- need help asap!
- tail shaft torque spec
- Yank SS 4000 2.6 STR? 2.73's DD?
- 4l60e conversion
- Just installed my Circle-D converter...
- How bad is this?
- 1500 dollar tranny cost 3-4000 to rebuild!!!!
- Shifter Locked
- Best Deep Sump Trans Pan??(C5)
- Is it easier to install a 4l80e to lq4 than a ls1?
- 4L60E which clutch pack is best?
- Mis-fire causing non lckup
- Driver's side rear trans sensor leaking
- 4L60E Tranny Controllers
- info on installing transmission temp gauge in a4
- Trans slipping??
- Anyone Shorten C5 A4 Shifter?
- Shifts into 2nd when left in 1st.
- stock trans, ss3600 and trans cooler how long will it last?
- Which trans to use?
- Can you use the stock torque arm with the 4l80e?
- review: Ace Racing Transmissions + Circle-D tc
- Shifting Hard
- 4L65E dipstick
- Gearing and Yank converter question
- TCI controller/4L80E issues
- removing pump, standing up or on a bench?
- please help, is this transmisson related?
- Anyone know about the 4L70E?
- 6.0 with 4l80e questions
- firming up 3rd
- Tranny trouble
- T56 Conversion
- Built Tranny problem wont shift 2-3
- help please?? locar dipstick question?
- Fuddle Bolts Question
- wondering if this is how its suppose to be
- problems help
- Is this guy nuts or is it me?
- ?? about TCI converter
- Came into $2500. What tranny to get?
- dfw local tranny parts
- 3.73 w/3400stall or 3.42 w/4000stall
- put headers or tranny in first?
- pressure control solenoid?
- stock vs meziere flexplate weights
- bell housing bolts
- wut do u guy think?
- stock converter lockup on deceleration?
- trans filter? deep or not?? 1998 3.8 camaro
- quick stall conv question...
- What type of fan should I mount to my trans. cooler?
- What Size Bolts - TCI Flexplate to Converter?
- transfering a built 4l60e from a 02 camaro to a 05 silverado
- Tailshaft seal...?
- rebuild the stock tranny?
- Mail order tune for stall
- TH 350 - shift up and down 2-3 permanently
- 2-3 shift not working!!
- Stall Questions
- Installed Transgo, now no neutral?!! what gives
- Gear question
- tranny is in neutral wont engage into any gear
- Th350 help
- Idle question
- How to replace pump stator?
- After tranny fluid change no overdrive!!
- part number for OEM style 4l80 mount?
- This 4l60e shit is gonna drive me nuts...PWM circuit questions...
- Transmission ?'s
- No first No DTC
- Need help with tranny cooler.
- any lenco vendors out there?
- Fel Pro Gasket = rubber or cork ?
- 6L80 into a 2wd??
- Issues with converter install, input shaft grinds when spining manually? Big story
- core
- Torque converter
- Th350 Trans temp gauge
- 94 A4 slipping going into 2nd gear...HELP
- Is There A Trans Temp Sensor?
- blew my 4L60E..
- Locked or unlocked converter on dyno?
- 4l60e metal breather tube on top of trans?
- Just installed my 4000 vig!
- 2-4 servo housing cracked open
- Another 4l80E Trans brake question.
- 3.73s and auto tranny question
- tranny problem
- installed new engine now tranny dont work????
- TransGo Install. Which solenoid is this??
- GM PART 26061475 - Slip Yoke
- What To Upgrade On My Th700r4
- worried about my 6L80
- idle with my mod lvl?
- Busted front pump? Trans overfull?
- Anyone else waiting for this
- ACPT carbon fiber driveshaft..what U joint?
- What stall for my daily driver?
- what would cause this?
- th 350 LINKAGE ????
- If you could build a tranny how would you build it?
- 1996 4L60e to 2000 6.0L will it work
- torque converter recommendations
- stall in stock tranny?
- I am having a weird trans issue.
- When will the transmission prices get any beter?
- Truck pan part #
- would high ATF fluid levels cause shuddering? (long post)
- Opportunity to get a running th350 for $50, Need some advice!
- 96 trans in a 94 camaro, will it work?
- Where to wire in trans cooler fan?
- Helpful Hint
- 4l80e swap wont shift
- th400 guys.. what kinda exhaust u running?
- puddle after shift kit install
- TH350 or glide???
- stall and gear install in CA
- At the end of the road.. HELP
- Idle/Surge Issues after converter install
- Camaro shifting hard after transmission shop increased the line pressure!!!
- About to go High Stall, Shift Kit, Oil Cooler ??
