View Full Version : Automatic Transmission
  1. Sonnax 77701-076 opinions
  2. 1-2 Shift Delay and Sluggish/ No 1-2 Shift WOT HELP!!!
  3. 4L60E Govenor Screen
  4. 3800 Stall to much for a bolt on ls1?
  5. 4l80e and controlling it in a high HP street car??
  6. 1/2 shift only when gas pedal lifted
  7. Performa, FLT or RPM....
  8. Feedback: Performabuilt lvl 3 and billet converter
  9. help
  10. 700r4 or th400
  11. Stall: Custom spec'd or Off the Shelf
  12. 4L80e pump bolt torque specs?
  13. M6 To A4 trouble
  14. 4l60e shattered pump impeller
  15. what convertor for DD??
  16. Corvette Servos
  17. selecting a 4l80e
  18. 4L80E Trans-go question
  19. 4l60e swap
  20. Choosing a 4L80E.
  21. Need help! Anyone please!
  22. lock up transmissions
  23. 4l60e vibrations please help!!
  24. 4l80 cooler line help
  25. hard shutter when starting from a stop
  26. Vent line question
  27. 4L60E shift kit question
  28. occasional hard 1-2 shift
  29. Have anyone tried this Stall will it work good?
  30. Trans Problems
  31. Did I screw the pooch?? HELP!!!
  32. trans cooler lines on 98 ta
  33. 4l60e to 4l80e 1/4 Mile Times
  34. lt1 blazer 4l60e prob .. HELP!
  35. LM7 5.3L bolted to 4L80E
  36. October Sale on 4L80E's and TH400's.
  37. turbo 400 shifting issue
  38. Random Converter Question
  39. FTI converters
  40. 700r4 4.3l
  41. Need 4l60e help
  42. will this work
  43. 4L60E limp mode?
  44. Its Back The PerformaBuilt Yearly Holliday giveaway! GET IT FOR FREE!
  45. 4l60e assistance please
  46. 4L60E Front Pump Clarification
  47. 4th gear shudder/surge
  48. 2000 Ws6 4L60E shift problem
  49. whats wrong, TC or tranny??
  50. trans tune question???
  51. converter break in period ??
  52. 4L80E Converter Seal Push Out
  53. 2000 z71 trans issue.
  54. Need advice putting trans dip stick tube back in..
  55. Choosing a race convertor
  56. Trans temp problem...help?
  57. Trans slipping?
  58. need to upgrade trans cooler
  59. LT1 Transmission Tourque Converter hits 5.3L Flexplate before Bellhousing meets motor
  60. Installing my torque converter this weekend
  61. Disappearing 4th Gear or OD
  62. LT1 M6 to TH350 or 400?
  63. 4L60E Bouncing off limiter before shifting into 3rd at WOT??
  64. do i need a tune for my converter?
  65. YANK SS3600/ stock bolt on car?
  66. how to remove trans line fittings?
  67. revmax torque converter problem???
  68. Will 4L60e reliably handle 510rwhp / 460rwtq!!!
  69. 4L60E Shifting?
  70. RPM Transmissions Track Rental October 24th 2012
  71. 80e to LT1 flexplate
  72. 5.3L swap, 4L60E PNP switch wiring issue
  73. Flex plate balance M6 -> TH350 swap
  74. Transmission clicking into gear?
  75. What type of oil does a 4l60e use?
  76. Driveshaft hard to remove/install
  77. Stall for TH350 Swap-Forged 346 Polluter/Nitrous?
  78. Need help identifying my tranny
  79. fair price for 4l60e?
  80. Delivered!!
  81. adjusting shift extension
  82. rebuild 4l80e
  83. 4L60E slips in every gear. Did a pressure test and here are the results...
  84. 1st to 2nd shifting issues th350
  85. Stall converter...How high should I go?
  86. 4l80e stall lockup slipping please
  87. Car in air wheels move car on ground it doesn't move?
  88. Good hoses to use for tranny cooler lines.....??
  89. any special kind of oil for stall??
  90. Picked Up A 3200 Stall FTI
  91. 6L80E YANK Stall fitment issues...
  92. performabuilt 4l60e in a 98 ls1
  93. Torque conveter markings what brand
  94. 4l80e moves forward in Neutral any help welcomed
  95. Need TH400 for +1000 Trans Am
  96. Transbrake and Valve Body Sale
  97. Th400 to LS1
  98. a4 GTO stuck in 3rd gear (limp mode)
  99. 4l60e problems!! Help
  100. Sale through September, free shipping on all transmissions
  101. When racing what do you do?
  102. Need rear shift cable bushing for 2000 auto
  103. Tranny issues
  104. trans temp gauge
  105. Help me figure out a plan to swap my T56 for an auto
  106. camaro a4
  107. TH400 no speedo?
  108. fluid
  109. WOT upshift into 4th
  110. 4L60e bellhousing to trans torque?
  111. Broken pan bolt
  112. Converter slipping/bad?
  113. 4l60e nitrous issue
  114. 4l60 help I have a little problem
  115. Should my trans pressure fluctuate like this (vid)
  116. wont shift inot third!!
  117. not shifting into 3rd at WOT?
  118. Testing a TCC solenoid ???
  119. 4l80e Valve Body Interchangeability
  120. ASR engaged after button is pushed to disengage
  121. 1979 el camino SS LS1 Engine swap
  122. Part # for flexplate
  123. Random Idea with Segment Swap
  124. P0502 code last night at the track
  125. Need some help
  126. looking for advise on selling a 4l80E
  127. 4L80E in 2008 GMC Sierra...
