6 to 4l60 swap
  224. HELP PLEASE 4L60 wiring questions
  225. what size stall?
  226. No 4th gear
  227. T/A 700r4 into truck?
  228. Guess what 4L80????
  229. Kickdown cable help? Pix inside...
  230. 2nd gear shifts with stall
  231. TH350 went out on third shakedown pass
  232. Converter Spacing 4L80E w/ Yank SS4000
  233. high stall converter is awesome
  234. Best trans. fluid for 460LE ???
  235. Stock converter?? (pics)
  236. 4l80e & 4l85e ?
  237. fluid
  238. can u manual shift proformicebuilt
  239. What trans to put behind nitroused 408
  240. Is it Bad To Manually Shift the A4?
  241. non stalled a4 guys with 3.23s...come inside
  242. trans tune
  243. TH400, Something rattling
  244. Torque converter
  245. Shifter cable problems
  246. 4l80e swap
  247. 2-3 shift ?
  248. How do you get the pump to stop leaking? I tried it all
  249. Finish Line Transmissions (FLT) Big Sale With New Policies
  250. 4l80e?