- Aftermarket Shifter How do I jump the Nuetral Saftey Switch?
- calculation for vss in front wheel
- stupid tranny cooler install question
- My first time stall install with pics.
- Help with Tail Shaft
- Part number for shift lever on 4L80E?
- Another Tranny question
- recomendations
- Help has anyone heard from John (Fuddle)
- Help...Car will not go in gear
- -95 4L60E electronics with -00 Ls1 engine
- Tranny Problems
- auto tranny build?? advice on my picks
- Where can I get a tail shaft?
- Where can i find a cheap factory/near factory stall?
- Trans Install
- Another which converter to get post...
- stall and rear question.
- rate tranmissions in order of streingth
- Anyone do an F-Body A6 conversion yet?
- Stall for 6L60?
- looking for a new stall
- 6l80e
- Bang!!!
- trans gurus, need your help
- 4L80E pump install question
- Buy a 3400 Stall with 25k miles?
- What 4L60E do i need to bolt to my LQ9?
- Corvette servo for 4L70?
- i NEED your guys' opinion.. have a chance to swap t56->th400
- 2000 LQ4 to TH400
- Converting non-PWM to PWM?
- Standalone for a 4L60E
- Overdrive Semi Auto
- Tranny Issues, please give me some advice!
- lq9 flexplate
- 4L80E tranny tunnel cutting
- Rebuild Kit - 4L60E - Circle D
- Built 4l60 slipping 2-3 shift
- T56 to TH350????
- th400
- 4l80E slip yoke question
- 4l60e b and m shift kit problems
- Pulling Trans?
- 01 5.3 engine, 04 6.0 harness, 98 ls1 4l60e...?
- Turbo 400 trans rebuild kit?
- 700R4 or 4l60E?
- 4l80e and "the ear"...
- My bird's a mountain bike... :(
- Broken converter????
- 4l60e shift points?
- TH400 Question - Early Shifting
- 3/4 Clutch pack question-adding extra steel
- **Trans cooler**
- Does FMVB wear 4L60E?
- figure out stall??
- 3000 stall with shift kit
- Need some help!!!
- 4L65E jerking off the line problems!
- 4L80 troubleshooting help!
- New tranny in
- "safe mode" after a burnout after a vig 3200 install
- Got my Performabuilt trans today!! one question though
- Why was this included?
- 4L80E in fbody WITHOUT BFH to tunnel
- Recommendation on a stall
- help!!!
- A big thanks to Yank & a question
- need help with th350 diagnosis
- TCI flexplate/ARP TC bolt questions
- upgrades suggestions here on c5 4l60E
- Problem
- what would cause this??
- 6l80e modifications help
- Pat's Performance 10"... anyone try it?
- What Trans Do I Have 4L60 Or 4L60E???
- Changing 4l60e rear main seal????
- Does the 93-97 V6 Camaro have the 4l60e?
- T56-TH400 swap, estimated cost/parts list
- New Website For Performabuilt Is Live
- is it just me or?
- Doesn't feel right?
- 4l80e stock stall?
- big stall = no chirp?
- shifter for the 4l60e
- TH400 what vehicles??!!
- need help with duramax/allison
- 700r feels slower than my old 350 trans?
- vigilante 4000 stall?!?
- what kind of transmission
- P0757 code question
- locking the trans for cam swap
- Transmission slipping???
- 4L80E: Here's one you dont see very often
- Trans cooler for a DD? Overkill?
- help me pick a torque converter
- Quick question
- 4l65e issues...
- 700R4 issues
- anyone have pics of tranny cooler locations
- ACE Racing Transmissions New Layaway Plan!
- Shifter removal
- Fuddle customer service sucks!
- Opinions for which stall?
- ***Century Transmission Summer Sale***
- TCI Flexplate/ARP bolt questions. Urgent.
- I can't believe I forgot to...
- i need a4 shifter linkage ASAP
- Tranny Pan Problems
- Stock Servo Removal
- 4l60e questions
- TH400 Issues.. Where to Start?
- Building a resto-rod, need TC advice
- Trans. cooler question
- What stall for LE1 setup LT1
- What bolts to use with ultrabell on a th400??
- FLT Free Shipping Special
- ACC Boss Hog converters?
- external oil cooler?
- TH 400 Bellhousing problem!
- Flexplate ?... Will 04 vette FP fit 01 Z-28?
- ACE Racing Transmissions Summer Sale
- picking a converter
- Tranny in limp mode pin E con. does not have 12V
- Circle D - Billet Parts
- Shifter for 4L80E
- 4l80e help -- how 2 use drive by wire
- converter flash!!!