  128. 4l60e in limp mode HELP (dd)
  129. Should I rebuild?
  130. Installed converter, car won't drive.
  131. 4l80e cross member
  132. Stupid 4l60e and a 2-3 flare shift, here we go again VIDEO ADDED
  133. Need help ! keep killing trannys
  134. please help! stuck in gear
  135. 4l80 rebuild
  136. 4l60e 2-3 bind
  137. 200r4 vs 700r4 physical dimensions
  138. TH350 install help/info needed
  139. Here is my problem ..... need advice!!!!! HELP
  140. 4l60e with lq4 dont know what years
  141. Tuner recommended overfilling tranny to help shifting with a big stall
  142. need diagram
  143. What trans should I use?
  144. Is changing transmission fluid bad if the transmission needs a rebuild?
  145. 99 2000 long crank work with 4l65e
  146. 4l60e deep pan
  147. New From Mad Dog Transmissions!!
  148. 4l60e wiring need help!!!
  149. torque converter o ring *URGENT*
  150. 4L60E TCC lock up jerking
  151. Wiring harness help
  152. Guys running a th350/th400 come in
  153. 4l60e HELP!
  154. What stall speed to run?
  155. trans wont go back together
  156. 4L80/Transbrake newb
  157. need help with trans cooler fitting adapter....
  158. Any "better than stock" options for these trans parts?
  159. th400 pump sealing washers and o-rings
  160. Noise from 4l60e in park and neutral only?
  161. How do i unlock a lock -up converter
  162. 4l60E blowing fuse
  163. My th400 just stop working
  164. Help- NSS switch install
  165. What would cause this
  166. Open House/Car Show Tomorrow
  167. th400 tci ls/th400 torque converter not seating
  168. bad transmission
  169. Does all Manual Valve Body have Check Balls?
  170. torque converter getting very hot
  171. Transmission Sale
  172. 4L80e with HD2 Not Holding First
  173. Street driving a rmvb auto
  174. Littel help trans cooler
  175. 4l60e pump
  176. 4L80e Stalls Car When Put in Drive??
  177. Tbrake users, any delay when you activate?
  178. 6L80E replacment parts???
  179. Trans pan bolt/holes
  180. Burnt 4l60e
  181. getting pulse instead of steady V to 2-3 solenoid
  182. Th350 guys
  183. SOS 4L60E Rebuild Gone Bad
  184. Advise Please!!
  185. Torque converter storage?
  186. 4L60e interchange
  187. Question about two steps
  188. th350 problem after ATI sprag installed
  189. converter pick?
  190. Best shift kit for 4l85E?
  191. Is it toast can you identefy the noise? Video
  192. 4l80 questions
  193. TransGo 4L80 Full Manual ... No second gear compression braking...
  194. 94' z28 apparent limp mode problems
  195. Wont shift out of park.. Shift release?
  196. P0758 code 2-3 shift solenoid B circuit fault
  197. Swapping 4l80e cases
  198. converter vibration?
  199. Safe Shift Point...
  200. Transmission depo??
  201. 2000 s10 5.3 4l60e trans tune
  202. trans cooler
  203. Do any 5.3's come with 4l80e's?
  204. codes after harness replacement
  205. Any experience with 4L60-E rebuild prices?
  206. no 1st gear (1-2 solenoid rattles) 4l60e vacuum valvebody full manual
  207. Help me pick a converter
  208. 4l60e have a hidden gear
  209. 4l60e ?
  210. Check out YANK's Labor Day converter sale
  211. Help the dummy find his shifting issue 4L80e limiter 1-2, 2-3
  212. Magnashift Anyone?
  213. Need advice and opinions, Big power blower car swapping over from the dark side
  214. Stripped torque converter bolt!!!
  215. Maximum RPM for 4L80e
  216. LS1 lays down in third at WOT
  217. just picked up a yank ss4000
  218. 4l60e exchange question
  219. 4l80e Tuning for LT1
  220. 4l60e
  221. Tranny issue.
  222. Correct flexplate for th400
  223. Is my 4l60e broken? Help!!!
  224. t56 to a 4l60
  225. trans cooler with ram air?
  226. Stock transmission acting sluggish
  227. 2001 C5 4L60E (A4) with Heads and Cam Help
  228. '02 Camaro SS 4l60e question
  229. 4l60e conversion questions
  230. 4l60e diagnostic... need a starting point...
  231. 4l60e vs. 4l65e Difference in anything?
  232. 4l80e swap wiring questions
  233. 4l60E dipstick vs 4l80E dipstick
  234. Performabuilt 4l60E Level 2 Broke after 3,000 miles?
  235. Rossler 4L80E Terminator 2
  236. which trans for me????
  237. Maybe its just me.......
  238. 4L80E Build Problem
  239. thanks greg at fti for my stall .new best all motor et for my cam only 6.2
  240. Car won't shift out of park.
  241. LT1 to LS1/th400 swap...trans xmember?
  242. p1860 code 2000 camaro
  243. Help mast 6l90 limp mode
  244. 4l60e shift problems please help
  245. How many people manually upshift their a4?
  246. Post Pics Of Your Hurst Quarter Stick Install
  247. 4L80E speedometer option
  248. Z28 4l60e "dragging"? No slipping.
  249. Tranny wont kickdown
  250. Reman Trans shops in Chicago?
